View Full Version : ECU Flash
- phantom knock i guess?
- help i am new
- EvoScan on a 1g DSM?????
- quick question
- Omni 4 bar MAP sensor ROM compatibility settings for USDM Evo 8/9
- What indicate Blue text in EcuFlash
- Is any one running a 2.3L Strokerw/big turbo On Stock Ecu/Stock MAF? Please Chime in!
- load cap address
- HELP Definition File (Xml) needed for Evo 9 MR JDM (80092002)
- Question on evo live map, load/timing not corresponding
- issues using my apple computer
- anyone with a modded/working 88590013 map?
- 88570008
- Quick Load based boost question
- High idle and I'm totally stumped
- loads very high
- fuel trims dont move....
- BOV / DV questions
- Comments on Tephra's Gear-based boost control w/ mrfred's direct boost mod
- AEM Analog Wideband Gague 30-5130 and evoscan
- Evo Scan connection issue..
- need help w/ immobilizer
- Fuel Pressure Question
- Can i log at 10hz exactly
- throwing DTC P0513 and car wont start
- Issue converting from 94170015 to 96530706
- Issues with TephraMods
- Knocking problem
- AEM stopped reading in evoscan
- Locked computer
- Coolant Sensors & associated gauges: dash vs ecu
- Cannot edit xml files
- USB to Serial Compatibility with Vista x64 Bit??
- ECU flash help
- EVOSCAN XML help plueeease...
- reflashing evo 7 ecu on evo 5
- Ecu controlled boost with aftermarket hp wastegate
- Configure AEM 5 BAR Map Sensor
- any geeks heavily modified the way gps logger does stuff?
- Question about Bosch 1000cc Injectors
- which thread has the evoscan LC1 scalings in?
- ecuflash 1.42 installed & tatrix cable 1.3 not working
- How good of a laptop will I need to start tuning?
- Evo8 ECU in a 1G DSM in the works!
- 97470001 to 96530706-v7t6 Problem ...
- 1.3 VS 2.0 tatrix cable's
- Convert evoscan files to logworks
- need advice about my map
- AEM to FLASH
- Immobilizer help!
- Can't get EcuFlash to read stock ROM
- How does my High Octane Map Look?
- Other/Additional Definition Files...???
- Problem converting to 96530006v5.10
- Customizing logged items in Evo Live Map
- error message when trying to upload maps
- Can't edit XML File
- Interpreting 2 Byte Load
- Looking for a Tuner!
- sh7052f developer needed for project
- how to connect to the ABS ECU?
- wanted: evo 6 LHD electrical wiring/circuit diagrams
- MAF Adder
- 96530706 + DMA +LiveMap + SD - working
- Can A GM 3 Bar MAP Sensor be Used to Log Boost?
- A tuner question!!
- ? Fuel Trims ?
- Data windows resizing?
- Best alternative for the 96420008 rom?
- Help with Duty Cycle Please!!!
- Running rich no matter what i do
- Can't save patch?
- tell your opinion...
- Why does my rom say 2004 when my EVO is an 05?
- Which Rom
- Need How To on INstalling MAP
- Patch: Force OBD Inspection Pass (acamus, mrfred)
- what is the perfect AFR and ignition timing ?
- Need Help For Those with JDM IX GT
- Name that Map
- Problems Connecting with Evoscan.
- Which Serial to USB converter works with Uego and Evoscan
- Interesting read: Ford developing laser ingnition
- e85 knock
- ROM version 96940013
- Going back to stock ecu
- Weird EvoScan issue with reviewing logs
- Is this false knock?
- need definition file .. help
- So I'm trying to disable my rear 02 sensor (Since thats where my wideband is)
- EGR hose off running really rich!
- Logging With An AEM UEGO
- Tactrix Fail
- How do I get into disassembly?
- Need stock EVo IX map....i have a new ECU and I'm not sure where it came from..
- help with my timing please.
- Switch to BCS from MBC to get higher boost @ track
- need evo x rom
- strange fuel cut, need help.
- retardation, strangulation...
- EGR valve forced open at high boost?
- Please help me evaluate and improve my tune.
- wastegate solenoid activation Rpm table question
- Can I use a mac?
- ecuflash question: wastegate solenoid activation, boost desired engine load and other
- evoscan No response from ecu(ecuflash work)
- target interpolated not populated after 240 load
- MUT Commands Known?
- when using map tracer problem
- Remove P0172 code from ECU ROM
- What would happen if I did this.....?
- evo 9 jdm rs stock ROM, xml needed
- Logworks 3 - how to make it log 2 bite load
- Downloaded evoscan on wrong pc
- can someone sent me a good definition for 93660005
- innovative lm-2 - insane values
- EGTs for Road Racing
- How Important is a 3 Bar MAP?
- EvoScan + Logging AEM UEGO = Arghh!!!
- Scrambled map from an 03
- Looking for Global/latency values:Precision 1200's?
