PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40
  1. MAF Scaling Document Inside
  2. need program for tactics cable
  3. Cant get any more timing??? Logs & Pics
  4. Fuel Trims are NOT Changing...Help
  5. Help scaling MAF
  6. how much do you set the Low Fuel Maps from the High Fuel Map?
  7. Map changes during a tune
  8. Mitsulogger help
  9. Evoscan Issue (Ecuflash works)
  10. Limp mode
  11. Evoscan Log Order
  12. ROM read & write error.
  13. calculating MPG and AFR
  14. Patch Idea-gear dependent boost
  15. E7 ECU in E4,E5 & E6 Stat limit probs 90550001
  16. Idle troubles
  17. evoscan question
  18. FIC 1050s installed today - observations and a question
  19. Mut Table question.
  20. E-85 Questions
  21. fuel and ingnition map
  22. Stock Evo 9 rom
  23. Can I open a map without hooking into car?
  24. Suggestions to improve efficiency to minimize knock and maximize timing
  25. Injector Duty Cycle
  26. Evo 10 - Ecuflash - 3 tables
  27. Ok thinking of ECU controlled boost
  28. ???Is an EMS neccasary for this?
  29. EVO VIII mapping questions
  30. max hp with stock ecu
  31. Magnus or any other SMIM with OEM ECU
  32. Data logging
  33. EcuFlash v1.35 no read defintions???Help...
  34. new mod idea - need technical assesment
  35. Flash Counter
  36. quick help with TephraMod V5
  37. Hks Eids
  38. norcal evo ix swap project help...
  39. Help with evoscan and LC-1
  40. What do we know about knock control?
  41. Patch request discussion: rev-down maf clamp (stalling issue)
  42. TephraMOD V5.8 - testing help required
  43. Let's see your lean spool disable Fuel Maps
  44. innovate, MACs and tuning! Is there a way?
  45. Evo 9 still knocks on racefuel??
  46. How accurate are the whp/tq/lbmin/airflow readings in evoscan
  47. Do “reputable” tuners use lean spool disable
  48. Phantom Knock on my IX...
  49. updated xml for 99860002
  50. Doubt about ignition advance in a tune
  51. Cel Light Removal
  52. 96420008 rom
  53. Buschur intake pipe
  54. some general noob question on EcuFlash
  55. evoscan 2.3
  56. Openport 2.0 - June 15th
  57. Project87
  58. Tuning for improved highway mileage
  59. I need ECU help guys
  60. EvoScan and ecuflash on linux
  61. Limits/Stationary Rev Limit/
  62. ECUFlash+Evoscan+Cable+WhichO2???
  63. Tune AFR to 12.5
  64. I need a working copy of Ecuflash v1.35
  65. Review/Advice Before Tuning (log attached)
  66. Weird injector noise when I flash my car
  67. How-To: Rescale your MAF (without pics)
  68. Higher than 319 boost limit
  69. going crazy.....
  70. EVO 8 stalling and idle issues
  71. ECUFlash XML's
  72. Load = performance???
  73. Installed 880's and now my FuelTrim_High is off.
  74. Air Fuel Calculator
  75. Data Log Lab
  76. Open port 2
  77. max boost on stock internals
  78. cold start enrichment table
  79. Mitsulogger question.
  80. Evo Scan V2.2 Help Plz!
  81. 2byte to 1byte load mod
  82. ecuflash v1.34 help
  83. rom help
  84. Why are there multiple desired idle tables
  85. lean afr ....effects?
  86. my car got slower
  87. very confused about email tune?
  88. Low load numbers
  89. Inconsistent pulls
  90. About to File for Divorce from the Factory ECU . . .
  91. Cant Read Rom???
  92. Boosting problems
  93. plugs for e85
  94. need everyones help..
  95. evoscan 2.1 wdb not on list
  96. Low RPM Studder (Injector Latency Help needed)
  97. Geek Squad needed!!
  98. Answer please: 2-step w/o being in gear
  99. Evoscan 0.99 Random "USB device not responding"
  100. JDM Map Sensor and Gauge
  101. Thottle hang issues . . .
  102. 96940011 & Evo7base xml
  103. Direct PSI based boost control on ROM ID 96420008
  104. Emissions Help
  105. Using Boost Control patches with V5 Patch
  106. If "Accel Enrichment" isnt accel enrichment, how do you fix this?
  107. afr dump
  108. V5, NLTS and the load threshold bug
  109. ecuflash guru'sand anyone else (fuel trims)
  110. software fix for the Rear O2 CEL for the Evo IX 88590015 ROM with v5 tephra rom?
  111. need a solution
  112. Two unique problems with Evoscan
  113. Tuned 2 Evos today
  114. EcuFlash and Vista
  115. Newbie immobiliser help required
  116. Looking for more maps, 80700010 Def
  117. PID boost control code
  118. Is there a baud rate mod for IX?
  119. MAP averaging
  120. Adjusting the MIVEC Min/Max
  121. FIC1050's
  122. 27.5 psi on 91 octane maps
  123. LC-1 vs. Stock O2 readings..
  124. logged some data, need some input
  125. ECUFlash Min Temp for Full Boost Control Setup
  126. evoscan aem uego
  127. 88580014 anyone? Tephra?
