View Full Version : ECU Flash
- Quick engine load cell question
- question
- On the fly adjustable boost w/ GM3 port?
- P0300 override code?
- Injector size scaling
- Ecu-boost : Stock Solenoid with pill VS GM boost solenoid
- Switch from AFC to Flash?
- Injector Latency - Warm start problem
- Lift-off Stalling
- Maximum load value on stock ECU?
- Using ECUflash
- logged: MBC vs ECU-boost (stock solenoid)
- logged: MBC vs GM 3port ECU-Boost
- How do you run 24.5psi on 91 oct???
- Twin BCS tuning?
- 1200cc injectors with stock ecu
- mitsulogger cannot innialize...
- 94170008 2Byte Load/RPM/Airflow Not Working!
- 88590015 Idle Table Conflict
- question about timing around idle with cams
- 2byte load on LOGWORKS2
- EVOSCAN 2.1 Maptracer Problems!
- 2byte AirFlow 88840016
- ECUFlash Maps in Excel - many decimals?
- Boost Cut/ Spike
- Well set-up ECU-controlled boost
- evoscan incorrect dtc list air intake, engine coollant, presure sensor, knock sensor
- New evoscan bad news for me!!!
- Which cable is better?
- AM ECU Unlocker 1.1
- So i plan on doin a self tune...few questions
- DMA source code - techie thread - for interest only
- Xml help.
- Newbie-Need Help on getting Evoscan 2.1 running
- Serial number for 2.1
- beginner tuner:
- 10,000 rpm on flashed stock ecu??
- Can't seem to work out knock on spool up
- A few questions on this log
- Immobilizer code - other reasons
- Car is Pissing me off! Help!
- Official 2 byte thread!
- Opinion on log and fuel.timing maps
- evoscan 2.1 problems and fixes
- Logging JDM MAP sensor on JDM Evo?
- evoscan 2.1 and coolant temp
- ecuflash 24 psi tapering 21 psi redline, which spark plugs???
- speedometer correction
- I need some serious help
- Power options for LC-1?
- Mitsu 3bar MAP sensor
- OpenPort Universal or just Mitsu?
- LM1 vs LC1
- Boost /fuelcut at 20 psi
- Help with CEL
- Tested: Number 67 Pill
- SAFC, Advantages to using ECUFlash instead
- whats so special about 96940011?
- help with tune
- Mitsulogger requestID file Question
- need input on evoscan logs.
- Load Required for CEL on Knock -- Tephra Mod Question
- Evocan help
- help, laptop stolen, need evoscan.
- logging 2-byte w/ mitsulogger.
- Am I missing something here?
- problem with ecuflash 1.34
- Idle Problem After JDM MAP Install
- Saving Stock ROM with CEL
- Start problems after rescaling ign map
- Problem writing/comparing/Test writing
- Tuning Evo VIII Timing
- 2.1 evoscan
- Question about logging fuel trims
- Confused "boost"
- Realtime mapping update - exciting idea from Merchgod on Romraider we could use!
- a new way to open more boost???
- help new to ecu flash boost problems
- Slow Spooling Stock IX turbo (4000 rpm)
- Help me.......ROM 92460000
- Aquamist 2D -> HFS-1 or HFS-5 ?
- How to install/use a wideband O2 sensor?
- Damn Map tracer! Need advice
- More Questions for tune my evo!
- help me with mitsulogger:
- need help with a/f at idel
- going into load based bost control, but need help
- JDM 99860002 EVO7, definition problems
- Verify some info regarding 2 byte load (Evo8)...
- 93 ocT "10% ethanol" = 13.5 AFR-WOT
- Disable clutch down to start car functionality
- Idle Surging.
- direct boost control in action
- Laptop question - Asus Eee
- XmlHandlerHelper problems
- Evoscan Logs
- pocket logger?
- how much timing increase
- Can Not Connect
- NLTS....and knock
- EGR patch request
- Evoscan formula for GM 3 bar MAP
- EvoScan 2.0 - logging HP and Torque...
- flash preppin'
- not sure if the horsepower is good..?
- ECUFLASH v1.29
- What do guys thinkof my log (GT30R)
- JDM MAP sensor vs Zeitronix Boost
- ECUFLASH Dictionary
- Hard time having ECUFlash to connect!
- quick NLTS question...
- Big cams = Injectors staying on during deceleration??
- good shop for a tune
- Which shop should I go to flash ECU (Socal)
- problem with notepad
- Spudder Problem Someone Help!
- Acronyms/Abbreviations
- Is there a way to change maps W/O laptop
- Evoscan help!
- blew away data.xml file, can you send me one?
- partial/moving throttle knock
- Load target changed?
- MAF Scaling + MAF Smoothing=AFR Adjustment
- Brian Crower 280s and Mivec Map
- LTFT mid Fuel trims don't change
- Race Fuel Tune.Info needed?