- AEM UEGO logging help
- TephraMod V.6 boost control problem
- Map Switching In Evo X While Using Aquamist? Tephra?
- Is Excel the ONLY way to read EvoScan logs?
- EvoScan 2.5 and LC-1 skipping?
- Electrical Q: quick ground question
- Who's tuned fp4r's?? Midrang knock?
- 2 different ECU's, same immobilized code, WTF?
- Anyway to disable CEL P0107??
- need help setting my car
- Lancer DE 2008-2009
- ecu flashing?.. new to it.. who did it results ?? who did your reflash??
- Ecu internal Counter and MFI relais (fan)
- Thanks to those of you putting in the work on the stock ECU.
- Logging aem wideband
- ecuflash could not recognise rom image
- 05 ecu in an 04 evo
- map switch help
- FP Green, FPR4 cams, Meth, And TBE Tune
- followed by injecting
- No 2 step?????????
- evo 5 2 bute mod
- using apexi avcr map sensor to log boost
- Installing sensor IN the Cat?
- New ECUflash version not working with 2.0 cable?
- 2.3 hks 272 stock everything else.
- Pegging 380 load with Evo IX
- EvoScan 2.5 Download link
- EvoScan v2.6 B16 Logging Problems with Zeitronix ZT2
- WBo2 lag time.
- ECU based boost / help
- care to comment on this map
- 3 bar JDM Map Sensor harness EDM Evo IX
- looking for stock evo rpm and airflow log
- EcuFlash 1.42 Released
- Speed Density - Evo IX - Possible? Questions?
- Everyone loves ECUFlash
- DISASSEMBLERS please read. New Platform
- anyones ecu failed afer reflash????
- knock after a NLTS
- ECUFLASH Knock
- Logging and Patching 2001 Evo VII
- merging 0-40 load
- Guidance from EcuFlash gods
- JDM 8 MR upgrade
- NO table info after rom read?
- Ralliart Torque Limting
- LC-1 Wideband Logging in EvoScan
- EvoScan Version Question
- Sensor questions
- Reasons why my fuel table would max out at 7.4?
- Boost Control tables
- what does MUT table affect
- EvoScan install Help plz!
- help with jdm evo 8 gsr map 93660005
- Way to adjust for tire size?
- Ecuflash error on a X
- Battery voltage WOT
- GM 3-port: VTA or not?
- 2 byte mod for 98640014????
- Periphery Bit for P0420 Code
- Acer Aspire ONE 11.6 netbook FTW!
- Problem with LC-1
- Random question: Does hex copy correctly?
- Ign Fuel Maps??
- sudden enrichment and stalling
- Comp. shuts down, when hooking up WB?.?.?
- scanning with open port 2.0
- What A/F ratio should i aim for?
- Need help finding new items to log
- Scaling 260 -> 300 with different roms
- Error message with Ecuflash
- Cold start enrichment for 94170015
- Best AFR for power and safety.
- Disassembly: 2-byte variables
- LC-1 Problems
- changes in fuel map does not have effect . why ?
- is this 2 byte mod correct
- slight hiccup peak boost 4th/5th gear
- More boost than 18 Psi/redline is nonsense
- how to start
- 35R tuning with 4" inlet pipe - question/advise
- Odd Issue....knocks ONLY @3k or lower
- changed values for Y axis
- launch control?
- LM-1 Logging Issue
- Help: Evoscan v2.2
- Evoscan 2.5 & Lm-1 issues
- So I took my MBC off today he he!!
- datalogged my car - opinions
- Tractrix cable question (not the average ?)
- Com1 Access Denied.
- Vista and patching problem, help me!!
- suspension data logging with evoscan ?
- Stumble at 7000 RPM with log...
- Virtual Dyno Room-Dyno Simulator
- Another idle issue
- ECU Pin 43 - Clutch Position Switch
- Trying to use 2 byte load
- NLTS Knock!
- Intake Air Temp vs Timing Table
- Opinions on tune...
- evo 7, 2001 JDM ecu no definations defined
- Switching to Low Maps w/o Knock ??
- Help Please with Boost Control 30R and Tial
- Evoscan - disconnecting on logging runs?
- Evo5/6 Load and PW Cap?
- Alt Map switching, installed and thanks
- Looking for Evo club, Seattle
- Evoscan: Diagonostic Trouble Code: o2 level 19.9%
- How low for timing to be dangerous?
- Evo Scan issue
- What happens at peak load?
- Can't log fuel trims
- creeping injector scaling
- Airvol question
- sputtering car, log inside.
- need a fully patched
- 885800014
- Log boost with Defi Boost sensor
- Unknown ECU strategy for boost control
- P0603 Error
- Knocking Issues at Low Rpm/Low Load
- Injector Scaling Formula
- Car Will not connect to ecuflash.. Evo 9..
- Does "baseline WGDC" = "Max Wastegate duty"
- Precision880cc latency values?
- Help for a ECUflash noob
- Stock BCS hose routing
