PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74
  1. Cosmis MRII
  2. Varrstoen MK5 Wheels
  3. New Max Performance summer tire, Kumho Ecsta PS91
  4. Front ball joints for stock suspension
  5. I F*cked up
  6. Evo 4-7 knuckle and brembo brake question
  7. Rear Ball Joint source?
  8. Anyone run 245/40r18
  9. 225 / 40 / 18" tyre pressure track / street
  10. Swapping front swaybar back to stock?! (Serious track opinions needed)
  11. Roll center kit worth it while instaling new Bilsteins?
  12. Brake Issue - Master Cylinder?
  13. Heavy street and some track use pads: Pagid RS29 Vs CL RC8 Vs Endless CC-RG
  14. best braided stainless steel brake lines?
  15. evo 7-9 brembo brakes on a evo 3
  16. Spring Rate Upgrade
  17. Track day street tire options
  18. Powdercoating Brembo brakes
  19. Evo 7 control arms
  20. Low Speed Popping - Check Your Power Steering Lines!
  21. Bad suspension setup?
  22. Looking for this rims
  23. TC105N 17x9 25offset
  24. Stoptech Trophy ST40's only in the front :)
  25. Question about wheel knock off VSXX offset fitmit
  26. Preferred Camber plates for oem struts?
  27. Sensible summer tires
  28. SSR Professors SP1 on Evo X
  29. Manufacturers Spring Rate Q's
  30. Where to buy Linea Corse Lemans
  31. Anybody ever buy the Avid.1 AV20? 18x9.5 +22 fitment question
  32. need part # bolt for sway bar bracket to lower control arm
  33. Any Brake pads recommendations for my Evo 9
  34. 17x9 +35 Work VSXX
  35. Ohlins Road Track coilover spring specifications
  36. Jic zms s/rs/rs2
  37. Yet another "what tire is right for me?" thread..
  38. Replacing factory springs - help please
  39. KYB OEM top hat replacement - EVO IX
  40. Best Current Replacement for A046s
  41. Just got my new Ray's and Tires
  42. Tires: Direzza ZII Star Spec vs Michelin Pilot SS
  43. center caps
  44. Rear brakes squeaks
  45. Rookie Wheel Offset Q's
  46. Odd handling only in rain/tar strips
  47. Anyone use CKS Coilovers? Suspension advice needed
  48. Installing IX Bilsteins on a 03 Evolution
  49. rpf1 and federal tire fitment
  50. XXR 535's
  51. Evo 5 RS front and rear end links
  52. Widening Rear Track: Spacers vs new control arms
  53. E-brake Adjustable?
  54. Alignment Issues
  55. Energy Suspension Bushings
  56. Undercarriage Crossbar (Brace) Removal
  57. wheel decision help
  58. Will enkei tenjin clear evo x brakes?
  59. rt-700 Out of business
  60. Michelin Pilot Sport A/S 3+ First Look Review
  61. Rear Brembo Caliper Mounting Points?
  62. FSB Attachment
  63. Suspension
  64. Rear upper control arm problem.. RALLY!
  65. Racing Brake Centric rotor combo
  66. Whiteline ALK/Perris PSRS Install
  67. Power steering
  68. Getting 2nd hand Bilstein MR's on a '05 GSR...do I need extra parts?
  69. Stripped Bolt on front subframe crossmember
  70. Rear control arm issue
  71. Wheel fitment question? 17x9 +30 offset
  72. Need aftermarket parts for my evo 8
  73. Megan rear camber arms
  74. Jaguar S type R brembos
  75. Lower arm bars
  76. Evolution 4
  77. Work CR Kai's 18x9.5 +30
  78. Rear camber bolt won't get tight
  79. Something similar to discontinued TEIN TYPE FLEX CONTROL MASTER?
  80. Brakes spongy after Girodisc caliper rebuild
  81. Help on new strut setup
  82. Outer Tie Rod End Replacement, Non OEM
  83. normal tires on drag strip?
  84. Bught new Bilstein HDs - what else do I need?
  85. All NT03 owners, need info
  86. Spacers
  87. RPF1 Alternatives
  88. Brake Noise
  89. Oem bbs wheels
  90. XXR 527 Forged
  91. fender rolling shops in so cal
  92. White line rear bump steer bushing
  93. Strut Brake Bracket
  94. Review: ST/KW 25mm Rear Sway Bar
  95. Front calipers pistons leaking brake fluid
  96. Tuning out understeer on evo 9. Track advice plezzz
  97. 18mm or 20mm spacers to clear 18x9.5 +38 Rpf1????
  98. Ohlin vs Fortune Auto
  99. Lower Control Arm-Front-Bushings (MR519675) - Specs?
  100. ST rear sway bar
  101. AP Racing/Essex CP8350 Brake Kit Review
  102. xxr 527 Evo 9 help
  103. Coils or springs
  104. Aftermarket Brake Pump for Evo 6
  105. Evo 9 KW V3 suspension vs D2
  106. Enkei RPF1 17" (9.0) VS IX OEM BBS
  107. Making the switch to coil overs
  108. Fd wheels
  109. Wheels fitment with brakes ???
  110. Brake issues
  111. BFG G-Force Comp-2 A/S review
  112. Anyone tried the nokian hakkapeliitta 8 studded tires on their evo yet?
  113. Tire and alignment question
  114. Suspension rough with cold. Suggestions/help
  115. Pads for Ralliart BBK
  116. Evo 4 CN9A Brakes aftermarket oem size options?
  117. Evo IX OEM Strut Assembly Replacement Options?
  118. Track Pad Selection
  119. Spacers??
  120. Need assistance for alignment values
  121. Pros and Cons for going from 17inch to 18inch?
  122. Need Advice re High Performance Summer Tire in Snow
  123. Drifting angle lock kit
  124. 18x10 wheels w/o fender work possible?
