PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. Severe Idle dips, HELP!!!
  2. Deatschwerks 1200cc
  3. Problem with Tephras NLTS patch
  4. WGDC drop/AFR safety gets 0..5vdc from ? pin
  5. Knock Sensitivity?
  6. Log boost with omni 4 bar map sensor
  7. logging problem
  8. ecu flash
  9. openport 1.3u firmware problems
  10. Weird knock spike and AFR dip
  11. Couple quick simple questions about tuning and logging
  12. Can no longer read/write to ecu, logging works fine car runs great
  13. injectors and sd questions
  14. How can i connect AEM W/B onto a laptop for Evoscan AFR Logging?
  15. Boost limit table for 88590715 v.7?
  16. hey guys i need help with an XML
  17. Stat rev limit on Evo7 GTA
  18. What rom id would this be???
  19. Radiator Tuning
  20. A little help picking a ROM
  21. Help configuring ecuflash & evoscan
  22. LM-1 and EvoScan
  23. ecuflash can not read my .Hex file
  24. Evo VIII ECU flashing without OBDII
  25. How to change inherits?
  26. Per cylinder fuel compensation looks pretty easy
  27. Best ROM ID to use?
  28. SD: 3d ve table
  29. nlts question
  30. SD: aem 5 bar sensor scalings
  31. P0601 Car in limp mode
  32. how does the "SD MAP Sensor VE and Calibration" table work?
  33. 1byte load restting under WOT?
  34. Fuel trims and P0171 headache
  35. ecu board number - which ecu is it ?
  36. EGR duty cycle Evoscan definition?
  37. How to flash o2 sensor back onto the ecu???
  38. ecuflash & evoscan files
  39. EGR Delete still getting P0443 P0403 P0090
  40. Logging Boost With Defi Sensor
  41. Updated 96260009 xml
  42. Converted to SD now CEL codes wont go away
  43. my first evo, ecuflash/ evoscan help.
  44. Got some logging done for the 1st time !!
  45. 88580014 MUT Address for LoadError & WGDCCorr
  46. Loss of communication?
  47. Help! ECU reads the value from another column
  48. where to begin with this log?
  49. Ecuflash, deleting a user created table
  50. How do I enter a hex value with a decimal point?
  51. FIC 2150cc High-z pump gas stock ECU possible?
  52. turbo boost error correction table
  53. Low load values
  54. Injector duty cycle question
  55. EcuFlash definitions
  56. spool tuning - how to ?
  57. AFR x Load Clarification- updated
  58. Need help with a question
  59. Timing issue? I think... Please help
  60. How do I tune with EcuFlash then write files with EvoScan?
  61. Walboro 255 ecuflash edits ecu edits ?
  62. Can't pull rom
  63. Ful cut but why??
  64. New to tuning a lot to take in check my rom.
  65. Getting started with logging and tuning. Some questions
  66. How to set ECUFlash baud rate to 62500?
  67. DSMs in need of CeddyMods development improvements
  68. AEM 5-bar with Stock ECU
  69. need help with ecuflash
  70. Need help finding Closed Loop-LT Trim address
  71. Tephra v7 alt maps
  72. ECU Boost on JDM Evo VIII
  73. ecuflash problems
  74. which table
  75. cant log fuel trims
  76. Where to begin with this tune?
  77. Questions with EVO 8 ECU in EVO 4
  78. do these tables look ok?
  79. Running Rich?
  80. Evo Scan real time graphing question
  81. EGR DTC codes after EGR delete
  82. Folding mirrors in when ignition is turned off
  83. V7 - EGR delete: Periphery
  84. Need help with idle issues
  85. getting fic 2150 to idle 14.7 not 11.5
  86. Tephra Alternate Maps How To?
  87. help with tephra please!
  88. Brain fart
  89. Why does my car suck so bad?!?!!
  90. 1 byte logging wrong values
  91. Actual AFR's to match AFR on fuel map?
  92. Hopefully a quick fix
  93. Do I need a retune??
  94. Weird timing issue
  95. smog law changes for 2013 in CA
  96. 88570008 Baudrate tables
  97. EvoScan 2.9 version needed
  98. please look @ these maps
  99. DMA 93660005 for 9626 V7 False Knock Analysis
  100. Need a little direction on setup pre ecu flash (gurus please chime in)
  101. evo 9 alternate maps not working
  102. installed 2150, no injector pulse
  103. 56890013 is this normal?
  104. ECU flash disconected during a flash and now I have a cell
  105. O2 Sim patch 88840016, 88840017
  106. 2006 Evo IX RS
  107. stage 1 EVO x noob questions
  108. Misfire, car running bad
  109. a few questions with my tune
  110. What first?
  111. cant load tephra v7 in ecuflash directory
  112. Help!!! Car leaning out!!!!
  113. bricked ecu
  114. Link to download Evoscan ?
  115. EcuFlash won't connect
  116. Evoscan/Ecuflash wont connect please help!!
  117. can anyone help me confirm map locations?
  118. tuning tips for 272s and smog
  119. How to Delete CEL Codes
  120. symptoms of a dead front o2 sensor?
  121. Evo8 ECU No Response Error... AGAIN!
  122. Why won't Ecuflash interface with my laptop?
  123. Help: Ecu write stopped in middle, cant flash or read and car wont start now
  124. reading rom from ecu?
  125. What the hell just happened!
  126. Evo VIII ecu to power a 3SGTE
  127. Is your cable finicky?
  128. Baselines for ECUFlash
  129. Anyone Provide Tephra conversion service
  130. Worth tuning yet?
  131. How to set up Tephra V7 with Omni 4 bar
  132. Tune to safe wot after cam install help!!!
  133. Tuning MAPerformance Rev3 w/FB TB/Ported stock log mani Q's
  134. Questions on 3d VE map, cold start, idle hang, live map?
  135. noob tuning help
  136. New exhaust, how will it effect my tune.
  137. Need to find closest tuner
  138. Timing and knock
  139. Issues reading ECU with ECUFlash 1.42 and 1.3U cable
  140. How do you keep track of your roms?
  141. Need please teprha 4.1 or 4.2
  142. FIC 1450cc scaling problems
  143. Post your tuning and monitoring setups!!!
  144. Imma noob!
  145. Can read nor save my Evo 8 stock ecu ROM
  146. V7 96532706: Car leaning out once warm on cruise. How to stop?
  147. Tuning Question
  148. Need Some Help Wrong Rom
  149. How to fix negative Fuel trims in SD?
  150. Self Tuning questions
  151. tuning help. evo 9
  152. evoscan ?
  153. SECOND O2 DISABLE wich BIT to CHANGE?
  154. 2 Byte RPM not working in tephra v7
  155. stock ecu anti-lag
  156. Logging GM IAT on SD wired to MAF harness
  157. ECUflash error
  158. Another fuel trim absence thread
  159. Fuel / Boost Cut?
  160. Injector Maf Scaling Help
  161. Tuning for MAP REV.3 and FB TB Q's.
  162. 88590016 ROm XML needed!!
  163. reflash ecu questions!
  164. in search of missing "Load"
  165. help needed - 'Ignition Coil Charge Time'
  166. question about afr's ?
  167. Is evoscan logging 2byte load for me?
  168. 05 Evo8 fuel cut only in 1st gear?
  169. Issues interfacing with car on Evoscan & ECU Flash
  170. wanting to learn how to tune
  171. Evo 8 ecu idle issues (2g DSM)
  172. Did tons of searching, 90550001 GM IAT patch?
  173. Tephra V7 OBD Inspection.
  174. Evo8 Working No Response To Known Codes?(Solved, somewhat)
  175. More than -10 degrees required in JDM rom 9626 v7
  176. idle issue after fic 1100 install
  177. Looking for tactrix cable
  178. thanks
  179. HELP...how to log load evo 6..
  180. Question on alt. maps
  181. boost control maps
  182. Tephramod Questions
  183. RPM/Speed to gear for RS gearbox
  184. Yet another cant connect to ecuflash thread.
  185. Injector shut-off map
  186. Just started tuning!
  187. about to give up
  188. Speed Density IAT options
  189. HEAD gurus
  190. My tune, any thoughts or ideas welcome.
  191. Disable ALL DTC codes?
  192. hows my tune?
  193. boost leak vs injector scale
  194. JDM 8 - Lean Spool addresses & scaling for 96260009 (96260709)
  195. Is this a good tune or a n00b tune, please scrutinize (ROM included)
  196. Test pull - how does it look?
  197. Finally got ADC0F Map Switching working on 88590715
  198. To tephra or not to tephra
  199. Track day Evo vid: Gopro + remote mic + logs
  200. DLP-IO8 Data Logging
  201. fuel pump low/high voltage transition table
  202. AEM 5 bar xml file / what volt settings?
  203. Delete
  204. Cause of the IPW Jitters on SD
  205. full closed loop possibility?
  206. Fuel Maps
  207. Help! Heater on and RPM goes up
  208. RomDiff tool
  209. Need Help Viewing MUT
  210. 1st SD tune attemp
  211. hell of a hard time scaling FIC 1550 need a little help
  212. Knock after WOT. please help
  213. Evoscan estimated WHP
  214. Guru needed!!! using bcs pwm signal for secondary injectors?..
  215. Misfiring on Lift-off changes.
  216. Very Rich on takeoff
  217. ecuflash/speed density help
  218. Can I put a EVO 9 AUDM ECU into an AUDM EVO8?
  219. Really weird things happening after ECU swap (reflashed same ROM)
  220. quick help in SD conversion
  221. Timing pulled on trailing throttle
  222. Strange load reading
  223. Anyone able to read 96260012?
  224. Tephra 7 full boost when cold 96260009
  225. How do you get the choppy idle?????
  226. Anyone seen this before?
  227. Readiness Monitors With Tephra V7
  228. Anyone recovered a Evo 5/6/DSM H8 ECU?
  229. Mid RPM phantom knock
  230. bad timing and fuel maps?
  231. My fuel and ignition map... Thoughts?
  232. stock 560cc's question
  233. openport 2.0 troubles
  234. Tephra NLTS Problem - Have searched.
  235. Knock at tip in from coasting
  236. XML for my ROM on diffrent laptop?
  237. I'm after a TMR 220 map, can anyone help?
  238. SD - stall after unplugging MAF
  239. Tephra NLTS mod pros/cons
  240. phantom knocks? logs attached
  241. Full build, idle very rich. learning.
  242. Idle controll for 2011 Ralliart 56940007 - Need def's ???
  243. Cranking Enrichment def's for a 94170008 Rom???
  244. what is "Idle Error" table ?
  245. Testing Boost Logging with Omni 4bar
  246. V7 E85 starting table Q's: 96532706
  247. NEED HELP ASAP! Just tried to change idle and now car won't start!
  248. WGDC ? - Boost tuning V7
  249. Out of Control Enrichment During Acceleration
  250. Ecuflash periphery bit differences?