  128. evoscan serial #
  129. Rom ID
  130. External Wastegate - Stock BCS setup
  131. Narrowband Output Graph
  132. 2byte airflow
  133. Can I use multiple patches ?
  134. Evoscan Help
  135. Evoscan reprogramming LC1
  136. New Tactrix Openport 2.0
  137. Map Tracing spreadsheet - looking for feedback
  138. my tune gone bad
  139. Reading CEL's with Tactrix
  140. 2byte load log issue
  141. Evoscan and UEGO problem
  142. Running LC-1 WB power?
  143. Logging Boost
  144. Please review my log
  145. ECU Flash Tuners
  146. Idling AFR's 10.0-.8; No Boost Leaks
  147. Issue logging AFRs with ZT2 and Evoscan
  148. Measuring injector latency...
  149. exhaust leak cause artifical AFR's?
  150. Does Sean Ivey use ECUflash?
  151. 2-step help!
  152. ecuflash gurus needed
  153. DLL power graph showing up blank?
  154. My load is too hi !!
  155. Smoothing out boost?
  156. Help to JORO-FOTO: Need us back! (crashed laptop)
  157. MAF Translator with Ecuflash
  158. Crazy AFR and no knock
  159. ECU Flash
  160. Flashing to 15 ROM
  161. 255 counts of knock.
  162. no breather?
  163. Different idling issues. Any Suggestions?
  164. Logging other Mitsus
  165. Adding resolution?
  166. ECUFlash timing/knock
  167. Moved/drove accross the country (observations, issues, looking for suggestions)
  168. Front 02 sensor dead, i think
  169. Detailed mapping of Periphery bits underway
  170. Immobilizer code
  171. Known Causes of Phantom Knock?
  172. New tune, now it bogs bad off the 2 step?
  173. EvoScan Issues
  174. Timing Map Help:
  175. ECUFlash Write Failed on Evo IX
  176. Burping at 5 grand
  177. There is one more Periphery!
  178. Evoscan 2.1 and zeitronix WB
  179. Deatschwerks Injectors?
  180. FIC 950's - any issues/praises?
  181. Evoscan Log Results
  182. A Great Tuner with Great prices
  183. EvoScan 2.2 and weird logging numbers
  184. Help Needed: 2byte setup for Evo 7
  185. Has anyone used the new Zeitronix-DashDAQ?
  186. How to get rid of GM 3 Port mid throttle overboost?
  187. BOV flutter problem
  188. FIC 1050 latency values?
  189. disable immobolizer
  190. Please help translate the log...
  191. For Your Consideration... Some Maps and Logs - 94 Oct.
  192. Do fuel trims really affect open loop fueling?
  193. Is it safe to log at 22 PSI on a stock ROM
  194. boost cut with 98640014 def
  195. Ecuflash guru's...help needed
  196. Please tell me what you think about this Log....
  197. Perrin EBCS with EcuFlash
  198. Knocks at red line fuel cut?
  199. Using Mitsulogger to log Zeitronix
  200. My Map/log
  201. Evoscan connect help.
  202. Tuning for higher compression
  203. Cold start rountine fuel enrichment Qs?
  204. JDM/EDM/USDM Ralliart ROMS: is there a difference??
  205. Howto: EvoScan v2.3 reduced diagnostic light flashing
  206. Help and input required please!!
  207. ECUFlash accel enrichment table not really accel enrichment?
  208. HOW TO Scale MAF Sensor?
  209. so i decided to pull my VC.....cams affect tune?
  210. what should my timing advance be?
  211. JDM MUT Table Pic Needed
  212. Pros and Cons of having the stock MAF in blowthrough mode
  213. How-To: Log Estimated Boost in EvoScan
  214. Help Me Understand
  215. Tuning for Torco Accelorator?
  216. Stock Evo with flash, post your power results :)
  217. My first patch for E85
  218. MR560648 defenition??? help
  219. what you guys think of my tune
  220. serial number for evoscan
  221. Adding the 280-300 load range on an Evo VIII
  222. Retune for season change? Suggestion please!
  223. Help with loadcalc on evoscan
  224. Jdm Map Sensor Won't Read
  225. Stock Turbo 369bhp
  226. Patch how-to: manifold air temperature logging
  227. low load knock
  228. Evo Ix Ecu Pins Are Here!
  229. AEM uego is outputting wrong voltages
  230. Changing fuel map scaling
  231. Do you need to tune for Injector Duty Cycle?
  232. Mustang dyno load = street load?
  233. Rescaling Your ECU for E85 - It's Easy
  234. Knock, Timing Help
  235. Evo Scan Wide Ban Question
  236. EVO9 ECU pins...
  237. Evoscan IDC reading 0
  238. Ok why the F wont evo scan work right??
  239. Ecuflash help!!
  240. weird throtle issue
  241. help with injector scaling
  242. evoscan download......
  243. Logworks
  244. What AFR's you guys shoot for
  245. Accell Enrichment News
  246. adding fuel: % vs. ratio
  247. switch from 88590013 to 88590015
  248. how does ecuflash deal with the multiplier
  249. saving logs
  250. openport 2.0
