PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40]
  1. Owners manual?
  2. Request IDs from 00 to 3F
  3. Good MAF info..
  4. Octane number found on Evo
  5. 21 psi
  6. where can I download a free log viewer
  7. Datalogging options?
  8. Confused, need help quick!!
  9. quick question
  10. EcuFlash ?
  11. Evoscan freezing
  12. Step increase in injector time at 7000 rpm
  13. Barometer readings under high boost/revs - measure of inlet restrictions
  14. EvoScan, Evo's, And Knock
  15. cant log into openECU
  16. MAF Hz
  17. Evoscan log script
  18. Making map-driven flash for the evo8 ecu.
  19. "hanging RPM's" and ISCV maps
  20. Flat Midrange
  21. Airflow HZ to Load Value?
  22. MIVEC dyno tuned!
  23. Map Switching
  24. evoscan ???
  25. Locked ECU's... Not anymore..
  26. My evo ix knock sum ok?
  27. 1,28 download problem
  28. fuel maps - I'm confused
  29. help real uick
  30. Quick Question
  31. what are your EvoScan idle tps readings
  32. Air temp in Evoscan
  33. Fuel trim nosediving during hwy cruise?? :confused:
  34. switching look up table
  35. Knock question
  36. EvoScan O2 voltage
  37. '05 ROM in an '03
  38. ECUFlash Power Record?
  39. f/s Tactrix Cable
  40. Which sensor reads air temp (noob question)
  41. Where is the correct .NET 2.0 download?
  42. 0 Knock with a/f @ 10.7-9
  43. Stroker Advice?
  44. Tactrix Cable
  45. ROM definition for ECU
  46. Last chance to get EvoScan
  47. P0300?
  48. How to Safely adjust timing
  49. How-to: Rescale Load Axis (percent) Values in Evo VIII ECU
  50. 2 step launch control @ 6,000 rmp
  51. Adding elements to scaling tables
  52. innovate lm-1 interface
  53. Boost control - what I have thought about so far - ideas
  54. ECUFlash and Outlander?
  55. Open Loop Load & Open Loop Throttle
  56. does ECUFlash work on Windows Mobile 5.0???
  57. MIVEC tuning
  58. Vehicle speed sensor DTC
  59. alky injection + 2 low/high maps
  60. Windows XP works fine Windows 2000 i got problems
  61. EVO IX Injector Scaling
  62. Another method of displaying Evoscan 0.8 logs
  63. Some good datalogging information
  64. Immobilizer not correct
  65. Can the idle be programmed into the tune?
  66. My idle keeps going higher...why?
  67. Evo IX Connector?
  68. Crazy ignition timing - Evo VIII vs IX
  69. Evoscan v0.8 feedback
  70. checked my afr's with the innovative......confused
  71. First datalogs, please comment
  72. evoscan guages
  73. 03 Lancer 5spd problems....Colby READ
  74. Getting a 2.4L base map
  75. Data Log Lab...
  76. Read from ECU window is blank...
  77. Knock counts at partial throttle (mostly when lifting)?
  78. noob question....reg lancer
  79. Lift off detonation sorted thanks to Evoscan/Ecuflash/Second Chance log viewer
  80. Evoscan log reader ?
  81. Lots of questions
  82. Links to Evom Vendors offering Maps via Ecuflash
  83. Evoscan
  84. Post your evoscan logs
  85. This is how to pin-point what load cell your car is operating in!
  86. Scaling Map to 300
  87. RPM hang up
  88. Common "Tuner" Tweaks: Intake, Fuel Pump etc.
  89. Feature Request?
  90. Lost immobilizer....car wont start
  91. Accel Enrichment
  92. Evoscan timing values?
  93. AMS Tuning Tips
  94. ATTN EVOSCAN owners a useful tool to view logs
  95. stock rom
  96. engine feels like it hits a wall @ WOT
  97. stock evo ix
  98. Time to reflash?
  99. Change Values to tune higher Boost?
  100. Wastegate duty cycles, target boost
  101. ECUFLASH with 2.3L stroker!!
  102. Flash Limit??
  103. What is the load algorithm?
  104. EVOSCAN Guages
  105. ECUFlash dyno results!
  106. evoscan logger release
  107. Evo 9 ignition maps
  108. ECUflash and Alky/Meth questions???
  109. Timing Maps W/ Alky or Race Gas---Screen Shots
  110. Where to Buy flashing cables?
  111. Ecu reading from 120-140 load table in High Boost!
  112. Injector scaling and latecy for different injectors.
  113. map scaling info in the knock problem spot thread
  114. Mynes Performance Custom Maps?
  115. Stock 9 Tuned on 104
  116. Alky/Pump maps anyone???
  117. Trouble Controlling Boost with Soleniod??
  118. knock problem spot at 3,000 rpm......
