PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74
  1. what cross drilled or slotted rotors to choose from?
  2. Wobble while braking...
  3. Nokian RSI Winter Tires
  4. Help!!!!!!!!!!!
  5. MR Suspension Into An '03???
  6. Just installed Pirelli Pzero nero m+s
  7. Ohlin Coil Overs ???
  8. Powdercoating stock Enkei's black?
  9. Darn rotors, help?
  10. It's starting to get cold when to put the winter tires on?
  11. Mr. Bbs Wheels
  12. Brake Problems
  13. Any Gold rims for evo8?
  14. Advans on MR question
  15. TOYO RA-1's as STREET TIRES
  16. Has anyone polished their stock wheels?
  17. Azenis Sports vs Azenis ST115
  18. Pics of EVO Lowered with Eibach Pro Kit plus Review!!!
  19. Starting to Cold...so which tires?
  20. Purpose of hub centering rings?
  21. New wheels/tires on my EVO - pics....
  22. Falken Azenis ST115 vs GR Beta FK-451
  23. Will the WRX STI BBS Rims fit on the EVO??
  24. What would it take to do a 1g skidpad??
  25. tires wearing..rain coming..good place to buy from?
  26. TEIN S or H
  27. Rims with no center cap/covers.
  28. Looking for snow tires!!
  29. SSR Competitions fragile?
  30. Need help on wheel fitment!!!PLEASE HELP!!!
  31. Stiffest tire? Closest to Advans
  32. New wheel from Final Speed
  33. 17 inch Steel Rims
  34. Wheel Opinions: MB Motorsports Weapons
  35. Toyo Proxes 4
  36. IMHO JICs suck.
  37. Installing Cusco Lab Ver1 and Ver2
  38. Has anyone added ABS to an RS?
  39. squeeling stock brakes
  40. Increased road noise with pillowballs[?]
  41. JIC Install and alignment
  42. East Coast suspension guru?
  43. Lug nuts for longer wheel studs
  44. wtb stock wheels
  45. Wheel locks
  46. New Brembo Brake Pads and New PS2s
  47. Weds TC005
  48. I need one stock used tire-
  49. How do you calculate Max Tire Load?
  50. What color is "Hyper Black?"
  51. What is the correct STOCK wheel size?
  52. Pirelli P Zero Nero M+S?
  53. Alignment specs
  54. Inexpensive black 5-spoke rims in 17x8?
  55. Alignment and Steering Question.....
  56. Alignement/Steering Wheel Question....
  57. is this a good deal of is there a catch?
  58. SSR GT2 - thanks Z1Auto
  59. Hotchkis Spring Review
  60. Front Caliper discoloration?
  61. Photoshop request
  62. Stock Rotor Problems!
  63. OE replacement rotors...
  64. Tire rack find...
  65. 8800 miles and need to replace drums and rotors?
  66. New Project MU pads installed
  67. Daddy need new shoes, so I got Pirellis to look mean on 22's
  68. Cheap 17x9s (other than FN01RC)?
  69. Suggested Alignment Specs for wheels and S Tech springs.
  70. ALignment is bad, here are Numbers Need help!
  71. Looks like a bad set up tires, falling apart
  72. idea tires for 17x 8.5
  73. Continental Extreme Contacts, Where did you buy from?
  74. Good non-directional tires?
  75. Need pics of Black evos with PAINTED wheels
  76. Questions with wheel fitment and S-tech springs??
  77. Brembo Brake Inerchangeability
  78. Squealing Ferodo DS2500 brake pads
  79. Cheap winter rims for snow tires
  80. LOwered Car and now there is a knock
  81. Bridgestone Praxis System for EVO
  82. Blizzak LM-22 vs. Blizzak LM-25 -- differences?
  83. Weird steering wheel vibration
  84. verifying tire size
  85. need pics of white evos on enkei WTE II's
  86. front strut bar
  87. help me choose between the two..
  88. 18" X 9.0" wheels - yes/no
  89. suggestions, tires for the winter?
  90. Toyo RA-1 on track - question
  91. Question about tires and balance...
  92. Emotion CR Kai's
  93. Cusco sway bar bushings?
  94. Tein - S Spring
  95. widest tire on a 17x9 with a drop?
  96. Does anyone make an 18" version of the stock wheel?
  97. would you ever get replica wheels?
  98. Best tires fo the drag strip?
  99. Installed: Kumho Ecsta MX 255/40/17 on stock wheels
  100. To resurface or not to resurface when replacing the pads.....
  101. Will 16 inch rims fit Evo 8?
  102. Check my New Volk GTU 18x8 on White
  103. Big thumbs up to TIRERACK
  104. Will my 18x8.5 rims with 245/40 tires rub w/these springs?
  105. If front is lowered more than rear, is it bad?
  106. Best All Season Tires
  107. just my luck--got my gram lights today
  108. Fitment question (17x8, +43)
  109. BFG KDW stats
  110. Post Pictures of EVO Dropped w/ Springs
  111. New Rays wheel
  112. Impressive service from Stoptech!
  113. Where can I get replacement Brembo stickers?
  114. question:any one with 5n01rc rims
  115. Zeal V6 Mini-Review
  116. The Firestone Quick Adjust Bolt Mod
  117. alignment
  118. Neal! Bad Tires!??
  119. Important Tire/Wheel Info For All In Maine!!!!
  120. stechs vs. tanabe
  121. Where to buy RPF1 in gold
  122. Apexi Coilovers opinions?
  123. has anybody lowered your EVO yet?
