PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. Speed density bad iat sensor
  2. TephraMod V7 & Omni 4 Bar MAP Sensor - Can't Log Boost - Help
  3. throttle hang issue. need help
  4. Loads?
  5. P0181 - Fuel Temperature Sensor
  6. 2.4 swap ?
  7. Inconsistent back to back pulls, too much timing?
  8. switching to another definition?
  9. Stock rom?
  10. Cruise AFR around 10-11, ideas?
  11. Read from ecu error
  12. DTC codes
  13. MIVEC Timing discussion
  14. Scaling maf
  15. ecuflash and evoscan rich problem
  16. Unknown ROM image
  17. leaning out and stalling at idle
  18. DSM / Eclipse 1995 Evoscan Coolant temp RAW x Scaled
  19. Any Ecu reasons why I would get a P0134 code and bad signal?
  20. Timing in Ecuflash Vs Logged timing.
  21. Open loop to closed loop transition - time related? Tephra V7
  22. Does this look safe (evoscan datalog)?
  23. Top ecuflash tuners
  24. Car won't start
  25. MAP scaling voltage for 2D SD
  26. Stalling with A/C ON
  27. Lean at Cold start on Speed Density w/ 9417 rom
  28. Evoscan 2.6 vs Tactrix 2.0
  29. knock control tables - which ?
  30. Logworks Load reading?
  31. Tuning and logging issues, Please help. Nothing Works!
  32. EvoScan and LC-1 logging? help
  33. boost tuning for high altitude
  34. tuning injectors w/ no O2 feedback and on SD?
  35. Tephra V7 and Grimmspeed EBC
  36. MUT table differences from one ROM to another
  37. ecu flash
  38. 88770005 XML anyone? please?
  39. Can I post a log?
  40. Evo Scan Question
  41. Changing map sensors from 4 bar to stock...
  42. original xml file for 94170008 needed
  43. updating my rom
  44. Going lean above 6000
  45. Stock/Omnipower map sensor connector/pigtail?
  46. How to E85 EVO9
  47. Actuating AC condensor fan??
  48. ECU flash doesn't recognize ROM
  49. Is it possible to have large knock sum generated from hard shifting?
  50. 30Hz BCS control available at Tephra V7?
