PDA
View Full Version : Lancer How To Requests / Questions / Tips
Pages : 1 [2] 3 4 5 6 7
  1. need help with switch and button start
  2. evo exhaust
  3. Crank Pulley Help Please!
  4. Need help replacing headlights
  5. Frankenstein Axles
  6. 02 Lancer ES, would like cruise control.. aftermarket or is oem plug n play?
  7. help finding where this part belong to?
  8. Exhaust question
  9. Exhaust compatibility question
  10. What's your opinion?
  11. What seats will directly swap into a 05 ES
  12. Quick question! Please read..
  13. car wont stay on
  14. oz rally after market exhaust??
  15. '03 OZ side and rear damage help
  16. 2003 lancer oz shuts off while idling/driving
  17. Q: DownPipe Size on 02 Lancer ES
  18. Changing Speakers on 03 CG
  19. '06 Sportsback Rear Wiper Blade
  20. Replacing my exaust system
  21. Smoked lights
  22. 4g18 to 4g92 transmission swap HELP!!!
  23. Torque/compression problem!
  24. Exhaust Manifold Replacement
  25. Evo exhaust on my rally
  26. 07 Lancer ES Air Filter?
  27. Exhaust Manifold/Catalytic Converter Mod
  28. instrument cluster help
  29. valve cover gasket
  30. CF hood
  31. How to take off center pillar on oz spoiler???
  32. Ralliart shift knob for my OZ
  33. electrical problems
  34. Replacing Interior Carpets / Roof Liners
  35. New Muffler?
  36. Lowering my OZ
  37. Trunk Wont Open after evo style wing install
  38. Bolt on Evo 7 or 8 body kit for 03 lancer es
  39. Newbie exhaust question 06 lancer
  40. 2009 Murdered Out Lancer GTS help!!!
  41. ?????Parasitic Drain on 02 Lancer OZ.
  42. Possibly have to replace A/C compressor?
  43. Custom gauges
  44. Is it possible to paint over a Carbon Fiber Hood?
  45. Suggestions on where to order a Camber Kit online for a Mitsubishi Lancer OZ 2004?
  46. Will a 06 oem sunroof assembly work to replace a 03?
  47. How to Instal Sparco Mud Flaps?
  48. Short Shifter
  49. Question about an Evo Gauge Cluster
  50. Will a 2006 ralliart bumper fit a 2006 OZ?
  51. What I was told about my lancer es
  52. need wiring help
  53. Question about "The BIG 3"
  54. Suggestions
  55. I want it LOUDER!
  56. Need to install a new Radiator Support
  57. Performance Mods 02 ES
  58. Going wingless
  59. Steering Wheel, will it fit?
  60. Modification
  61. Valve cover gasket
  62. Best mechanic
  63. body kit...or just bumpers
  64. Spectre CAI Fabrication QUESTION
  65. Folding Back Seat Down
  66. Redoing Front End
  67. Question on installing fuel pressure gauge sensor.
  68. paint job?
  69. Help!!!!!!!!!!!!!
  70. Euro style headlights for 05 lancer
  71. Spyder Header...
  72. flex pipe issues
  73. Dash Gauge lights not working
  74. How to replace struts on a Lancer
  75. Stalling bad?
  76. Evo 7 body kit on 03 Lancer ES
  77. Looking For New Wheels...
  78. Automatic Intake
  79. 2003 Lancer OZ dome light question..
  80. Interior & Exterior Ideas?
  81. Fuel Upgrading??
  82. Exhaust Question
  83. Headlights and Tail Lights
  84. Crankshaft pulley bolt
  85. 03 Lancer OZ RALLY- Transmission Fluid
  86. Alternator pivot bolt nut...
  87. stock oz shifter question. just bought an ebay ss
  88. Exhaust Questions !
  89. online store to buy parts for OZ rally 2007
  90. 2002 Lancer Es Rear Bumper Help
  91. 03 lancer oz rally---lubrication
  92. 03 lancer oz rally grill question
  93. Stage 1 Clutch
  94. Should I buy this car?
  95. engine... struggling?
  96. Lower Control Arm Bolt :(
  97. Painting Rims
  98. Suspension Question..
  99. noob exhaust question :)
  100. Heatshield for K&N SRI
  101. 03 Lancer OZ Rally..removing/installing bearings
  102. 03 Oz Sideskirts?
  103. 03 Oz crossmember
  104. How to/Where to mount HID Ballasts?
  105. 2003 Mitsubishi Lancer OZ rally Questions
  106. sunroof
  107. Lancer OZ Rally Questions.
  108. Headlights
  109. LOST and looking for help!!
  110. LOST and looking for help!!
  111. Stock Muffler
  112. 2002 oz rally to evo conversion
  113. 2003 Mitsubishi Lancer OZ rally Questions
  114. am i missing anything?
  115. throttle body help please
  116. evo scan flash!
  117. Wheel Lock?
  118. OEM genuine release bearing
  119. ralliart curious
  120. black or dark blue?
  121. Help! can you paint eye lids ?
  122. Need stock radio bracket/holder
  123. Lancer 2004 eye lids PLEASE
  124. Brands
  125. New to the Lancer Family
  126. timing belt install PLEASE HELP!
