PDA
View Full Version : ECU Flash
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. What's the general consensus on a blow-thru setup?
  2. evo ecu on evo 3
  3. 2006 Eclipse, manual trans, V6
  4. Idle tuning - question/advice
  5. ACD/ABS dash lit flashing
  6. Idle Stepper Look Up Table Findings....
  7. valet patch
  8. TPS adjustments or tables?
  9. accelerator enrichment = too much
  10. Cannot read from ECU (searched)
  11. Ok driving to 9k feet on sea level tune?
  12. 88580014 Stuff Required
  13. Viliv S5 UMPC review
  14. Innovative LM2 EVOSCAN support?
  15. Hitting higher loads now and wondering what do I need to do to accomodate ?
  16. injector and ignition logging
  17. Engine Trouble Code Cycle Time?
  18. Evo9 FP Red Timing Maps/Fuel tables
  19. Searching for tephra mods on 99270000
  20. Mitsulogger v2.0 Beta 1a Released
  21. Running full time open loop = no maf needed?
  22. egr/cat monitoring disabled in rom
  23. removing rear o2 sensor
  24. EvoScan 2.5 issue...
  25. OmniPower 4 bar settings
  26. How to compare ROM Metadata from 2 different ROMs
  27. How do I remove the load an IPW caps?
  28. tuning in WA?
  29. how to run a ics button on a 05
  30. FIC bluemax 1250 - any input on pump gas?
  31. Fuel Cut Ignition Timing Retard
  32. Wish I had an Evo but issues with Evoscan
  33. Evoscan Logging Problem
  34. Searched but found no exact answer.
  35. Patch Request: Improved 2-step control/resolution
  36. Ecu boost control inop
  37. Evoscan disconnecting during logging.
  38. Logworks 2-byte load problems
  39. airflow 2-byte mod for 96260009
  40. evoscan error msg
  41. Am I supposed to be hitting 300 load cells???
  42. VP12 PErformance chip
  43. Upgraded to 1.41 and lost info...
  44. ECUFlash and Wide band logging
  45. tactrix sd card logging any closer
  46. Car does not start with tephra rom 9626009
  47. Tuning for maf pipe?
  48. Ecuflash can write but not read
  49. terrible startup.
  50. Two installs of same ECUFlash, two different 88590015.XMLs :(
  51. get rid of rich dip at WOT
  52. Problem with Ecuflash
  53. very simple question: better fuel economy??
  54. psi based boost on a BBK?
  55. Timing Question:)
  56. Running 2 different versions of ecuflash...
  57. PLX R-500 wideband
  58. how to switch to 90550001?
  59. Periphery bits - advice required
  60. 89280002 rom ID
  61. Running e85 at 12.5 AFR WOT
  62. which parameters to log for tuning timing?
  63. What does "inheriting evo9base_20081101" mean in Task Info field?
  64. Imobilizer Delete anyone?
  65. Info on some things
  66. EvoScan RPM skipping
  67. Activating 2-Step
  68. ISCV control system disassembly
  69. VIII patch to reset fuel trims?
  70. Injector latency base?
  71. Ecuflash + Mitsulogger
  72. 0011 to 0006 Conversion Problem
  73. Tuning with LS enabled
  74. Training Videos: How to tune an Evo with EcuFlash
  75. 4th gear log to sink your teeth into
  76. Oh dear...
  77. Are these 1byte load spikes normal?
  78. EvoScan v2.5 USB error / issue
  79. CA Smog Check
  80. Narrowband voltage in Evoscan
  81. Common Roms
  82. front 02/closed loop disabling.
  83. Standalone User - Help me understand the stock ECU
  84. ACD Pump: all 3 acd lights on - fyi
  85. HELP: Evo 8 Rear o2 heater circuit patch
  86. 03 jdm evo 8 (car running rich after tbe)
  87. EvoScan Map Tracer - Alt-Maps (and standard maps)
  88. Evoscan error... New 1.3 cable + Logging wideband
  89. Mivec and timing numbers to promote spool
  90. Stationary Rev Limit
  91. Weird 96940011 to 96530006 issue
  92. Found - New items to log
  93. Weird issue at idle and cruising! Not the common one you always see. Please read!
  94. need help with evoscan!!!
  95. Trying to determine software for gauges...
  96. How Do I Fully Uninstall Tactrix/Open Port FTDI Drivers?
  97. keep throwing p0171 with bosch 950cc
  98. VERY ODD - JDM EVO 8 MR MAPs (how can this be?)
  99. Best ECUflash version
  100. Fuel light/cell adjustment
  101. Mitsulogger 1.6 not working
  102. Weird Knock Issue
  103. Load went nuts!
  104. unknown rom image - jdm evo 9 mr rs
  105. Ruining in open loop for idle??
  106. Mid Trim adjusting at idle?
  107. Need help switching 94170008 to 94170015
  108. need help ALS
  109. Rich Idle and Cruise AFR's since injectors
  110. need to figure out AC signal.
  111. Knock on shifts.. Help
  112. Need help re-flash my evo vii gt-a
  113. 2 byte mod XML problem
  114. FS: 2 JDM map sensors
  115. E85 Tuner
  116. Too rich AFR's causes knock?
  117. USB to Serial Adapters That Work
  118. No start after flash (experts please)
  119. couldn't add timing with 264/272's over MR cams??graphs
  120. Lift off knock
  121. Knock between 2800 and 3000
  122. Can 12 V ICS pinouts support any power?
  123. Setting Up Larger Injectors
  124. Mitsu 3-bar MAP sensor calibration
  125. ROM's and some questions.
  126. Can't Download latest version of EVOSCAN
  127. Etacs rom
  128. Can not read/write to ecu...not locked
  129. ecu locked
  130. openport 2.0, ecuflash 1.41, and evolution 9, not working!
