View Full Version : ECU Flash
- tuners in North Carolina?
- Where can I find ECU reflash shop in Seattle?
- Tephra mod showing strange knock CEL
- Boost limit Address for 94170015
- Ecuflash 1.29?
- logging and scanning software help
- Evoscan cable or Tactrix 2.0 cable?
- Help please with adjustment boost
- Urgent: USDM EVO8 Doesn't Start anymore, help needed please
- 1000cc injector e85 question
- Gets rich right after shift when at WOT
- NLTS tuning....lean during shifts
- injector scaling problem
- I need a baseline tune...help
- Evo scan.... Connection issues
- Load Calulated Not Reading
- send me an older version of ecuflash
- EvoScan UserGroup Meetings
- openport 2.0 scan tool software?
- ECU Boost Control Duty Cycle info
- ? Mivec Temp Trim Table ?
- Is this normal decrease in load?
- HELP!! Can't connect to EVOScan
- MAF or MAP sensor ???
- Ralliart no pasa de 15 psi........ help
- injector scaling
- EvoScan 2.5 fixs
- WTF Evoscan 2.5 (weird logging issue)
- bad MAF?
- lean afr's at idle
- another logging AFR w/ ZT-2 w/ serial/usb adapter.
- V1.38 problem
- Ignition Retard Vs. Air Temp
- MIVEC and high boost
- Timing w/cams
- Air Density Compensation Table
- Help me with my first tune! (Maps and log inside)
- Load scaling on a IX
- Long Term Fuel Trim Request ID and scaling
- Tephra v5.10 94170015 Boost control BUG!
- Problems with stationary rev limiter
- Just filled up with e85 and...my car is not happy :(
- table cuestion!
- Evoscan help
- Should i be able to read with ecuflash without the reflash connector?
- Sudden drop of load during pull...
- can a tune go bad?
- GM BCS users: Are you using a 10 ohm resistor in series with BCS?
- new to TehpraMOD
- Evoscan,computer crashed-nedd to download again
- Map switching on evo IX
- Load/Boost 3rd gear run vs 1-4 gear
- Some Help please
- super locked ECU???
- evoscan 2.5 Log and reading ACD
- Changed ECU, OBDII testing
- please help with ecuflash problem!
- Need a little help fine tuning
- Boost control using EcuFlash and stock pills
- what else can I do
- question about map switching
- 500WHP on Stock MAF&ECU
- EVO Drive Cycle for OBD-II emissions
- My first log, What do you think?
- Ingersoll Rand Boost Solenoid, confirmed works and cheap
- modified xml file but no changes appears in EcuFlash?
- JDM MAP sensor calibration
- Fighting the P0300 monster
- how to install tephra mop
- 2 step question
- tactrix cable No software
- new intercooler
- Logworks or Evoscan maptrace
- MAP switching issue on Evo 9
- EvoScan 2.5 + LM1 = no reading (but EvoScan .99 is fine)?
- how-to: control closed loop AFR with your wideband O2 system
- aquamist hfs1 + tephra mod 5.10 problem.
- How to tell if your tuner ripped you off
- need the XML 88580015
- Tactrix Cable
- 2 byte clarification
- Stock tune + 15% displacement. Will it run?
- Is it possible to log with Openport 2.0
- Tuned car and now it won't start.
- Boost control tables
- Idle issues
- MalibuJack HELP!
- FIC 1150 injector latency times but what does it mean?
- Question about 2-Byte Load and MAF Scaling
- Very Odd P300 Issues ... any insight?
- Evoscan & Evo 6
- Immobilizer issues?
- Evo 6.5 Help
- Ecu boost control (solenoids "?")
- injector scaling help
- OBD-II tables (ecuflash 1.38)
- Logging other Innovate sensors trough Evoscan?
- MAF Scaling and size findings.
- how to control boost through the ecu
- Race gas map??
- Evo Scan 2.5 Issue suddenly
- Software question?
- Low load timing not matching your maps?
- Extension Cable for OP2.0?
- Wierd problem after clutch line install!?
- Anyone understand ICS maps?
- Ignition map help.
- Stalling issues..Mind looking at my maps?
- Rom ralliart and cams brian crower 272/272
- not sure whats going wrong....mitsulogger won't log correctly
- need help fast
- ECUFlash 1.38 cable fix.
- bad log results!!
- No communication with ECU through ECUflash, EVOscan
- knock sum count
- Greddy Solenoid & ECU control?
- Definition creation help for 01 Mirage
- My car was un-tuned
- Equipment needed for tuner?
- Dell Mini... anyone use it?
- ACD and ABS flashing
- Fuel trim scaling
- Major fuel economy issue
- Which Map do you guys need to help?