  127. 2006 Lancer SE Spoiler?
  128. Rrm postage question
  129. advice on exhaust and headers?
  130. 2003 Mitsubishi Lancer OZ rally Questions.
  131. Anti rattle brake clips request
  132. 4x100 wheels for a 05 lancer
  133. Why should i get a lancer Oz when i have a civic already?
  134. Replacement Parts Needed
  135. Tranny liquid leak, cooler line strip from radiator
  136. Throttle Body
  137. Ralliart Lip Kit?
  138. upgrades for 2003 lancer ES?
  139. Need help
  140. RRM Light Weight Pulley?
  141. Installing Headunit
  142. Projector Headlight Alignment
  143. Ignition Coils
  144. gauge cluster bulbs
  145. Painting. Interrior
  146. Headlights
  147. OZ Rally badge
  148. 02' OZ Rally Hood/Front Bumper
  149. Help needed: 03' OZ Rally Clutch Replacement
  150. Sounds from dash..in 03 oz
  151. RRM Piggy Back (ECU)
  152. Fire Extinguisher Install
  153. 2002 Lancer door panels
  154. Know your car, Know the owner, know yourself.
  155. From ES to ralliart to evo compatibility
  156. Question on lancer steering wheel
  157. (Newbie)Help with my 02 oz lancer
  158. Looking at an '03 OZ
  159. Sound System Rewiring
  160. Camber Kit Caster Plate
  161. 02 OZ rally
  162. drip molding
  163. 03 Lancer ES or OZ Rally, First Car?
  164. How would you go about fixing this?
  165. suggestion on mud flaps
  166. Finding Turbo Parts in Canada
  167. lancer 05 executive model
  168. 2003 Mistubishi Lancer ES Head Torque Sequence, HELP!
  169. 2003 Mitsubishi Lancer OZ Rally Radiator Support Installation
  170. How do I make my horn work again?
  171. Fitting question
  172. How to replace the expansion valve on a 2002 OZ Rally!! Help!!
  173. Notorious HVAC Temp Control Problem!!
  174. How to tap into the dome light?
  175. Power Mirror fuse?
  176. Sparco Steering Wheel Help
  177. Why did Mitsubishi have 2 different bolt patterns? OZ vs LE/ES?
  178. Boosted 06 ES help?
  179. JOB:4g94 front end break down to bell housing
  180. A/C System Replacement???
  181. New to the Tuner Game
  182. 2004 Lancer ES (Yellowing)
  183. Need Sub Help, 2004 Lancer ES
  184. Question regarding ES to EVO 8 GSR cluster swap
  185. Changing Rotors
  186. lancer 2002 ignition coils HELP
  187. Helping Relocating 2002 OZ 02 Sensor???
  188. Looking for help regarding my gauge cluster.
  189. How to install a clutch
  190. New to modding need help/advice
  191. I really need help!!
  192. rally-style lights
  193. Front motor mount help
  194. 2004 Lancer Headlight removal
  195. Drain plug leak
  196. 02-06 body swap possible?
  197. engine upgrade
  198. Evo seats to Lancer: Seat Lowering Brackets
  199. **urgent** ch lancer door trim help!!!!
  200. Bottom rear EVO seats on a OZ rally 03
  201. Fender flairs for a 05 CH lancer ES
  202. Noob here needing some help. (pictures)
  203. Aftermarket ES Exhaust
  204. need help
  205. Requesting Angel Eyes Headlights for 2007 Lancer ES Limited Edition
  206. Car Customs
  207. 2002 Lancer A/C Fans Not Coming On
  208. Installing Universal Rally Armor Mudflaps
  209. 2003 Lancer Lug Nuts
  210. aftermarket Front and rear fenders
  211. Ohio Turbo set up
  212. 2005 oz rally art cold air question
  213. Any suggestions on how to install my eyelids?
  214. will RA fogs fit in an OZ?
  215. Anyone know where i can get colored halo's?
  216. LED Interior Lights
  217. Do i need to replace gasket if i remove valve cover??
  218. Simple question
  219. Will this fit on my car!?
  220. Lancer OZ Rally Rims
  221. 03 Lancer Roof?
  222. New trunk for a 2005 Lancer ES
  223. EVO 8 ECU into a 4G94??
  224. Window problems!!
  225. aem ems
  226. n00b questions : 4g94 swap 4g92 mivec head
  227. Help from the gurus!
  228. I need help!!! AHHH
  229. Aftermarket Tail Lights for 2005 Lancer ES
  230. Re: Problem turning temperature knob
  231. A n00b with some questions.
  232. Opinion wanted: Fair price to ask on a Lancer needing a HG?
  233. evo 8 TB on 4g94...issues?
  234. posting question
  235. How to request: returnless--> returned fuel system
  236. Wiper Blade vaccuum?
  237. Multiple questions about bulbs
  238. Newbie Questions
  239. Evo motor in OZ
  240. Climate Control..
  241. Should I buy?
  242. Interior light problems!
  243. How are these tail lights suppose to fit?
  244. cold air intake on automatic?
  245. Control Head and Clutch Kit
  246. How to fix windshield sprayer
  247. How to Change a Clutch?
  248. Dome light/ under dash LED
  249. How To: Engine Swap Request
  250. Gutting The Cat
