View Full Version : ECU Flash
- V5.10 and alt map spool up ( 3k-4k rpm) knock
- Spooky EvoScan behavior
- Knock logs don't work
- Unknown table for 88590015
- Help with load issues
- Installing GM 3 Port Boost Solenoid
- Native DTC and MUT_45
- Can the Turboxs Knocklight be hooked to service light flash
- Weird EvoScan issue I've been having
- Is it time for a fuel pump upgrade?
- AFR's Evoscan vs Logworks
- WGDC w/ a GM 3-Port
- Immobilizer Code lost – Where or who can retrieve this for me?
- new 2.3l motor in any advice on base tune
- EcuFlash 09 Ralliart tables Vs. Evolution 10 tables
- where can i get evoscan 2.5?
- ECU Corrupted – need HELP rom# 96420008
- Evo Scan Question
- ecu unlocker
- Resetting Trims and effects
- Off throttle at cruise but still showing 12.4afr?
- The definitive EcuFlash Evo 10 thread
- Evoscan not connecting.
- Evoscan help, im verrry frustrated
- Solenoid: Bleed vs Interrupt
- Adding periphery
- Air Temp Compensation table
- Very Odd Lean Idle Issue, Tried Everything Need Your Help
- Audio Logging of Knock
- need help base map for 720 inyectors
- Evo wiki help for rom collection
- Help with changing injector scaling on my current tune
- broken ecu???
- xml request
- OP 2.0 Loggers?
- Are stock injectors sufficient?
- Difference in tune for altitude
- tactrix cable
- Having a strange knock issue
- ELM327 Bluetooth & Evoscan/ECUflash
- Acceleration enrichment for 88840017
- help reading rom
- Periphery questions:
- Tuning with the new Magnus
- EvoScan 2.5 vs DLL Dyno??
- Modified XMLs
- Decrease load at 5500 rpm evo VIII EDM
- WGDC Gauge
- Stationary Rev Limiter Missing
- Changed back to stock intake and different bov, now getting p0234?
- Knock control - load vs RPM table found
- What is needed for 2 maps?
- need help on the base numbers on bdel table
- To add immo code to my xml file
- E9 IX Def file needed
- How To Disable Egr Code
- question! Map sensor stock ecu
- what rom is this? tried searching..
- Changes in Boost after LICP & FMIC Install??
- coolant temps and timing
- Strange problem with "stop engine"
- Two questions
- BEC and WGDC Change %
- Any howto on fixing the endian issue?
- What's your suggested AFR target??
- Logging Boost Error Correction/ evoscan v2.1
- Timing & Fuel maps: Load auto-rescaling (XLS file)
- ECU Flash on a 1.6L Mivec
- IAT log you don't want to see
- My 60-1 Hifi map
- Ecuflash Error
- Ecuflash Error
- COP alternative?
- Hybrid Boost control and a ?
- 2byte to 1byte load factor
- E85 roms
- extream afr swings @ stop light
- 1 week of tuning with ecuflash on E85 DLL
- Is there a Tephra Mod on my Evo8 96940011???
- Correct formula for 2ByteLoad
- Installing evoscan 2.5 issue
- trying to log HP and TQ?
- EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
- Openport 2.0 hardware failure
- EvoScan 1.4E cable
- Unknown ROM
- Difference between 2004 jdm ralliart and 2005 evo 8?
- 3 port boost control solenoid
- dataloglab question (help?)
- Injector latency help please - PTE880's
- flashing problem
- .Zip Files
- 264s to an already tuned Evo 8.
- logged Evo 9 idle Airflow values
- The stock ECU has gear dependent boost control!
- P0105 MAP Circuit Malfunction
- Ecuflash 1.40 freezes Evo 9
- Someone advise on this map
- Couple issues w/ "Direct Boost Control"
- I F**ed UP - Question about immobilizer ECU and reflashing
- Question on Logging.
- P0304 Misfire Detected - Cylinder 4.
- EVO 7 Stock rom
- Need help! Disable o2 Sensor?
- need help tuning this is my first tuning
- 94170008 xml
- Lean Spool with ECUflash 1.40
- rear o2 sim patch for my 03 evo!?!
- EvoScan 2.5 not showing values under Map Tracer feature. Any ideas?
- Need some help, for my first tune
- changing COM port in evoscan
- Please help with NLTS
- Fastest Map Switch?
- load% taper. Boost leak?
- ecuflash problems
- ecuflash v1.38
- Periphery Bits CEL Fix - on ECUTek - how to??
- GM boost solenoid and boost pill question
- ECUflash problem
- Dynos and "Knock"
- "Drive" and "Nuetral" ECU definition
- Disabling Various ECU Functions
- Cable wiring??
