View Full Version : ECU Flash
- Evo scan 2.9 vs Ecu Flash High Octane Maps
- 94170008 Rom Tephra v7
- new injectors now lean idle on cold start
- No connection, evo 3, CE9A
- Tephra v.7 96530706 e85 fp New tuner Rich Help.
- SD conversion map definition for fuel temp sensor?
- looking for advice.
- Tephra Mod Check engine flash on knock.
- Evo 9 mr 80920002
- Installed Peak/hold driver need help disabling P0201-4
- Help Evodroid
- ELM with 88590715 issues
- Dual map and ecuflash
- Omni 4bar readings Vs Boost guage readings.
- Swapped to SD, great cruise and Idle, AWFUL WoT (rich)
- SD Kit and SD rom selection
- 96531706 SD phenem
- How do you use the fuel temp sensor for SD tuning
- Per cylinder fuel trim
- PEAK and HOLD amps for stock injectors.
- MMCFLASH - where to buy and which one
- 10.0AFR decel 941701715 v7
- Who can help the trbotaxi pass inspection?!
- Evo 7 wbo2 logging issue
- Evoscan 1.3open Evo9
- STOCK MAP Sensor EVOScan calc's please?
- I have my tuning locked in now time for cams not sure where to start with tuning at
- p0141 impossible to clear
- Decel IPW Subtraction Comp tables help
- Can anyone identify what country, and spec of this EVO 8 4plug ECU.
- New fuel pump STFT now -20ish yikes
- How to upload 93 Oct tune to ecu
- Lean afr Fp Red, E85
- Hard start, too much fuel cranking?
- Pass Inspection in Mass after P0300 Disable?
- Evo IX E85 conversion
- Evo 3
- Maf scaling gone wrong.
- Omni 4 bar random bog
- 2002 montero defs
- Problems setting up Omnipower 4 bar MAP sensor
- Help!!! Super rich after PTE 1200cc injectors
- Tephra please help evo 8
- Evo 8 audm
- Clutch switch LC vs NLTS
- 2byte load for 96420011
- Going speed density little help
- Little help with tephra v7 please more like a question
- Evo 9 wont connect with ecu flash
- 96530706 Evo 8
- ECU Knock control algorythm thread
- 90550001 live map rom
- Can't go past 175 load
- new laptop dumb question with EcuFlash
- evoscan
- Car really leans out around 2000-3000rpm
- Logging boost using WG solenoid pin
- Setting up ALS (slightly unusual)
- Setting up Evoscan for SD
- Help Please hybrid boost controller ECU settings
- Fuel Pump Prime Key On
- EVO 8 2004 ECM/ECU Replacement Question
- tactrix open port 2.0 adapter problems
- Calling Tephra Please. ETACS MUTIII information for EVO 8/9
- need tephra v5.10 96530006 xml
- Disable DTC via hex editor
- Fuel Issue, Unknown Issue, HELP.
- Definition File needed for EDM Evo IX
- OMNI 4 Bar Failure Analysis: Quick and Dirty Teardown
- Pte 1000 latency issue
- Ecuflash wont read rom. Searched already.
- Calling Tephra Please. V7 Issue, gear based boost
- EvoScan bug reading MUT 07
- Looking for o2 simulator patch
- Problems getting ECU controlled boost to work.
- Lower Load Knock - We don't care?
- flash CEL but 0 Knock!!!
- Missing Tephra v7 tables
- Ignition Retard Limit 96531706 (tephra SD)
- MAF to SD no start help.
- MItsubishi FTO ROM Challenge
- Mivec Advance effect on 2-Step
- Faulty injectors causing Fuel Pressure issue?
- Fuel trim and O2 sensor activity at 0
- tps
- Remote tuner recommendations?
- Evo new build tuning woes
- Unknown rom file on Evo IX JDM
- LTFTs are 0 after switching back to 93 from e85
- Problem with ECUflash
- Unknown Rom File Help!
- Cold Start - Lean after throttle Input
- Stationary Rev Limit
- valet mode
- 53590009 no xlm moving forward
- Rom 88840016
- Help, Sever issue at idle, Logs only show ISCV steps out of line NO CEL CODES
- Help scaling help fic 1650 high please
- Sort out this rom?
- unknown rom
- Evo live map for GTA 80700010
- At a loss with Knock Sensor. Constant 8-9 under minimal/all loads
- Unknown ROM file
- Open Loop Tables
- Tactrix Reflash connector causing clicking relay/blowing ecu fuse
- EVOScan MAP Sensor Voltage formula???
- Replaced fuel line, tune waaay off.
- BISS Screw Vacuum leak...
- Fuel trims stuck at zero!
- Evo 8, SD, S90 70mm, ASNU 1050cc : top lean tip-in
- Tephra roms small maps please need
- Injection timing with non stock cams
- evoscan help evo 9
- RC1600cc scaling/latency
- SD Tuning Questions
- Evo 8 Stock ECU reflash help
- BPR8EIX on stock turbo : strange signs on spark plug
- Sard 800cc scaling/latency
- tephra 7 boost control
- ECUFlash Issue
- Injector flow rate linearization tables for ID1000 ?
- cat back and short ram
- Tuning Idle
- How to Tune EGR Needed. Not sure if anyone ever did this, vs disabled?
