PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40
  1. cailbrating evoscan for bigger injectors
  2. Help: Cant download my map of JDM EVo 9
  3. Mitsulogger and 2-byte functions
  4. ecuflash issues...
  5. USDM vesus EDM!!! changes in the ecu map!!!
  6. another evoscan issue
  7. [B]InjPulseWidth Unit on Log[/B]
  8. evo scan framework?
  9. Confused by ROM ID
  10. Does this log seem possible? Straight 93
  11. reflash question
  12. 2byte load & RPM for 96940011
  13. Can Ecuflash works on JDM EVO 8 MR?
  14. Fuel trims
  15. Anyone use an MBC AND the BCS together?
  16. gm solenoid strange boost?
  17. Understanding xml definitions
  18. ECUFlash Tuned by myself-Results/Dyno graph inside.
  19. Ecuflash 1.31 2d graphing...
  20. Code- Immobilizer
  21. Car wants to die after runs!!
  22. Window XP/Vista Tablet and Logging
  23. Ecuflash Mac Official
  24. Problem with 1.31
  25. ecuflash wont recognize my evo?
  26. Fq340 Rom
  27. need log at 5000 elevation with JDM MAP and 2-byte load
  28. FQ360 Map!!
  29. Copy 88840013 to 88840016 ???
  30. Speed sensitive 3 step (NLTS, launch RPM, Rev limit)
  31. Wierd issue
  32. 2 byte versus Load calc
  33. GM 3 Bar Map Sensor
  34. MAP sensor CEL threshold
  35. Stationary Rev Limit,,,couple ?'s
  36. jdm rs mivec map?
  37. GT35r Suggestions
  38. Nolift to Shift??
  39. ECUFlash Fails to read my Evo map!!! Help Please!!!
  40. anyone datalog on the road course?
  41. USDM OEM EcuFlash file ???
  42. Got my WB hooked up and I got a few Qs (Mitsulogger)
  43. No MAF? No problem!
  44. ECU Reset
  45. ECU Flash on a Mac?
  46. cant diagnose cel light?
  47. unable to connect to vehicle interface.
  48. Wrote wrong map onto my car and now it won't start or respond to Ecuflash
  49. EvoScan Mitsubishi Datalogger - New Features
  50. Tuning with Evoscan
  51. Should i pull some more timing
  52. Tuning for temperature/elevation needed?
  53. Popular EM reliable?
  54. 88590015 MUT Table
  55. i need a logger...
  56. Weird Thing With My Ecu Map!!
  57. Intake=re-scale MAF?
  58. Encrypting for Dealer visits
  59. Stock map with P0300 fix
  60. Feature/Patch request: Temp disable A/C under WOT
  61. Anyone Logging Mivec?
  62. Odd knock sum/jolt episode
  63. I feel the need to lean!!
  64. Cable problems
  65. LoadCalc to PSI
  66. ecuflashsh not conecting
  67. Wavy Boost
  68. Datalogs...b4 and after
  69. Injector Scaling in ECU Flash
  70. Any Resolution To ECUflash 1.30 "unable to connect to vehicle interface" ??????
  71. What do guys think of these logs!!!
  72. IS the load logging with Evoscan accurate????
  73. How to connect AEM wideband to Evoscan?
  74. Looking at my logs with ECU flash
  75. what do you log with evoscan
  76. Accel Enricment Question
  77. problom with ecu flash
  78. more boost or more timing?
  79. Can't datalog..with either mitsulogger or evoscan
  80. Another Fuel Trim Question.
  81. Wastegate Activation / Deactivation value question
  82. please help car not starting!
  83. ECU boost control mods
  84. Need XML for Evo 7 MR560648 (E6T34871)
  85. 2 logs on the fire
  86. Impact of LICP on Tune
  87. Calling Malibu Jack!
  88. '03 EVO 8 tune, thoughts?
  89. logging many load variables
  90. noob needs help
  91. Engine just rebuilt... when do i flash?
  92. PATCH: CEL Flash on Loaded Knock
  93. Injector voltage latency problem
  94. Fuel trims on stock intake/injectors
  95. Evoscan and larger injectors
  96. Hks 264 272
  97. Fuel trim adjustments
  98. EcuFlash Glossary
  99. Evoscan MPH sample rate?
  100. Noises while flashing...
  101. Odd Load Spike?
  102. Help scaling injectors
  103. AFRs in Germany
  104. cold start acceleration enrich table?
  105. Stationary rev limit Problems??
  106. VVT map
  107. JDM IX_MR: Removing speed limiter
  108. help with ecu swap
  109. Code scanning on ODB2?
  110. need tuning for evo 9
  111. Something interesting venting BOV to atmosphere.
  112. I need a little help.....
  113. L@@King for best tuner in CO
  114. Need EVO IX stock map ASAP!!
  115. Tuning Guide for the GM 3-Port - My Experience..
  116. Different a/f in each gears at same load??
  117. Mitsulogger and LC-1 ?
  118. Mitsulogger and LC-1 ?
  119. misfire at 7200 rpm?