- need a driver
- ECU code & Boost & WTF
- Locking the Ecu!
- injector latency changes between 91 & E85
- Something new happened today after changing spark plugs...
- Ecuflash/Evoscan on MacBook with BootCamp/Parallels?
- need Mitsulogger
- unable to read/write in cold wheater
- 94170014 vs. 94170015
- Finding load cells
- Boost Enhancement Table Addresses?
- JDM IX Immobilzer issues (have original immobilizer code)
- Who do i talk to to get Evoscan 2.0?
- from your experience what is the best Ecu Flash
- HELP!! - Fuel Trims and O2 feedback
- Most 2004 Evo Rom?
- economy tuning
- EvoScan2.0 writing weird log files...
- Anyone using an Asus Eee PC w/EcuFlash?
- LTFT Low, Mid and MAF Scaling
- Knock on deacceleration??wierd
- Can somebody assist me for inputting this log into the DLL?
- Evoscan maptracer help, again
- Car Idling really rough, please advise!
- hp record?
- MUT Request Boost Error Correction?
- Having EvoScan 2.0 Maptracer Problems? Read Here.
- Need Help! Need definition for 07 JDM
- Updates for evoscan lap timing?
- Logging 2-byte Load
- Car acting odd after disconnecting battery...
- help in using 2-byte load with maptracer.
- Mut 86 Wgdc
- Evo IX Unresponsive to Fuel Map Changes.
- best boost control method?
- Tuning for high boost on 93oct
- IveyTune? Turbo Trix? RIPP Mods? Tuning Suggestions
- Formula To Log Gear In EvoScan?
- evoscan problem
- Speed density/MAP patch-who needs patch...
- ecuflash definition files
- This Month's Modified Magazine
- In order of importance....what's best to log w/ wideband?
- LC-1 and Evoscan 2.0 problems
- which xml file to use? HELP!!!
- What and How do we tune for maximum torque?
- zeitronix and serial to usb not working?
- Ecuflash For Evo X???
- does anybody have a map for the new evo X base, tuned, stock whatever.
- Hints for the patch writers
- evo scan
- stumped with knock...please give input
- immobilizerkey readout
- Blow Through Mass Air Meter
- Wideband loaner...
- Scrambled Map? Easy fix.
- ECUFlash Training?
- fix for "unable to connect" error in ECUFlash 1.30+
- Bought a car with a scrambled map
- 94170008 def error and fix
- EcuFlash installation problem
- Normal Range For Fuel Trims +/-
- Can we use evoscan and/or mitsulogger to adjust basic Idle?
- Need Ecuflash 1.29a!!!
- .xml file help
- tuning percision 780s
- Samco intake hose driveabilty?
- ECU does add timing...discuss
- Tactrix cable and PDA/Pocket PC - working logger
- Idle Trouble
- Scaling Injectors SUCKS!!
- how to read hex from 1.1w to 1.34 program?
- How To Log Boost With GM 3bar map sensor?
- More Problems?!?
- new evoscan templates
- Cosworth IX Idle Problems...
- ODB Port Help
- ecu unlocker 1.1 w/1.34?
- Stft/ltft
- EcuFlash: can xml tables be written for use on other vehicles?
- MAF vs MAP & other tuning issues
- EcuFlash help
- Went to the track last night - 12.3 Log inside
- JDM Evo IX GSR Rom Stock
- Ecuflash help
- Lean Spool Trailing Time
- Can I share my Evoscan with my 1g DSM
- Tactrix Universal or not?
- baseline MIVEC degree?
- Lowering Coolant temps
- Peak torque
- Cable for Ecu flash
- EvoScan + PLX M-300
- Pre-boost tuning
- Pro tuner using ECU boost control?
- Free Evo IX Maps from EIP Racing?
- Service engine light help!
- Disabling Speed Cut
- anyone have a "Stage 2" map?
- Running rich between shifts
- Which WB?
- Evoscan Maptracer Issue
- Mellon Tuning
- Evoscan and AEM Uego
- lil help EvoScan v. 99
- Help with fueling issues
- Rpm neutral and drive correct values?
- EDM MAP sensor
- Error in tables ecuflash in idle...
- IC Water Spray Function
- ecuflash stopped working...
- Does anyone usually use the "accel enrichment" table?
- Definition file for EVO 8 JDM 2003
- Accuracy of logged items
- Evoscan: bhp & torque readout
- how to reset ecu if original map is lost???
- Dumping fuel and knock
- 8 map
- Another source of knock discovered
- patches not saving in rommetadata for 96940011
- Conflicting opinions on tuning – Just lay it out please
- Can't get my ecuflash to work after update??
- load rescaling and knock sensor filter maps
- Just got tuned
