PDA
View Full Version : ECU Flash
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. In need of some assistance: xml file
  2. can i go back to stock timing tables and keep other settings
  3. Airtrek reflashing
  4. Need HELP logging AFR on Evoscan Autometer Digital
  5. xml for 1998 RVR x3 4g63t
  6. Evo 5- No definition for ID05092012 - use H8 n/a instead?
  7. Opinions on Fuel/Timing maps
  8. ACD ECU unable to connect with ECUFlash
  9. Jdm evo 9 on tephra v7 rom: 88592715
  10. ECU flash developer mode?
  11. Long iddle upper after cold stard
  12. Evo ECU, Naturally aspirated car
  13. Idle timing 2.4LR
  14. Hitting Negative timing between shifts
  15. Evoscan
  16. Identifying Rom & Help Logging
  17. Ecuflash Randomly Decided to Stop Working?
  18. Car runs super lean and surges on hot start
  19. Need definition file for Outlander (JMC728)
  20. How to switch maps on Ceddy rom ?
  21. 88583714 v7 SD xml
  22. 2byte load eval equation for 88590015
  23. 3D Speed Density Tephra V7 ROMs BARO Fuel Compensation
  24. Outlander turbo, wont read ECU
  25. Evoscan
  26. Omni 5 Bar MAP values.
  27. Boost cut, fuel cut or anything else
  28. Colt Czt Edm 2005 (not Ralliart) Definition Help
  29. Flashing Back to Stock Immobilizer Issue
  30. 96260009 tephra v7 rom
  31. Closed Loop not working evo 8 ECU on Evo 4
  32. ROM image not found (Flex Fuel)
  33. Looking for 94670106 definition file
  34. Hello - first time tuner
  35. Proper Tuning Order?
  36. evo 9 gt wagon rom definition EcuFlash
  37. Rear O2 Sim not working?
  38. Seeking knowledge about current ROM (file attached)
  39. Unknown Rom
  40. OBD inspection settings (88591715)
  41. Tactrix Openport 2.0
  42. Tephra 9626 v7 rom
  43. P0170 fuel trim error
  44. Problem With ECUFLASH 1.44.4799?
  45. ECUSCAN APK Download, Does it Exist?
  46. Subaru Legacy /Liberty 1999-2000 Cable and Evoscan
  47. MAF disable, P0102/P2228
  48. How do you disable/remove cels from the ecu with ecuflash?
  49. Evoecu.logic website almost down?
  50. Changing the timing retard past -10?
  51. aem wideband
  52. dma logger + live tune
  53. Unknown Rom Image
  54. Help, tephramod , boost
  55. Booost control question
  56. Peak boost lean issue
  57. ECUunlocker - what does it change?
  58. Rookie, Need help! Car has knock.
  59. getting knock (spool, lift)?
