PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. Evo ix Maf comp vs coolant temp?
  2. Pulled my first logs from my "Pro Tune" but looks Ef'd up?
  3. How to Find out an ECU's ROM ID
  4. speed density
  5. v5.10 to v7 conversion
  6. intrest in tephramods v7 for 96260009 aka JDM evo8mr
  7. Denso 3 bar map sensor scaling help
  8. why is my boost so high?
  9. Using Watertempsensor to log oiltemp?
  10. Anyone have scaling for denso 720s ?
  11. Initialization procedure after knock sensor?
  12. Mitsubishi Connectors - SJD Logo
  13. Fuel trims out of wack what is my ecu doing
  14. GT30R - question about boost control
  15. Boost builds, stays flat, then surges??
  16. ROM loading wrong deffinitions
  17. Innovate LC-1 to Evoscan
  18. LTFT Low not moving
  19. Need to flash my evo ix back to stock and cant read Rom
  20. need rom image 9417008
  21. 02 Feedback trim hitting +25???
  22. Does knock cause Backfire or the other way around?
  23. SD for 88840017
  24. AEM wideband not recognized in evoscan?
  25. Can knock Sum detection pull boost?
  26. How to setup my 2step/ launch control
  27. Problem during cruise after injector install. Car hesitates and AFR's swing bet 13-16
  28. Can someone help??
  29. Later spool after switching to Tephra V7
  30. Tephra V7 + ICS lamp on USDM
  31. evo running lean
  32. Purchasing older evoscan software possible?
  33. ECUFlash aggravates me
  34. Idle issue - very lean, weird STFT
  35. AFR question
  36. EvoScan Injector Actuators
  37. Zeitronix ZT2 Narrow Band Switching
  38. How should I smooth out my AFR map?
  39. Help, moved to 96260009 and problems
  40. Logging AEM wideband on Evoscan2.7
  41. OBD II Scantech
  42. What wire is the rear 02.
  43. problem with evoscan logged values in excel
  44. Primer Cranking Enrichment Table-Max Value-255?
  45. Logging while on track
  46. Speed Density for newbies like me
  47. Is this even possible?
  48. plx bosh afr eval equation (have all info)
  49. Can you Locate the table for Ignition Trim Vs Air Temp
  50. Stationary rev Limit not defined in my ROM
  51. Cruise AFR Question
  52. can't log wideband, tried just about everything
  53. check this crap out
  54. Which v5.10 for Jdm evo 8
  55. 96530706 tephra no fuel cut?
  56. Desired ISCV Not Working with Tephra 88590715
  57. Which netbook for ecuflash and evoscan?
  58. converted to tephra v7 and issues
  59. Help a noob out...02 issues
  60. Evoscan newbie questions
  61. evoscan 2.7final issue
  62. Is there a step-by-step for setting up speed density?
  63. Mfg Injector Latency vs What we use
  64. Looking for Bone Stock Map from an 05 RS
  65. connecting a wideband instead of rear o2
  66. question regarding power
  67. Car randomly running super lean and throwing CEL
  68. Injector Voltages, Why?
  69. Tactrix cable missing second connector
  70. car surging when coming to a stop
  71. Autometer Wideband 4378 Compatibility
  72. sd xml equation for greddy map sensor
  73. Need patch for v7 88580714 from P0125
  74. livemap does not work with Openport 2.0 cable
  75. Targeting different boost levels for different gears with v7
  76. Torque seems low and late
  77. Open loop settings for Economy cruise
  78. Help with scaling FIC Bluemax 1450 injectors
  79. Innovate LC-1 N EvoScan
  80. help! TephraMod saving wtf
  81. Questions with my log
  82. Need confirmation of Load Limit address
  83. Question about check engine light on knock
  84. Reflash Connector
  85. hey there
  86. LM1 readings in EVOScan v2.7 are off from Logworks
  87. Looking for defination file for Dataloglabs
  88. AEM wideband loggin with evoscan problems
  89. Looking for help initial setup / tuning help in central ohio
  90. Part throttle wierd load drop?
  91. PLX and evoscan
  92. how to keep injectors slightly open on decel
  93. Fuel trims not budging after inj rescale
  94. help pc crashed got a mac.. need evoscan serial
  95. Common: No response to any known code
  96. Evo Scan Maptracer not loading 96531706-v7
  97. Need Help Installing Tephra V7
  98. knock sum and knock voltage
  99. Dyno Vision Software v1.0.0
  100. I need rom for EVO7
  101. 3-port solenoid overboosts when cold
  102. Setting up a new tune - huge backfire on WOT
  103. Extremely low load when hitting boost
  104. stock tune afrs okay with 3 port boost solenoid?
  105. MUT Standardization for logging purposes
  106. IDA Pro Code Change Help?
  107. How do I activate "No lift to shift" NLTS on a stock ecu - evo 9 ?
  108. who does the best email tunes?
  109. trying to order cable from evoscan site and an error occurs?
  110. Ecu unlocker.
  111. Limitless 1.3u Connection Issues...
  112. How to lean evo ix on startup with ecuflash?
  113. Tired of looking for the right answer.. IX rpms hang up when shifting
  114. Help! New Evo owner with a couple questions
  115. Scaling Omni 4bar MAP for JDM E7.
  116. 96531706 speed density questions
  117. Autometer map sensor for loging boost?
  118. EvoScan AFRMAP not mattching "High Octane Fuel Map" in V7 Rom
  119. Controlling 3 Port Boost Controller with Tephra v5.10
  120. need help here..
  121. working towards timing tables with 1/3 degree increments
  122. Eculink Or Evo 8 Conversion
  123. Is this much knock something to worry about?
  124. MAT scale ?
  125. cold startup idle
  126. help with ceddymods! please...
