PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. Ecuflash can't read my ECU
  2. Custom EvoScan Gauges
  3. Odd Injector Scaling
  4. Ecu Differences Lancer vs Evo?
  5. Tuning without wideband
  6. I need help
  7. WGDC table for 73HTA FP Green + 3 ports GM solenoid
  8. limp mode for blown off I/C pipe?
  9. Stock 1-BAR MDP Scaling?
  10. what does open loop and close loop due and mean?
  11. Race gas and methanol
  12. 96260009 throttle hang
  13. Torque Limiter
  14. how to tune a atmospheric bov?
  15. AEM 3.5 Bar MAP = Kavlico 3.5 bar MAP?
  16. About adding MUT Table to EcuFlash?
  17. 96532706 dma/live map questions
  18. what does the MUT table do?
  19. Danger associated with setting injector scaling too low?
  20. about wideband gauge
  21. Evoscan AFR formula without wideband?
  22. 03 JDM evo 8 boost control help
  23. scary evoscan log (2.7.0031)
  24. Thank you everyone!
  25. how to change air to fuel?
  26. Can someone send me a Map?
  27. help needed!
  28. High octane map/no low octane map
  29. about Ecu Flash and wb02
  30. TurboXS wideband hook up
  31. Non-working Evoscan AYC/ACD/ABS datalogging
  32. richer afr =more peak tq?
  33. Injector Hic cup
  34. LC-1 1.0 firmware
  35. about A/F
  36. Evo 8 Idle Issues
  37. Evo9 JDM won't read
  38. E85 Auto-Calibrate
  39. Weird problem with tactrix
  40. has anyone been using mac's for tuning
  41. Evoscan 2.4/2.5 problem.. **help please**
  42. ECUflash - turn off read/flash???
  43. ecu flash questions
  44. Help ASAP please read
  45. Evscan 2.5 Stops Logging Randomly
  46. Fuel trims dont change....
  47. RC1200CC Injector Warm Starts
  48. noob question
  49. Omni 7 BAR Scalings
  50. Any teach tuning on here
  51. SD 3750rpm leans out/stutters any ideas?
  52. Can I see some Fuel maps for...
  53. Help on how-to: Log AFR from the AEM UEGO w/o a serial cable
  54. fuel trims seemingly not moving in evoscan
  55. injector scaling question
  56. Low fuel trim adjusting
  57. Going to be tuning my Wagon
  58. Hey guys is my o2 going bad??
  59. Closed Loop Address Wanted
  60. Is there sombody ho speaks german / need a file for a evo 6rs
  61. Knock control tables not there?
  62. evoscan issue?
  63. FIC 1650, 1750, 1850 injectors on DD
  64. Help needed, tuner wont reply and my tune is all over the place.
  65. Tuning bc 280s
  66. Wierd knock issues, help wanted please
  67. 2 step stopped working
  68. Mad knock issues while on the 2-Step. Need some help
  69. Disabling Immobilizer
  70. US ACD bleeding with EVOScan
  71. Evo 8 ecu in 2G DSM... don't start :(
  72. Can't Read or Write ECU
  73. Vendor Tuned 88590013 ROM and switching to 88590015
  74. 94170715 V7 Idle....
  75. annoying knock
  76. Asynch Addresses needed
  77. Outlander Turbo evo 8 Ecu
  78. Dual map on stock ECU
  79. will an evo perform correctly with the front 02 sensor unplugged??
  80. Logging/Tuning Issues
  81. 2byte Load hitting 336?
  82. AEM 5-bar MAP sensor compatibility settings for USDM 8/9
  83. How to use v7 Boost Control with a 5 bar sensor
  84. Fault Code Help Needed
  85. What is this?
  86. is my load to high?
  87. Can A ROM Go Bad While In The Car?
  88. Need help tuning FIC Bluemax 1250!!
  89. Tuning after bigger cams
  90. Zeitronix 5bar MAP Sensor and Boost Control
  91. Can't Read/Write ECU
  92. Coil Charge Times
  93. Zeitronix and Evoscan Boost reading
  94. Fuel Trims
  95. Ticking noise with loss of power and phantom knock..
  96. FP 80mm intake Pipe Maf Scalings?
  97. P0443 problems?
  98. Finding Immobilizer Code with ECUflash
  99. GM 3bar map sensor
  100. Does anyone have scaling/latency for delphi 1200cc injectors?
  101. Evoscan log file?
  102. New Fuel Pump.. Rich
  103. Lean spool address needed
  104. Loging past 8k with evoscan?
  105. timing advances on its owne
  106. 1350cc Scaling help & Cyl 1 Misfire
  107. Disabling code for improved response?
  108. GM IAT (MAT) all over the place.. 200.. -8 F
  109. Ingersoll Rand 3-port wiring ?
  110. 2 byte load confusion.
  111. Having trouble with my PTE1200s
  112. Big thanks to all of the Stock ECU gurus from AWD Motorsports..
  113. Can not read DTC's
  114. Boost Limit Table?????
  115. Trouble with Evoscan logs.
  116. Timing sheet/pic that explains the areas of the timing map
  117. EcuFlash 1.42 not working, worked fine in Jan
  118. Fuel cut from a standing start.
  119. I need help please!
  120. Problems with V7
  121. aem widband and evoscan?
  122. Throttle stick
  123. Evoscan + Win7 = randomly disconnected
  124. help: can't log proper load???
