PDA
View Full Version : E85 / Ethanol
Pages : 1 2 [3]
  1. E85 Tune = +59 Hp & +97tq
  2. The New Fuel of the Future :: Wood.
  3. question about e85...
  4. what if no e85 is around during emergency?
  5. Why can't E85 just stay E85 lol
  6. Injector scaling for PTE 1200's
  7. E85 with 100% meth or 50/50 meth/water?
  8. To the ''dark side''
  9. After E85 fill, running leaner and leaner.
  10. E85 Spark Plugs and Gaps
  11. E85 Sensor spec sheet
  12. Octane Rating of E-70? Winter Blend?
  13. E-85 tuned, stranded for 500 miles with only gas stations
  14. E85 - 13:1 (gasoline AFR) - ACK!
  15. Should i switch??
  16. Tips for better cold start w/ E-85 & AEM
  17. 91 octane to E85? Should I make the plundge?
  18. Unable to break 26psi
  19. 1600 cc injectors
  20. E85 - First timer, observations on mpg.
  21. Confused about WB reading.
  22. Can someone critique my timing map.
  23. Fuel upgrades for E85 and BiggerTurbos
  24. Question on single pump w/in-line vs. double pumper
  25. Single pumper numbers and turbo-please post!!!
  26. Just filled up on my first tank of E85, does E85 ping?
  27. Tips on a AMS 30r on E-85?
  28. EvoX on E85?
  29. Verasun files Chapter 11, gets financing
  30. New Zeitronix ECA - Ethanol Content Analyzer
  31. Max power on Lucas 120lb running E85?
  32. fuel trims
  33. Base Low Coolant Timing Map
  34. Storing E85 in 55 gallon drums
  35. $1.85/gallon - Also good info for California E85
  36. Filled the tank of the evo last night for $25!!!
  37. Low-throttle richness solution?
  38. Our results with E85
  39. E85 = +73whp/+62wtq over 91 oct
  40. injectors help
  41. Another cornfed on the list
  42. E85 = +60whp / +55wtq peak
  43. My AMS 35R tuned on E-85...1000cc Inj with Single Walbro Pump....
  44. E85 tune
  45. E85 from your own political view..
  46. safe psi
  47. DUAL fuel Pump
  48. Winter coming up, back to 91 or stay with E85?
  49. E85 usuage
  50. Mixing your own E85
  51. Who has been using E85 the longest?
  52. Internal engine material changes with E85
  53. Bad E85?
  54. CNG powered Evo wins international rally race
  55. E85 Email flash tuners?
  56. E85 or E100 ???
  57. I just got off the phone with BP fuels
  58. Any help? Lean A/F @ high RPM
  59. CEL - Idle Higher than expected????
  60. seasonal e85 tuning question
  61. Lean Cruise limits
  62. Evo Red, E-85, and passing inspection..
  63. e98 track day's
  64. Ignition amplifier needed when using E85
  65. E85 - RC 1000cc - idle and cruise
  66. Up-stream 5th injector.......idea???
  67. Injectors for switching to E85
  68. E85 and CA smog
  69. E-85
  70. Evo 9 - E85 - 400 club
  71. Time with E85
  72. Plugs and E85
  73. Our second E85 station just opened up $2.65 gallon.
  74. P0300 and E85 ???
  75. Is a highflow Fuel Pump mandatory for E85?
  76. Hyper Ethanol Production
  77. Atl Fuel Cell
  78. Getting ready for first tank of E85
  79. 1200cc injectors for e85 and stock 8 ECU...injectors to big for stock ecu??
  80. Before and after E85 Dynojet graph
  81. E85 price gouging!!!
  82. E85 stations
  83. Road Racing on E85
  84. Potential great news for California E85
  85. My new E85 Storage container
  86. e85 storage in gas cans
  87. Downsides of E85
  88. What kind of boost are people running on E-85?
  89. E85 hints and tips…
  90. Knock with Toluene
  91. Do you guys use colder plugs with E85?
  92. Just made the switch to E85…
  93. Flex Fuel capabilities for the Stock ECU. When?
  94. E85 Volitility class by month
  95. Double Pumper necessary?
  96. E85 combustion (burn) rate
  97. Anyone switch to E-85
  98. grade of gasoline in E85?
  99. E10 cocktail fuel - ???
  100. E85 and catalytic convertor
  101. Dual fuel tanks
  102. E85 tuning notes
  103. My E85 Impressions
  104. Counter to aniti-ethanol folks
  105. graph of run today on e85
  106. Torco/tolene data logging questions
  107. How to get E85 in your town
  108. Swift Fuel?
  109. Made switch to e85 today
  110. FIC 1050cc settings for e85?
  111. Please post your E85 stock turbo IDC%
  112. Question about Methanol
  113. E85 tuners - step up and be counted!
  114. Thanks RRE for Stage 1E (E85) 383whp/ 383 tq V5 Tephra mod
  115. 25 Days until my E85 coversion at AMS....
  116. Anyone switched from Meth to E85?
  117. engine wear with e85?
  118. E98 where to buy
  119. CornFed Independence
  120. Great news for ethanol users. You can make your own E100.
  121. Motor Oil with e85
  122. Flex Fuel Sensor
  123. fuel pressure monitor via ECU
  124. cars run on that h20?
  125. Another corn fed evo!
  126. E85: fuel pump body grounded to chassis?
  127. FIC 1050 folks: what are your peak IDCs and whp values?
  128. How much E85 can I mix with gas and not retune?
  129. Fic 1000 E85 injector scalings/latency
  130. What you Need for E85?
  131. E85 max power rich
  132. Getting upgraded fuel just a few questions
  133. different injector scaling needed for E85 and pump gas?
  134. Boost cut, spark plugs, or what?
  135. 606awhp@30psi E85
  136. High volume fuel rail needed for E85?
  137. Which Walbro is everyone using?
  138. E85 fuel trims
  139. A new E85 converted Evo
  140. What type of gas do you guys use?
  141. 26-28psi stock turbo on E85: FMIC necessary?
  142. E85 in a JDM evo?
  143. 1000cc inj. and Evo9 Fuel Pump
  144. E98, Who has acces to it in the mid west?
  145. What kind of gas mileage are getting on E-85?
  146. E47.5
  147. afr/lambda to aim for with different ethanol content
  148. New production method for ethanol.
  149. is there a difference between e10 vs 92octane
  150. E-85/70 tune from Mitch Mckee @ Vividracing
  151. Pumps in NY
  152. E85 vs. 100 octane
  153. E85 now available in Los Angeles
  154. Lower fuelpressure or injectorscaling?
  155. Ethanol content boost
  156. Stock ECU E85 settings
  157. flex fuel on stock ECU coming soon...
  158. E-85 recommendations
  159. Interesting study about MPG on different ethanol blends..
  160. Converison. Injector for my setup?
  161. E85 cold start tips and tricks
  162. Daily Driven E85??
  163. low lead 100octane?
  164. ethanol content gauge group buy..?
  165. E85 and Evo Green
  166. Fitch® Fuel Catalyst in an EvoIX
  167. E85 seasonal changes?
  168. Interesting E85 conversion product
  169. xylene
  170. Best Turbo for DD E-85 2.0l?
  171. ethanol content gauge
  172. Legal Ramifications of E85 Conversions
  173. Any benefits from mixing E85 + pump gas?
  174. Full Flex International
  175. New Site On Alternative Fuels
  176. Evo on E85
  177. Indycar switched to E98, why not E100
  178. e85
  179. E85 Questions