  51. PTE 780cc injectors installed but ecuflash cannot access fuel maps !
  52. ac relay, ac switch, idle switch in evoscan
  53. Introducing AcidTune, a Cross Platform OpenGL Map Tracing Package
  54. 2Byte load for 96260007
  55. omni 3 bar not registering over 19psi in evo scan
  56. posted in diff section and got no answers
  57. EVOIX how to bench ecu
  58. Fan Control 94170015 doesn´t work
  59. HELP tuning! low throttle knock
  60. Autocross AFR tuning (2nd gear)
  61. Corrupted ? Pics inside please view.
  62. Definitions / ECU / WTF? Help please
  63. EGR Tables in 94170015
  64. Failed Emissions, 2G w/EVO8 ecu. hydrocarbons at idle to high
  65. EVo 8 RS - 93670005 definition
  66. 03 read issues
  67. ECUflash help!!!
  68. Can't read ECU to save my life..
  69. Logworks3 and Ecuflash Plug-in?
  70. launch swtich by Map switching harness
  71. Stock MAF scaling tables USDM IX
  72. 1G with EVO ECU beginning questions
  73. Weired starting problem, just cranks when warm, starts after reflash
  74. 88570008 updated xml wanted please
  75. GPS EvoScan button doesn't work
  76. 2003 Evo 8 rom definition
  77. 88840016 how to use TephraMod V7
  78. OPENPORT tactrix 2.0 HELPPP
  79. New user here, need help on Evo 8 unknown ROM ID
  80. Trying to get the new motor running.. 2.0L > 2.3L with speed density
  81. Pins EGR to SAS works of Evo 5 with Evo VIII Ecu
  82. Evo scan problems with new netbook.
  83. Can we log ABS sensors individually?
  84. tuning on tephra 96531706 map SD VE
  85. Loss of logging and 80hp w/ missfire
  86. Tuning Method questions
  87. Evo IX ECU Pins for purchase
  88. Can't get wideband to log
  89. Computer reloaded, now can't read/flash
  90. Couple ECU based boost control questions.
  91. Disabled Lean Spool-Now worst Log ever-Log Attached
  92. Evo 8 rom flashed to an evo 7 ecu?
  93. tephra mod/2 step
  94. How to get car to start on new pcm, without immobilizer code?
  95. LC-1 slow response
  96. Evoscan and lc1 not playing nicely
  97. Done tuning... Or am I?
  98. inconsistent knock *logs*
  99. beginner at tuning, cant get AFR's to lean out up top
  100. Cannot adjust Rom
  101. Is it me or have people been getting some crappy tunes lately!
  102. Need BIG MAP Traslator
  103. 8/9 Openport 2.0 logging via internal SD Card
  104. ive searched
  105. How unsafe is my new tune?
  106. Let me see your launch maps
  107. 90550001 sd
  108. knocklight in ROM?
  109. Need Help: ECU defaulting to low octane maps?
  110. Evoscan problem when i scan ACD/AYC for code.
  111. V7.... can you map swap a pump gas AND E85 map?
  112. Problems with radiator fans (Want change values with ecuflash)
  113. FIC 1100 tip-in issue
  114. Adjusting what temp to turn the fans on
  115. evo 9 trouble - need community help
  116. EVO 9 stock map
  117. Omni 4 bar install, getting different readings?
  118. ECU comparisons
  119. Quick queston about lean spool
  120. I need a 91 octane rom for lancer evolution ix stock !
  121. Lancer GLX 4G18 XML request
  122. Anyone else using a MAC to tune with Ecuflash??
  123. scalling issues with maf, idle hz is off in closed loop, forced open its perfect.
  124. Stock map sensor wiring?
  125. need some help with software
  126. Is there any potential for ECU damage in 3 ports without resistors?
  127. "Scramble boost" with 3-port??
  128. Any ECU flash guru's also own any Mazda's?
  129. possible bad knock sensor ?
  130. 2.1L tuning issue
  131. Please check my log
  132. need help!!!
  133. Newbie Knock Question
  134. FP Black
  135. Benefits to tephra V7
  136. 9417 SD warmup issues
  137. how to set up NLTS properly
  138. HOW TO - Setup Boost Error Correction tables via PSI Based boost control (Simplified)
  139. Anything else I can do with with my tune?
  140. Injectors cold start
  141. Quick question - timing on manual vs 3 port
  142. Ralliart K1 K2 C1 AYC/ACD Rom
  143. In a bind! ROM NOT READING. "Urgent"
  144. 1.42 saying unable to connect to vehicle interface
  145. HELP! Fuel cut on SD and melting IACV.
  146. Strange 4th gear knock...
  147. Why my logfile looks like this?
  148. Anyone know?
  149. LC-1 new firmware beta1.20
  150. do we need an aftermarket wideband at all?
  151. Bucking or stutter at low load/rpm
  152. gps not logging fuel trims
  153. Converting from AEM EMS S1 to oem ecu+SD
  154. Rich idle before it "catches up"
  155. Cobb a/p cable work with ECU flash?
  156. Cobb a/p cable work with ECU flash?
  157. retune after rescale???
  158. Help with wiring Lc-1 to simulate narrowband for closed loop control
  159. Advantage of innovate vs aem?
  160. Leaning out cruise AFR a bit?
  161. 89960000 xml
  162. Need help tuning Idle after MAF swap
  163. I cant not retard the timing more than -10º ¿?
  164. Auto-Disassembly Script
  165. help with boost spiking
  166. Correct way to log LOAD with a 2.0 cable??
  167. how to log a pull in evoscan?