  125. Latest EcuFlash beta, now EvoScan not working. Anyone else?
  126. Finished my first time tuning, I think
  127. Boost Cut not working
  128. cannot read rom info
  129. Injector faulty?
  130. Crazy Idle
  131. Need help with knock
  132. What does MAF Scaling/compensation really do?
  133. Differnece in ROMs
  134. Apexi map sensor to log boost JDM evo 8
  135. closed loop long term trim control xml definition
  136. First tune. Opinions for the advanced?
  137. EcuFlash reverting back xml that's not there..please help!!
  138. New Here
  139. Fic 2150 scaling helllllllllppppp!!!!
  140. fuel map european gas
  141. Weird Cutout WB readings.
  142. Tephra V7 map sensor upgrade ?'s
  143. Need help with HI OCTANE MAP V7 user
  144. 2001 Eclipse ECU Questions
  145. Can't flash or read the ROM from your ECU - Start Here!
  146. Fuel Trim Issue(s)
  147. Can't read ecu
  148. ZT2 Install help...
  149. Ecuflash connection problem
  150. V7 SD conversion- for good!! UndR hood pIcs!
  151. Battery offset tables for 1600cc?
  152. Cant connect to ecu
  153. P0125 -
  154. Stock Boost selenoid... Still ?
  155. 96260009 1 byte load
  156. UEGO, Netbook, EvoScan, not talking - need HELP!
  157. I think my ECU is toast...
  158. Evoscan/tephra v7...
  159. MAF Scaling - 55590006
  160. Evoscan problem with Win7
  161. gm 3 bar question
  162. Unknown rom image error???
  163. Engine break-up under moderate to high loads
  164. Afr = ?
  165. Blue screen of death while logging/flashing
  166. Does this look like normal O2 activity?
  167. Maf compensation help
  168. Live Maps TPS Alt Map Switching??
  169. Big issues..
  170. JDM Evo 8 FQ300 need advice on rom
  171. Merlins EcuFLASH Evo 7-8-9 Tuning Guide
  172. 30 counts Knock, no idea what the issue is
  173. SD V7 88590715 Help Please.
  174. New Excel File: Map tracer from CSV log
  175. knock knock
  176. Experienced with ECMLink.. help familiarizing with ecuflash?
  177. Open ECU cable?
  178. map needed for cammed evo
  179. MAP and MAT sensor all-in-one
  180. Tricks to running just a tad more timing up top
  181. Front O2 Sensor specs or universal ?
  182. wiring question for sd
  183. flood killed wbo2?
  184. Grimspeed BCS help!!!
  185. REQUEST: Ignition timing unit step in tenths of degrees (or at least .3 tenths)
  186. JDM Map sensor idle problem???
  187. 880cc Injector Cold Start Issue
  188. evo 9 ecu flash problems
  189. Evoscan & Data Log Lab Question
  190. Cannot view Ecuflash now
  191. Gm 3 bar scailing
  192. Where do my Injectors run out of Fuel?
  193. Is my O2 sensor dead?
  194. Tephra v7 and Load?
  195. FIC 1050cc Injector latency and scaling
  196. Ecuflash shuts down after read
  197. Starting problems after injector scaling
  198. Evo scan and Profec e-01?
  199. Changed injectors, now IDC won't log
  200. Evo5 starts, then dies after a few seconds... log inside
  201. Speed Density - Wideband o2 Necessary?
  202. Feedback
  203. 96532706 Problem
  204. Northeast tuners familiar with V7?
  205. My a/f gauge messed up.....
  206. Best MAP for EVO VII
  207. Is it safe to customize your ROM INFO in the xml..
  208. MBC with JDM map sensor???
  209. Problem switching 05 rom to 96530706 or 94170705
  210. First time tuning, need advice on my Fuel Map
  211. how to use evoscan and ecu flash on mac
  212. v7 for 94170008 doesn't work
  213. is something wrong?
  214. Dialing in injectors w/out rear o2?
  215. Can't read the EcuTek tune evo 8
  216. Best place to purchase new cable
  217. What are good settings for the launch maps
  218. Compressor surge, or BOV flutter? (my evo)
  219. Switched to SD and have the craziest code ever?
  220. How to access periphery tables
  221. locking ECU flashing with ECUflash EVO8
  222. can we disable knock sensing EVO8 94170008-0015?
  223. V7 big TIMING map converter?
  224. testing the new FIC 1100 cc/min saturated injectors
  225. Need Evo 4 injector scaling and latencies
  226. running rough - log
  227. car turned off at full boost
  228. What type of load should a nearly stock IX reach?
  229. SD Troubles....HELP!
  230. Figured it out: Low boost false knock (aka low boost flutter)
  231. evo speed meter
  232. Looking for stock EVO VIII data log
  233. tuning accel enrich
  234. Fuel maps don't line up?
  235. Yep- another Connection Error thread
  236. Is there a V7 88590715 DTC: P0037 fix?
  237. Fuel Cut or something bad..HELP!!!
  238. Evoscan Serial Retrieval Link
  239. 96531706 Tephra SD v2 - AEM 5 bar Map Sensor
  240. Are AFR's related to LOAD?
  241. USDM to JDM base map?
  242. stock evo 8 injector latency
  243. Need help with High AFRs
  244. Brake pedal revs engine ???
  245. Trying to scale my new injectors
  246. Mut request or variable to log 'selected LTFT'?
  247. Anyone in the Detroit Metro area that can help me flash ecu an ROM?
  248. Evo 8 MAP sensor in an evo 9
  249. MBT on E85 FP Red IX
  250. Connection Error