- ECUFlash 1.37 cable fix
- $$ Anyone with latest Evo7 JDM Definition file please
- It's alive! (Speed density, stock ECU)
- TephraMod O2 Simulator
- No Injector Duty Cycle data
- EcuFlash Version 1.37 released
- 88590015 Evo Live Map - source
- Status of fuel trims after reflash - VIII vs IX
- MUT Requests to monitor processor IO ports with SH based ECUs
- 90550001 v5.10 Weird problems..ideas appreciated
- v1.35 graph viewing issue
- 88590015 Evo Live Map - ROM and software
- HELP needed, please read
- PTE 1200cc scaling/latency
- Talk about knock...
- help with lean idle
- Huge knock count during cruise
- Pump gas record?
- How To Log
- EGR CEL Removal Code Question
- Evo 8 Reflash went wrong.. HELP
- Dataloglab evoscan 2.5 definitions?
- Air Temp Comp/Tables for E85
- LTFT Mid Issue scaled maf
- can't get the throttle to stop diping
- Confused about my Fuel Trims
- The "Ive upgraded my injectors and I still have niggling issues" Thread
- new feature in ECUFlash 1.35: periphery bits
- Knock Filter 1 is Purge Control?
- Anyone got the link for the EvoScan/Lowworks How to?
- Put in cams now runs lean
- rough idle on hot startup
- Logging LC-1 with EVOScan? - help
- Changing values w/ certain modifications.
- Evoscan to datalog before tuning?
- am i running out of injectors??
- help with 1000cc injectors
- EvoScan Registration
- EVOScan reading a/f in V?
- How do you change the color schemes in ECU Flash?
- Quick qusetion about evoscan 2.4
- EGR Solenoid as a 3 port option?
- lean out = massive knock
- Evoscan Request Numbers
- Boost Desired Engine Load?
- What is the point of this timming block? Pic
- Evoscan serial number problem???
- Self Tuned
- Too lean?
- Car shuts off/ Bucks at 60% throttle 2100 RPMS 6 psi boost
- Stepper table question
- ECUFLASH cable
- Anyone interested in Disassembling an Evo 5 / 6 Rom ?
- My AFR. Please comments, Advise and Solutions
- Strange Looking ROM tables, any help??
- question about lean spool
- First Logs with WB (weird knock up top)
- Detectability
- I need someone to host my logs
- Yesterday run my Evo8
- Need help Controlling Boost with GM Boost Selenoid
- Fuel Trim Issue Post Cam install
- installing LC1
- can i bring my fans on earlier?
- Will Evoscan support Openport 2.0 Cable?
- Bigger injectors?
- EVO 7 GT-A ECUFLASH Problem
- Tactrix cable doesn't work
- Flash evo Youtube video
- Map confusion
- New Maps for Evo 7 and 9
- Another idle problem with A/C on.
- anyone in phoenix area????
- Looking for a stock map
- Low RPM Issue
- downloaded the AYC/ACD ROM
- Map sensors and difficulty tuning
- My first shot @ it!
- Tephra!
- Autosmoothing tool for Fuel and Ignition Maps
- Original ROMID
- afr & timing
- Dyno tuning; tail pipe or LC-1 best?
- Knock on Deceleration?
- Looking for help, running off the map
- Help Reading Rom
- 4K RPM idle
- Engine Load %
- evoscan, can't open logs w/excel
- 1000ccs on stock ECU
- Anybody pass emisions without a cat?
- IX won't connect to PC?? experienced tuner can't figure this one out...
- 36 counts of knock...scary!
- High/Low Octane Fuel Map confusion
- AFR advice please
- having problems with knock
- USDM EVOX map offsets
- Can Anyone In Jersey Give me a temporary Street Tune?
- You and your load......
- Zeitronics and Evoscan ?s
- ECU Pin 38
- flashing back to stock..
- Definition of Load?
- 3rd gear Pull very quick "hiccup" / pop???
- Need Addresses for Lean Spool Start/Stop for 94170015/14
- Solution for ECUFlash 1.35 freezing with 100% cpu when reading/writing rom.
- which logger works with mac?
- Problem reading ECU with EcuFlash
- Separate ignitor/coil setup than works on Stock ECU :)
- Need help with my logs...(how to start with new mods)
- is it possible
- disable o2, Version 1.35.1650?????
- Smoothing your tune with graphing
- Please take a look at these logs
- Shift Light in cluster?
- Possible BOV issue?
- LoadMut 2-Byte doesn't fit with the Ignition (ROM)
- My Fuel And Timing Maps Please Take A Look
- Fuel trims...again.
- Bulletproof tuning for track use
- TephraMOD V5.10
- Do I have a boost leak? log graphs attached...
- NLTS boo boo.
- This rom any good?
- innovate lm2 and datalogging
- Minimum Temperature for Boost Control?