  168. EVO GTA Mapping probems 88780004
  169. Sample disassembly
  170. fuel mapping question
  171. LC-1 serial output not same as DB gauge in Evoscan
  172. Phantom Knock?
  173. MAF Hz formular correction
  174. Load for timing? (evo8)
  175. good remote tuner??
  176. help eliminating this knock
  177. Add cruise timing using EGR table
  178. XML files for ecuflash!!!
  179. Should I switch my High Octane timing map with my Low? PIC INSIDE
  180. Another "Cant log from Lc-1" thread
  181. Evoscan wont detect my USB COM ports UGH!
  182. trying to get evoscan downloaded
  183. Lancer Evoscan Problem -PLEASE HELP-
  184. I cant log my lc1 help please!!!!
  185. lift off knock
  186. Problems with ECU Load heeeeelp!!!!!!
  187. map tracer fault?
  188. 30psi 0 knock on the 2 step!!!!!!!!
  189. Logging from my Depo Wideband Gauge
  190. Help w/E85 cold start
  191. HELP Injector Scaling Address
  192. Quick question regarding EVO 8 ecu hardware vs software?
  193. Evoscan and Serial UEGO problem!
  194. 9417 and dual map boost questions
  195. 89280002 to 88570008 possible?
  196. Can Evo IX's Log Wideband AFR via Rear O2 ECU ADC Input (Logging AFR w/out serial)
  197. Tephra Boost Control question
  198. complete 96260009.xml
  199. throttle tip-in and timing
  200. Reading Rom
  201. Evo 7 communication issues
  202. Bouncy idle with AC
  203. Won't take timing up top Help!!
  204. JDM map sensor with 94170715
  205. Check my 2.3 timing
  206. map trace problem
  207. Logging AFR through ECU From PLX wideband
  208. stock MDP sensor formula
  209. Anyone logging IAT and not using speed density?
  210. what afr/timing to aim on spool-up ?
  211. can't boost more then 30psi ???
  212. Ecuflash problems!!
  213. '03 evo 8 - ecuflash timeout error
  214. Any definitive fix for RPM hang?
  215. 89280002 2 bite load and rpm
  216. connection problems, ftdibus.sys problem
  217. Larger injectors - warm start issues
  218. Request: JDM MAT Scaling or JDM Evo9 xml
  219. Problem with ecuflash conection
  220. thermo fan duty not working with 98640015
  221. Full ALS for a JDM evo 7 that works ???
  222. Logging Issues with Tephra V7 94170715
  223. Used Evoscan for the first time! Results!
  224. Innovate Lc-1 issues
  225. correct RPM/Speed to Gear values for Evo 9 RS
  226. Need AEm 3.5 bar Map sensor equation for Evoscan
  227. Whats happening here??
  228. I Need to know how to scale Omnipower 4 bar in Kpa
  229. Horribly Confused (Evo 8/TephraModv7/EvoScan)
  230. NLTS for 96260009 TephraMod on 3 plug ECU's
  231. Problem with write......
  232. Uncontrollably RICH
  233. stock rom 94170008
  234. Disabling P0069 via Periphery4 (FEA) bit14 does not work.
  235. EVOSCAN macbook pro
  236. Help with ROM
  237. troubles opening saved ROMs
  238. Boost Leak vs. Load
  239. no stationary rev limit w 90550001 rom
  240. Anyone seen a 1.80E-05 error in logs?
  241. installed FP red and then tuned it...
  242. evo 7 ecu with 96532706
  243. Log boost with Autogauge MAP sensor?
  244. STFT Control
  245. WBo2 help
  246. Will Evo 8 wideband o2 work with Evo 9 ECU ?
  247. rc 550 injector scaling
  248. Parallels vs Bootcamp(searched)
  249. Messed up 96260007 maps
  250. AEM EUGO - white wire - EvoScan ??
