View Full Version : E85 / Ethanol
- E85 / Pump gas switching issues.
- what size injector for 700-750HP on E
- E85 switch in Europe help needed not looking for High whp
- e85 quality question
- E10 fuel
- Getting 85% in iowa during winter blend
- Ethanol 2.0
- Running straight methanol
- Ethanol production/steam powered battery charging and misc projects finally under way
- Cold starts with e85 and a light weight battery
- e85 1000hp fuel system design recommendations...
- e85 boost gauge options
- Small Build List, need suggestions or comment
- Interesting Ethanol Content Tester
- emissions+e85 in CA
- E85 or meth?
- Ethanol Production Facility Map / Usage Map
- e85 double pump needed??
- e85 + winter car storage
- Choices??
- Those with a GM flex fuel sensor and AN hose?
- E85, 750cc injectors, Scaling and Latency
- E-85 Station Resource
- Ethanol to go by-by? Or just more expensive?
- JayRacing PT342 fuel pump
- Running E85, Got P0134
- What fuel injetors/fuel rail is everyone using for E85?
- Low MBT on E85
- transporting e85 in virginia
- e85 and the cold
- E85 driving normal a/f?
- E85 Stabil or such?
- E15
- Can I use MAF to control timing ?
- Running a Bosch 044 inline, instructions
- lean on e85?
- Primer Cranking Enrichment-First Pulse-Max Value 255
- E85-Dyno tune or Street Tune?
- e85 on Stock evo *8* turbo?? (not 9)
- Transporting E-85
- Stock fuel lines+ID2000s+Buscher rail+double pumper=how far can you go?
- Corn Ethanol: A net energy gain
- inline fuel filter
- E-85
- stock BOV over 28psi?
- setting up Zeo ECA and FF sensor
- Mixing fuels
- Best MBC for stock turbo
- regular swapping from E85 to pump
- Known best injector?
- Miss when not on WOT
- Attn: People who know things: critique My E85 map?
- E-85 FlexFuel Emblem/Badge
- Have I run out of power?
- can sitting e85 cause for an AFR change?
- injector hp levels?
- e85 swap
- Question on injectors/fuel...
- Need help deciding on injectors
- iTune's E85 tuning notes: AFR
- Thoughts on my E85 35R timing map please
- E85 and Low Boost
- P0401 EGR flow low
- Race gas will be illegal in CA??
- What is your max load?
- Injector scaling for 1200cc injectors...
- E85 and low compression pistons?
- AFR for HHO
- AFRs for a tracked car and E85?
- 2150cc and c-16 any experience?
- E85 I cannot get rid of this knock.
- Post your E85 Fuel Maps
- AFR Tuning and Knock on E85
- Bigger injectors or adjustable FPR?
- More algae developments: sweating fuel
- First fill up :)
- I just picked up my first 15 gallons of E85 - a few questions.
- e85 questions-plan on switching
- Looking for basic fuel map
- 1000 evo running E85?
- E85 Auto-Calibrate
- converted to e85, now constant knock issues..
- In tank fuel filter turned brown
- Correcting an E85 Tune
- Emmissions and E-85
- Its been covered but still need help on E-85
- anyone ran e85 on bone stock
- Oil Analysis on E85
- Ralliart on E-85.... stock fuel system can't keep up!
- missfires and E85 = bad news
- Knock during spool/load up
- 1200cc not enough?
- E85 Seasonal blend information
- For safety: best season to get e85 tune?
- What is the future of E-85??
- "Miss" under throttle on cold E85 car
- Any site more accurate then e85vehicles
- excessive knock on e85
- E70, fueling and timing
- 100 octane tune for daily driver
- what kind of injectors will i need for high 600 whp on e85
- Moving away from Petroleum (long)
- Stocking E-85 in 55 gallon Drum.....Will it go bad in a period of time??????
- E95 What is the verdict.
- Which injector size should I use 1000, 1150, or 1250?
- brass and e 85
- EthaMax Injectors
- Fuel pump help?????
- emptying the tank?
- Just found out my e85 evo8 drive fine with 93pump gas, wow!!
- e85 cold start from up north
- COBB offers E85 maps for AccessPORT
- What gas cans are you guys using to store and refuel with E85?
- Register as E-85 vehicle?
- e85
- 253.1 MPT of E-85 W/ 1350's & FP Red
- E85 vs 93 oct
- anyone try these denso 1600cc ???
- Was getting P0171 when running E85, switch to 93...no codes
- ROM 96530706 Tephra v7.0 on E85 - questions
- Any one running E85 AND meth/h20 injection?
- Cellulosic ethanol plant opens in Pennsylvania
- How many gal. of E85?
- e85 and nitrous?
