PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. Tephra + state inspections (specifically ny)
  2. Need help evo 8 map no start
  3. 88590015 won't show fuel trims?
  4. Column Too Narrow
  5. Cant find correct definition file
  6. Evo VIII motor in Evo IX chassis
  7. EvoScan Gauges: Widget rescales when data item is set
  8. Speed density fuel trims help!
  9. evo 4 with 7 ecu pin 79?
  10. Lean AFR's, poor cruise, stutter/miss
  11. 03 Lancer automatic ecu-> evo8 rom?
  12. Need XML for 88590715 for my evo 9
  13. ECU pin removal tool.
  14. New turbo swap tune
  15. 2006 evo 9 mr says unknown rom when trieing to connecto to ecuflash???
  16. wtf is this backwards wizardry
  17. EvoScan not connected to ECU
  18. Evo 8 ECU to Evo 5 Engine
  19. Ecuflash runs great but EVOscan will not work.
  20. You guys know you can flash with a VAG COM cable...right?
  21. Help need just finish swap
  22. HELP! Can't read Evo IX rom
  23. Can't connect to ABS ECU with Evoscan
  24. ecuflash trouble. Not reading evo ix
  25. base map for e85 evo 8
  26. Openecu/Evoscan not Read/Write
  27. Stock 8 mr boost
  28. Looking for a E-Tune
  29. accidentally hit write to ecu before saving immobilizer info
  30. 10.0 AFR after reflash
  31. Evo 8
  32. Suggestion Needed: Fuel and Timing
  33. scratch tune SD with no maf logs
  34. MUT Table Formatting
  35. Standalone logging of ACD ECU with OP 2.0?
  36. ACD bleeding program - NEED TO BUY!
  37. Can help me? when the load beyond 220, tps 100% ,the car appears to be powerless
  38. How to fix cold start high idle
  39. Decel fuelcut delay
  40. Strange Sd setting Omni 4 bar
  41. Black puff
  42. What maps does 3step use?
  43. Idle and knock problem HELP!!!
  44. Taxtric Cable question????
  45. Having some rich issues on SD
  46. Desired ISCV settings for lightweight flywheel?
  47. Need help flashing a Carisma
  48. Concerns after Walbro 255 install
  49. Programmable ecu output?
  50. ECU flash pls Help wont read ECU
  51. ceddy rom WGDC fail safe lookup tabel
  52. Help to disable 02 Sensor
  53. Tephra mod V7 IC Spray options
  54. need help on Evo 8 unknown ROM ID
  55. Need Some help setting up ECUFlash - Roms not reconized - Getting tuned Sat!
  56. Fuel Pressure regulator gone bad?
  57. cold start idle dips rich
  58. 03 EVO 8 Tuning options
  59. Assistance with my 3-port
  60. using evo 6 ecu on evo iv
  61. MAF Scaling Questions
  62. Uncontrollable leanout between 2-3k on WOT
  63. 06 evo, aem data... what do you think?
  64. Tephra V7 - Table descriptions??
  65. How do my logs look?
  66. Need help please! - Cold idle problem
  67. 96530006 upgrade questions for Evo8 EUDM 2005
  68. Need some help opening a map
  69. Trying to aquire 96260709 Tephra-mod v7
  70. Quick wiring q o2 sensors
  71. EVO is pulling timing no knock
  72. 8859 obd circuit test by pass?
  73. Defective injector only when cold? -*Idle Issues*
  74. How to tell 1.3u vs 1.3r?
  75. Evoscan 2.6 does not work after Ecuflash update to 1.44
  76. SD converted issue...help pls!
  77. First time Tuning an EVO
  78. Stock tables for thermo fan
  79. Lean Idle - After fuel pump swap - Direct wired
  80. Trying to figure out what "Load" item to log in EvoScan to use in ECUFlash.
  81. Tablet for tuning/logging?
  82. can't read ecu or write to ecu
  83. Getting started
  84. Safest way to go back to a stock ecu?
  85. PS compensation definition?
  86. RequestID="CALC" not working for EvoScan v2.9.0023?
  87. Evoscan help
  88. Iphone evoscan app w/ app radio
  89. VERY VERY HIGH KNOCK - Evo 9 - Need some help, getting a little scared
  90. Using a 1.3R to flash
  91. Load Logging
  92. Help! my ECU is locked because i modified my flash ROM, cant rewrite ROM or start car
  93. Car won't start after gearbox failure
  94. Logs, rom
  95. tephra xmls changed over last 2 years?
  96. car wont idle
  97. Idle + Boomba problem
  98. Modify Ecuflash Cell Size?
  99. Is this what running out of fuel looks like....
  100. Launch bouncing
  101. really bad cold starts on pump gas 93
  102. AEM WB Logging through Pin 73 Formula?
  103. id 2000cc Injectors stock ecu?
  104. Random overboosts
  105. Rescaled maps!
  106. defination request
  107. warmup ignition retard map
  108. Cold start issue, wont stay running after start
  109. Tips for run-in tune
  110. Ecu wont read from ECUFLASH
  111. issues logging aem uego with evoscan microsoft 8
  112. Take a look at my log?
  113. 94170715 V7 will not boost over 15 psi
  114. Bad sensor or what? Can't figure this out
  115. Injen maf scaling
  116. How to get started
  117. AEM Uego - ECU logging
  118. need a new laptop and some suggestions
  119. Map tracing on evoscan issue
  120. Cold start idle with fresh build
  121. Scaling for lambda in ECU Flash
  122. Maps don't show up?
  123. 88590013 -> V7 - Immobilizer Hex?
