- Cylinder head shave
- 2002 oz rally turbo build
- Looking for a bodykit author.
- 2006 Lancer ES Heater core replacement
- can i add cruise control to the cs3?
- Rollcage fitment
- Key Question
- 4g92 non mivec head swap problems/questions
- Need help tracking down an aftermarket bumper
- New advice for new a new driver?
- Upgrading 2003 Lancer
- Bigger injectors for 02-03 lancer es?
- 2004 lancer dash backlight doesnt work, (needles still light up)
- 2002 Lancer OZ Rally - Brake dust shield HELP! :)
- 2006 Mitsubishi Lancer Spoiler
- 2006 Mitsubishi Lancer ES Automatic Transmission
- 2006 Mitsubishi Lancer ES Automatic *Urgent Helppp*
- Clutch pedal question
- 2007 Lancer Es Exhaust tips
- Who is generally the least expensive Mitsubishi parts dealership in the USA?
- 4g63t swap 02 Lancer OZ Rally
- Lower oil pan bolt size?
- 02 a/t to 06 m/t swap
- Need info
- Evo 7 throttle body
- Question about car
- Idle Air Control Valve
- Fender Vent
- Outlander suspension??
- Gj4s swap in 03 es
- 2003 Mitsubishi Lancer oz rally exhaust fitment
- 07 ch lancer dash lights not working
- Auto Power windows
- Lancer Ute?
- Timing bearing spring Lancer 2005 auto 1.6L
- Integrated catalytic converter.
- 2002 oz fop lamps
- 2002 Lancer ES Service Manual
- Fuel rail conversion
- Havnt really seen this...
- Replacing Headlight Covers
- In Search for a engine wiring harness
- Third brake light no longer working
- Lancer 2006 front bumper fixing elements
- auto to manual performance swap
- Where to start? Turbocharging boost 2011 Lancer 4 cylinder 2.0 L
- Gated Shifter
- O3 OZ Rally - Affordable OEM Rear Quarter Panels or Rust Free Used?
- clutch pedal switch bypass?
- Will 2003 (or 4/5) evo front bumper for on 02 Oz rally
- 90k mile maintenance confused about obscure fluids. What needs change? 2003 Lancer ES
- Is Zerex Asian Mix (Blue) coolant ok for 2003 Lancer (ES) ?
- Where is the oil drain bolt? Dont want to accidentally drain transmission or somethin
- Newbie help - 2002 lancer oz rally overdrive too short
- Instrument cluster swap from ES to EVO
- How to install aluminum grill on to a fiberglass hood Dodge Ram
- OEM Evo X hood for my Lancer
- Evo 9 type rear bumper?
- 2003 Lancer Front clip swap to 2005
- Passenger Door Latch Replacement
- ashtray light and cig lighter light
- Needing help
- Unfamiliar piece found under steering wheel
- Lancer exhaust system help
- Exterior Aesthetics
- 02 Lancer OZ build, I need answers.
- 2016 Lancer GT Intake
- A/C Delete? (anyone have experience?)
- Installing foglights on a 03 Lancer LS.
- Best oil
- Lancer 2002 Auto ecu diagram
- 03 OZ Rally double din
- Need help deciding
- 02 Lancer EGR Valve Hardware
- HEADERS and EXHAUST
- Can someone measure ...
- 2003 lancer Temperature control knob
- Looking for vis racing hood grille
- A few issues with my baby...
- Exhaust
- Will a 02 LS ES Fenders fit on a 02 oz rally mitsu?
- Major maintenance marathon advice
- Arizona emissions
- Oil leak, spark plug tube seals, valve cover gasket
- Lancer ES purchase question
- Help Buying First Lancer - Want tips/feedback/suggestions!
- Question about trunk floor boad/lining
- 03 ES radiator fan controller
- Aftermarket Shift Knob
- 06 Lancer ES. Can't find parts.
- Drum to Disc Brake conversion Lancer ES
- Windshield Wiper Electrical Digram(s)
- replace radiator/front end
- 2003 OZ Rally Dashboard cluster question
- How can I stop the fan control module from cooking?
- P0442 Check Engine Code
- Need help/ suggestions
- Lancer LS did not come with fob, can I program one?
- Driver Seat cushion
- Inside trunk latch
- Need a acc link in fuse box.
- Radiator fan
- 06 lancer es lighting gone
- 02 OZ Rally Mitsubishi branded Wind Deflectors?
- 04 lancer es bulb size cig and srs light
- HELP: lowering my lancer OZ 03
- Searching for the model rims on my lancer oz rally
- my horn doesn't work :(
- 2003 lancer es stock (fuel pump)
- My 03 mistu OZ Rally
- Are the old lancer members still around??
- Overheating/Coolant Leaking Problems
- heater hoses diagram needed
- key wont turn
- Lancer ES header fitments
- 2003 OZ Warped Rotors
- UK Lancer 2004 CS_A - Keyless Entry - Is FCC ID code same as US one?
