PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. logging works, but can't read/write...
  2. Strange fueling issue while coasting
  3. Stock XML def. needed
  4. How do i convert to SD and EDM Evo 9?
  5. uninstalled ecuflash, and installing same version...WTF?
  6. How To: Speed Density on the evo8 using tephra v7/Phenem pre-patched roms
  7. Found another odd v7 table discreptency
  8. does the Evo 1-9 adjust timing to fractions of a degree?
  9. GM BCS equivalent???
  10. How to switch your stock rom to another
  11. Close Loop-LT Trim Control Findings
  12. ECU Flash and Scan Tools
  13. Speed Density Round 1 = fail
  14. current 1000cc injector of choice???
  15. EvoScan won't log injector duty %
  16. How to determine immobilizer hex?
  17. PO1400 Manifold differential pressure circuit malfunction
  18. Knock Sum Decay Timer 88590015
  19. Palmer Performance Engineering
  20. 9653xxxx cold start ignition maps: need clarification
  21. WGDC Log vs. Actual BCS Settings = Something Weird
  22. Logging Issues:
  23. Questions for the v7 Gurus about psi based ECU boost control
  24. looking at ignition retard limit control, need some logging assistance
  25. Cannot connect to ECU.
  26. Out of injector?
  27. P0069
  28. what happened to the post your timing maps thread
  29. Tuning out throttle hang and bov flutter with SD
  30. Need an evo 8 owner to check something for me
  31. orig: "88580014" and flashed into "88580015" then car wont idle
  32. changing cluster - require flash/dealer?
  33. smoothing vrs afr?
  34. Fuel trims tutorial?
  35. How do i Switch Roms?
  36. Tephra V7 & OMNI 4 bar
  37. seeing that one asked "definitions" where are they?
  38. help po300
  39. Something very very unusual with my Evoscan..
  40. Tephrya V7 Maps with all features for Evo 7 JDM ?
  41. few quick tuning quesions
  42. 94170015 V5.10 SD to 96531706 and Logging air temps 100*s higher then before.
  43. TephraV7 Load Based Boost
  44. 300M Coils
  45. FIC 2150cc notes
  46. Turning off the knock sensor
  47. evo 9 base XML
  48. adjusting knock settings for a 4g93t
  49. 8859XX15 patch to log IPW contributions
  50. Injector scaling/latency for RC 750
  51. AVCR boost solenoid
  52. help me with my evoscan error
  53. Evoscan problem
  54. ECU Load Based Boost Control Question
  55. some major idle issues on SD-0015 map
  56. Tune critiqe Please AMS 30r kit
  57. Need expert opinion on boost curve
  58. AFR goes rich on light (very light) acceleration
  59. HOW-To 96260009 JDM8MR to 96530706
  60. BOV flutter/stutter under acceleration
  61. ECUflash DIY cable
  62. Boost Control Theory
  63. which reflash+tune?
  64. Why cant read the ECU?
  65. Converted from 96260009 to 96530706 - running lean
  66. Can't save 3D mut table
  67. Speed Density IPW Drop Out on 96530006 Patch
  68. Launch Maps
  69. Maps for Rally Evo IX with turbo restrictor???
  70. Omni 3Bar MapSensor help
  71. Can't view any TPS related parameters in Ecuflash
  72. 600whp capable on stock ecu?
  73. 96420007 to 96420008 was a no go.
  74. C# Program : EVO Auto Tune
  75. Need a definition for 96530006
  76. fat chick problem/ECU flash
  77. how to download current map?
  78. tephra mod rom issue
  79. Idle timing and S2's
  80. Anyway to get more boost off the launch?
  81. Question - Alt Map Switching and Injector Latencies
  82. Stock Inj duty cycle
  83. Evoscan injector scaling settings?
  84. P n P connectors for the GM 3 port
  85. Mapping with new cams??
  86. Help-keep getting error message intermittently when trying to connect Ecuflash to ecu
  87. Mitsulogger for iPhone??
  88. Service Engine Soon Light - No Code ??
  89. Anyone logging boost with JDM MAP on Tephra V7
  90. jdm evo 8 stalling
  91. need some help with 80700010
  92. egr solenoid "boost control" with external WG?
  93. Tactrix Cable Issue
  94. 36 psi boost on Pump Fuel
  95. idle ?'s
  96. How can i get a hold of Scott Gray
  97. pro tune w/ your own switch
  98. Rear O2 and fuel triims
  99. NY:need help with ecu !!!
  100. Maf and Injector scaling at the same time
  101. 96530006 Full Rear O2 Deletion (now including heater circuit)
  102. need ecuflash 1.29
  103. why should i get a evoscan?
  104. evoscan 2.7 beta map tracer not working
  105. EvoScan Scaling Factor?
  106. Increase Fuel pressure & Latencies
  107. open port cable using bluetooth instead using usb cable
  108. scaling and latency for Bosch 1600cc on pump gas?
  109. FIC 1450 BlueMax Flow Matching Data Sheet - how to use data to setup injector latency
  110. Can we get an ECU How to sub-forum?
  111. P0603 obd2 code after disabling immobilizer
  112. Kernel in .RPG files
  113. **Need Help setting up V7???** Here is your answer
  114. Official / Injector Scaling and Latency Forum
  115. Wideband not working in evoscan 2.6
  116. Problems connecting to Evoscan
  117. PATCH: Clutchless starting without disconnecting the clutch position switch?
  118. Speed Density MAT
  119. Before & After evo 8 to evo 9 turbo
  120. Two versions of ECUFlash on the same PC?
  121. Problem saving xml def to rom ID
  122. Evo 8/9 ECU pins, pin removal & installation, and map switching harness how-to's
  123. AT/SST/CVT MUT communication
  124. modifying tehra patch
  125. rc 550 votaje latency compensation ecuflash
  126. live map apps
  127. Fuel trims
  128. '03 Evo Starting Tuning
  129. Mut Sniffer
  130. Anyone have evoscan v2.7b1-4?
  131. Is this just a dream of mine or can i get this in my car
  132. ecu flash and gm maft how would you tune?