  124. Map tracer tutorial?
  125. Idle speed
  126. ECU thinks I have a MAF again...
  127. dashcommand in project,need ur advice pls
  128. stationary rev limit
  129. Evoscan TCU logging (GT-A and similar)
  130. Low loads for power
  131. What maps are used when the car is ice cold? Odd lean condition inside
  132. Need explanation for 1b load readings
  133. p0107 code with omni 4 bar
  134. Dip in AFR at peak boost
  135. JDM Evo 8 | EvoScan | Omni Power 4 Bar
  136. Can't flash new ROM in?
  137. WGDC a bit too high?
  138. WGDC wont go down.
  139. Fuel trim Logging
  140. WGDC = 100% under this load?
  141. how would you adjust closed loop afr
  142. Rear O2
  143. Adjusting Odometer for different Gears?
  144. Tuning Boost/Gear with HKS 4.11's
  145. Fuel map after scaling
  146. problems with tephra v7
  147. Tephrav7 reverting to small map?
  148. very lean when cold
  149. Evoscan Wont Connect to ECU
  150. SD map
  151. Help evo 8 Rom file adustment
  152. 2g dsm
  153. How to switch tables
  154. Valet Mode
  155. Boost Error Control Issue
  156. Intermittent AFR's wildly swinging
  157. do you need to tune after tephra
  158. High knock stock tune/motor P0300
  159. JDM Evo 8 ECU information request
  160. Disable P0125?
  161. problem flashing rom on evo 8
  162. Experience needed about knock
  163. Boost on gauge doesn't match evoscan logs
  164. p0420 Cel Light...can I remove light with periphery edit?
  165. New VI 2.3l Build Issue
  166. EvoDroid 7 Gauges (how to build, modify and examples)
  167. Looking for Opinions
  168. No Injector Signal HELP!!!
  169. having issues reading rom
  170. Rich idle/cruise AFRs
  171. SD Rich on throttle lift.
  172. Fuel Trims after S2 Cam install
  173. Stumped @ idle fluctuations
  174. tuning help/advice
  175. Selling my evo
  176. Evodroid - lock screen?
  177. Idle problems on rollout
  178. big map translator out of whack
  179. tuning after cams
  180. Hitting boost cut after Tephra V7
  181. Boost Control Problem - Advice Needed
  182. 2.3 stroker timing map question
  183. GM IAT for tephramod v7
  184. Weird issues after cam install
  185. Boost control solenoid
  186. AFR idle with 280 cams
  187. 96420010?
  188. Tuning Evo789 ACD
  189. TPS% vs AFR
  190. AEm 30-2301 Non-Linear formula
  191. ECUFlash Write problem
  192. Immobilizer code help!
  193. Fuel trims at wot
  194. Evoscan full trims help
  195. Tune for new transmission
  196. Issues connecting EcuFlash to Evo 9
  197. Need some tuning help, low power and dont know why???
  198. Timing randomly being pulled in upper RPMS
  199. flame doesn't emerge when launch map in operation
  200. where can i get evoscan 2.8 i have 2.9 but it wont read codes...
  201. knock sensitivity settings
  202. help me,TephraMod V7 in my 88840017
  203. Had to remove damaged MAFS screen. How do I adjust for it on V7?
  204. SD Conversion Help
  205. unknown rom
  206. evoscan not logging
  207. 2007 JDM Colt Version R 1.5 turbo
  208. car won't start when converting to tephra mod 03 evo 8 jdm
  209. help delete o2
  210. trying to use a serial cable with evoscan
  211. Evo 9 FIC 1050cc Map??
  212. Nlts rpm drop
  213. Non Starter after using TephraModV7
  214. Evoscan/Ecuflash on Ipad?
  215. So I was tuning launch maps.. Wgdc corrections while stationary?
  216. alt maps
  217. Too much fuel - regardless of what I do in the maps
  218. Small edit fields
  219. how to tune Anti Lag Map ?
  220. New to ECUFlash... can't make sense of this error...
  221. Fuel Cut on JDM Evo8
  222. Estimate tss from airflow hz?
  223. Higher loads
  224. 9.69@150.80 1G Talon With EVO ECU.
  225. Someone please give me a base map to drive on...
  226. Idle Issue (Evo8 Ecu in 2g GSX)
  227. Where can I get a stock 2005 usdm evo map?
  228. Problem Logging 1 Byte Load in EvoScan 2.9
  229. Tephra 90550701 setup on EVO VII won't start
  230. Help! Is my wide band going bad? or am I missing something [Video]
  231. Can't tune load 20 Column
  232. Help Tuning My Evo4
  233. Mac book pro and ECUflash questions
  234. Issues with tuning a built evo 9. Stock turbo.
  235. not sure i believe my boost error...
  236. logging mtx-l wideband to evo 6 ecu ?
  237. quick baud rate question
  238. 5V output from pin 87 by modifying definition file
  239. 1.3DA cable logging on Laptop?
  240. Engine Start problem
  241. IAT Correction table & Live VE Mapping?
  242. SD Fuel Tuning
  243. sd logging with tactrix op2
  244. mitsubishi maf 1525a016
  245. Should I switch maps when moving to a 10.5 housing
  246. 3D SD table - load or VE?
  247. current map description is invalid or incomplete
  248. wired map switch harness, have a question
  249. ecuflash keeps defaulting to Kavlico
  250. Speed Density: A little confused
