View Full Version : E85 / Ethanol
- 320 LPH and stock fuel system (hangar)
- flex clean up
- what is this
- Please confirm I have everything needed for Flex Fuel
- Walbro 450 High Fuel Pressure
- Thinking about going with Ethanol
- helps !
- Innovate flex fuel kit/ flashing check engine light
- Can Ethylol 95% purity be used instead of ethanol at 99.9% purity?
- E85 questions/concerns
- Officially on E
- Looking to run e85
- need help building fuel system
- Flex e85 plus bolt ons
- Car won’t start!
- What is E85 "Rich Knock?"
- Upgrading fuel system
- Department Of Energy Ethanol Handbook
- Need some insight on flex fuel sensor and tuning
- 93 to e85 ditch inline pump?
- Oil color E85
- Need a website for a flex Fuel kit
- What would cause e85 gauge to read e17
- Want to go e85 and 91
- Clear gas Ethonal free? Any good ?
- Check out this build
- e85 cold start help
- Sunoco pump e85 vs Sunoco e-85r tunes?
- So hard to start! Help with IPW adder
- Backfire at wot help
- Help fitting flex fuel sensor to the fuel return line
- E85 or no?
- E100 Optimal AFR
- FiTronic Install
- E85 and fuel lines (evo 8/9)
- Tephramod E85 Cold Start??
- 05 evo 8 fuel pump help
- e85 and AZ
- Issues with injector scaling
- Logging wideband
- Duty cycle high
- E85 ETune?
- Analogue output FF
- E85 stations in MA
- Diy e85
- e85 and Seafoam?
- Injector upgrade for E85
- E85 smell
- Taking the plunge. Is this feasible?
- E85 shelf life
- FP Super 94, 2.2L, 42 PSI, e100, MBT?
- Want to make an e85 transfer: Stock evo Plz help.
- Zeitronix e85 sensor install
- Ethanol and fuel senderm
- E98 vs Ignite E90 hp/trq differences
- Zeitronix ECA
- FP Green injector and fuel pump setup for 93 and E85
- FF sensor (GM)
- E85 Gauge w/ output for under $100
- Innovate Ethanol Content gauge not same readings
- E85 hard to start in the cold?
- E85 NO MORE!!! Now called Flex Fuel ethanol and is lowered to E54
- Thinking about going to E85
- Can I drive a evo with no meth?
- Need new injectors look for adevice that works
- Boost cut issue
- E85 longevity
- What plugs do I need?
- Evo * Mr tuned By stay tuned
- Reputable tuner highly advises NOT to tune Evo VIII with e85
- Stock Turbo Fuel Setup
- Is Walbro 255 enough
- First time tuning E85 and ECUFlash. Logs & Graphs inside
- E85 after a year in a glass smuckers jar
- Need help with Minimum IPW Patch
- Injectors for E85
- Tuning Over 350 Load
- HTA 73 Target Boost
- Oil Consumption with E85
- E85 on Hyundai tiburon
- Tuning help for E85 FP Black 2.3 stroker
- Dual Map Tune... what to do when switching?
- 9 turbo + E85... 800cc injectors enough?
- Switching from e85 back to 93
- E85 Locations
- Super caked up injector 20k miles on just e85
- Best pump to use for E85
- review my map...
- E85 96531706 - Car dies after startup
- tried a 07 bmw335i fuel pump
- Maxing out the double pumpers at 700hp?
- E85 + Winter (what should I be worried about)
- Making your own ethanol at home... possible, realistic, cost effective?
- E85 vs c85
- Autronic Anyone?
- Flexfuel sensor install / return line modification for 7/8/9 above intake manifold
- E85 - P0171 too lean code - Long Term Fuel Trims + 12.5%
- E85 - Fuel Caddy
- E85 Question....s
- e98 cold starting
- Thinking of making the switch
- E 85 app
- California, E85 and smog testing
- Whats it take
- Best ECU to run full flex system
- Long term storage of E85 and my results
- E85 Shelf Life
- Thinking on converting. Suggestions?
- No E-85
- MIT study - E85 and FI Motors - Good Read
- Low vs high impedance
- ideal peak timing
- GM Flex fuel sensor to AEM Series 2?
- How hard to tune E85 myself.
- Searching for a fuel pump that can take e85 and 93 octane!
- aem wideband issue running vp c16
- Got the car back today finally!!!
- e85 qucik questions
- My new e85 setup
- E85 for my setup?
- bulit engine om e85 start up issue
- E85 tuning method MBT questions
- e85 sitting for over a year
- Evo 8 With some Mods not quick enough but
- Startup Help, 2150's AEM EMS... E98
- Idle AFR's on E85, 2.3L, 2150cc, SD
- Bosch 040
- Coldstart
- Fuel Trims
- US Govt possibly restarting an ethanol agenda
- ID2000, E85, and open loop issues
- ramp up timing
- Timing concern
- Cold accel enrichment
- cutting out on e85!
- Storing E85 in truck bed
- Can't wait for my E85 tune and more power!
- E85 is Uber cheap around me for some reason)
- Which injectors to buy...
- Can I run E85
- Testing e85 at the pump - fill up routine
- Upgrading turbo for E85
- Wanting to make the switch to E85
- Running E85 on a C16 tune
- stock fuel pump
- full pump and injectors questions
- E85 in the news...
- Question on E85 + Entirely Stock Fueling + More Boost
- evo x requirements for e85
- Switching to E85
- Fuel filters for e85
- Rich E85 Idle?
- tampa gets e-85 !!!
- Fuel pump testing - see results inside
- Whats up with 100oct?
- New flex fuel sensor
- correct injector size for hta35r on E85 setup
- Mixing fuel bad or good?
- Switching to E-85...
- E-85 Ethanol Fuel for 85 cents per gallon
- E85 lean issue
- e85 cold start issue
- MPG for E85
- Help with e85
- Pros & Cons e85???
- need local tuner E85
- H20 contamination? Rich?
- aem uego e85 afr value?
- E85 and 93....
- Ethanol 2.0
- Intercoolers and E85
- E85 compatible?
- Custom Ethanol badges
- E100, what's the ideal afr?
- E85 fuel system
- anyone running E85 using a water separator??
- Has any built there own double pumper?
- E85 on single fuel pump???
- E85/car hard to start
- Quick shot of my new frugal fueling solution...
- What is the average MPG you get when running E85 including city and hwy
- No gains from e85
- Running E85? Educate yourself with this article!!
- Going lean on wot on e-85
- 1000cc injectors E85 and MAP EF2 turbo
- Looking to upgrade my fuel system......recommendations
- Mixed feelings on Walbro 255
- E85 Yellow Fuel Cap
- E-85 Question...
- start e85 stations
- Anyone running E85 in tampa bay?
- Dispelling some ethanol myths...
- E85 boost question
- E85 Fueling Problem
- Open or Closed Loop on E85?
- Bosch 2000cc Injectors tick loudly running E85 now...
- STOP 38 cent/gal e85 tax!!!!!
- Storing the evo over winder with E85 in the tank?
- E85 prices rising in my area, what about yours?
- fuel options....
- E85 vs 91 at 20psi
- Cold idle ?
- Converting to e85
- Question on e85 conversion
- Lean on 2nd tank of E
- Running really rich on spool
- E85 fuel heater or extra injector???
- cheapest place for NEW GM flex fuel sensor??
- People that DD with e85
- Anyone seeing E85 supply issues?
- a couple Noob e85 questions
- tuning a stock evo to e85?
- Quick question for you E85 guru's? I have 2 gas containers of 5 month old E85
- E85 temps changing AFR
- Fluttering car when i accelerate
- Ecpoenergy:clean and free or cheap energy
- Fuel system after 3+ years on E85
- CA e85 catless smog test + tephra v7
- Fuel Filter
- New Movie about Ethanol
- Does E85 increase power down low?
- Injector Reccomendation for 2.4 build
- Ethanol Myths Busted
- Has anybody ever used nitrous with E85?
- Can I make my own E85 or E98? Please help!
- EVO IX and E85 air temp correction?
- Is this the end of e85? Senate backs repeal of ethanol credit
- Is BTU comparison between gas and E85 valid
- what dyno numbers should i expect if i go with e85?
- e85 detinating
- Help! GM sensor won't talk to ECU (Linkg G4) :(
- Need help making E50
- Urgent help re: GM Ethanol sensor
- How to install GM Ethanol sensor with high flow fuel system?
- 1450cc bluemax FIC injectors-e85-pump
- Another newb e85 queston??
- Long-term affects of E85 use?
- For you guys using the E85 testers...
- Need e85/e98 in drums in chicago area
- how about this timing table?
- Illinois e85 Blend.
- quick ? about this timing map
- E85 Tester- Is This Right?
- Pros and Cons of going E85
- e85 gauge
- What's required to switch to M100?
- Made the switch to E85 with dyno results
- E85 and making power.
- Noob question about e85!
- delivered e-85??