- 2" exhaust manifold to 2.5" catback exhaust
- Will an '05 ES front bumper cover fit an '06
- Temperature control knob stuck - 02 Lancer
- '03 OZ Cam Seal
- Speedometer stepper motors?
- 'Project Car' - Where do I start?
- bad slave/master cylinder? 2002 lancer ls
- Srt 4 swap???
- Evo 9 taillights on 03 Oz?
- evo drivetrane to 2003 oz rally
- OZ lip Kit (Front, side and rear) on ES 02
- 02 Lancer ES bumper cover part question
- 2004 Lancer ES Parts
- Car Seat Anchor Covers
- tactrix ecu flash tool??? does it work?
- how to/what do I need to reflash my ecu???
- hood stack i think
- ac delete help!
- 02 Lancer ES Gauge Cluster Question
- Camber Kits for lowered 05 ES
- Help with reducing NOx for smog
- Help with rev limiter
- Overheating Problem on 02 Lancer OZ!!
- Lancer OZ Front Grille
- Tips on 02 Lancer ES
- Advice on Possible Lancer Purchase
- Failed State Inspection
- Evo Coilovers on an ES?
- Location of oil pressure sending unit in 2004 Lancer?
- Mud Flaps
- '02 lancer radiator replacement
- help need some good info.
- Modification 02 Lancer
- Auto Lancer Shift Knob Problem.
- Aftermarket Aluminum Wing
- Need help identifying.
- 1.6i mitsubishi lancer 2006
- exhaust
- rear upper control arm for 2004 sportback ralliart
- body kit/hood, quarter panels, bumper needed
- 06 Lancer ES--What fuel pump to use ?
- o4 lancer es headlights
- Headlights dimming/flickering when 2000rpm's or less
- CAI for 2007 lancer es
- Aem Tail light recommendations??
- Srs catback help
- 02-07 lancer wheel fitment & clearance (lowering)
- acceleration
- 2003 Lancer ES
- What should i do?
- 02 OZ Rally headers
- In need of wiring diagram!! Help mee!
- MagnaFlow Cat Back Install
- anyone selling an evo? even a wrecked one?
- 02 Lancer to Evo8 Conversion?
- Windshield Wiper Fluid Tank - Removal
- HELP! What is the problem?
- Ralliart Grill?
- dropping an evo engine in my lancer es?
- Axle back for 2010 Mitsubishi Lancer ES
- o2 Sensors - '06 Lancer
- Any body openings in a 2004 Lancer ES to run wiring into engine compatment?
- Oil Control Valve - Weld Job OK?
- 2002 Lancer evo conversion kit
- Removing OZ Rally Lip Kit
- 03 OZ Fuel Injectors/Spark Plugs
- Motor oil / Transmission oil question.
- About vortex fins
- 2002 lancer es front bumper
- Lancer 1.3 :(
- What's a 2003ish Lancer Spoiler Worth?
- What to do with 2002 Mitsubishi Lancer Oz Rally
- Lancer Es 2005 Questions
- ralliart strut bars
- Lancer Noob Needing Help with Value
- 02 lancer wont idle after sitting for a while
- Alternator Belt!
- High rev in neutral
- Clear Instructions for Replacing Alternator Belt?
- Struts??
- Question about 02-03 & 04-06 Bumpers
- 2002 Lancer ES Cluster & Other Questions
- 2004 Lancer "Check Engine Light"
- inner turn signal always on?
- Shifter knob swap
- AC Compressor Clutch?
- Wheel Bearing Request
- Affordable Mechanics in Calgary
- Catback bolts/nuts
- Steering Wheel
- Advice on upgrade path (2005 OZ)
- Modding a 2004 OZ rally lancer
- After market stereo/head unit
- 2005 Lancer es Stereo mount
- deeper exhaust sound
- 4g94 engine ignition coils
- 4g94 dies out after throttle
- Cam and crank seals
- 2007 lancer es bumper
- 100% Pure Gasoline?
- Power steering flush and pump install
- 02 lancer Clutch Bleeder screw
- Tail Light Tinting and Exhaust Questions
- Disabling daylight running light
- a/c swap with alternator
- Yakima Bike rack clip positioning question
- Catalytic converter and exhaust manifold replacement
- Trying to do some troubleshooting
- Tips for improved performance on 02 Lancer OZ?
- What do you think?
- 04 Lancer ES Modded/gutted 12 sec 0-60!?
- A/C Compressor, drier, and expansion valve replacement
- my 2003 lancer es
- OZ Rally 03 Exhaust and other options in Canada
- Wanted: 03-06 OEM EVO Front bumper
- Removing center console HELP!!!
- 02 Lancer Es Interior Swap
- injectors
- Tail Lights...
- Body kits & Valve Cover Questions
- Ch lancer speaker sizes
- Factory fog/driving lights for 2002-03 body style?
- OBX 4-2-1 Header
- lancer oz rally head swap
- 02-03 oz wheel center caps
- Need AIR BAG HELP!
- Best aftermarket bumper for ride height
- Front bumper help, what bumper is this off
- Muffler for 2004 Lancer ES
- 03 lancer muffler
- Yet another seat question:
