Log In
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40
  1. Question about boost level and knock with a flash
  2. What's the best formula for figuring out LOAD?
  3. Anyone with JUN 272s with ecuflash......
  4. Change MIVEC to JDM after tune?
  5. need help!!!
  6. 2005 ecu in 2003 Evo?
  7. First log attatched
  8. MUT at high baudrates WORKS! 62500 tested.
  9. Load Analyzer Question
  10. High/Low maps the same
  11. Funny Numbers in the X and Y axis
  12. Custom street tune?
  13. How does "Fuel Trim" work in the ECU?
  14. A few questions
  15. 2 quick questions.
  16. dyno and tune the Car tell me what you think
  17. tools for disassembly of a ROM?
  18. 2nd o2 Sensor?
  19. Quick way to calculate actual AFR
  20. AMS 2.3 + RnR GT30R results w/ dyno
  21. SmoggyLog: 91 octane, 95 degrees out, 21.3psi boost
  22. Logging AFR with evoscan?
  23. Logging Load
  24. I want more PSI??
  25. ECUEdit Now Supports EVO Logging!!!!
  26. Strange Fuel Problem
  27. Please Help!
  28. Car dying in neutral - Fuel trims way off - HELP!
  29. is this timming ok??
  30. Datalog Lab Dyno
  31. Lean at idle...getting very frustrated!
  32. ECuFlash wont work on my car after Mitsu gives me new immobilizer...
  33. What Wideband lamda for Evoscan and future logging programs?
  34. Unexplained Knock
  35. Evo 9 hex on Evo 8?
  36. eflash question?
  37. stock ix hex
  38. EvoScan Charts - Opinions Please
  39. Stable Boost is Very Important!
  40. How to ECUFLASH Questionsl.
  41. No direct reading of load from ECU?
  42. creative way to keep a lap top in the car.
  43. 04 & 05 ROM differences
  44. Stroker Timing
  45. sending rom
  46. libmut
  47. Need help analyzing EvoScan logs
  48. Cable for sale
  49. coolant and air temp revisited
  50. Locked out of my ECU
  51. ECU Hi/Lo Octane maps selection
  52. Changing mivec map...few Qs?
  53. how to make more rich or more lean
  54. 18:1 AFR at Idle!?
  55. Looking for advice/comments on my log
  56. tratrix cable and other stuff i have no idea of
  57. EvoScan w/LC-1 Problems/Warning!
  58. best AFR safety/performance,
  59. evo scan question.
  60. Mitsubishi Logger proof of concept code WORKS!
  61. Take a look at my logs :) please
  62. How much boost with 100 octane
  63. 2 Step and knock sum??
  64. what should i set my ecu to
  65. Heading back to the Dyno
  66. O2 Sensor tests
  67. Newbie Wideband Questions
  68. Suddenly ignition cut, Log inside
  69. Decipher my datalog (Evoscan)
  70. Bad o2 sensor?
  71. 93%-98% duty cycle on Evo IX with just a mail-in flash?
  72. Internal ID: undefined
  73. Anyone having this problem with v0.9?
  74. Evoscan 0.9 airflow volume reading
  75. Confirmed: AEM UEGO logs in evoscan 0.90 just fine.
  76. New to ECUFlash - logs inside
  77. Injector pulse width
  78. Evoscan 0.90 problem
  79. Evoscan 0.9 map reading
  80. ECU Scan and Zeitronix
  81. OpenSource Flashing
  82. Stock Boost Control solenoid question.
  83. Unsafe timing map?
  84. 8MR JDM ROM and xmls link
  85. EvoScan V.90 Is Ready
  86. OBD Scan/Reset software for OpenPort cable?
  87. BCS operation?
  88. Looking for Base VIII/IX Flash's
  89. question.....
  90. Australian Delivered Evo IX Map - 88580013
  91. Calculating Load
  92. Problem flashing 06 IX RS. Error CRC
  93. ECU Can handle at least 3000hz
  94. Evo IX GSR serial routines 1 to 14 disassembly
  95. Knock sum=36, octane number=0, forged pistons, false knock story
  96. Ecuflash updates?
  97. having trouble with ecuflash please advise
  98. Full working EDM 9 Definition file?
  99. questions on fuel trims
  100. problems everywhere lol
  101. evoscan features
  102. For those who can get a decent load calculation
  103. Direction for stock map.
  104. modifying a locked ROM?
  105. I am new to ECU flash
  106. Stock 04 rom w/ P0300 fix
  107. TPS values
  108. a few updated EvoScan definitions
  109. Why cant I see Immobilizer under MISC.
  110. Evoscan 8000 RPM Logging limit?
  111. rev limit and off throttle knock
  112. Tractrix Cable for EcuFlash?
  113. EvoScan Accel Enrichment?
  114. big turbo ecu flash help
  115. Custom 2 map tuning? for evo 9!
  116. Evoscan Log Analyzer 2.0 with Load!
  117. ECU flash
  118. SuperH emulator
  119. I need some help pls
  120. rescale flash
  121. Map request basic bolt ons
  122. 7000 RPM IPW step on US Evo IX
  123. 20G maps
  124. ECU Flash users?
  125. AFR & intake questions
  126. pulls timing with no knock at all
  127. Octane number update information - 1-3=increment/4-5=no change/6=decrement
  128. new to ecu flash
  129. Evo IX ROM available?
  130. having idle & cold start problems
  131. how much knock is ok?