  133. ECU Flash Problem
  134. Low Load/Cruise Timing?
  135. Universal USDM rom
  136. ecu periphery2 6FDF
  137. JOT Virtual Dyno Room max rpm Question
  138. Urgent! need help!!
  139. Quick Periphery Bits/lean spool question
  140. wastegate duty deactivation RPM doesn't work?
  141. leanspool tables
  142. who has evo8 ECU pins??
  143. g/rev Scaling
  144. JDM 8 MR read template
  145. Serial port with Evoscan...
  146. lean spool or not to lean spool
  147. Boost problems
  148. Dual ECU
  149. AEM 30-5130 gauge serial hookup...
  150. AEM wideband and EvoScan issues
  151. Going Lean ???
  152. #65 pill and 44mm WG
  153. New thread for Speed Density tuning?...
  154. How do you learn to be a developer?
  155. Maf temp adjustment table
  156. DataLogging with Custom Gauges
  157. phantom knock on shifts how to fix
  158. turn off oil pressure light
  159. Ecuflash for 09'+gtr?
  160. Help: Evo IX running lean, stock MAF/Injectors
  161. Differences in Peripherys v7
  162. logging boost with aem tru boost
  163. Knock is back...WTF?
  164. TephraMod Knock CEL Flash discussion
  165. Upgrading Rom
  166. effect of degrading CAS on data logs?
  167. Auto Tune Program [Dev]
  168. logging boost with jdm evo 7
  169. 2byte load logging issue..help
  170. Getting desperate here....
  171. Ralliart Thermostat = change temp scale?
  172. MAF scaling or injector scaling/latency
  173. question.. lookin for some opinions
  174. timing recomendations log attached
  175. [Disassembly] Periphery Deciphering
  176. Idle Stability Control Table Q's
  177. rpm and load values are random please help here is the rom a xml if anyone can fix it
  178. HELP ! ! ! - EVO 7 - RICH .... :( other problems
  179. Boost Tuning Help
  180. Map interpolation using a flex fuel composition sensor?
  181. What reflash cable do you guys use?
  182. v7 + closed loop wideband or something else incompatible?
  183. anyone care to help me out?
  184. EvoScan: 0% throttle = 13.73???
  185. is 62500 baud a must for 2 byte load
  186. jdm injector scaling and latency
  187. xml needed for JDM Evo 7 RS
  188. help plz
  189. anyone with 90550001 2 byte table
  190. new live map app
  191. CEL( 3 Codes)
  192. SVN repository online! All XML, ROMs, tools, spreadsheets go here!
  193. Ecuflash Expert, please help and guide me. Thanks
  194. Having trouble reading ECU with Ecuflash
  195. Need v1.3 of Ecuflash
  196. Advanced fuel control options
  197. Updated From ECUFlash 1.29 to 1.42, Can't Connect
  198. Speed Density airflow difference
  199. flashing 09 lancer de?
  200. please help!!!
  201. confused with load and RPM scales
  202. 2010 Ralliart ROM help with logging in EVOscan?
  203. turn off knock sensor
  204. PWM routine: what is it all?
  205. Need Help, got error message while reading EVO 6 JDM ECU
  206. Rich Idle questions.
  207. Idle Issues
  208. Intellectual Property
  209. need help guys!!
  210. Can anyone transfer my tuned rom to tephras v7?
  211. throttle hang and enrichment
  212. What can I, David Buschur, do to help?
  213. stock ecu speed density from a vendor
  214. I need definitions for this rom 90160003 please!
  215. Symptoms of bad/faulty knock sensor
  216. Defogger / defroster to start/stop logging.
  217. What could be the problem??
  218. V7, Twin Solenoids and Altmaps (88570008, 96260009, etc)
  219. 88590015 fuel maps
  220. Warm start Idle issue...?
  221. Help with idle and CEL issue
  222. Front o2 sensor probems
  223. EVOscan.... other loggers work better?
  224. [Dev] SH2 disassembler
  225. Evo 5...where do I plug the tactrix cable??
  226. PSI Based Boost issue...
  227. n00b Here: 96940011 Serious RPM Hang
  228. Is my Tactrix Cable busted?
  229. FIC Easytune
  230. Need 2004 stock rom
  231. When cold it sounds like it has an exhaust leak.....
  232. Speed Density tuning an EVO8 w/dyno sheets
  233. 94170015 and 96530006 xml files
  234. Need tactrix cable
  235. launch maps
  236. Injector latency base?
  237. Please Help, Bricked Evo X ECU via EcuFlash
  238. ECU Flash on 2010 Ralliart Sportback.
  239. EVOscan problems
  240. 2step not working,, 2003 evo..
  241. Coil Dwell on stock ECU...again
  242. new EvoScan to Logworks file converter
  243. TephraMod V7
  244. Not scaling injectors..and fail emissions
  245. Rom 94170015 questions
  246. Fixed boost leaks -> Now Very Rich
  247. Poor Cold Idle (Yes I searched)
  248. Hard to shift at 8k rpm for my JDM Evo 9
  249. 90550001 xml
  250. Are my logs and power OK for my mods?
