PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74
  1. Brembo painting..!! i need Help
  2. Works Camber Plate Removal
  3. Looking for coilover
  4. 15mm spacers needed
  5. dangerous?
  6. CE28N Time Attack 'Japan Edition'
  7. Sway bars
  8. In need of stock Evo IX caliper mounting dimensions
  9. Swift Spring ?
  10. Small vibration at 75mph
  11. Rim Shopping....
  12. New Ame Tm-02 Release
  13. AMSOIL Brake Fluid ... Thoughts?
  14. Falken Azenis rt-615 or no?
  15. proper way to mount tires..
  16. G-Sport R1 slicks, anyone have info?
  17. Essenza Tires any good?
  18. Yokohama super advans ver. 2 scuffs and scratches.
  19. Blinking Anti-Lock Indicator
  20. Has anyone used these tires???
  21. Weight of 17x9.5 Enkei RPF1 in SBC!!!!
  22. quick rim question
  23. Anyone have any information on this set-up?
  24. Anyone running OEM size Stoptech slotted rotors? "Warped rotor" issue
  25. Tire Pressure
  26. Camber kit?
  27. wheel sapcers
  28. high speed brake vibration question
  29. Bilstein HD Application For EVO
  30. 235 40 18 on 18x9.5 rims?
  31. Remote Reservoir Coils
  32. How long did your Adavan stock tires last?
  33. Installed 2 piece R.B. Rotors, Hot Lap Brake Duct Kit and Whiteline R.C.A.
  34. coilovers making noises
  35. How to tell if brakes need rebuild?
  36. Advan A046D 235/45/17's
  37. What happens if i drop my car?
  38. Brake Light on and off while driving when really cold.. Any ideas??
  39. Alignment spec ?'s
  40. ce28 weight differ from each other
  41. Lots of grease on rims-- help!
  42. mechanical grip
  43. 265/30/19 on 8.5's? should fit..
  44. E brake...need help!
  45. Stock advans vs 255/40 azenis
  46. EVO9 AXLE: how much abuse(hp)can it take
  47. street brakes question
  48. How Long Did It Take Your Stock Struts To Blow Out After Installing Springs?
  49. Alignment help
  50. stock wheel weight
  51. Why people choose 17x9 over 17x 8 and they are both putting 255's tires????
  52. Toyo RA 1 heat cycling?
  53. StopTech BBK 332mm
  54. Will This Fit? 18x10 +22
  55. recommend me aggressive deep wheels for my silver ix
  56. Powdercoating BBS wheels = Good Idea?
  57. Quick Brake Bleed Question
  58. Best Balanced Size
  59. tenzo dc-6 18 x 8?
  60. Please Help! Very annoying!
  61. Can the Evo suspension take well to bumpy roads?
  62. Shave Rotors?
  63. Agressive Suspension
  64. Stock ADVANS, Winter, and Me....
  65. Track and race season is coming - what are you running?
  66. quick help: changing brake lines
  67. Driveshaft Hub seperation problem Evo 8
  68. Dealership Scratched My Rims
  69. Tell everyone what u think about your aftermarket tires and compare
  70. Caliper torque specs?
  71. volk
  72. Tire change question.
  73. any pics of?
  74. Evolution 1 - 3 Stock Spring rates.
  75. wheel spacer
  76. Should i purchase new rear rotors?
  77. SS Brake Lines
  78. Will gram lights 57 optimise match apex silver
  79. *** Rubbing Concerns (235-40-18) ***
  80. Recommended wheel offset on Endless 6-pot calipers?
  81. CCW Wheels?
  82. Brake pin wont come out.... anyone had this problem?
  83. NEO CHROME aka Aurora plated wheels? anyone run them?
  84. Found some information on Tenzo wheels
  85. 18 x 9.5 35 mm 5zigen fn1orcs 265 or 255
  86. Stock brakes not so durable
  87. Need E brake adjusted !
  88. is $2000 for a set of volk rims + falkens
  89. Enkei PRF1 17x9 offset?
  90. Expereince with Girodisk
  91. Benifitcal suspension bushings
  92. squeal when I turn wheel all the way and brake
  93. Azenis = sh*t?
  94. pad life...
  95. swift sway bars
  96. Do I need to roll my fenders with this setup?
  97. recently lowered car drives fine, still need alighment?
  98. tein s-tech ?
  99. 18x9.5 +25 Bbs Rg-r??
  100. Hubcentric Rings Who Uses Them??
  101. Brake system question?
  102. Evo Thread Pitch For Lugnuts???
  103. rotor
  104. Toyo RA1 vs Advan A048
  105. Megan Coilover Durability?
  106. good coilovers for the street/ track bot circle and strip
  107. brakes squeekin AND.....
  108. 16" Rims and tires for winter?
  109. H&R Coilovers?
  110. Alignment Issues
  111. KWV3 coilover assembly question(s)...
  112. Won a set of Bridgestone's what size?
  113. High temp touch-up paint for Brembo's?
  114. fender rolling question
  115. Evo IX Stock Alignment Specs?????
  116. help ?
  117. Why are EVO brakes to blasted expensive?
  118. General Altimax Arctic?
  119. What wheels are these?
  120. 18"x9.5" @ +27 / +36 offset Prodrive GC-05F
  121. 17" work emotion chrome
  122. wheel locks?
  123. Pics of your wheels on you evo
  124. Whiteline Roll Center Correction kit--need some help
  125. spring install.. will I lose stock feel??
  126. coilovers
  127. 18x9 +29 tire size?
  128. Help with some questions...
  129. Powder coating wheels
  130. wheels offset
  131. Who has Tein SS OR BC Racing coilovers installed? Which is more like stock?
  132. MR bilsteins w/swift. sway needed?
  133. Advan TCII , Spokes ?
  134. Official - 17" Wheel Thread
  135. staggered offset question
  136. how is it to get service for Ohlin's coilover?
  137. Steel wheel alignment....
  138. 17s vs 18s
  139. Best snow tires?
  140. Titanium brake shims
  141. Damaged stock wheel with lugnuts--fixable?
  142. Best Coilovers For Evo Se?
  143. Is there a way to measure tire contact patch or grip?
  144. Anyone have opinion/used VOXA rotors?
  145. Wide Body Offset
  146. Whats the best tire for..?
  147. First impressions: Goodyear F1 AS tires
  148. Nokian Hakkapeliitta FTW
  149. struts vs. coilovers
  150. DC-5 or DC-6
  151. Big as possible
  152. Mintex disc pads
  153. coilover valving
  154. WTK: Evo IX Brake and Wheel Hub Specs
  155. Having some Braking Issues
  156. Any difference in spring rates between Evo VIII & Evo IX?
  157. For those of you running snow tires in the snow
  158. What Size Tire???
  159. handling/tread life for summer tires
  160. Is 265 too wide for street driving?
  161. Evo VIII & Evo IX OEM shocks and struts the same??
  162. installed new pads and rotors...draggin brakes/buzzing sounds
  163. 18"x9" vs. 18"x9.5"
  164. How do they last "Hawk HPS"
  165. Lookin to do some Brake upgrades...
  166. Would a 18x9 +20 fit an Evo 8 no problem?
  167. Rota P45R's: Gloss Black w/ Red Lip vs. Royal Black w/ Polished Lip??? **POLL**
  168. Curb Rash + Some
  169. Quick Question
  170. Advice on bushing press
  171. Sport Max wheels
  172. Aftermarket Valve Stems
  173. Camber kits: what do you use?
  174. What else do I need besides lowering springs?
  175. good non noisy tires ??? which one to choose from ?
  176. Whiteline Max-C Camber Plates just released!!!
  177. Interesting Tire/Wheel Factoid
  178. f/s tristsre/ 06 se bbs wheels
  179. Best sway bars / biggest sway reduction?
  180. Ride height adjustment and its effects on the suspension setting
  181. Volk Sf-Winning
  182. volk gtps off of 3000 gt
  183. wheel spacers
  184. stiff brake pedal?
  185. calculating offset question..
  186. Pic Request: Evo w/ SSR Type-C RS Wheels
  187. Pillow ball mounts for stock shocks
  188. Yokohama W4S
  189. Got an alignment
  190. found some wheels... need help?
  191. MR Wheels
  192. wheel shaking strange noise question
  193. shock education
  194. Max Tire Size
  195. Winter Tires: quick answers, quick questions...
  196. MR Bilstein and Swift Spring Combo or Megan Coils ????
  197. new shocks
  198. OEM wheel fit 245-45-17 tires?
  199. blizzaks
  200. i'm so happy, got to share some news
  201. Rota P45R +15 Front Offset
  202. Ksport pillowball top mount installation?
  203. outer tie rod replacement
  204. What a piece of cake to install pad shims...
  205. More than just bilstiens....
  206. Enkei RS5 wheels and tires help
  207. Blizzaks
  208. Sport Compact Car Brake Upgrade Review Evo VS STi
  209. ARP wheel studs installed
  210. Official ADVAN Wheels Thread - RCII, RG, RGII, RS, TCII, Kreuzer, etc
  211. Smoother/better ride
  212. P45R in Red Metallic with Silver Lip
  213. ssr gt2 white wheels with tires
  214. New brake pads means new roaters?
  215. rota p45r's
  216. I'm looking
  217. My Jic A2 experience....
  218. steel rims
  219. Which Michelins?
  220. Wheel fitment question!
  221. Nokian vs Nokian (for winter)
  222. Camber plates or eccentric bolt?
  223. Kosei K1 17x8 - what tires
  224. Question about offset fitment. .
  225. help wheel noise
  226. Endless Braking System Installed - Photos and Weight Comparison
  227. 16s..what rim
  228. Suspension Settings For Drag Racing
  229. Enkei RPF1 questions
  230. Need some wheel info please
  231. Looking for opinions: DMS 40mm
  232. wheel spacers...
  233. Look what happened today =(
  234. powdercoating mr wheels part 2
  235. Hawk HPS Brake pads are squeaking.
  236. ERRRRRRRRRR my wheel jsut about fell off!!!!
  237. Snow tire traction
  238. Wheel lugnuts
  239. Need info on Bilstein HD and springs
  240. Did I receive real Buddy Club QF's ?
  241. stock dampers+swift or mr dampers+gf210
  242. Broken Rim!! HELP
  243. optimum tire pressure for 245/45r17 falkens
  244. Ideal tire pressure for some 245/40/18's?
  245. 255/40/18
  246. Volk te37 bronze color code
  247. Hotchkis and Bilsteins
  248. Adjusting Rear Camber
  249. Good Year Eagle F1 All season
  250. requesting pic
