PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. OMNI 4 bar readings WAY off
  2. DynoVision Update v1.1.0
  3. Octane Level.
  4. AEM 3.5Bar MAP Sensor + EvoScan
  5. Another Idling Issue
  6. knck on throttle lift off
  7. flashing an E7 90500501 rom into a E8 9920007 ecu?
  8. MUT Table address Location
  9. Half the window is cut off
  10. new to ecu flash and tephra need help
  11. How connect 3-port with Tial EWG using both ports?
  12. Need help Evo 5 gsr
  13. IM DONE! with 96530706, put the car on 94170715 last night
  14. Need some help with regards to AYC/ACD/ABS ECU
  15. Tuning for the dragstrip and leanspool behaviors
  16. engine hesitating between 3 and 4k rpm
  17. Boost control on v7
  18. 87 octane tune-reduce cruising timing and high load timing?
  19. evoscan error help "&H"
  20. how to wire clutch switch
  21. Samco intake pipe messing with maf?
  22. bought evo, Rom on car
  23. Coming from a subaru and ecuflash, where are all the tables???
  24. Some questions about SD tuning from scratch
  25. This look like MBT?
  26. first start problem
  27. Fully tuned 2.3ltr timing Maps
  28. reccommended stationary rev limit?
  29. Speed density trouble. help needed
  30. Timing map don't match logs Tephra v7
  31. Why is my 1 byte load so high compared to baro+temp compensated 2byte load?
  32. Car Runs Lean at WOT regardless of MAP
  33. JDM MAT sensor scaling - voltage/temp
  34. Correct Asynch_vs_TPS XML for 8859x715
  35. JDM Map sensor, voltage / boost scaling
  36. Call me dumb...
  37. very high load
  38. Omni 4 bar MAP sensor "too much sensor" for reasonable boost levels?
  39. RRE dual tune rom+def
  40. intake air temperature scaling
  41. help analysing this log
  42. Seriously considering making a "no boost (econo)" map
  43. Evo 8 Internal Id Not Foud
  44. What controls A/F ratios at higher loads?
  45. black smoke on 12.0 afr
  46. can't log LC-1 via serial cable
  47. Analogue output logging speed quicker than serial?
  48. change the xml.
  49. Failed to read the ROM
  50. HELP ON THE JDM EVO 8 !!!! cant read ignition and fuel
  51. No IC relay timer control with the rom
  52. coolant temp fuel trim????
  53. descriptions for sub_C28 etc routines
  54. big throttle body
  55. TPS reading
  56. Setting base timing with ECU flash *IN A DSM*
  57. need stock rom and xml for 01 eclipse
  58. Average fuel consumption with evoscan!
  59. immobilizer delete problems!!!
  60. Mitsu re-flash connector for 1.3 cable?
  61. Down shifting knock
  62. Wideband AFR dropping, hesitation, brick wall feeling
  63. IC Relay Function
  64. cant connect to evo 7 or log from it
  65. .hex and .bin file types added
  66. Why are Peak Boost and Torque Coming on Late??
  67. problem with ecuflash
  68. bucking at boost
  69. crazy knock or??
  70. Ecuflash wont connect
  71. noob question: how to 'read' Load
  72. ECU based boost control question
  73. odd VD results/lcq issue?
  74. ROM read problem
  75. Any fixes for stalling with 96530706 or 94170715
  76. fuel trims arent logging
  77. Locked out from changing Injector Scaling in ECUFlash
  78. High knock count on idle revving *log inside*
  79. anti-lag set-up help
  80. 3 inch GM Maff
  81. als not working on my friends jdm e7
  82. Can I still use my "GM" 3 bar
  83. 2.3ltr High Idle
  84. WGDC#'s for a stock turbo..
  85. Dual Map Behaviors ?
  86. Intermitten ability to connect to ECU. Internal battery dead?
  87. EcuFlash - X and Y axis values getting mixed up
  88. Can't start the engine with 96530006 replacement for 99270000
  89. Review new Octane Booster TORCO in Panama...by Just Tuned.
  90. Disable ALL circuit tests in the ECU
  91. Tephra V7 96530706 IC Control
  92. Need -19º stock ecu evo VIII 2004 USDM
  93. On the right path??....AFR's(specifically)
  94. P0170 fuel trim bank 1. - solution ?
  95. Afr's as lean as 7.4
  96. Boost problem with Grimmspeed
  97. Is there a flywheel weight somewhere in the ECU?
  98. p0125 is stuck to my car like glue
  99. what is that ????
  100. Wired +5v into pin 26 (rear o2 heater control)
  101. My experiences 96530706 vs. 94170715
  102. wideband question
  103. Evo scan 2.7 issue
  104. Issues After Walbro Install
  105. OMNI 3-bar MAP sensor scalings
  106. What happend with my map?
  107. disabling engine code?
  108. Need stock map
  109. Lean at takeoff when COLD or A/C on
  110. Troubleshooting CRAZY problem STFT during cranking (-23%/+26%) Timing Adv -20/+24
  111. rear o2 wire color (evo ix)
  112. EDM Evo8 99270000, what can i use?
  113. Stick with OEM 7 ECU or change over a newer one?
  114. Evoscan can't read the ecu + overboosting
  115. Help, Hot start condition, Very Lean, Red hot header, wont idle.
  116. From where to get evoscan, can't have paypal
  117. ECU load throuble, I need help with my proyect.
  118. 2.3 Stroker Knock
  119. cant view ROM's?
  120. new and need some help
  121. too lean at idle
  122. how to: full time open loop ?
  123. wierd problems after tune?
