View Full Version : ECU Flash
- Anyone still having off-boost SD stutter issues?
- aem analog gauge logging question
- FIC 1050 SP asnu latency needed
- SD MAP sensor - which ECU pin to use?
- problem loading rom into evoscan
- Tuning Issue Evo Mr with SSP 600 kit
- Evo IX owners/tuners: Can we flag the ECU to turn on the AC compressor at idle
- Odd rich conditions, unstable idle, etc..
- Speed density problem
- Help with some info
- logging 1 Byte load
- How to connet LM-2, Log to the EVOSCAN?
- evo9 ecu alternatives and wiring
- Cruises at 160 degrees
- ECUflash 1.44 crash windows 7
- Help get my evo started!
- Injector scaling smaller than actual size
- Starting my first tune
- cannot open ROM file
- Help! WGDC not correcting on target boost???
- A little help please
- Anyone done a formula to log AEM 2Bar sensor?
- evoscan not reading external wide band
- Intercooler Sprayer Output Control
- Speed density bug
- will omni 3 bar map sensor work with zeitronix LCD display?
- Cam lope on VIII
- Fuel Trims not budging
- Logging error in EVOSCAN.
- Sd blend tuning?
- Odd problem with boost control
- evo ix with gsc s2 cams, maps?
- All 88590015 / 88590715 TABLES!
- sd map ve calibration column missing?
- Lost ROM/MAP. NEED HELP.
- Very strange WGDC behavior - 5th gear only?
- logging boost on jdm 96260009
- Injector duties help please
- map tracer has wideband as 1200 when its actually 12afr
- eeepc evoscan issue
- Self tuning help
- odd little issue
- Something wrong with my EVO 8 FQ340?
- Fuel Cut and Load Limit removal for EVO 9 SD Tephra???
- Setting up for Self Tuning.
- What am i doing wrong??? NEED HELP ASAP
- editing map after turbo setup change (hx35 to s256)
- Evo 8 Powered Datsun 1200 ute
- evo 9 maf smoothing table?
- Logging 2byte Load with EvoScan & 96530706 Question
- Erratic AFR's at WOT only
- Quick Ignition question
- ECU Flash not reading ECU? (Newb question)
- Is rpm drop per rev limit adjustable?
- Over boosting when BDEL and BCLO set up...
- ECU boost control load address details...
- WGDC stuck at 0%?
- New to tunning and need help.
- Evoscan for andriod devices
- CEL after ecu swap
- Direct Boost OMNI 4-Bar
- 2D and 3D conversion chart
- How to log 2byte load through mitsulogger
- knock sensor triple & single gain switching point?
- Evoscan J code -16
- need help on how to start tuning evo ecu first step
- How much does the bleed hole in the Halman mbc effect fuel trim?
- Can someone tell me what is going on?
- Speed Density Evolution 9 Fine tuning
- rich cold start
- Scaling injectors trying to read fuel trims?
- evo 8 hx35 logs
- Help, EcuFlash not working on Windows8
- Can someone verify that this log looks okay?
- evoscan logging wideband direct or with serial cable
- Phantom knock or not?
- Lm2 wiring to ecu
- Problems leaning out cruise in OL
- 8858 XML improvement. 88580714 88582714 88586714
- Bypass valve compensation
- Evo 8 ECU Bench test help from code gurus
- FIC 1650 idle and accel issues.
- xml needed 96940011 inside
- Cleaning up a log
- Searching for Advanced Fuel 8858:
- octane level in evoscan
- Can not richen AFR
- Wastegate flutter with GM 3 port
- Please Help: Unknown Rom Image
- Mivec log VS Mivec Map : oscillating actual
- ECUflash 1.44 cant write .
- Evo IX - car wont start after ecu upgrade
- A couple of fuel questions......Need some guidance
- Newbie here
- first time using evoscan
- Timing randomization from 2k to 3.5k rpm
- Evo 8 ecu clicks?
- Running FIC 2150's
- FIC 1650cc Bluemax Injector Scalings?
- 1.3 cable with bad USB end fixable??
- Evoscan panel#1 cannot display the log info.
- Unknown Rom Image
- LC-1 O2 connection?
- Alpha N code possible?
- 59230001 xml needed !!!! please help
- Erratic Timing Jumps vs Timing Tables
- Closed loop mivec?
- 88590014 to 88590015 update failed.
- New Evo owner....need some assitance with Speed Density
- Tephra v7 launch How to increase limiter delay?
- load question
- P0141 code on 92460000
- 9055v7 and ecu boost
- Unable to read DTCs
- Phantom knock,could it be timing belt pulley noise?
- MAP Sensor Settings
- Picking up "phantom" knock
- (hopefully) quick question about copying maps
- Have a JDM Map Sensor? Need a favor.
- Code P0110 IAT Circuit Malfunction
- How to wire zeitronix wideband into ecu?
- Modded Stock Injector Scaling
- Did my first log
- HELP Rough idle, car stall
- ECU Unlocker, does it unbrick or just unlock? Difference?
