- An 4g94 engine swap with an evo.
- My 2004 OZ Rally engine swap
- Coil on plug conversion?
- davidoliveira
- New here.. and in need of guidance/help
- 4g63 swap
- '15 SE - Rear fender modification or replacement
- Can I get a 5 lug hub from a different car and put them in place of my 4 lugs?
- needing help with head unit wires...
- Searching for clutch install guide
- Passenger windows no longer working, Help.
- Rear seats
- 4G63 swap into 03 lancer ES
- Clutch replacement help
- Installing Evo 8 Wing on ‘02 Lancer ES
- OEM foglight install for 02-07 Lancer
- 2002 OZ Rally Steering wheel
- 4g94 Turbo Project HELP!
- Is this fixable?
- Will the Mirage dohc 4g69 fit my 03 cs6a
- Having issues with shift linkage mounting location on 04 lancer ralliart 2.4L sohc
- Dipstick is covered in oil
- 04 Lancer ES 2.0 Throttle Cable Adjustment
- Was up ppl
- (VIDEO): HOW TO replace valve cover gasket, spark plug tube seals, PCV 02 Lancer 4G94
- Healights
- how to bleed the back breaks 05 oz rally
- Evo 8 rear wiper on OZ
- brake caliper piston won't push out
- Computer
- 4g94 rebuild
- How to Change/Remove Cat Converter and O2 Sensor on a 2002 Lancer (Non-Evo)
- new to website help appreciated
- stereo factory plug
- 02 OZ Rally to EVO front end conversion???
- Help needed to identify this exhaust manifold
- Pioneer avh2800bs VS Metra 70-7001
- Oz swap to awd
- Evo 9 steering wheel on a 2006 lancer
- Power from an O.Z?
- 2002 Lancer Oz Rally Head Gasket
- Remove trunk panel sportback -10
- Has it been done?
- Advice and opinions? 2003 Mitsubishi Lancer es engine rebuild or swap?
- Exhaust question !!
- 4G94 Head removal questions
- Lancer oz, mirage engine 1.8 4g93
- Instrument panel changing
- How to: Remove the 14mm Left Nut on Exhaust Manifold 2002 Lancer
- 2006 reverse camera installing
- Lancer 2002 oz rally evo front conversion
- auto headlight switch install
- please help!!
- turbos
- Where to plug the harness for 2010 GTS Fog lights
- (VIDEO): HOW TO fix collapsed radiator hoses
- (VIDEO): HOW TO flush radiator, replace t-stat & hoses
- Is it Possible?
- input shaft bearing on 03 lancer oz has rubber gastet??
- How to change your injector filters and install injectors
- How-To: Manual Transmission Disassembly/Assembly
- 02 lancer rotor and brake replacement
- 02 lancer valver cover gasket swap
- lancer oz
- Help on 02 lancer rear motor mount /roll stopper
- how to install mp3 cable on 06 lancer es
- How To Request:
- How to locate/replace Oil Pressure switch
- cig harness?
- 4g64 swap questions.
- Getting oz winter ready
- How to get to Fuel Sending Unit
- 03 Oz Rally Project "start
- Starting a new project
- My Lancer issue
- Cold Air Intake Install
- 4g94 to 4g64
- 02 Lancer - Dead slave cylinder!!
- (VIDEO) How To: Clean and or replace EGR valve 2002 Mitsulishi Lancer
- How to coolant bypass mod // Throttle body (video)
- Flip key for my '04 OZ
- Keyless entry writeup
- What front lips to buy??
- Roof Rack
- How much is it for a bumper, fenders, and hood for an evo x
- speedometer cluster
- evo engine swap
- New Gauge Cluster; How to correct the miles?
- Video: How to change spark plugs and ignition coils 2002 Lancer
- Turboing my 2002 Lancer
- Lancer Left engine mount
- Building my 2002 Lancer
- Will the 2004-2006 lip kit fit the 2002 lancer
- Help on 2002 Lancer lights .
- How to remove 2002 Lancer Engine Bay
- Short ram intake help pt 2
- Help installing Lancer K&N Intake
- How do i install LEDGLOW on 2002 Lancer
- Best After Market Car Deck?
- How to install window regulator/motor (video)
- How to remove drum brakes **easy way**
- How To: Install Electric windows? (Need Help)
- How to disable your DRL (04-06 Lancers)
- How To Request: Wheel Stud Replacement
- ****How To: Install your own Limited Slip****
- Lancer Body change
- 2 switch + button start mod
- Install Vacuum, Oil Pressure, and Water Temp Gauges
- how to remove dashboard to paint
- 03 oz rally auto conversion to 5 speed??? help please
- custom grill for 2002 mitsubishi lancer
- Input Shaft Bearing; NEED HELP!
- 2002 Lancer - Adjusting distributor/spark timing
- Do Luck lip
- How to: 2001-2007 Mitsubishi Lancer Short Shifter Install DIY
- coloring trim
- [How-to] EGR system check
- oz rally 2004 lip
- RRM Piggy Back
- How to install an Aux input into a Lancer Es 04
- how to- changing bulbs for an LED dash
- seat brackets
- Plasti-Dip 06' Grille
- HID Projector retrofit on girlfriends 2002-03 Lancer ES headlights..
