PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74
  1. ATTN: Cusco Zero 2R OWNERS!
  2. have you had a brake air guide snap off?
  3. Brembo vs Endless
  4. Clunk Clunk Clunkity Clunk
  5. Black Racing Pro-N1 fitment?
  6. Neal: news on SSR SP1?
  7. Bolt Pattern for EVO VI
  8. Slotted Rotors
  9. Falken Torque 5 Wheels for EVO - DON't FIT!
  10. Painting the stock rims.
  11. bendix brake pads?
  12. Hotchkis springs cause rubbing?
  13. Need tires for 18x8" Privat Sekt
  14. Need diagram of EVO rear strut/spring
  15. Help - Brake piston stuck out
  16. Suspension suggestions?
  17. Why is my front caster messed up?
  18. ATTN: Project Mu B-Force break pad owners...
  19. Performance Difference: Volk 18x9 vs Oem Enkei
  20. Need Help! Removing hard lines from master cylinder
  21. PLEASE help diagnose clicking sound
  22. what does dual height adjustability mean?
  23. EVO8 brakes fit what else?
  24. question for anyone with volk racing ce28n wheels.
  25. What tire size for 18x9 with 34mm offset?
  26. Wheel Advice
  27. I need help please. 245/40/18 on 18x8.5+30 with stock suspension.
  28. Do patched tires BLOWOUT at high speeds?
  29. Brute Force Brake pads, POS!!!
  30. Tein or HKS coilovers?
  31. Forgeline ZX3-Rs installed. 18x9
  32. Tein or Cusco camber plates?
  33. Tire size on 18x9?
  34. 18x9 or 18x9.5?
  35. What's needed to eliminate wheel hop?
  36. anyone using track coilovers?
  37. FS Espelir ASD springs
  38. Will Evo OEM rims/tires fit on a 2G eclipse?
  39. bad day
  40. Will these rims fit an 03 Evo?
  41. Volk Evolution pictures.
  42. 18inch black wheels
  43. MR BBS wheels- dealer cost?
  44. What are some other tires other than the Advans that I can put on my evo?
  45. RRE BuddyClub suspension thoughts pls.
  46. "Street" Alignments
  47. Does anyone carry the TDR Visage wheel yet?
  48. MR type shock/spring for '03 Evo again....
  49. "Brake" light under hard braking??
  50. Alignment after lowering the car
  51. jic flt a2
  52. Does anyone make an 18" rim that looks like this...
  53. To Volk or not to Volk, that is the question.
  54. wheel studs??
  55. 18x9's 38mm Offset....Rubbing and Looks?
  56. Help me find this trunk bar!
  57. Gold wheels on silver evo
  58. Rim Help!
  59. Red wheels
  60. Tein H-tech rubbing issues?
  61. Attn Neal
  62. Anyone mounted 17x9 wheels with 275/40-17 tires?
  63. Installed coilovers = Noise?
  64. Kids, don't let this be you!
  65. Pics of my new shoes.....
  66. Alignment Specs
  67. Screw + Tire = BAD??? How about after a few weeks?
  68. Is this a brake indicator?
  69. What SCCA AutoX class would my friend be in?
  70. HELP: leaking brake cycliner??
  71. Cheap Stoptech Slotted Rotors???
  72. Wheel fitment?
  73. Volk LE28n and Bridgestone S-03 questions ???
  74. Anybody got pics of Racing Hart CR
  75. Who has TOYO RA-1's and how long do they last
  76. new to evo... bad brakes @ <1000 miles?
  77. What rims are these?
  78. Any pics of 5Zigen FNO1RC black with polish lip?
  79. Endless SS S front installed
  80. HAWK HPS pads..how R they??
  81. Are there any stiffer-than-stock springs that don't DUMP the Evo?
  82. JIC FLT-A1 Coilovers
  83. Wheel wax
  84. Fitment of 18 x 9 wheels - do the wheels stick out beyond the tire?
  85. Falken Azenis 615 vs. Toyo T1-S vs. Stock Advans
  86. Best Hotchkiss sway bar setting?
  87. Need Help - Vote - Which Coil-Overs
  88. Color Choices for OEM Enkei wheel!
  89. how much do HKS Pro coilovers cost?
  90. Tein S tech springs or coilovers?
  91. What off set etc. needed for wheels on Evo 8
  92. 18x8.5 +32mm offset?
  93. stoptech vs Works vs Agency brake lines
  94. 215s for daily driving?
  95. WORK:Emotion??Centercaps
  96. Anybody running 245/45/17 w/ stock springs?
  97. Question about wheel spacers
  98. desperately looking for the right wheels
  99. got my new wheels on
  100. Pics of Drilled Rotors ON CAR!
  101. OEM Brake Fluid for the EVO
  102. brembo brake pads
  103. how much do stock wheels cost?
  104. HKS Pro coilovers?
  105. Ohlins owners, what camber plates fit !?!?!
  106. Thanks again Z1Auto!
  107. ZEAL Function Xs
  108. rear toe ?
  109. Rear strut tower brace
  110. Advan Neova's on my car now!!!
  111. Best lowering springs???
  112. What company makes this rim?
  113. stock wheel paint code number?
  114. wheel spacers?
  115. Which tires for autocross?
  116. MR Bilstein damper questions
  117. Question about springs...
  118. Wheel Fitments ALL FINDINGS HERE PLEASE
  119. Rotor blanks
  120. Daily driven evo: ss steel brakelines and upgraded brake fluid necessary?
  121. How do you adjust ride height on Tein coilovers?
  122. need pictures of 17x8.5 with 235!
  123. FS MR suspension
  124. hotchkis rear sway bar ?
