View Full Version : ECU Flash
- Tephra v7 MOD-96260709. Newbie and need help!
- Which air intakeż
- Running rich on accel but clean logs
- Need help with fuel cut [logs/pics inside]
- How to log your AEM UEGO wideband with just a serial to usb cable
- 3 port fluttering at target boost
- Setup evo 5 launch ecuflash help..!!
- Need XML file (unknown rom)
- fuel trims won't go past -9.9%
- Pulled Rom- No start
- Spoolup knock & AFR inconsistancy. Lean Spool the cause?
- Finished tuning my car!
- Unknown rom / ID 84185028
- 94170715 - Tephra V7 Min Temp for Closed loop
- Prosport wideband logging
- Cold Start Problem - Pls Help
- Stock turbo E85 tune, can someone help out?
- need evo 5 gsr base map
- Decel Fuel Cut Resume
- Help! Power dip on DynoGraph 7200 RPM, Evo IX + Bolt-Ons
- tactrix three port solenoid
- Someone step up, help others out and make some money...
- looking for definition Ecuflash ????
- Switching to smaller injector, adjust tune?
- ID 1300cc
- faulty 2.0 tactrix?
- Fuel Pressure Solenoid
- EVAP purge/ventilation solenoids
- Need Advise on Map Sensors for Ecuflash
- SD tuning
- how to keep inject the fuel while throttle lift off?
- Notify me here of any of my threads that need to have defs fixed
- Evo 2 with evo 8 ecu, need base map urgently
- Ecuflash doent recognize basemap
- Fuel Tuning with Double Pumper
- 1st Gear Spool
- Evodroid7 owners
- Non-Typical Boost Curve Question
- Evo 4 ECU location
- 18.4 AFR off Throttle
- OEM ECU ROM for Evo 8 RS EDM
- Lean Spool AFR mapping table
- Tuning Over 300 Load
- Evo 7 no clutch switch - Enable Stat Rev Lim?
- Idle temporarily rich after stop until return to trim/stoich
- SD scaling differs from ROM to ROM
- Odd MiVEC logging/p0011 code
- Evo 5 ECU into Evo 4
- Weird issue with XML's, table's and tuner seeing different things on the same ROM
- Evo wont let me tune! Help please!
- Tactrix EcuFlash 1.44.4503 and Windows XP
- Idle Issues on Evo IX with AC on
- Advice on tune / beginner sanity check
- Trying to get load under control..
- Old ecuflash threads not displaying code/tables
- This look like a bad timing map?
- Disable EGR code?
- Can't Log Fuel Trims
- AC issues. Proof to show the weirdness. I think its a ECU/ROM prob
- rom sd 8857 8858
- Can someone please Transfer my tune to v7 for me PLEASE
- Grimmspeed EBCS over boosting
- Reliable method to flash ROM's, can evodroid do it now
- nnj evo 9mr
- Toyota Starlet 1.3l Evo 8 ecu 965 Tephra ( Very Rich AFR)
- Reflash cable
- Can someone put me on SD?
- Please Advise - AEM Brass Map Sensor
- Knock Sum/Voltage
- 1g with evo 8 ecu Map switching not working.
- Anyone have a stock 99050701 ROM? Have donated.
- rich afr on closed tps
- Just switched to SD - sanity check please
- SD inner workings
- SD V7 Help with Fuel tables
- Please delete, double post. Sorry
- unable to connect to vehicle interface and other problems
- ICS flash on alt map evo 9
- HP Stream 7 tablet running ecuflash & evoscan
- Accel enrichment throttle tip in issue after ethanol
- free tuning help
- dont understand whats goingn on here.
- 96530706 v7 on evo 7 gta
- Most updated XML/def files?
- Start up tune request Sd e85 2000cc 6266
- Knocking with no obvious reason!
- anyone with the .HEX
- Knock Control Questions (2.4L w/ Phantom Knock Issues)
- Extreme lean at partial throortle
- Ecu mr420757 question?
- Extremely rich at 1400RPM!
- evo 6.5 logging for etune
- Tactrix USB problem - The cable is broken..
- Lean out issue
- 2005 USDM Evo 8 ROM ID?
- Evo 5 tuning
- Coil Dwell Disassem and Denso Coil Behavior
- throttle hang during NLTS
- Enabling Mode 23 on Evo IX
- Need Experienced Log Readers 2.0 or 2.3 Log?
- Snap, crackle, pops!
- Getting rid of knock at high rpms
- 5858 Spool on 2.3l
- Newbie Questions
- OBD2 inspection WA
- Speed Density Intake
- rc1000 idle weirdness
- SARD 800cc injectors with stock ecu and rail?
- 12.0-12.5 afr at idle. Is it ok?
- Evo 7 Flash Sudden Lean
- Front O2 sensor dead?
- How to make new definitions??
- EcuFLASH support for an electric DV/BOV?
- Knocking On Low Timing Pump Gas
- tune shops
- too rich untill operating coolant temp
- Battery voltage workarounds
- Tephra Actual Timing way less than Target
- SD - AIT or Fuel temp ?
- can someone check my rom if its right?
- Car Won't Start - Ecuflash/Tephra
- 54560003 2009 JDM Lancer Evolution X 5MT immobilizer issue
- can't connect to ecuflash/evoscan, PLEASE HELP
- Help Me Diagnose 3 Year Old Jitter Issue
- Table to control idle right after starting?