- Lnacer 0Z timing help
- How To: Relocate Cruise Control for Evo Steering Wheel
- armrest question
- Problems W/ JDM Headlights
- Trunk Issue
- How to: Evo 8 front conversion swap
- How to remove and paint valve cover! 4G94
- How To Sea Foam Your Car.
- 02 Lancer Evo Front Conversion
- How and where to install a vacuum gauge
- HOW TO: Fix Cruise Control On RRM Bored TB
- where can i buy mods for 2003 lancer es?
- DDM slim ballast HID installation
- How to Install Cams
- How To: Remove Stock Fenders (w/ pics)
- How-to- Change outer tie rod for 02-03 Lancer OZ Rally
- How-To-Change Non- ABS Brakes, Rotors, and bleed the system for 02-03 Lancer OZ-Rally
- HOW TO: Evo Battery Tray
- HOW TO: Install Sound System In Lancer, Radio, Speakers And Subs
- Remove Door Panels
- HOW TO: Install Vortex Generator, Rexpeed
- How To: Install Rexpeed Carbon Fiber Antenna
- How To: Install RRM Clutch Line
- How to: install B&M short shifter kit
- request for how to do timing
- How to: change my middle light console
- apexi turbo timer
- How to replace starter
- How to Hardwire Stock Radiator Fans
- AC Blower Motor/resistor
- for sale!?!?!
- Changing Turn Signal Lights
- How-to: Upgrade the "Big 3"
- radiator cooling plate
- Diy: Side skirt
- How to Change Cabin Air Filter 02 OZ Rally
- Install Evo 8 spoiler
- Fiberglass Sub Box
- diy rear diffusser.
- How-To install evo iii spoiler on oz?
- Lancer ecu to zeitronix Zt-2 wiring
- How to install slim fans
- 03' Lancer 2.0 Front Crank/Cam Oil Seal Replacement
- oz kit
- Replacing spark plugs (this is probably been asked so much)
- radiator removal?????
- please i need to know
- What is...
- will the 03 evo hood fit my 02 oz lancer
- how can I make a mesh grille for my 02 lancer oz
- how to remove mirror glass?
- How-To: Factory Evo Strut Bar...
- adjusting 2003 lancer headlights?
- ? on E85
- How To Remove Stock Side Skirts
- how to change the location of alarm light
- How to Swap your ECU...
- where to get a turbo manifold
- Dynamatting my 02 OZ lancer
- hey i need help
- Stock side skirt removal?
- OZ Rally Lip Kit
- question about car audio system
- under hood bushings...
- Change Brake Lights
- Tranny filter, HELP????????
- Can I swap a 4g64 for a 4g94
- will a 03 lancer trunk fit an 05 lancer es
- 2004 Lancer ES ... grill???
- Install CAI on 2006 Lancer 06
- cold air intake
- 03 Lancer OZ Cold Air Intake
- How to: 02-03 Projecter headlights and HID install
- request on how to do timing belt and waterpump
- DIY: Power steering fluid flush/change
- How-to-Swap Evo9 Steering wheel to your Lancer OZ rally
- 03 Rally
- How to install ipod to radio
- Wheel Bearings on an 03 Lancer ES
- Lancer OZ Projector Head lights
- How do I remove these screw from the filter box
- Help me! How do you install front strut bars!
- DIY: Clutch secondary/slave cylinder repair
- Spoiler...
- Turbo Build
- How to make you own lip!!!
- how to flip your round turn signals with the running day lights!
- How to: remove trunk panels
- How to put rear seats down
- How To: tap water lines for 16G turbo set up
- How to Install Rear Transmission mount/roller, plus upgrade
- 02 OZ LANCER, can anyone answer my questions?
- Low and high beam on at the same time
- How-To Automatic Transmission Flush
- Question about the Blower Motor
- How to install interior lighting... Good Pics
- How to: change spark plugs link not working???
- how to: drip molding removal
- Cedia Headlights
- Mesh Grill
- Spoiler
- replacing the mirror switch on 2002 lancer ES
- Squealing!!!! ITS DRIVING ME CRAZY
- RRM Piggyback ECU Install (Manual Transmission)
- How to: Change Belts and/or Crank Pulley for 04+ ES
- H.I.D questions???
- Aftermarket Side Mirrors
- How to fill holes from spoiler.
- unbolting the camgear
- RPM signal wire
- RPM signal wire
- How to: Evo rear seat conversion
- How To: Megan Racing Seats & Brackets
- How to: 04-06 bumper removal
- How to change the Valve Cover Gasket on 2.0L Lancer 4G94
- How To: Fill/fix the license plate holes in your OEM bumper
- How To: Alternator swap
- How-To Replace a Clockspring
- How-To : Port a stock Intake Manifold
- RRM High Flow Cat Install (rust problems included)
- coolant bypass mod
- DIY Guide for flipflop trunk mod
- How To: Change Rotors/Drum Covers..
- Side Turn Signal Always On (Adding LED)