- v7 omni4 bar set up help...
- How to Eliminate "Rev-Hang" on the 05+ EVO 8/9s
- Evo stalls w/ AC on only when depressing clutch on decel
- Anyone move the IAT but still use MAF?
- EGR flow changes with speed density
- 88770005 xml needed !!!! please help
- need help ASAP ! 88770005 rom can read all table properly
- newbie ecuflash confusion
- Re: "stock ecu antilag disassembly" What shuts off the sas routine?
- Post-Starting fuel enrichment
- Constantly Knocking
- help with decel tuning
- 5 & 6 counts of Knocksum at 100% of TPS
- exhaust manifold pressure in speed density calculation?
- Rich AFR during spool-up!
- Types of computers ECU
- Anyone know where to get IX ECU pins?
- help with negative fuel trims
- How to---Map Sensor Scaling
- ecu
- Rear o2 causing idle problems?
- Tephra V6 vs V7
- Lean Idle
- openport 2.0 or evoscan 1.3???
- How do I increase samples/second in EvoScan?
- rich between shifts - normal ?
- How to modify my EVO6 injector
- Connecting Wideband to Evo IX ECU for Logging
- Tephra V7 Idle Issues becoming frustrating
- 2005 evo 8 does it have a map sensor
- SD, car starts and runs but dies quickly
- Confuse Injector Scaling
- is a tune needed right after map switch installed
- Help!ECU can not be linked with OPENPROT2.0 EVO9 not read the ROM.
- Cannot modify rom after ecuflash upgrade.
- Huge Huge Knock Just Driving Around?
- horrible cold start, need help!
- EvoScan: Errors were found in the original data.xml (Mac)
- Idile issues
- Can't control boost! PSI Based Tephra v7
- High Knock after install 280º Cams
- how to read rom?
- Tephra Mod V7 and 3 Bar Question
- Idle spikes rich sometimes
- This may be a silly thread, but can anyone give me a map to start my car?
- Looking for a SD start up/break in tune
- WGDC vs Wastegate
- What units do you Log oil pressure & temp
- Evoscan with Windows 8
- After tune, A/C having issues
- EcuFlash higher boost tuning question
- High octane ignition Map and warm start?
- data cable
- How to Log AIT
- logging AFR
- Which Load to log.?
- 2.4 base map
- V2.9 evoscan shift data to left into logging note header is normal
- Where did MMC Flash go?
- tephra v7 evo 8 ecu locked
- AEM WBD error in evoscan
- EVO IX 88590015 XML Needed.
- Using rear O2 to log AFR help
- Tactrix 1.3U
- problem with my rom
- Idling big injectors
- Evo 8 with v7 No Start After Scaling Injectors
- Scaling and latencys id2000
- EvoScan J2534 Read Error - 16
- At wit's end with Tephra V7
- Need help logging Stack AFR Gauge
- Help with Tuning
- Wideband and Evoscan Don't Match
- tephra v7 knock control
- low rpm throttle stutter tephra v7
- Need help with Injector Scaling
- 3port BCS GrimmSpeed - set up troubles
- Injectors scaling 513 vs 542
- How to adjust idle in newest version of ecuflash
- New battery rich idle help
- unusual idle surge in open loop only.
- Decreasing stock boost level
- Help with Colt czt definition
- need help with rom
- Evo 9 tuning
- ROM will not read in ECUFlash
- Innovate LM-2 Can be used on EVOSCAN?
- How to tune my EVO6?
- evoscan/ecu flash on a Mac?
- ecu flash and twin inline pumps
- Newbie needing help with Knock and timing map
- ECU Wired narrowband simulation from Innovate MTX-L
- 88580014 fuel cut multiplier
- What is the fault condition for WGDC to use "fault"
- Dangerous knock sensor settings?
- Making a gaugeless dual map tune with only Wideband and MAP wired to stock ECU?
- need a 2.4 s3's base map!
- Evo 7 Maxed out injectors and weird power graph?
- Rallyart JDM rom 98650011.xml needed
- A (probably) easier method to connect LM-2 to EvoScan
- What to do here?
- Need help logging AFR in evoscan
- Inconsistent Knock Readings
- Going to 96530706 Tephra phenem v2 from 96940011
- p0141 rear O2 heater cel even with periphery bits disabled
- Rough idle after sensor swap and flash
- How change load on the table
- EvoScan and AYC parameters
- locked timing while cranking starter
- Tephra+HFS-3 Failsafe help
- Feedback on log
- Newbie dyno graph and logs
- HFS5+Tephra Map Switching+MAC valve+MBC
- new to tuning, I have questions
- MIVEC gas mileage tuning
- ECUTEK cable, use in Evo?
- Scaling needed for aem 3.5 bar map
- need help! tuners chime in. new build issues
- obd2 port, wont connect.
- Logger
- random idle and cruise rich
- MAP Sensor and 94170715 Rom
- CEL Light (Cams)
- Little help plz with weird fuel trim all of a sudden?
- How do I make the cell size larger?
