PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. Difference in observed injector latency vs maps?
  2. Trim issue
  3. Evo 8 Map Wanted Please!!!
  4. brakeup around 4000 rpm
  5. no BCS boost curve and funny fueling..
  6. 22 psi Boost setting for stock turbo
  7. Another simple way to log mileage
  8. EcuFlash Rainbow Color MAP
  9. Adjustable Cam pulleys, worth it?
  10. MAP Averaging (tephra v5.10) makes boost goofy on dyno?
  11. Boost Limit dependent on Boost Control Load Offset?
  12. 2 byte load for 96420008 but logging 96940011???
  13. How many times have you flashed?
  14. How to install ECU from another car?
  15. help changing com ports?
  16. Knock Control Settings/Loads
  17. what logging software is this from?
  18. Disabling BCS (wastegate solenoid)
  19. Injector Latency base???
  20. project import boost solenoid NEW
  21. Coldstart ignition map for 96530006
  22. Odd phantom knock finding...
  23. Load calculated?
  24. How do you log boost on EvoScan
  25. tailpipe "sniffer" wideband o2 that evoscan can log??
  26. Take a look at my maps?
  27. need help with psi boost maps
  28. Yes I'm Alive :-)
  29. can you estimate what your boost is with load?
  30. Stock Evo IX Rom
  31. need help with aem serial port
  32. ZT-2 advanced users, please helpl
  33. No fuel trims: no adjusting, no control?
  34. ALT field fault.
  35. Acceleration Enrichment Map Discovery
  36. Cranking enrichment
  37. FIC 750 injectors
  38. IC Sprayer activate on Knock?
  39. weird issue w/ ZT2 lcd screen
  40. Evoscan woes...
  41. lap top crashed need evoscan
  42. screen shot of a log?
  43. Quick question about AEM Meth kit
  44. SCC aka Spark Control Computer(HWID) at F8A - discussion
  45. Boost and Timing on 91 + Meth (9 Turbo)
  46. Tuning JDM Evo VI
  47. PCMScan questions...
  48. Need advice on tuning style
  49. "ABS" goes nut w/ EvoScan cable?
  50. P0137 code and EcuFlash
  51. 80700010 GT-A TephraMOD
  52. Increasing/decreasing values in ECU Flash
  53. Need Rom Definition Please
  54. FIC 850cc Scaling Assistance
  55. Problem with ecuflash 1.41
  56. MUT32 vs. Actual AFR
  57. ECUFlash Scaling
  58. 94170015 and evo7base with mods
  59. subroutine @564 what does it do?
  60. Rom swap?
  61. how tp disable p0138?
  62. Limitless cable for the loss
  63. Welcome to Logging....
  64. Mivec cam tuning
  65. SD - first test success
  66. trouble reading ECU.. whats wrong?
  67. In need of 94170015 rom
  68. Ecu Removal for Flash
  69. Free Reving Knock
  70. Need a base map for a HTA35R
  71. evoscan 2.6 on vista 64bit not reading wideband
  72. Boost Issue
  73. 88580014 AUDM - EDM Dual or single BCS?!?!?!
  74. Factory immobliser
  75. Home made knock detector
  76. Need two additional solenoids switched by ecu
  77. Laggy moving off - Need comment
  78. tactrix 1.3 cable
  79. quick sanity check
  80. Gear-depending boost problem ?
  81. Question about ECUFLASH communication
  82. Evoscan Airflow Hz pegged??
  83. Logging aiflow with evoscan
  84. ECU tune and manual ICS button
  85. Speed density (again)
  86. GT35r - Bov VTA Vs Bov recirculated
  87. 88590015 - MUT 8A = 0-100% Throttle position
  88. EvoScan download assistance
  89. For Anyone Considering an AEM Boost Control Solenoid . . .
  90. Help.. Battery died while in valet mode, now car wont come out of valet
  91. New Motor, New Turbo, New Problems
  92. Timing idle autopilot?
  93. Evoscan 2.5 maptracer question
  94. Richer/Advance or Lean/Retard ?
  95. LEAN SPOOL question
  96. low load knock and heat
  97. need full house XML 94170015
  98. Cold Start Confusion
  99. Need map.. Please help
  100. Need a map.... changed turbo
  101. need Evo 9 owner to test rear O2 *heater* sim patch
  102. Fuel Trim issue
  103. ECUFlash RVR X3 4G63T issues...
  104. force full time open loop
  105. HELP! on Tempra Patch V5.10 for 9470015
  106. 1000ccs/flashing cel
  107. 94170008 to 94170015
  108. trting to pull map off friend car!!
  109. How to disable P0710 ?
  110. evoscan reading 150 load at iddle
  111. Evoscan EGT reading
  112. Starting sets for GM 3-port solenoid ?
  113. Can some1 look at my tune?
  114. MDP questions? ?
  115. Path from MAF pulse to Injector pulse
  116. Need help logging AEM wideband in Evoscan 2.5
  117. numerous tuning and wideband problems
  118. Openport 2.0 unusable
  119. (RPM)ReScale Boost Tables/ ReScale Fuel table
  120. Omni 4bar map sensor Plug and Play
  121. BCS for ECU controlled boost
  122. Mut Monitor V1.5 Release working with OP2.0
  123. Idle Stepper look up table
  124. who are the best shops a tuning with ECUFLASH (country wide)
  125. Strange dip in timing ! Why !?!?!
  126. open loop tuning??