  124. Will ASA JS5 17" or 18" fit Evo?
  125. Lighter rotors for the evo
  126. Brake help....
  127. ? on cornerweighting
  128. Fitment question (18x8 45mm offset)
  129. bilsteins or aftermarket?
  130. Best tire for wet conditions
  131. R-Compound Tire, CHEAP!
  132. Does lowering the car worsen Performance around the curves?
  133. Project Mu NS Pads...Love them!!
  134. SPrings Springs SPrings
  135. Track settings for a 04 RS?
  136. From stock tires to BFG T/A KD
  137. Brake Bleed questions
  138. 4 Piston Rear Brembos???
  139. springs for trunk w/ stereo?
  140. anyone knwo what wheels these are?
  141. 18" Enkei RS5 fit Evo?
  142. 18x8 +30
  143. stock brakes.help??
  144. Max Camber out of Stock car/Camber plates
  145. Suspension Bushing Upgrade?
  146. Brake Pad suggestions
  147. Storage of Mounted Tires
  148. Attention: Tein Flex owners
  149. Volkers for the Evo
  150. Bent on which rotor to buy :/
  151. Neal - SSR GT2 sizes?
  152. tire pressure
  153. Woudl you buy Yokos again?
  154. Where can I get a new Advan today!?
  155. 3mm spacers affect handling?
  156. Need some new rotors
  157. New StopTech article on brake pad bed-in
  158. My Evo tires were 40 psi when picked up new.
  159. torque wrench
  160. JIC problem
  161. Tein Flex question
  162. Tein STechs - Going for another allignment...
  163. Who makes the lightest wheels?
  164. Alignment after Drop and rear sway bar feels worse...
  165. request
  166. Anyone has Dunlop SP Super Sport Race?
  167. Work Emotion CR
  168. Larger rear bar -- Does it stick the front or unstick the rear?
  169. 18" x 8.5" TE37's / Fitment Question
  170. alignment
  171. EVO Trunk Bar Solution - Cheap and Clean!
  172. will lowering the EVO make it handle worse?
  173. Gurus and track monkeys: help needed with ideal suspension setup.
  174. 255/40/17 Azenis
  175. Suspension ?s
  176. Pad material transfer to rotors?!?!
  177. Wish me luck
  178. Wear rate of the front original rotors - EVO 8
  179. Cusco Rear Sway Bar On Stock Car?
  180. Next year i will buy new Wheel's but... which ones.
  181. shocks
  182. Tein H-Tech springs
  183. 17x9.5
  184. Cusco Rear Sway bar settings
  185. Good deal on tires?
  186. Brake sqeak after Alignment!
  187. Just installed Tein RAs
  188. Black wheel look
  189. Need Rojas wheels, 19x9...
  190. Ohlins coilovers
  191. Question for the tirerack people
  192. I think I messed up....
  193. Need adj. rear sway bar tomorrow, help!
  194. BFGoodrich g-force Sport 245/45/17
  195. Racing Hart Cx's
  196. Which TEIN coilover setup?
  197. Gram Lights 57S - colors? Recommendations?
  198. Official HKS coilover review thread
  199. Winter Tire and Wheel Reminder
  200. toyo proxes VS Pirelli's
  201. EBC greenstuff owners
  202. Tein coil-overs
  203. car making squeaking noise.
  204. HOW MUCH TIME DIFFERENCE FROM 17" to 19" WHEELS??
  205. LTB Motorsport.... Sucks!
  206. A lil' Pkg came today
  207. Flushness may be my enemy (need advice)
  208. tire pressure
  209. Tire's keep wearing out... i need help...
  210. EVO back to the dealer...
  211. teaser pic of new rim
  212. what are you useing for winter wheels and tires?
  213. Best street tire for autocrossing on 17x9 rims
  214. question about rims size
  215. Bigger tires and Gravel Roads
  216. Ultra high performance tires for New England???
  217. fitment issue?
  218. I need HELP Adjusting my Caster!!!
  219. Anyone with 18 advan RGs on rally red?
  220. Weight of stock EVO Enkei rims?
  221. Talked to Hawk Perf. (Brake pads) today
  222. Lightweight Rotors
  223. Cusco sway bar torque spec
  224. Many Questions? Everyone please look.
  225. Aligment- any regrets after you changed it?
  226. Front Lower Tie Bar
  227. Question?? Any Help?
  228. Vendors who sell Zenki lugs?
  229. Widest Cheapest Lightest 17" wheel i can buy....?
  230. Neal!!!!!!!!
  231. Lower car for free!?!?
  232. I Need New Tires
  233. Time to buy tires......
  234. Anyone using hubcentric spacers like H&R
  235. help with brake pad question
  236. cusco 6 point roll cage
  237. RA springs
  238. cusco sway bar question
  239. Best Track Coilovers??
  240. Would you even put these tires on?
  241. Looking for Axis Hiro and tires
  242. Privat Zwanzig rims?
  243. My new wheels
  244. Michelin Pilot Sport PS2's
  245. Coilovers or Springs?
  246. Cusco + Vivid = happy!
  247. Steering Wheel Off-Center after Alignment
  248. Lug Nut ????
  249. want to buy rims now
  250. PICTURES of 17 wheels (other then Volk)