- Boost Limit ECUFLASH
- ecuflash 1.38
- Knock Sum discussion
- Mut_05 = Mut_06 - 20
- BCS testing data
- problem with evo 9
- Veh Interface
- FIC 750's scaling and latency issues and THE MEGA FIC 750 thread (hopefully)
- FP Red intake pipe, hard pipe vs stock, power and scaling
- EcuFlash Problem
- EvoScan and EcuFlash - Questions And Answers
- evoscan/dataloglab problems
- evo x xml
- Help me do this real quick
- Setting base idle using SAS mode....
- I just Screwed up....HELP!
- no ECUFlash updates
- Flashing Problems
- JDM 3-Bar Map Sensor Group Buy #3
- 2 step
- Idle drop
- More injector woes
- Interpolation between high and low ign+fuel map
- Air flow meter???
- Getting my car t pass inspection
- fuel trims
- looking for stock 96420007 ROM
- Boost control correction is pulling WGDC w/out being enabled!?!?
- Is this a boost leak?
- evoscan load
- evoscan
- disable P0300 test
- Looking for help with P0300
- 96940011 And P0300 Codes..
- keys
- will ecuflash work if i own a mac??
- Possible to disable P0300 Random Misfire code?
- Stock fuel line technical specs
- 9MR stock MIVEC map
- need help with 1.3 cable and ecuflash
- need unmodified 94170008 and 94170014 ROMs
- One more knock source discovered
- my LC1 is pissing me off!
- rear o2
- Check my logs (KNOCK)
- How long after a P0300 till the CEL lights up?
- Stft/ltft
- ecu flash 1.40
- Knock sensor detection via MUT
- Special Request: I need to disable Fuel Pressure Solonoid circuit in the ECU
- Bought New Car - Need Tuning Advise
- X axis for 88590015 for OBD Diagnostic trouble codes table
- Need some help...
- Cosworth Mivec with FP Red, help.
- Ever seen Evoscan make your car misbehave?
- Speed Density Implementation Discussion
- RC 1000cc car doesn't start well
- Readiness code
- Help me diagnose this knock?
- How do I log Fuel Level in Evoscan?
- 94170015 MAP to MAF Patch:
- Problem with load
- Strange bost issue
- injector size scaling
- Phantom knock?
- higher boost/lower timing - how far is too far?
- Help Understanding Logs Values
- What would happen if you saw more load then on your amp scale?
- Rom Id Problem--HELP
- Quick ALTMAP question
- ecuflash evoscan issue
- HELP cant write/read ecu
- Ignition Retard Limit
- BCS activation RPM causing problems?
- fed up with knock control
- IAC Maps & limits
- borrow a GM BCS to characterize?
- No lift shift : Please help
- rich afr's during spool
- Help please with Hex-editor use
- Periphery code for immobilizer activation
- how-to: airflow rate in gm/s or lb/min and mpg
- knock sensor filters
- tune for stock evo with aftermarket cams
- o2 sensor and flashing
- disabling lean spool
- Correct latency values
- I cant connect!!!!!!
- help with ecuflash
- What do you think about this my method ?
- Tuned by TTP Engineering, Orlando
- highest MAF Hz logged with stock MAF?
- Weird rpm/boost limit table on 94170015
- Ignition Timing E85 vs 91 octane
- Car wants to stall coming to a stop
- "Logged Timing" deviating from Timing Map, every log, every time it does, it KNOCKS!!
- Volumetric efficiency
- Tunning With A Restrictor
- tactrix cable problem
- Load Limit? - Anyone Ever See >380?
- Playback error evoscan v2.5
- noob question about immobilizer
- Please help!!! 2 Evos wont work with my ecuflash
- 94170015 issues other than boost issues! please help!
- New FIC 1250cc on 93 and E85 - Latencies
- What's the most stable version of ECUFlash to use?
- Ecuflash v1.39 thread
- LM-1 logging
- Evo IV ECU to Evo VII ECU
- What do u think
- Coolant Fan Temp
- 23mins of Open Loop driving
- “Max WGDC cold engine / CEL" table for ROM ID 96420008
- high idle
- EcuFlash DSM help needed, non evo related
- EGR exclusion
- rear O2 sensor function?
- OBD-II Codes Table Explanation Please
- 04 evo with o2 sensor problem after tune
- EvoScan v2.7 MapTracer Bilinear Interpolation
- Noob confused about ecu tuning
- idle fluctuation
- Logs, timing and fuel map
- switch ROM ID's...
- cable for ecuflash
- Tuning Cam Idle
- what maximum side injetor can i use on stock ecu