  60. Tephra 96260709 XML
  61. 4G93T DOHC GSR ECU swap with Ceddymods & MAF, Denso Injector scaling help
  62. ECUFlash Blobbits Tables - Can't See Values?
  63. Desperate help
  64. Wont Read DTC Mitsu OBD1
  65. 90550001 Tephramod V7 Ecu Controlled Boost
  66. ALS/SAS Routines in 90550701
  67. JDM evo 9 MR xml
  68. 92930012 knock+startup definitions
  69. Beginner need help accessing TScomp ROM
  70. Evo 6 WBO & 3 Bar MAP for logging
  71. Failed flash on Tephra V7 leads to default to Alternate Maps
  72. 90550701
  73. Questions and issues with Evoscan Tephra 90550001
  74. Wanted Tephra ROM/defs for E7 90550001/98640014
  75. Advice on tuning new BR RPM 2.3 and Tephra V7 SD
  76. Tune walk through
  77. Need help logging AFR in evoscan
  78. 6.5 TME ECU map
  79. Evo 8 JDM Ecu Into Evo 6 Help
  80. Evo9rs will not start after flashing stock map
  81. Please Help!!! Ecuflash stopped half way, now car wont start
  82. Looking for hex file for evo 5
  83. Whats the max timing to run on evo 8 cams?
  84. Speed Density and 2.4L motor.. Questions
  85. Iat/weather dependent afr
  86. How to backup ECU prior to DIY tuning
  87. Unable to Read/Write using ECU-Flash
  88. Cant read a Evo 8 usdm rom image.
  89. Load value logged is incorrect
  90. P0141 CEL with rear o2 simulator
  91. Incomplete def files
  92. MAFAir temp reading different with v7
  93. What RequestID & ScalingFactor for AFR Logging?
  94. Logging Steering Angle with Openport 2?
  95. Help with EcuFlash
  96. Openport SD card logging
  97. Fresh build, rich idle and dies after blipping. PLEASE READ!!
  98. Evo 5/6 25570100 & 25570300 Development Thread
  99. Lean tip in continued...
  100. Lean afr ac on
  101. need help with evo V logging/tuning/cable needed
  102. What could be causing WGDC to decay over time?
  103. First time logger for evoscan
  104. [help] cant open this rom?
  105. [HELP] EVO VIII MR 2004, Fuel cut on boost / hit brick wall
  106. Running lean on warm start and coming to a stop
  107. Evo ix cop - starts / runs / cuts out :(
  108. ecuflash definition help
  109. upgrading to 88580714 v7
  110. Stock MDL560 Injector Latency
  111. Playing with the SH-2 On-Chip Debugger (AUD)
  112. 94170015 SD rom Where can I find it
  113. Decel fuel cut delay
  114. Rich cold start SD
  115. p0462-88590715
  116. Help can not connect to ECU
  117. 88570008 Tephra 5.10 Non-SD
  118. 88590715 Tephra V7 loves my wastegate?
  119. Mitsubishi Evo 8 year 2003 speed limiter off
  120. Disappearing Tephramod V7 Speed Density
  121. My 2D to 3D Speed Density Conversion
  122. Wastegate settung's issue
  123. Mitsubishi Colt CZT EDM need XML definition
  124. Car dies at idle when AC is on
  125. CHECK ENGINE LIGHT fast flashing, but log showing NO KNOCK
  126. Logging Boost with AEM X-Series 30-0306
  127. Knocking Issue.. Evo 5
  128. EVO 8 UK unknown rom
  129. Need xml definition for 90552701 (90550701+DMA)
  130. Another Evo 8 unknown bin....
  131. Unknown ROM
  132. Car starts up fine and idles but then dies unless I hit throttle
  133. High Idle - Please Help!!
  134. Mitsubishi Colt 2000 engine light
  135. Wideband control
  136. can anyone identify what is wrong?
  137. E9 tuned - problem -
  138. Rolling "Anti-Lag"/ Launch on Stock ECU
  139. 90550701 Idle Tuning
  140. EcuFlash Problem while installing PLease HElP
  141. EVO IX EDM/AUDM Speed density Tehpramod is it possible ?
  142. How to Disassemble & Reassemble Evo ECU Code
  143. H8 Ecu Disassembly
  144. adress min coolant temp for closed loop edm9/adm9
  145. 88770005 JDM evo 9 XML
  146. Flash Evo 7 GTA ROM into Airtrek Turbo ECU
  147. Grimmspeed EBC map on EVO IX
  148. fueling when driving cold
  149. Cant Find Imobilizer hex code for my 06 MR
  150. "unknown rom" tried everything need help
  151. unknown rom 88596715 evo 9 usdm.
