- Need a Bilstein / Swift and Fortune Auto Comparison
- 8-9 SE BBS colour code?
- brake shutter is back AGAIN!!!
- EVO Suspension Modeling
- which wheels fit an alcon big brake kit?
- Tender springs to help with droop on heavy spring rates
- Stupid question about RPF1 and lugnuts
- spacers......... who has them?
- Different tire size
- Adjustable caster/camber mount?
- Damaged my brake modulator unit
- Need lug nuts for my stock wheels and extended studs??
- Anti-Lift Kits Perrin vs. Whiteline in Street Mod
- ADO8 245/40/18 on 9.5" rim
- Does anybody know this guys setup?????
- Project Kics R40 - Who has them?
- Control arm bushing help!
- i need rear wheel bearings....
- I hate understeer
- Mix and Match swaybars?
- Lug nuts & hubcentric rings for evo 9 enkeis
- Toyo Proxes 4 tires
- Advan RS-D 18X9 ET25
- Another tire question:
- '03 Evo 8 Front Lower Control Arm Bushings - ALL
- 24.5 inch slick, 15" wheel or 26 inch and 16 inch wheels???
- 18x9.5 CE28N offsets for IX
- Slide on wheel spacers, Where do I get them?
- Owners with DBA 4000/5000 Series Rotors (come in) research purpose
- Tein MonoFlex Knocking Noise
- do "all season" tires work in the snow?
- please help with wheel fitment
- Tire, Brake, and Coil Questions
- Highest/lowest offset for Evo 5 and 6.
- Apexi EXV N1 vs. BC Racing BR Coilovers
- Neal out till Aug 15th
- OZ rims for my Evo 9
- Squealing Brakes (metal on metal sound)
- Any issues with this setup?
- fitment with a 265 tire
- Compatible Wheel Lock/Lug Nut Set
- Question for the suspension people 'in the know' :)
- DS2500 & EBC Yellow user input
- 2011 X Spring rates and suspension ?s
- Evo8 GSR Front Right CV Boot - Interchangable with any other platform?
- I think it is time for some coilovers after R compound install.
- Ongoing Squeaky Brakes
- How do you care for your volk wheels (stickers, etc.)
- Anyone running a set of Enkei RPF01 SBC (Super Black Chrome)???
- Help with tire suggestions
- who's running CL RC5+?
- Brake bleeding preference
- ISC coilovers
- Just received my JIC FLT-TAR coilovers, need advice.
- Wheel Identification
- ce28 or re30 on RR, what color should i go with?
- Wheel / Tire help
- 18x9.5 +20 Rota Grid fitment on 265/35
- Centric premium versus Centric standard rotors
- 255/45/17????
- Federal 595RSR inital impressions...
- Suspension/Coilover Problems!!!
- Evo 5 rear shock
- Suspension pros
- Getting tired of changing power steering pumps...... help needed
- Odd tire wear?
- Max rear rotor thickness?
- Did I screw up my first brake job
- strut adjustment???
- Neal out till Aug 1st
- I need your expertise, Tire People!
- Split motorsports
- Bilsteins installed today {thumbup}
- is anyone running 18x9.5 +44
- Changed Brake Pads Do I Need New Shims? Or Can I Re-use?
- Rear diff options for the street
- The brakeman
- Who sells Team Dynamic wheels?
- Those who have use HP + rear pads.. are they loud?
- Obtainable alignment specs after coilover install
- SAI help
- after market sway bar and aggressive rims
- bilstein shocks
- Function & Form V2 coilover reviews?
- Anyone use Pirelli PZero Rosso tires?
- Where to buy oem inner tie rods
- Wheel question.
- Aluminum vs steel lug nuts
- Tein EDFC
- Wheel fitting!
- NEW Cusco ZERO-3G Gymkhana/Rally Coilovers
- Bad Bish gets some suspension/chassis work from Robispec
- lug nuts need help
- please help me, upper arm bushing
- new tires need spacers
- Looking for some help/advice/info.
- Wheels for an Evo 1
- EBC BlueStuff NDX Review
- Brake Pads Advice... Please Help.
- biggest spacer
- STU wheel recommendation
- Bled brakes incorrectly, now what
- Good sticky drag tire question
- Rear Upper Toe Control Arm Cracks
- trailing arm bushing
- brake shake and squeals again
- Where to get Hankook R-S3 255/40/17
- help with new wheels / tires / lowering springs
- Best non-directional tire?
- Help: Swift/Bilstein combo too low?!
- Skid Plate
- steering radius on IX SE
- How can you tell if the tire has a soft sidewall or stiff sidewall?
- Evo 8 xxr 527
- which R comp
- Neal out until July 5th.
- Help me choose my tire size...
- tire fitment with new spring
- Which Ultra High Performance All-Season Tire Has the Stiffest Sidewall?
- Kics R40 will fit Volk RE30?
- hoosier r6 on stock se rims?
- Anyone using carbotech XP-16 pads?
- Rebuild Bilsteins??
- Help! Whats wrong with my Brakes
- blown tie rods
- need help on bbs lm tire size
- drag aligment specs?
- Nagisa Auto Adjustable lower control arms...Pro's/Con's ?
- Loud Clucking coming from Rear brake rotors.
- AST Blog - 929 Evo
- Lower tie rod question
- DD coilovers
- belstein with swift vs. kyb with swift
- Bilstein Revalve ?
- Rear Suspension Spherical Bearings
- Advice on new brake pads and rotors
- mb battles 18x9.5 +15
- ***apexi n1 strut seized in lower mount?***
- Steering wheel shakes when I hit the brakes, new rotors needed?
- cutting / removing plastic inner fender wells
- Wheels that look good on a lancer DE?
- Coilovers for the stanced and the low
- 18x8 +40 on my VIII
- R comps & sping/strut combo?
- IX Whiteline F sway bar hits subframe?
- Oops, staggered offset question, same size tire.
- Used Tires:
- My experience with TreadZone.com
- Wheel Spacer Help Needed
- steering wheel shakes over bumps
- to mount fitted, now a new problem...help please
- Introducing the New Rota T2R's in 18x9.5 and 18x10!
- 17x9 wheels that are still alive and are under $1,000 in 2011
- Road Race Suspension Sey Up?
- Stock front lower control arm bushing, How much camber am I losing?
- Vibration under braking NOT cured by rebedding
- Alignment bolt
- parking brake shoes
- Sent my Bilys off... Warning to all! + Poll on if I handled it correctly
- Recommended Tire Pressure for Stanced Cars [chime in]
- 45mm offset and spacers ??
- Wheel fitment question
- Alignment recommendation
- energy problem
- Spacer/hubcentric ring question
- Racing Brake ET500
- HKS rear coilovers - how to adjust
- Swap to coilovers ?
- Here I go again: PSS9 problems :(
- Eclipse Wheel Spacers
- Coilover reviews d2
- HKS Hipermaxx RS Clunking Badly... Need Some Advice
- Brakes make a thumping sound (video)
- Z1 Star Spec Vs. RS-R
- Rear end stiffening overkill?
- Will rays g games 77f fit
- Brake bleeding. help
- advice needed for diy rear tracking
- Braking Woes...
- Forged Performance: Apex Silver Evo on Volk RE30's and Tein Flex
- Brake Caliper rebuild
- Do TEIN lowering springs cause problems on 06 MRs?
- Subaru Brembo calipers
- Need help with offset and tire size
- work emo xd9 fitting?
- Raybestos ST-43 pads up front..what for the rear?
- alignment specs
- Can a 275 35 18 fit under the rear of a fender rolled IX
- Lower Strut Bolt Orientation Question
- spherical upgrade
- Evo 9 Graphite Gray WHeels
- Datalog ABS
- bumpy braking/slow down?
- Pic request of cars with neutral rake
- XXR 962 fitment?
- Anyone heard of CST Coilovers?
- What tires fit 18x9.5 wheels?
- will this rub on hard turns??
- semi-slick tire!
- Bushing ?
- Tread width VS. Section width?
- Neal out till May 31st
- coilover feedback???
- rota force
- 18 x 12 wheels?
- Do I need suspension mods to get a nice stance with 18X9.5 wheels?
- Bought new rims, let me know your views about it
- Do I really need wider tires
- Rubbing sound
- Need Quality KW V3 Installer in Illinois
- Possible to convert front Mac Suspension to Double A arm?
- Hoosier
- ABS delete kit, wheel sensors?
- Aftermarket Lug Torque
- cheaper coilovers...
- Conti DWS great DD tire.
- Strange clanking
- LF: Yokohama WInter F310 Tire
- brembo brake pads on rockauto???
- hipermax III coilovers
- How low should i go???
- Issue with control arm bolt!!!!!
- Robispec streets install issue
- Coilovers to low!! need some help
- Evo 7 Suspension?
- SS brake line issue
- Front and rear sway bar decision..
- SCCA BSP modifications
- Vorshlag vs Ground Control Camber Plates?
- Will 2008 OEM Bilsteins fit on a 2005?
- My car is pulling to the right PLEASE HELP!!!
- Looking for Opinions on Brake pads for Evo8
- Braided lines instead of factory???
- Biggest tire for factory 17's
- Fitting 18x10.5" under stock fenders
- Tire fitmment question
- Does this Alignment look good?
- Need new tires...and I'm broke
- What camber plates will fit on bilstein pss9?
- Another amazing experience with MAPerformance!!!!!!
- Street/Track tire's
- High HP Suspension tips Bilstein Shocks or Coilovers
- Evo X front brakes -> Evo IX
- Lowering springs on bilsteins
- Tire trade worth it? Eagle F1 for Nitto 555
- Buy 4 wheels or 5 wheels?
- Importance of rear brake pads
- need to replace blown re01r
- Fortune Auto 500 Coilovers with different spring rates - opinions wanted
- HELP! OEM schocks or coilovers