- Lets talk cold start
- 248.3 Miles to one tank of E-85
- E70
- Real world E85 "issues"
- Need help with e85 please!!!
- Gizmodo: Microfueler Home Ethanol Pump
- Evo E85 Registry thread???
- Lean Or Rich On E-85 Maybe A Boost Spike
- Just made the switch to E85.. awesome!
- good article on algae-based production of ethanol
- E-85 Going Away?
- E85 Fuel Filter
- "E-85 Army" Stickers
- Map Change Harness for my E-85!
- May get the Zeitronix Ethanol Content Analyzer but need advice.
- Help
- E-85 a/f
- Curious about DLL and how accurate the HP/TQ #'s are compared to a mustang or dynojet
- supra pump died
- Do I need an ethanol content sensor?
- Tephra Map switch is a waste of time, E-85 sucks
- e85 ON STOCKER
- Should I trade my HFC for a test pipe w/ E85?
- 1st day on e85......1200 PTE and walbro impressions
- low rpm knock with e85
- E-85 storage observations
- tuning by turbine color with E85
- To those running E-85..
- E85 big injectors low idle Q
- E85 parts checklist..Have i missed anything??
- Worlds Most Powerful Octane Booster
- E85 vs. Q16 - discuss
- E-85 is a corrosive
- GM Ethanol Sensors now available from TTP at affordable pricin!
- E85 spark plug poll
- E85 Locations
- E85, GT3076, 1600cc Inj, Single Walbro?
- E-85 vs meth injectors/pump
- E85/meth combo
- Got some E85 thats smells like yeast burning?
- E-85 +/-
- My E85 tune... thoughts? torque suggestions??
- got my 1200cc PTE injectors in W00T!!! E85 here I come
- E85... Will it eat the stock fuel lines or not.
- Ken Block and E85
- methanol suppliers
- e85 and Oil - How they mix
- What do i need to run C16
- Noticed something about E85 gas prices
- CBRD BBK Full and E85
- Jay Leno & E85
- E85, Injector Gunk & Seafoam.
- Question about those of you that switch between pump and E85
- e85 and n2o?
- Max power on 1600s and 1200s
- E85 from 91oct. Should I close my plug gap some?
- My motor on E85...
- specifications for E75-E85
- CES eth content sensor installed, flex fuel patch coming soon
- Lead fouling
- What size/ brand of injectors do you use for E85?
- So I haven't even driven my EVO yet but I'm thinking about E-85
- E85 Year Round MIDWEST
- E85 Spool AFR Transition
- E85? Dual Maps? New E85 Forum Needed?
- E85 vs C16
- EPA May stop future e85 stations
- EVO gets twice the gas mileage of Prius!
- Difference
- Are the Greenies confused?
- Flex-Fuel = more HP?
- Read fast B4 this gets moved to OT.
- can i or what do i need to run e85
- Tephra Patch and E85/91 octane Injector Scaling
- E85 and Track Weekends
- where can i get C16?
- Cross Country on E85
- Packed and ready to get tuned
- How-To: Warm/Hot Starts (and cold ones) with E85
- E85 Blender Pumps
- Who likes E85!?!?!?
- Fuel Rail?
- Getting ready for E85, some questions...
- show pics of flex fuel sensor mounting location
- fuel economy
- E85 % calculation - how to mix yer own :)
- E85 and Emissions
- Injector "gunk" and E-85
- switch
- e85 tuning ?
- E85 Road Race Tune?
- e-85 EGT's
- Are my mods enough to run e85?
- changing maps?
- 10 % ethanol fuel
- HP Guess...
- e85 tryout?
- E85 Timing Maps
- HELP?! Please...
- White Lightning Flex Fuel Kit
- More alternative fuel goodness
- P0300 Gone...
- Highest Miles on E85
- Are there really NO certified containers for E-85 ?
- E-85 or Meth wich way to go ?
- Ams and the amazing tuner chris!!!
- Is there a difference if use e85 winter or summer?
- E-85, what other supporting mods will help me reach 400 whp?
- Fuel system for a GT4094R
- E-85 pumps across America...
- From beer to ethanol
- Ethanol/Gasoline mixing pumps
- Double pumper finally installed!!!!
- Ecu Boost Control + 3" FMIC+geared 272s+E85 + Stock Evo VIII turbo=rally torque
- Poor Mans Ethanol content analyzer
- fuel regulator and fuel rail E-85?
- WingzPerformance.com '98 GSX goes E85.. See inside for gains
- e-85 and DEQ?
- Fuel rail-e85?
- Simple question
- Best Hi Boost Controller That Helps Prevent Taper(Stock Turbo)
- E-85 in Turkey Lake Plaza
- E85 Fuel Cell Setup?
- Are you running E85 all winter up north?
- buschur double pumper
- Mod advice sought on E85