  125. Best Pillow Balls for KW V3 Evo 9
  126. Sizes
  127. Best coilovers for my Dd evolution 9?
  128. Lowered car, realign urgent?
  129. ce28 18x9.5 +42 for $700
  130. Rear camber adjustment
  131. Does alignment need a specialist?
  132. Mismatched Tires
  133. aluminum aftermarket gold control arms
  134. Evo 7 and 04 lancer cedia
  135. Lower Rear spring perch orientation
  136. Can someone tell me what springs setup he has exactly?
  137. what's the best trackable summer street tire?
  138. Stock struts with after market wheels
  139. Wheel Bearing / Diff Noise?
  140. Has anyone used Hankook V12 Evo2 tires?
  141. Does anyone still use Motorcycle slicks?
  142. Anyone tried Bridgestone Potenza RE 003s?
  143. Front camber bolts fit in the lower strut bolt hole?
  144. better to buy 8.00,8.25 or 8.50 x17 tyres?
  145. RS brake help
  146. New XXR 527 size 18x8
  147. New XXR 527 size
  148. Smaller brake discs
  149. front camber adjustment
  150. All around brake job
  151. complete bushing replacement
  152. Spherical/pillowball bushing for front LCA
  153. Drag Radials
  154. Best place to find stock IX Enkeis?
  155. Urgent - rotors
  156. Squeak noise from right rear when turning left
  157. R33 wheels on Evo 9 fitment help.
  158. Bilstein not rebuilding OEM Evo IX MR shocks??
  159. Cheap track day rim?
  160. Rotor suggestions
  161. Calling out anyone with Carbyne Design wheels
  162. GT Radial Champiro SX2
  163. Energy suspension hyper flex master kit
  164. Evo IX Wheel help South Africa
  165. Ohlins road and track coilovers
  166. Air leak sound when braking. Can't figure it out.
  167. Roll center kit... are the current kits not as useful as one thinks?
  168. will evo 8/9 tie rod end and stabilizer link fit evo 6?
  169. Kw coilover rebuild
  170. tien camber plates over stock strut mounts?
  171. D2 street spec coilovers road trip review
  172. Uneven Trailing Arms
  173. Abnormal wear? Hankook RS3
  174. Better wet traction...
  175. Mustang wheels on a evo8
  176. Varrstoen ES2 18X9.5 +30
  177. 17x9 et 21. will they fit?
  178. reclear brembos
  179. Clicking while braking
  180. Another review for the Bridgestone RE-71r
  181. D2 street spec coilovers unboxing first impressions
  182. K Sport Kontrol Pro CMT150-KP
  183. How to: ABS removal with ACD working Evo ix
  184. how will the fabrication/cage pictured affect handling?
  185. Semi slicks
  186. review: Bridgestone RE71R
  187. Achilles ATR Sport in snow?
  188. What brake fluid are you using?
  189. Federal 595 RS-RR review
  190. $108 brake pads/rotors for all 4?
  191. I need these wheels!
  192. Evo IX Aftermarket Wheels
  193. 1996 Evo IV rubbing on struts
  194. Fitment help please
  195. SuperPro DURO3741K Duroball spherical bearing for front control arm anyone?
  196. Ohlins Front Suspension Noise Over Bump/Holes
  197. going +-3k on coilover valving?
  198. Delayed steering response?
  199. Street Warrior Z26 Brake Kit?
  200. +48 rims with 235/45/17
  201. Enkei WRC Tarmac Evo
  202. Standard 17inch wheels with spacers?
  203. Braking 101
  204. Brembo piston stick :(
  205. ID this set of wheels please!!
  206. AST 4100 vs FA 510
  207. FS-PA-18inch Work Emotion CR Kais
  208. Higher HP Street Tire Question
  209. Anyone used 88Rotors?
  210. Evo 5 leaking shock absorber
  211. Stripped wheel stud with wheel on it.
  212. evo 6 urgent help needed
  213. d2 coilover spring rate suggestions?
  214. Help - Best wheel & tire size set up for circuit racing
  215. New suspension suggestions please!
  216. Difference between USA evo 9 mr and evo 8 mr suspension
  217. Suggestions for springs?
  218. Question About FA500 Suspension rates
  219. Stance Super Sports
  220. Whiteline Rear Sway Bar (RSB) Bushings Wear Out in Three and a Half Years?
  221. Pls help/advice tire size
  222. Direzza DZ102
  223. Are evo 8/9 shocks same as evo 10?
  224. NEW ZEALAND OWNERS - wanted evo 5 wheels
  225. Will this tire run? 275/40/r17
  226. Loosened Strut Tower Nuts
  227. What type of coilovers do I have?
  228. NT03 fitment question
  229. Frame rail question
  230. Evo IV brembo upgrade - will my wheels fit?
  231. Strut top bolt size?
  232. rotor dust shields
  233. Alignment issues
  234. Not so Advanced Auto...7 different lug nuts none fit.
  235. Rays gramlights 57optamise time attack
  236. What size spaces for bbs rs rims?
  237. tire size help?
  238. EVO VI control arm bushings
  239. bilstein qestion with lowering springs?
  240. Unable to align car?!?!
  241. evo8/9 top mounts/hats compatible with evo6?
  242. New Brake pads
  243. Evo 8 and 9 steering racks compatible?
  244. a wheel size and tire question!
  245. FEBEST 0420-CT9 Front Lower Ball Joint
  246. Enkei NT03 center caps
  247. Aggressive street radials on stock 17s
  248. OEM Front Tie Rod end help
  249. Suspension 101
  250. rear wheel hub assembly part #?
