PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40
  1. really hygh knock on really low load
  2. Up to Date IX XML for EcuFlash
  3. Tuning for 0 knock, having an issue with one area
  4. VIII with a IX turbo map!
  5. p1104 p1105 codes and running rich
  6. Individual Cylinder Question
  7. New log for review
  8. Anyone here with a 2.3 or 2.4 on ecuflash?
  9. ECU Flash "An Error Occured"
  10. How to view logs
  11. anyone with 96420007/8 ROM running JDM MAP sensor
  12. data log lab and logworks?
  13. High Oct Load table - Whats the diff?
  14. Where to download an older version of ECUFlash
  15. Looking for recomendation on Wideband
  16. Are these roms interchangeable?
  17. tuning for e85 advice needed
  18. Logging Data
  19. Dual boost solenoid schematic & ECU pinout for Evo X
  20. An idea for cars with no ICS switch
  21. rich idle problem
  22. Zeitronix WB, NB simulating, + EVOSCAN
  23. Injector scaling help
  24. Evoscan maptracer help
  25. EcuEdit?
  26. Help: Vista OS OK?
  27. Idle Quality with RC1000 cc injectors
  28. Evoscan code reader issue
  29. ADC assignments for USDM Evo IX 88590015
  30. Trying to find a fuel/timing fix for aftermarket diverter valve
  31. tactrix issues with vitsa
  32. Map for 05
  33. DMA logging now working - logging 25x faster than MUT
  34. Question KNock voltage level
  35. Meth Failsafe and Patches
  36. from 88590014 to 88590015?
  37. Two Speed limit boxes? why?
  38. Airflow/rev question
  39. can the standard ecu be patched to support wideband lambda?
  40. DMA logging first test a success
  41. High Compression High Knock
  42. injector voltage Stock evo 8??
  43. need 2-byteRPM formula for mitsulogger
  44. EcuFlash 1.28
  45. I look for....88840017
  46. 2.3L ECUFlash Tune?
  47. PATCH: KNOCKCEL+NLTS+AltMap (V4)
  48. reflash without afr log!
  49. Tuning with MAFT
  50. ECUFlash mods - Anything else I can do?
  51. remove maf honeycomb (not a noob lol)
  52. Which ROMID's have ICS
  53. USDM Evo 9 ECU pinout here
  54. WGDC Correction (direct boost control)
  55. help
  56. ecu def
  57. De Tune for Winter
  58. DMA logging/mapping idea
  59. Evo Live Map 88590015 Download Ready
  60. Help Me!!!!!!
  61. Question about tuning,and fuelpump..
  62. ecutek to ecuflash....
  63. IX low on power, excessive load, what's wrong?
  64. Any One In San Antonio ? Ecu Flash
  65. need some help with my 2 byte load
  66. MUT logging - 375 to 750 items per second
  67. ECU FLASH connection...
  68. MWDC / BDEL question.
  69. Help with Maps for Stage1+ VIII
  70. Having problems downloading EcuFlash
  71. Trouble. ECUflash wont Flash.
  72. fuel pump tune
  73. Evo 9 Running Lean
  74. Fp Green
  75. Tuning or logging cable, WTF do i have here?
  76. GSC cams produce false knock?
  77. Target AFR
  78. Stock map
  79. wastegate solenoid on/off?
  80. Can't get Load to hold flat
  81. Evo live map - hugely experimental alpha logger/realtime mapping skeleton
  82. Anti-Lag option.
  83. Mut table for rom 96420008
  84. How to determine what load cells are being used????
  85. Evoscan 2.0 formula Syntax
  86. Fuel Trims are way off--need some help
  87. Fuel flow switch?
  88. Getting AFR's closer to Tables
  89. Live mapping PC side app - progress yes and no!
  90. exhaust manifold
  91. Most Common 2003 Evo Rom?
  92. Has it happend yet?
  93. questions about simple log parameters
  94. AEM UEGO Wideband AF issue..
  95. JDM EVO IX help
  96. Power Falls out
  97. Fuel Injector Question
  98. Evo 2byte Airflow changes
  99. Can idle timing affect idle AFR?
  100. Gt30r
  101. GM boost solenoid LOUD!!
  102. Post your fuel map please (Evo 8)
  103. Evo IX+110 Oct=Bat out of Hell
  104. Problem with A/F changing...
  105. no injector scaling
  106. 1 step colder spark plug, any changes to Timing?
  107. **Lean Idle with 50-trim, Cossies, and PTE 880s***
  108. Need some help with my car/tune guys...
  109. Bez's perephery calculator
  110. EVOscan 2.0 maptracer issues
  111. Selling GM Solenoid & JDM MAP Sensor
  112. What are the signs for airflow meter going bad?
  113. Mitsulogger question
  114. cant read or write to a ecu
  115. Help With Running ECU Flash
  116. Can u remove the CEL for EGR
  117. engine load question
  118. ECUflash with Evo 6???
  119. MIVEC disassembly notes
  120. What BCLO do you run?
  121. logging wideband question
  122. boost change on altitude your experience
  123. Idc% Evoscan 2.0?
  124. Question about tuning timing. .
  125. Can't seem to download ecuflash ver.1.34 and am missing taxtrix driver for evoscan
  126. how to tune for cams?