  127. Need advise
  128. Car not starting in the cold (video)
  129. Trying to find info on crank/cam sensor signal for ecu swap
  130. Load dropping off
  131. tantrix cable
  132. UK IX FQ-360 Rom
  133. ecu flash jacked up!!
  134. Stock ROM needed...
  135. Map switching harness inop
  136. Disabling EGR and fuel pressure solenoids
  137. Look screwy logs, what could cause this?
  138. Differences between EvoScan and Tactrix cable?
  139. New Injectors, help
  140. Evoscan LoadCalc reading zero
  141. difference between load based boost control and direct boost control
  142. logworks open port 1.3 logging
  143. NLTS not working after clutch adjustment?
  144. Scaling help please
  145. Any success with bleeding AYC with Evoscan and Limitless cable?
  146. Tuning Kelfords
  147. injector problem?
  148. Help a noob with Evo 8 JDM
  149. Can a Titan motorsport WB logg with evoscan?
  150. Two evo9base xmls?????
  151. ECU Swap & Immobiliser Code Issues
  152. looking for 0300 cel fix
  153. Ix rs 97710001?
  154. hey any help
  155. CEL P1400 after VSR intake install??
  156. Open Source OBD-II/MUT project for Mitsubishi Vehicles.
  157. Lots of DTC questions P0141,P0441,P1400,P0183,P0443,P0446
  158. FP Green and Revolvers installed...looking for?
  159. deleting evoscan data items?
  160. Tephra Rom Mod - Ver 6 ??????
  161. Just a got a 35r (63) does someone have a base mapI could have?
  162. Open Loop > Matt55
  163. evoscan to logworks porting
  164. Fuel trims and idle
  165. IC settings in Ecuflash??
  166. Alternative MAF Sensor Implementation
  167. anyone using an lm1
  168. tephra any alternative
  169. Help with Ecu Direct Boost Control
  170. does this tuning method work?
  171. patch how-to: 96530006 MAT logging
  172. boost cut
  173. anyone have a 05 evo 8 tune (turboback, intake)
  174. Evo 8 ECU in my 2g DSM, help please!
  175. EvoScan 2.5 and VISTA..HELP...
  176. Time discrepancy
  177. Question about barometric pressure sensor on an interesting project
  178. Help/Advice Please
  179. Any issues on these graphs? Idle problem. Help
  180. evoscan 2.5 w/ vista woes
  181. 94170015 work for all 03-04 Evos?
  182. Anyone in the Indiana area interested in tuning a VII?
  183. Which cam, kelford 177A or 177C?
  184. OEM replacement primary O2 sensor
  185. EcuFlash ver 1.39 Please
  186. Load with V.5.10 Tephra
  187. Editing ROM
  188. help! please
  189. Is the 97250001 ROM patchable?
  190. Question about EGR Disable
  191. Thermo fan map
  192. XML Rom editing problem - Vista Ecuflash 1.40
  193. MDP Connector?
  194. Can you disable Front 02 sensor?
  195. ECUflash ver 1.34 help
  196. Adventures in load-based boost control with the GM 3-port solenoid.
  197. 5000ft tune... Looks rich...right?
  198. Reserialized Tactrix cable still won't read/write w/ Ecuflash 1.35 and up
  199. Wierd Evoscan 2.5 Problem
  200. Need help with Evoscan 2.5
  201. Testing 3 Port
  202. Can an ECU be repaired??
  203. 9653006 map
  204. rate this tune for me
  205. Good Base Map for EVO VIII using ECUFlash
  206. Opening an EvoScan Cable
  207. e-85 tune?
  208. Just what are the old Knock Filter Maps
  209. Need older version ecuflash
  210. Issues at full throttle 3rd/4th gear pulls
  211. Can't log AEM WB in Vista (Evoscan)
  212. Stalling , idle problem , take a look at the graphs please
  213. 2byte airflow limit?
  214. Tons of knock...need some advice
  215. Decel Fuel Cut and Cooling Fan Maps for 94170015?
  216. XML for JDM MAP & ECU Boost for 96530006?
  217. Any Reason to Keep These in the ROM?
  218. gt3582r & stock ecu tuning process...?
  219. ECU controlled Window Switch
  220. aem wideband
  221. low octane altmaps - anyone using them
  222. Weird idle issue after swapping back to stock intake
  223. Boost control problem
  224. ignition timing trims
  225. HELP: unable to read/write to ECU with ECUFLASH
  226. throttle/ boost
  227. P0141 and p0136
  228. Definition of Idle Conditions?
  229. new mod feature - thoughts required
  230. Building to much boost with 2 step
  231. wgdc correction based on MAF IAT
  232. Evo IX 272 ignition map anyone?
  233. Timer unit - interrupts for CAS, airflow, injector/coil schedules
  234. Calibration Id
  235. open port 1.3u-b
  236. 99860002 and Load related datalog
  237. WGDC settings help
  238. Evo Scan Load Problem
  239. couple logs from the new all stock 2.3
  240. Evo X xml rom
  241. DLL help
  242. Need help w/ECUFlash 1.40 - Not responding
  243. e85 fpgreen 1 walbro...
  244. ecuedit and OP-2
  245. Additional injector drivers - spare outputs discussion
  246. getting "overboost"CEL and boost limit is maxed at 319??
  247. Knock control - ignition retard
  248. Who's using GM 3port and Direct BC with big turbos/tial wastegates
  249. Knock control - fuel enrichment based on knock sum
  250. Tephra - Map switching 3 maps?