- 2003 Mitsubishi EVO Lancer 2.0 idle issue
- Tuning:expanding LOAD parameters help
- 4G64 noise machine (phantom or real knock)
- Fuel trim low stuck but mid works...
- XML definition for EcuFlash
- evoscan update gone bad
- Please HELP! Need xml for Pajero/montero 3.8 mivec
- EvoScan 2.9 Error: errors were found in the original data.xml
- Intermittent P0170 - Fuel Trim progressively getting worse
- help with evoscan problems
- Speed density on AUDM evo 9
- Evo VII ECU Help
- MAF size for CP9A?
- Super Rich AFR on Full Boost
- EVO VIII SD Problem
- Way too much knock on car I just got here is the timing map
- Trouble editing my Inherit ID
- Need help with TephraMod-V7 rom please
- Lancer EX / GT 2.0 definition
- Who has Increased knock multiplier
- Idle surge on hot restart
- Evo8 ecu in a 323 GTX
- ISCV tables vs spool - relations
- RPM/SPEED ratio filter strength
- Always stalling post high revs
- How to disable P0622 CEL
- Electronic throttle maps in preEVOx ecu
- Problems dialing in FIC Blue Max 2150cc injectors
- ECUFLASH v1.44.4347 not working with TephraRom v5.10?
- How much dwell does the ECU add during cranking!!??
- AEM UEGO Logging issues wont work tried everything
- Ecuflash cant read ecu..Failure to transmit kernell
- Strange load/TPS reading above certain RPM
- FIC 1800 Low Z tuning.
- can anyone look at my map
- How can I log boost on a 7?
- Beginners tips!
- ecuflash upload problems
- how to change your rom or modify xml to show sas
- Editing the stepper at idle
- Load isnt logging whats my load factor or how do I add it rom 97250001
- Unable to connect to ABS/AYC ECUs using Evoscan
- Looking for the 9055 V7 SD ROM, whos got it?
- stock evo 8 high knocks
- Whats the best way to control a solenoid with the stock ECU
- mpg on 2.3 questions
- 9653 Wideband -> Front o2 patch
- need help getting ecu flash functions unlocked
- Need help!! So I can go to a show
- please help, 03 evo ecu possible brick
- Evoscan won't log past a certain load
- Can't run much high rpm timing
- Question about immobilizer disable and programming key fobs
- O2 Sensor Mystery
- Barely runs after cold starts, runs great once it warms up.
- need help opening ROM in ECUFlash
- How can I move the load to the left few cells
- Tactrix 2.0 south yorkshire
- Help with my Tune
- Need xml for 88590515
- Evoscan 2.9.0092 not logging
- Unstable idle - surprising cause
- FIC 750cc Injector Tuning (Either Too Rich or Too Lean)
- Can someone please make me a def for this ROM? locked by previous tuner
- (Logs) Knock at mid-high RPM
- Built 2.4L start up problems
- IX JDM RS Rom
- Oil Pressure Logging Stock ECU Pin 64 / MUT83
- Switching stock ECU maps with AEM failsafe gauge.
- evo 5 gsr with monster ecu need reflash?
- Speed Density startup help
- unknown IX 6spd rom
- Help with tune
- ROM image problem, help
- need help wih tuning evo8 ecu in 2g
- what cable works on both a 99my Impreza sti and a 2010 Impreza boxerdiesel
- Cold start
- Flex fuel sensor with stock ecu
- Sold my car, posting my own tune
- SD IPW jitter fix not working on 96531706
- Which load for boost tables?
- Can't get 94170715 Speed Density ROM to start.
- Thoughts on things to change in tune?
- I dont feel safe with my map please rate it looks boxy
- Help With ECU Flash think i need definitions
- How to add 2 step/ launch control
- New to the tuning game
- New Laptop/software transfer
- Viewing Data of Map
- Evo V Ceddymods; struggling hot start
- rich issue top end
- PTE 1200's E85 injector scalings
- 2d KPA->Load and RPMVE in Excel
- Need a good Rom for a 8 ecu
- XML help
- Can anyone send me a flash for my 9
- New to ECU flash need a little help
- evo 8 FLASH Port HELP!!!
- GM 3 Port/ Tephrav7 Help
- 8 ecu in evo 7 help
- Wrong ECU
- FIC 1450 issues
- 90556701 v7 sd 7 ecu
- is this working O2 sensor ? *log*
- Turn off P0121 with ecuflash?
- Evo8 converted ECU into a B4 VW Passat 16v Engine
- evo8mr jdm tephra mod problems
- ECU Flash changing my Tephra Roms? Please help!
- Injector flow rate linearization tables for FIC1100 and FIC1650
- Cant log afr via wideband
- 88590715 - Off throttle lean spike
- 56940013 xml
- Please take a look at my timing map for my E9
- Cant log from Lc-1- a little help needed
- knock control isn't working, Ceddy's
- ICV problems
- evo 7 fuel cut
- problems with evoscan
- Issue loading map to maptracer
- E85 96531706 - Car dies after startup
- strvdm
- What are my ECU Options?
- Fuel pressure spike, lean AFR's, miss/stutter