  152. RPM Recovery Tables
  153. In need of Evo 8 speed density base map please
  154. Ceddy rom for Evo 6 TME
  155. Evo 8 tephra v7 jdm xml
  156. Launch map -- Knock!
  157. Editing Evo 8bin...no definition
  158. Tuner lock ecu and needs to be unlock
  159. 8859 SD pump gas stalling when reaching 140 degrees F
  160. Cobb 3 Port question
  161. EVO 9 Beginner Mod from Ground Up Questions ECU EVOSCAN Wideband
  162. GM 3 port wastegate solenoid not working right
  163. ALS tables on tephramod v7
  164. Afr going richer gear by gear
  165. I need the tephra roms and xml 90550001 v7 for evo 7 jdm
  166. Returning The Tactrix OpenPort 2.0?
  167. Montero mods
  168. Ecutek camshaft ECU flash
  169. cant change scaling for BDEPSI over to omni 4 bar on 9653 Rom
  170. Looking for some definitive scaling values for GM IAT
  171. Logging issues
  172. Need help with IPW added table
  173. WGDC Correction Wrong address?
  174. can't recognize rom nor find the correct xml for evo 9
  175. My 6062 car on maf idles rich like mid 11 afr on ID2000
  176. Definition file Help needed $$$
  177. Base map
  178. JDM Evo 7 ROM - 90556701
  179. high rpm knock on transistion from low to high throttle, fuelling not keeping up
  180. Tscomptuned?? Are they still around?
  181. Is this real knock?
  182. High knock on 4th gear.
  183. Novice trying to find my ROM ID using Hex
  184. Knock and log evaluation
  185. Evo 8 Tephra v7 JDM Version (96260009)
  186. Thermo fan sensors
  187. SD throttle let off rich condition
  188. Question regarding injector scaling relating fuel table values
  189. Retrofit a EVO X MAP sensor on a Evo IX
  190. Another Dwell Time Question
  191. Thinking about enabling my launch map on tephra v7
  192. EcuFlash - Scaling Issue
  193. Cant read my Rom
  194. idle issues
  195. How to disable fuel cut on decel?
  196. evoscan and ecuflash evo 9
  197. i'm searching 2009 1.8 cvt lancer .xml file
  198. ECUFlash issues
  199. Fuel trims O2 feedback 24s
  200. Tephramod v7 Switching problem
  201. Lean tip in
  202. Recent tune reading 9+ knock..
  203. EVO 9 timing maps issue (Redundant Fields)
  204. How to Limit Max WGDC in TephraMOD v7 88590715
  205. Evoscan Map Tracer
  206. Look for Stock 8/9 Roms
  207. High Load Figures, 368!?
  208. emission state inspection cal id
  209. EVO 8 bench flash pins correct?
  210. evoscan on bootcamp logging afr's
  211. Siemens Deka 80lb scaling
  212. Deq catalyst heater ready?
  213. Tephra Rom evo 7
  214. ECU Flash will not flash my Evo 8
  215. Need edit my edited file
  216. Airtrek ECU Definition
  217. Speed Sensor Failure
  218. Issues regarding load logging with an evo 8
  219. Version 1443721 > not under win10...
  220. evoscan+ecuflash=fail
  221. Question about Ceddymods
  222. Guidance to lean the mixture from 5000rpm to 6500
  223. Need some guidance (Stalling issues)
  224. EvoScan - Excel files repeats values every 27 cells
  225. Can someone help me with Launch map? 35 counts of knock
  226. Evoscan not logging boost correctly
  227. EcuFlash setup help
  228. EcuFlash tables values are all jacked up
  229. Tuning not affecting the car.
  230. Evo 6 GSR Memmodel
  231. Airtrek 1byte engine load
  232. Evo ix pop & bangs exhaust
  233. ceddy mod
  234. sd 2.0
  235. Datalog EvoScan w/ Full Innovate Chain
  236. Easy Question
  237. Airtrek Ecuflash issue
  238. Take a look at this...
  239. Knock with Tephra V7 launch maps
  240. High Knock with Tephra V7 launch maps
  241. Load Question
  242. 9417 SD - Dies instantly after startup when cold
  243. Evo 8 Exhaust Pops + Bangs
  244. help me decipher my tune
  245. Speed Density 96534706 - What am I doing wrong?
  246. unknown rom image
  247. AEM 5 Bar Setup
  248. Car will not start without pressing the gas pedal
  249. Unknown ROM - Ecuflash
  250. 88580714 Tephra v7 Flash (Car stalls)