  127. Could this be possible w/ ICS spray on knock mod
  128. Quick timing map question
  129. 2.4l fueling????
  130. sd injector dropout problem
  131. ID2000s/FIC 2150s on MAF? Anyone doing this?
  132. New Stumpers ? ? ?
  133. Help ID ECU Hex file + definition to use
  134. Wont read my ecu
  135. connected limitless cable then all hell broke loose
  136. evoscan freezing gaming laptop..
  137. Quick evoscan questions(hopefully)
  138. Complete Newbie wants Tephra
  139. Reason not to use RAW ADC locations? (Dev)
  140. Evo IX 88590013 getting P0443 code
  141. PTE Injector Scaling Opinions
  142. ECU flashed,,, check engine went on
  143. Alternate download location for MitsuLogger?
  144. Minimum IPW
  145. noob here
  146. new o2 sensors, check engine light wont go :(
  147. simple question
  148. Mapping Evo 7 GT-A
  149. Check engine light after tial q install??
  150. Mode23 logging with Evoscan 2.7 and EVOX MR SST AUTO
  151. Turn signals and rear wiper staying on after ECU read
  152. Stock Evo IX MR ROM
  153. Help: Car Nearly Stalls After Fujita F5 Intake and UICP Install
  154. Unknown rom id..some help
  155. EcuFlash 1.42 Problems
  156. installed o2 housing, now lean idle.
  157. stalling issues
  158. Logging AutoMeter Wideband O2 with EvoScan 2.6
  159. Car wrecked, wires crunched, car won't start
  160. Partial Throttle Knock - Tuners PLEASE HELP!
  161. air temp vs timing
  162. Help with reflash connector slot/repairing wire
  163. Adjustments to your tune after installing cams
  164. Added ebay filter, increases load by 40 under boost.
  165. knock cell on time
  166. Evoscan actuating the ABS
  167. Serial number for Evoscan not working.
  168. ISCV tables empty 88590715 and decel questions
  169. Timing map w/logs. What am I doing wrong?
  170. How do I adjust tps values in the computer
  171. New turbo big knock
  172. Dumb question, needing help.
  173. ID2000's & EcuFlash on an E85 03 Evo 8
  174. Can not get Evoscan Maptracer feature to work with V7
  175. 96260009 IAT comp tables needed
  176. another quick qustion
  177. Problems with EvoScan 2.6
  178. can somebody please send me a stock IX and VIII base map
  179. Tephra Modded ECU's for IX
  180. Help request - Multiple Codes (GVR4 w/Evo ECU)
  181. how does one find where things are in mut?
  182. evo vii JDM basemap?
  183. ECU XML needed
  184. Large picture of EVO ECU?
  185. Android/Bluetooth logger?
  186. Rich all of the sudden
  187. ill pay someone to fix my idle.
  188. Interesting remap in JDM car
  189. cant log 2 byte load using 4013
  190. P0462 code - can't clear :/
  191. cant log 2 byte load?
  192. Anyone ever notice ? ? ?
  193. Actual DynoJet vs VDR Comparo...
  194. my first crack at this tuning thing check it out.
  195. how do you post your maps here?
  196. Hot Start Issues
  197. about timing with fp black
  198. Datalogging Camshaft Position/Timing on IX?
  199. Tephra v7 issue
  200. Review my tune w/ logs
  201. Need someone to look at this FP green tune
  202. Have a quick question about ECU Flash & launch control!
  203. wifi OBDII keys work with MUTIII
  204. A few questions...
  205. OpenPort 2.0 Not Responding
  206. Reflashing tuned Evo9 --> stock map (smog purposes)
  207. Having trouble with my Evoscan log folder...
  208. Need manifold air temperature logging Patch
  209. Partial Throttle AFRs and Timing. What to shoot for?
  210. If you log EGTs, what readings are you seeing?
  211. HKS 264/264 Fuel/Timing Tune
  212. Help needed to scale Apexi map sensor
  213. Load Values During Logging
  214. Start IPW latency mcsec
  215. Evo 8 Load Logging
  216. v7 - WGDC question - 96530706 rom
  217. Using EvoScan to log crank angle sensor output at startup?
  218. Las vegas Ecuflash tuners??
  219. AEM to Stock ECU SD conversion?
  220. zt2 not matching up with evoscan
  221. car running lean but out of my control?!
  222. anyone have a fp red or black timing n fuel map?
  223. Stock ECU boost control vs MBC - an intelligent and friendly debate
  224. No isc/bbk throttle body
  225. Tephra v7 tps map switching
  226. how do i use a greddy 3 port solenoid?
  227. Anyone willing to share their v7 Map for an fp black?
  228. need help with scaling
  229. Rich Idle and no Fuel trims
  230. Logworks and LC-1 via rear 02 logging
  231. Min coolant temp for closed loop table - 96532706
  232. Plx wideband ?
  233. JDM E7 99860002 to 90550001 v5.10
  234. Clarification on which loads are used for fuel/timing look up based on ROM
  235. Evoscan and afr logging
  236. Help: Haltech 3 bar map sensor formula
  237. EvoScan won't log but will read ECU...
  238. Idle Control Problems
  239. AFR Map values not coinciding with logs...
  240. Ajustments after cam install?
  241. Tuning my FP Black setup on E85
  242. About timing?
  243. Tactrix cable problem
  244. Apple with ecuflash
  245. fuel trims in logs mislabelled?
  246. Logging / Tuning Q.
  247. EcuFlash 1.29="no response to any known code" 1.42="unable to connect vehicle int.."
  248. Few DTC's clear question
  249. Quick V7 Q
  250. P0125 - Yes another thread ...