  131. MAc book
  132. Found - LT Fuel Trim Control !!!
  133. Lots of timing advance for low end - Comments ?
  134. New to this, Help wanted.
  135. Boost control with Ecu
  136. Noob question re Alt Map Swtiching
  137. disable idle test
  138. idle test
  139. idle test
  140. switch to 88590015
  141. EvoScan stops logging AFR?
  142. knocks
  143. Load dipping issues
  144. Netbook - opinions
  145. PO125 issue
  146. EVOScan - Injector Duty % issue
  147. P1400 After installing the JDM Map
  148. Timing pulled until fully warmed up
  149. MIVEC with cams/stroker/large frame turbo
  150. Omg nlts.........
  151. Making the car run better in the Heat with the AC
  152. Noob needs help!
  153. Interesting MAF based datalog
  154. evo 7 launch control
  155. which tables need to edit ?
  156. Trying to change only rev limiter
  157. evoscan cable question
  158. NLTS patch is awesome!
  159. so ... Lets play wont my car start???
  160. Found - Short Term Fuel Trim maps
  161. Hard Starting with New Injectors
  162. Help - Bogging when cold
  163. Inconsistent IPW's sometimes causing smoke on spool? 90550001
  164. Question: Load Scaling NA to Boost
  165. ECU works but now I cannot flash or read
  166. EvoScan Error
  167. Maf Scaling Offset Address for 9417008
  168. Evo 9 boost
  169. Changing mininum speed on launch control?
  170. EcuFlash BUG on E6 GSR ECU !!!
  171. where to find boost definition for ralliart
  172. PTE 1000cc Driveability
  173. evoscan error question
  174. A/C fan threshold
  175. Timing/Fuel map for Reverse Gear ?
  176. Need spare 0-5v logging input???
  177. LC-1 Signal oszillating
  178. Evo X maf?
  179. anti-lock brake light blinking with evoscan cable
  180. Any ideas on what could be causing this?!?
  181. P0170 Fuel Trim Bank 1 Fault Code
  182. Evo7, Tephra RA rom / current map.
  183. HELP!!!!! 3 port GM boost solenoid
  184. AFR's with CAT
  185. Fuel Sender/Pump connector??
  186. Gm maf/maft ?s
  187. AFRMAP not matching real values
  188. Injector Scaling and 14.7 AFR
  189. Evoscan disconnects during full throttle
  190. help with 2 byte load for 98640014
  191. 94170008 to 94170015 potential problem found
  192. hwo to add a new table?
  193. Need disassembler's help — top clutch switch
  194. latency increments??
  195. Tuning Fuel 2009
  196. Evo 9 Wagon GT-A rom?
  197. Closed loop control
  198. Found: Purge solenoid duty @ MUT_4A
  199. Do all 8&9 ECU's have an ICS light output?
  200. Bought license 9 days ago, still nothing from Evoscan?
  201. Electrical Connectors and Pins?
  202. Evo 8 MR ECU Pinout
  203. unable to connect to vehicle interface.???
  204. P0135 CEL Fix for 90550001/98640014?
  205. Innovate LM-2 analog out into Evoscan
  206. Evo 9 ECU pin removal tool
  207. How does this E85 Timing Map look?
  208. Largest Injectors being run on stock ECU?
  209. Found: code that transfers injector times to the hardware
  210. 94170008 stock rom from 2005?
  211. stationary rev limiter
  212. Individual cylinder knock test - initial results
  213. Stock Flash for 88590015 ?
  214. EVO 6 logging 2 byte load?
  215. Newb to latencies and trims
  216. Ecuflash incomplete definition
  217. Wrong RPM reading after 011 to 006 switch for the 05
  218. Hitting a max value for EvoScan AirFlow
  219. Added free flow CBE, how should I tune ?
  220. A/C Logging and RPM control found !!!
  221. ROM tables hosed with Ecuflash 1.41
  222. Factory ECU Dual Pump Control
  223. Knock Sensor Sensitivity VIII VS IX
  224. Cobb ap
  225. How does the ECU interpret Beyond Tables?
  226. Cyl # index found
  227. Rich AFR's after shifting to next gear.
  228. 96530006 can't logg trims
  229. Misfire or Load Limiter?
  230. 2-byte Injector Pulse Width
  231. Issues and problems
  232. JDM MAP sensor and altitude
  233. Mut Monitor V2.0 Released 12/04/2009
  234. Coil on Plug - std ecu
  235. Imobolizer code?
  236. Logging data for Horse Power
  237. completely given up on trying to tune and log
  238. how to unblock a ecutek flash
  239. 91 oct at 5000 ft. what do you think?
  240. EvoScan v2.6 Beta11 now supports EvoX and OpenPort2.0 datalogging
  241. Post your ETS intake maf scaling
  242. P0125 Trouble Code
  243. help me understand my logs ...
  244. Speed density users, accel enrichment tip
  245. PTE 880cc Scaling help
  246. GTA downshift ignition retard / multimap ?
  247. Why is there no scaling in maf tables?
  248. tactrix 1.3 vs 2.0
  249. I need old ecuflash version
  250. Parse errors in EcuFlash