  132. 35r and EvoFlash. Lets see what happens...
  133. Determing Evo IX ECU Ign. DTC mode
  134. what is this?
  135. Boost Control using Max Wastegate Duty #
  136. All available Eflash vendors & info
  137. Vehicle Speed (kph) Confirmed on US EVO8
  138. Which log is the "right" log?
  139. Who should I get an Email Tune for my IX
  140. EvoScan? How Long???
  141. Dynoed My 05 Evo 8
  142. data logging
  143. ROM year info
  144. When will the ECU *REALLY* pull timing?
  145. EvoScan help! Timing + Knock count
  146. EcuFlash Trace?
  147. MIVEC voltage?
  148. Long term fuel trims not changing
  149. New injectors
  150. ECUFlash with Apple MacBook
  151. evoscan .net framework??
  152. Question, ECU load determining accuracy
  153. idle ac solution?
  154. Does reflash clear ecu memory?
  155. Logging boost with EvoScan
  156. Low Boost Question
  157. 16g/20g Alky users post your timing!
  158. Any tips on tuning Mivec?
  159. how are you guys logging A/F?
  160. Help with starting EcuFlash software!
  161. This is why TurboTrix is the best =)
  162. Bad ECU reflash?
  163. Noticed This With Evoscan
  164. FS: Tactrix Cable
  165. Need help with Evoscan
  166. instead of standalone
  167. 2004 ECU Rom question?
  168. timing first? or AFR's? pointers for Alky?
  169. Morality of sharing tunes
  170. Wideband tuning question
  171. Should you mess with the low-octane timing maps?
  172. MBC Or Not to MBC
  173. Any base flash suggestions?
  174. Target AFR log graph
  175. load flopping.... need some input
  176. Locked ECU Unlocker tool..
  177. EVO 9 maps 13,14, and 15
  178. Fast shifting knock is something to consider.
  179. problem
  180. 680cc injectors
  181. A great tune with EcuFlash (by EIP Racing)
  182. JDM ECU and EcuFlash
  183. Help with injector scaling
  184. Help reading map
  185. Random knocks with stock tune
  186. ecuflash PROBLEM!!
  187. A systematic way to lean out the fuel table
  188. First Reaction to a datalog
  189. definition for MN132750
  190. Ecutek and EcuFlash
  191. EcuFlash Knowledge Base
  192. Perrin EBCS anyone?
  193. reading/clearing CEL codes with ECUflash cable?
  194. Car stumbling, Logs/Maps inside..
  195. evo 9 boost control orific removed
  196. Quick Question.....
  197. flash for 10.5 housing on a evo with an 9.8?
  198. Inmobilezer code problem
  199. Need Some help!!
  200. how does this log look?
  201. TPS to openloop
  202. Evoscan website haxored!!
  203. Having trouble reflashing Dynoflash map
  204. Topic of the week?
  205. Mivec Tuning?
  206. tuning idle for large cams
  207. Just received cable, High knock and timing pull on stock map?
  208. ecuflash in texas??
  209. 03-04 rom read?
  210. Connection help
  211. Logged the 2 step today
  212. Posting Maps
  213. A weather related tuning question
  214. Boost Control
  215. Who's using Greddy/Denso 720's?
  216. displaying dual map question
  217. How to detect pulling of timing?
  218. I did some logging......inputs?
  219. ecu flash dyno tune results
  220. Stock 04 Map
  221. Rescaling Axis
  222. Cables in stock?
  223. Ecuflash tuning basics......
  224. engine immobilizer quick question?
  225. Is there no way i can use ECU Flash
  226. New information Load and throttle tables
  227. EGR temps
  228. ecu flash + bov now car flutters?
  229. ELM OBD2 and ECUFlash
  230. Correlating Evoscan Fuel Trim to OBD-II LTFT
  231. Remove WGA sol without fault?
  232. Knock, pulled timing and the low octane maps
  233. PRESENTING evoscan
  234. What happened to the Locked ECU?
  235. Coolant Temp and EvoScan
  236. Vehicle speed at &H2F confirmed
  237. Chaning the ROMS
  238. Evoscan with Innovate
  239. open ecu ?
  240. Safer tune produces more power.
  241. MAF readings at different RPM's
  242. Data Log Lab
  243. Help Viewing EVOScan logs in Excel
  244. e-flash questions
  245. Launch control help!!!!!!!!!!!1
  246. Evoscan ?
  247. Evoscan question?
  248. Question?
  249. Load found on Evo
  250. Where do I buy EcuFlash?