  120. First log of a friend's tuned evo IX please help..complete newbie
  121. Dyno'd my first custom tune
  122. Immobilizer code change
  123. Car Down On Power Big Time
  124. Limits and Evo IX
  125. AFR Tuning - HELP
  126. Question for stock-ecu tunners
  127. hardware install failed
  128. How can i tuning my ECU ?
  129. Changing Immo in the ECU. Programming keys with new Immo. Possible?
  130. Tune for Cams
  131. can't read ECU, need help
  132. can't read ECU, need help
  133. Mitsulogger formula to Logworks formula
  134. Evoscan wideband probs
  135. 431whp Stock turbo E98
  136. Logs attached for new mods -- anyone w/DLL?
  137. Help! Clutch in idle problem
  138. Need Map Opinions, Weird Timing/Load Issues
  139. Need your help.... please read
  140. Some help with a tune and possible wideband issue
  141. conservative meth tune?
  142. Timing : Fuel?
  143. Strange problem
  144. Trying to get a disaster running. Any help appreciated.
  145. Another Log Review...
  146. Cutout downpipe benchmarks
  147. Safe AFR
  148. ECUflash
  149. Did a few logs tonight...
  150. Any Interest in More Custom Pills?
  151. I cant richen up my car
  152. 2 byte load for 96940011???? Am I missing something?
  153. automatic tracking of peak boost
  154. evoscan > 250 load
  155. Need Some Help ...
  156. Tuning a stroker motor
  157. how to change my idle with ecuflash
  158. Help with Ecu boost and custom pill
  159. immobilizer code is 0001
  160. My Evo IX Maps
  161. Installing Wideband Suggestions
  162. adding extra cells to get to 300 load
  163. P0300 cell fix?
  164. Help With Evoscan And Ecu Flash
  165. EVOScan not working anymore..
  166. Check out my Evo IX tune...
  167. Need ECU Defintions for 03 EVO
  168. tuning for unleaded vs. leaded race fuel?
  169. Universal rom
  170. Help with Funky AFR
  171. Mivec and boost
  172. how to let torque hold longer?
  173. Ecuflash
  174. Tactrix and LC-1 Newbie ?'s
  175. need help
  176. a few observaions,
  177. fouled plug and logs
  178. Tune for Walbro
  179. injector question
  180. Simple help with AFRs
  181. installing 880's tommarrow and....
  182. RPM selection and DLL
  183. Where now???
  184. Ecuflash
  185. MacLogger 2.0
  186. Turbo Boost Error Correction basics?
  187. Stationary Rev Limit
  188. Using Mivec to induce Lopey Idle
  189. ECU flash help
  190. 2 Byte Load Spike in Logworks
  191. Good books/resources on tuning?
  192. Any comments on my tune?
  193. Log of slipping clutch
  194. how does my graph look?
  195. EvoScan v1.0 to be released next week with Map Tracer support
  196. wierd boost observations
  197. wierd boost observations
  198. Cause of high idle
  199. Winter de-tune
  200. Tested: Ebay Filter
  201. Adjust Baseline WGDC RPM points and boost control?
  202. 20glt iam impressed!!!
  203. 2.1 bar boost on Evogreen - What timing???
  204. Stock 05 Evo Map
  205. How much fuel are you guys taking out?
  206. What IAT sensors?
  207. Change the init in a ROM?
  208. Boost with 100 Octane
  209. Insalled LC-1..Free Air Question!
  210. Help, my tune
  211. Evoscan difficulties... need a genius
  212. Wideband O2 Shootout!
  213. HP/Torq graphing function from EvoScan??
  214. LogWorks3 Beta 2 out for those of you
  215. For those searching for a wideband meter
  216. knock sums present while accelerating during idle why??
  217. ? for those using Logworks
  218. Does anyone have MAF scaling for open filter on gt3076r?
  219. Question about EcuFlash & Evoscan
  220. ? about Vishnu ECU Flash
  221. Advantages of GM solenoid over MBC?
  222. XmlHandlerHelper Error help!!
  223. tactrix cable ?
  224. Data Log Lab help
  225. ecu responding to nothing, locked?
  226. 2.0bar boost - which Boost solenoids
  227. Idle speed adjustment not working ...
  228. First time ecu flash, help with flashing anti lock light
  229. another log to view evo8
  230. going to be tuning a 35R car
  231. Evoscan 99 2byte load problem?
  232. Bigger turbo builds less boost on 2step
  233. WGDC wont exceed 78.43. Please help
  234. evo 7 P0136 and P0141 error codes
  235. Opinions on Tune ...
  236. Test Pipe=Rich???
  237. Invalid Evaluation Expression in EvoScan
  238. Ideas for Meth fail-safe points.
  239. Looking for an EVOscan tutorial
  240. Weird AF/R variances.
  241. Your opinions on my self-tune are appreciated
  242. Getting anti-lag working on EDM
  243. evoscan knocksum = ECUknock
  244. Evo VII GT-A ROM
  245. Logging Air Mass Strategies
  246. Question about Evo 8 & 9 Rom's
  247. Tested: JDM and GM 3 Bar Map Sensors
  248. Problems with HP/TQ in Evoscan
  249. Injector scaling ? AFR - WOT
  250. Apexi drop-in filter?