- Fueling issue. PLEASE HELP. Possible Tune, possible mechanical failure.
- Omni 4 bar and aem wideband logging
- Call out: favorite mod theough ecuflash
- Random Wiring Harness - Unable to connect with tantix
- Can I simply disable EGR via EcuFlash?
- Dialing in Launch Map using Tephra V7
- SpeedDensity - AFRs jumping
- Speed Density Idle problem ( 70 LOAD- 10.5 AFR )
- USDM ROM in EDM ECU ?
- Definition Guru {pcfreak}
- Evo 8 Speed density : Car won't start
- Airtrek ecuflash defs
- Evo 8 Speed Density issue : P0110 IAT Circuit Malfunction
- AEM IAT , Omni 4bar MAP .. Testing
- Max total upward wgdc correction vs tps table issue
- evo swapped 1g dsm issues with tephra v7 sd
- Emissions Readiness
- Unknown 2g or EVO 6 ECU / MD346010
- help with ecuflash
- Can't find big map translator for v7
- evo logs pics please
- 2g DSM w/ EVO 8 ECU, logs, advice please
- E85 built motor missfire problems
- Need definitions for my ROM (ID 90120001)
- Ecuflash help!!!!
- Weird start/ no start issue ongoing issue. **Help**
- Switch from 96530706 (MAF) to 96531706 (SD)
- Problem Downloading Evoscan error 403 forbidden
- Help with tuning please
- Making Hybrid ECU MOD
- WinCE EvoscanPPC Replacement Battery?
- Closed loop - A/C idle tuning
- Evo 8 timing map questions
- IX Flash to VIII MR ?
- Ecuflash Experts needed! V7 conversion MAF to SD
- Anyone in Bay Area Ca with a cable?
- Help with low load / RPM knocking
- ICS control for Tephra V7, specifically 8859
- Ignition Retard Limit for Evo 8
- LT fuel trim definitions
- ⛔★ Stalls with clutch in, can I flash higher idle RPM?
- Injector pulse width 0? log inside
- Live map and speed density for 90550701
- Evo 5/6 SD jitters !
- 2 issues i need resolved asap if anyone can help
- Easy Map Alt activation EvoIX
- Help! Went to omni 4 bar now A/f very lean
- Loading Base map sent via email
- unknown rom file
- TephraMod V7 96530706 issue - help
- Log boost from Defi sensor on Evo 8 EDM
- Direction Address
- I need A tunner
- First attempt to datalog
- Data logging evoscan unstable on Evo 8
- Tuning pops and bangs in - graph attached
- Sputtering/misfire when going from v5 to v7
- What is wrong with my car? (review logs pls)
- Pull with little knock, then a pull with lots of knock... How to Tune?
- HELlo
- WGDC much lower than table with corrections disabled
- Virtual Dyno Help?
- EcuFlash closes 10 seconds after opening without internet
- Evo 8 ecu in 2g cranks but no start
- FIC 1120 Scalings/Latency
- ECU replace ?
- Outlander Turbo - EDM flashing
- OMNI 4 Bar with 96531706
- Newbie check in and advice needed
- LF Newest Evo 9 STOCK ROM
- Evo 8 Usdm Ecu Needed
- Evo 5 to Evo 7 Ecu Swap Help Needed.
- WGDC mismatch on Evo 7 w/ Tephra ROM
- IAT Sensor Question
- Cant open tephra tunes with xml packet
- Geek mapped
- 2 byte load xml
- pops and bangs
- EvoScan: Help or Point me in the Right Direction
- Help tuning evo 6
- Load values
- How To: Aggressive Launch Control
- 1b load rolling over at 300?
- Id 1000cc
- Scalings
- Need help setting up a startup tune on an Evo 5 ECU.
- Tuner needed
- Problem reading Rom in ECU flash.
- MATScaled
- ECUFlash Unknown ROM Image
- xml files
- IPW Patch
- Boost oscillation on 3 port fix?
- Idle speed control (isc) system
- Let's see your fully tuned ACD maps
- Weird timing doesnt match map
- EvoScan Live MapTracer Error
- Load 1b or 2b??
- Definition 92290022 not working
- Real or False Knock???
- Evoscan 2.8
- MAF Hz over 600 at Idle?
- "ROM not recognized by current definitions" (abort, save, and make new definition)
- 6mt rom ok for 5mt
- ISCStep 100 at WOT!!! ISCV Problem?
- Why I canīt read IAT????
- evoscan v2.6 with ecuflash 1.44 using tactrix 2.0
- Ignition maps
- A little guidance, please
- definition files for map sensor scaling
- Wideband on rear O2
- Ignition Coil Charge Time
- Evoscan Cable 1.3U Pin switch
- Need help extracting rom (Previously tuned)
- Evo 8 ROM
- Pin 9 on OpenPort 1.3U
- Anyone using a GM 4 Bar MAP Sensor?
- Evoscan issue
- MAF To speed density
- Switched to V7 Timing map all wacked
- Grimmspeed 3 port Global WGDC?
- Review my data log ?
- Decrement in timing?
- Unable to Log (Load 1Byte) evoscan 2.9
- Launch Limiter not working