  124. Stock 9 GSR map anyone?
  125. Is this right? MUT 2byte/Evoscan
  126. Can't open datalogs with excel
  127. EVO 8 2003 Standard ROM
  128. Getting knock on closed/open loop transition
  129. How to increase 2-btye airflow?
  130. 05mr cant read rom
  131. 2byte load/Mitsulogger
  132. ix SD fic 2150's base map needed
  133. What rpm ranges are low, mid, and high for knock tables
  134. Electric Water Pump Controller
  135. New to Evo tuning.
  136. 90 load in evoscan?
  137. actual afr not matching with map's afr
  138. Cams and lopiness???
  139. rev limit
  140. idle tables jacked up
  141. ECU FLASH Help PLZ
  142. how to change Fahrenheits to Celsius ?
  143. issues with my ecuflash...
  144. Help please I need Evoscan 2.7
  145. Wideband/Evoscan Problem
  146. ecuflash won't read rom id
  147. E85: knock count on spoolup and load spikes
  148. Speed density tuning question
  149. question about injector scaleing
  150. Engine Simulator for ECU development?
  151. Want to ditch xede....
  152. fuel trims not changing
  153. Possible brick?
  154. Passing emissions testing with a JDM Evo 7?
  155. Disabling EGR CEL
  156. have ECU flash need ECUscan is it still free???
  157. GM 3 Bar MAP Sensor Install
  158. Need map. please help
  159. a few little V7 launch map questions
  160. Question about Cam/Crank sensor and the ECU.
  161. Quick ?? that I am not seeing anywhere about tephra v7
  162. Want to add Maximum Ignition Retard Settings in ALS
  163. High idle on cold start - TephraMod v7
  164. help, TephraV7 rom scaled for Evo3 ?
  165. How you all getting on with tuning 3d VE maps?
  166. Trouble setting up Tephra v7 (94170715)
  167. Evo 8 rom to use on Evo7?
  168. can someone plese confirm this
  169. evo 9 rom
  170. Opinions on consistant high knock sums 90550001
  171. EVO 9 Cobb Stage 2 Map for ECUFlash
  172. 2.3ltr Timing Maps
  173. Load vs Boost
  174. getting very rich at 100 load. cant see why?
  175. new injectors all scaled but
  176. Speed Density Help
  177. XML file needed for a JDM EVO7
  178. knock sensor help
  179. carnt get mitsulogger to connect
  180. Dyno pull AFR way off AFR values in high octance map... Any ideas?
  181. Maybe a noob question, help importing tables into stock rom
  182. Help: EcuFlash can't read ECU
  183. Safe boost with stock internal/headgasket/turbo ?
  184. Serial to usb pointer goes everywhere
  185. Can't remove boost cut
  186. Computer/Evoscan/Stupidity Problem
  187. 1 count of constant knock across the board?
  188. Evo 7 with Tephra patched 96532706 wont start! HELP!
  189. 2byte MUT Addresses for 96420011
  190. How to open MUT table?
  191. Formula's needed zeitronix
  192. Can too low timing cause knock?
  193. Oxygen sensors
  194. Tuning for HPDE/Time Attack
  195. OOPS! No Device Detected......help!
  196. Looking to buy an evo 8 that needs a few things
  197. Built motor in car LEAN now !
  198. Precision 1000cc injector scaling and latencies
  199. Car wont start after TephraMod :( Bricked ECU?
  200. High idle/cruise afr problems
  201. Logging with AEM EUGO?? HELP NEEDED ASAP!
  202. Evo 7 Flash on Evo 8??
  203. MAP Sensor Install
  204. Insepction with V7 need help!
  205. running very rich beetween shifts
  206. Load2mut have problem
  207. Rom 96531706 w/sd issues!
  208. Openport 2.0, SD Card logging and logcfg.txt
  209. usb to serial converter
  210. Ecu Flash noob question
  211. Stock Evo Tweeking Maps?
  212. Aem bcs
  213. Water/meth for dummies
  214. How to set min temp for closed loop ?
  215. PTE 680cc
  216. definition 97470001???
  217. Zeitronix Map Sensor Speed Density
  218. Idle Stepper look up table question
  219. Boost Control
  220. how to turn sensors off?
  221. Recommended tuning books to read?
  222. evo ecu ICS light output
  223. This is getting ridiculous... Help please
  224. anti log evo 6
  225. XML Needed
  226. Converted to Tephra v7, stationary rev limit/ NTLS clutch switch issue
  227. EcuFlash 1.43.3172 crashes with V7
  228. ecu evo 7 lost data and id
  229. Passing emissions with tephra
  230. omni 4bar map evoscan issue showing + pressure at idle
  231. how do you set an exact figure? such as inj scaling 666
  232. Output Pin Control
  233. Speed Density 2.0 (3D VE Tables, Baro)
  234. SAS Mode locked Timing
  235. How to log boost via Omni 4-bar?
  236. Innability to choose year make and model after clicking read from ECu
  237. Wierd timing jump: from studder thread: LOG, and IMG of timing map.
  238. Scaling Denso 690cc help please
  239. disable the immobilizer
  240. Alternator charge current map?
  241. Random high knock and bogging at WOT low RPM
  242. ecuflash crashes
  243. Any great tuners around nebraska
  244. SD Baro Auto tune interest
  245. New 3D VE Maps SD Rom
  246. Really lean ?
  247. Need Some Help
  248. Ecu Flash Does read 2009-2010 Evo's?
  249. *HELP!* Why is my ICS manual button activating EVAP solenoid??
  250. Evo8 maf-t in 1g