  125. Redrilling Rotors? Suggestions
  126. question about going to 18" rims
  127. will Hotchkis springs damage my shocks?
  128. just installed Hotchkis springs...problem...
  129. WHEEL WEIGHT"S (big list)
  130. Help with buying Rims PLEASE!!!
  131. Best Tires for Stock Evo Rims
  132. question about volk CE28N rims
  133. Rubbing w/ 245/40/18x8.5 +30 help
  134. Where to find adj. front sway bar brackets?
  135. Stock Rim corrosion
  136. Stock lug nut size and socket recommendation?
  137. Tanabe Sustec Under Brace: Lancer Evo 03-up (center)
  138. Left rear Brembo grinding?
  139. What are the most lightweight wheels you can find?
  140. Kuhmo Special Pricing???
  141. 235/45/17 on 17x9 Wheels?
  142. Hey Neil!!
  143. anyone running 19x8s on lowered evo?
  144. good deal? stock advans
  145. blowout
  146. BFgoodrich g-force T/A KDW2...any good?
  147. Hotchkis with 19inch wheels, got pics?
  148. Anyone having squeeking brakes??
  149. brake upgrade help
  150. MB Motorsports Wheels?
  151. Volk gt-7 wheels
  152. Privat Fahrens 19s????
  153. Tire choosing help
  154. will 255's rub with Hochtkis springs?
  155. Tanabe gf210/Hotchkiss springs for autox
  156. Ferodo DS2500 rear pads positioning
  157. Variations of tire sizes on stock rims
  158. used 57f black 18x8.5
  159. how much do stock rims weigh?
  160. Privat Fahren's Question
  161. Alignment ???\results
  162. ADVAN RGII vs. Ray's Ralliart R-01
  163. Kumho V710s in 245/45WR17... Neal?
  164. Testing Neova, BGF KD, and Kumho MX on 4/20/05
  165. volk wheels...need input..
  166. Shoping for new tires :helpme:
  167. Other car manufacturers compatable wheels???
  168. any1 have a schematic of rear suspension?
  169. Tein S Tech question !!
  170. Autox: Azenis or Neova?
  171. Are these rotors made?
  172. StopTech and EvoMR
  173. where can I get some Volks CE28N with polished lip?
  174. my new top secret edition volk le37
  175. how much is your evo dropped?
  176. where can i get tein RA's for cheap after tax+shipping
  177. Need help with coilover choice
  178. >>>ESPelir ASD Installed<<<
  179. New Wheel from Euromagic
  180. AS Evo GSR w/ Rota Torques and Hotchkis
  181. A simple wheels/tires Question
  182. Looking for a way to get Rays A/X MEs?
  183. new tires are in
  184. tire wear
  185. help with rims
  186. Falken Azenis RS 225/45R17
  187. front caliper piston sizes
  188. Which is the better tire??
  189. Are there any suspension parts that may wear out...
  190. Wheel Speed Sensor on 2005 RS???
  191. Tires PSI?
  192. Only Replacing 2 tires on the Evo?
  193. ? abuot some volk racing GT-P in 18's
  194. Experiences with Falken Ziex ZE-512s
  195. Suspension clunking.. help!
  196. Who Makes These Wheels
  197. My new wheel and tire setup with brand new azenis RT-215 (255 40 17)
  198. velox pg-5s or pg-10c anyone have these?
  199. Omni-power Coilovers?
  200. What rims are these?
  201. RA-1's Noisy?
  202. Question for those with 255/40 with stock wheels
  203. project gravity: lancer ES
  204. Yoko Advan Neova
  205. Brake backing plates???
  206. Evo on Rota Torque Rims
  207. Tire Positions and Handling
  208. I know this has been beatin to death but...
  209. Fuzion Tires
  210. I need advice please
  211. Tein Type Flex on an Evo
  212. Asa Ar1??
  213. ::HELP:: Which size Tires to buy?
  214. DOES THE 19x8.5 ADR M-sport fit the evo?
  215. brakes making funny noise
  216. Specs for TEIN Basic Damper coilvers...
  217. New Hankook R-S2's on the Evo
  218. 19's fit on Hotchkis springs?
  219. SSR Professor 18x9 Black with Polished Lip...who has these in stock?
  220. Paint Code for Stock Enkei Rim?
  221. Coilovers " NO pillowballs"??
  222. SSR Professor SP1
  223. replacing rotors..torque?
  224. Volk GTU's
  225. JDM vs. USDM Bilstein suspension on the MR:
  226. Neal/Miles help on guarantee?
  227. volk racing sf winning 19 black
  228. TDR wheels mounted
  229. rear pads worn but front pads are still fine?
  230. Enkei's and tires in today 9.5x17's!!!!!!
  231. Vulcan tires Co. Good or Bad?
  232. brembo caliper paint is pelling
  233. how low can i go?
  234. Anyone have slotted Brembo rotors in stock?
  235. Help WTB: rear coilover pillow ball top hats
  236. Neal out of office till Monday the 11th
  237. Need Everyones Help!!!
  238. HP - High Performance Designs - Are they any good?
  239. Hotchkis Rear Sway Bar-Issue?
  240. Broken Axle
  241. Got new rotors, important question!
  242. Please help me decide between two Volks!
  243. Tein Flex Camber plate settings
  244. Review: RRE / Peformance Friction 2-peice rotors and pads
  245. I want these Volk Wheels! Help!
  246. wow... what wheels are these?
  247. Will my wheels camber with S-Techs?
  248. Help, removing rear trailing arm
  249. Tire Loosing Presure...Help
  250. Gunmetal Ralliart Wheels on White EVO