  119. Further questions on EcuFlash w/ EcuTek
  120. Starting to tune.. logs and such inside
  121. EcuFlash Part 2...
  122. ECUFlash and TURBO Lancer
  123. Gt35r tuned with EcuFlash result
  124. Flashing tools do not recognize flash method 'evo'
  125. 1.28 now available
  126. Evo 9 and Lancer Auto support added to V1.28
  127. ECUFlash Dyno Day
  128. ECU Flash working with SAFC
  129. ECU Flash Results
  130. ECU explorer for loggin
  131. I get this error when I open my ECU Flash and also can't read rom file.
  132. How much timing are you running on pump gas?
  133. just ordered my cable
  134. Can I still read the ECU w/ Exede connected
  135. Got Tuned With ECUFLASH.. Results/Findings
  136. My ECUFlash track results
  137. uh colby......
  138. 05mr
  139. Re: adjusting fuel map
  140. adjusting the fuel maps??
  141. When i pull my current map...this is what i see...
  142. 2-step function
  143. Flash back to stock....
  144. some IX info to digest
  145. Ignition timing on my JDM Evo IX
  146. Reading ECU with current flash
  147. Windows 2000 NT compatability?
  148. No knock, ECU pulls timing - why?
  149. AFR consistency per gear?
  150. HKS RS intake tuning?
  151. EcuFlash Ignition Table
  152. got new flash uploaded...
  153. Whats the latest on IX Flash capability?
  154. differences in 03 vs 05 timing maps
  155. Wow props to the shipping department.
  156. Fuel cut map
  157. Boost control with ECUFlash - What are you using?
  158. Limit on number of cells that can be copied and pasted?
  159. Anyone with 780cc / 16G/20G map?
  160. EcuFlash - Finally got some time with it today...
  161. post your maps here
  162. EcuFlash ReFlash Limit ?
  163. Just got ecu flash and i want to tune my cams and fuel pump how do i?
  164. Maf Scaling??
  165. Who is running larger than stock turbos on Ecuflash?
  166. Did i do this correctly?
  167. Anyone else have this problem?
  168. I CANNOT get 1.27 to read ANY ecu (screen shots inside)...
  169. Flashed it with the wrong ECU identifier!
  170. Cable for ecuflash
  171. IC Sprayer Settings
  172. Adding additional columns in map definition?
  173. Immobilizer Question
  174. What to use for DataLogging
  175. my first datalog =)
  176. Ecuflash Simple Question
  177. Boost question
  178. warranty question
  179. Question regarding tuning methods...
  180. HKS 264/272 with 680cc injectors --- EcuFlash MAP included
  181. Internal ID #'s
  182. Is Ecuflash for Evo9?
  183. problem connecting
  184. EcuFlash cables are back in stock. First come-first shipped.
  185. I need the stock EVO IX base maps?
  186. Unknown ROM image?
  187. Ecuflash using mapsensor w/o piggyback possible?
  188. Service Engine Soon
  189. ECUFlash Rom table Help??
  190. Rom table help??
  191. Unable to connect to vehicle interface?
  192. First tune with the ECUFlash app..
  193. Any ETA for the IX's?
  194. Apple puter for ECUFlash and min requirments for PC
  195. IC maps?
  196. error loading FTD2XX.DLL
  197. ECUflash before and after dyno results!
  198. Injector Scaling with ECU Flash
  199. Palmone Tungsten E2 OBDII Cables
  200. Knock sensor threshold
  201. EcuFlash stationary rev limit work on 03's
  202. IX or IX MR Dynoflash
  203. EcuTek'ed... what are my options?
  204. XML Defs (Updated for ECUFlash 1.27)
  205. Caution - "Knock Sensor Filters"
  206. Used ECUflash today - WOW!!
  207. New Release Version 1.27
  208. ecuflash cable
  209. Must Read Before Using Software!!!
  210. Do Not Post Vendor Purchased Maps
  211. 2003 first allocation stock rom?
  212. Why cant i get ECUFlash running?
  213. ECUflash tutorial for beginners
  214. TBE, Intake, MBC
  215. Re: Please Read Concerning Posting Vendor Maps Thread
  216. Lean Spool RPM
  217. Grass Roots Tuners
  218. fuel economy
  219. tweaking maps
  220. Engine Coolant Temp...
  221. Users Guide?
  222. Rescaling Load Table
  223. XML Def files
  224. Which Wideband For EcuFlash?
  225. We need some "how to's"
  226. 2 Step Map Definition
  227. Injector scaling
  228. 280's Map
  229. OBD-II software that can use the 1.3m cable?
  230. ECU FLASH Tuning Questions
  231. ECUFLASH Released!!!
  232. Updates for "ECUFlash for EVO, Subaru, 3rd Gen Eclipse" freeware??