  127. EvoScan 2.0: Map Tracer not working for me?
  128. Airflow 2-byte??
  129. Lost my evoscan serial number...help!
  130. 2 byte load the same for 94170015 as 94170008?
  131. Time pulled without apparent reason...
  132. OT: pressure differentials over long vacuum line
  133. buschur mass air pipe w/filter version 2
  134. Ecu Flash buggin
  135. let's see your maf scalings
  136. P0300
  137. Cant DL my ROM using ECU Flash please help
  138. review a log
  139. How do you interpret Maptracer in Evoscan 2.0?
  140. Take a look at this screenshot, 94170015 rom ID
  141. Can I burn newer rom ID's onto an older model ecu?
  142. 2 byte load dumm question
  143. question about my tune
  144. ECU knock algorithm effective at 2500-3500 rpm??
  145. more timeouts in EvoScan 2.0?
  146. Trigger logging session using TPS?
  147. converting target AFR's for different scalings
  148. Went for a drive
  149. Evoscan2.0 is out
  150. how to log afrs, need explanation
  151. Any need for AFC?
  152. engine code raeder download link
  153. cant log AFR with evoscan
  154. Let's see your fully tuned timing maps
  155. newb question..
  156. ECUFLASH shows error and unknown code?? Any ideas??? CANNOT FLASH MY ECU PLEASE HELP
  157. fuel pump dual voltage- load value?
  158. Min temp for full boost control
  159. Link for Evoscan Plz
  160. Problem With Scaling Injectors
  161. Inconsistent Knock...
  162. tuning closed loop knock
  163. converting to a toyota maf?
  164. What is wrong with these maps??????
  165. Rom ID issues, '03 Evo 8
  166. EcuFlash + Pocket PC???
  167. Weird dip in curves and low output on dyno!
  168. Possible to tune for aftermarket recirc valve?
  169. Does evoscan have real time logging?
  170. problems with evoscan and ecuflash
  171. O2 sensor
  172. EVO IX fueling troubles...
  173. Modified maps for download
  174. different maps
  175. Hitting boost cut suddenly, what to set BDEL to?
  176. Bosot Estimate
  177. Bucking low rpm
  178. evoscan settings??
  179. Thoughts on the wideband
  180. strange knok on high gears low rpms
  181. Any chance of improving boost control?
  182. do i need reflash?
  183. How much boost on pump gas do you run?
  184. Not logging LFT or HFT in Mitsulogger
  185. Disable IACV
  186. car back to stock and still few knocks?
  187. An Idea on logging backpressure need some info and input.
  188. 2byte load's
  189. Anyone running Mitsulogger on Vista? I need some help...
  190. AFR Too High? Newbie still learning
  191. Anyone care to take a look at my ROM ?
  192. ECUTEK - Out For Evos?
  193. What does your tractrix cable look like?
  194. Zeitronix AFR in DataLogLab
  195. ecu boost controll help needed...log included
  196. EvoScan Questions - Please help.
  197. ecu flash 1.29a
  198. Very Interesting Tuning Case
  199. LogWorks is working, but evoScan is acting up...please help...
  200. Pulling off ISC bad idea or ways around it ?
  201. evoscan log ?
  202. Short term fuel trim
  203. Need Help with ROM but no way to post
  204. RPM/load Values
  205. Look at my logs....Whats wrong?
  206. Gt35
  207. Obdi / Obdii
  208. A Good Flash!?
  209. What program do i need to run Open ECU's programs ?
  210. Can't Flash ECu When its Cold Out??
  211. 'octane level'
  212. Where to get replacement o2 sensor for LC-1?
  213. Not Detecting Car When Running ECU FLash
  214. Anti Lag
  215. New Ecuflash user has a few questions.
  216. EvoScan Question
  217. Weird Dip in Load
  218. My evo ix overboosting??
  219. Car won't idle Evo9 Cosworth Cams
  220. Tactrix cable not working with MacBook
  221. JDM Map sensor off?
  222. engine braking effect
  223. mod roms to run 6 injectors?
  224. How much memory is needed to tune effectively?
  225. MWGDC and TBEC Tables?
  226. Rear o2
  227. Rom immobilizer
  228. Overboost
  229. Need Help!!!!!!!!
  230. EcuFlash V1.34 released
  231. Is my NLTS working right?
  232. Help me with DLL please...
  233. Evo ix loads of knocks
  234. Which of these is the correct scaling for the PTE 780cc Injectors?
  235. evo X ecu
  236. 2.2 with gt35r would appreciate some help
  237. corrupted dynoflash
  238. Cams to big for Stock ECU?
  239. EcuFlash Versions
  240. Ecuflash ROM definition!!! help
  241. Proper EVO IX Car Definition in Data Log Lab??
  242. Does disconnecting battery effect boost immediately after?
  243. Evoscan dyno curve accurate?
  244. ECU Flash not working...
  245. mitsulogger??
  246. Reputable tuner, what should I expect?
  247. How old is MIVEC?
  248. maxed stock inj?
  249. GM BCS + NLTS = boost spike!?!
  250. AEM Uego won't log!
