PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74
  1. Stock vs swift sport..... help me tom cruise!
  2. Girodisc is Introducing a New Brake Pad Line - Help Us Name It!
  3. It's time for brakes, and i'm doing it all!!!
  4. Will this big brake kit fit behind stock wheels ?
  5. Lug nuts for 18x9.5 +38 RPF1
  6. Opinions on wheels that look similar to XXR 527s?
  7. Rear Spring Spacer Help..
  8. Metal on metal sound when driving, vibration?
  9. Looking for some wheels for my GG open to advice.
  10. brakes squealing/squeaking
  11. Camber kit questions
  12. Where to buy PSS9 adjustment wrenches
  13. ?n SPRINGS OR COILOVERS???
  14. brakes seem to always be applied
  15. Winter Season Reminder
  16. My new Evo and AutoX Experience
  17. Snow Tire help??
  18. Replacing front inner tie rods and rear wheel bearings need advice!
  19. Enkei RPF1 18x9.5 +38 fitment
  20. tires opinion
  21. Strange noise from front left
  22. Ford Revo Knuckle and GM Hiper Strut
  23. EVO V Winter Tire Fitment
  24. Neal out till Sept 24th
  25. What size tires
  26. How can I stop Hawk HP+ Pads from Squeling so much?
  27. master bushing kit questions
  28. MR Billsteins Replace or Repair
  29. 4D tires
  30. Faded calipers
  31. Bilstein rebuild turn-around?
  32. evo x wheels ??
  33. Hoosier oval track tires for drag racing
  34. speedline turini
  35. Buying "old" tires?
  36. Front L/R shocks part number same?
  37. Wheel trivia! Will they fit?
  38. ra04 raliiart enkei wheels
  39. Getting TE37 to fit?
  40. Pillow ball mount issues - advice needed
  41. Weird Vibration 40-60 mph
  42. Best lowering springs?
  43. 18x8.5 et 44 ??
  44. Opinion on Rim size for 2.4l Street/Strip/Track Combo
  45. xxr 521s
  46. Brake issue after motor build
  47. outer tie rod different sizes?
  48. XXR 527 issues!
  49. Backing nut in front subframe broke loose - what to do?
  50. 2006 MR Noise While Turning
  51. Street Tire Pressure
  52. Top Mounts/Bushings
  53. Help diagnose Track Tire wear / setup
  54. Are My Toe/Camber/Caster Within Limits
  55. Enkei nt03 sbc?
  56. tire size question?
  57. ABS light on in the wet
  58. Rear suspension squeak
  59. Volks...
  60. wheel centering issue, help!
  61. How to get nut off rear strut?
  62. Popping noise at low speeds
  63. Help with wheel fitment
  64. New Rims for evo VIII
  65. Help with STANCE combo.
  66. [ Info needed? Brakes, Pedal goes down too much ] -.-
  67. Getting my rx7 wheels on Tuesday need help
  68. Nitrogen Tires?
  69. Staggered.
  70. 16x8 +20 offset ????
  71. XXR 527 Fitment on Evo 9 ?
  72. Neal out till Sept 4th
  73. Would you guys replace these pads?
  74. Well I think I've finally found a decent Rays/Volk bronze paint!!!
  75. Ceramic Pads and Slotted/Ported Rotor Squeel
  76. Body Roll
  77. EVO 9 MR with Megan Racing Street Coilovers Review
  78. What tire size to use with Volk TE37 18x9.5 +22
  79. Qu: Autocross & Stretched Tires (10.5"x245)
  80. My brakes breaked...
  81. open ended lugs for stock gsr wheels?
  82. Suspension Question
  83. Tein Mono Flex instructions
  84. Rough bumpy ride need advise.
  85. EBC OrangeStuff Review
  86. BC Racing BR series coilover damping settings rough Street use
  87. Questions about Lowering 06 MR
  88. Help with a final decision - coilovers
  89. Ohlin's R/T DFV installed, settings?
  90. Request: 17x9.5(+xx) & 18x9.5/10.5 Enkei Nt03's
  91. Brake issue,has anyone heard of this?
  92. axle / a arm question
  93. Sub Frame Rigid Collars
  94. xxr 527
  95. wheel lock help
  96. Race pad question...
  97. TE37 18x9.5 or 18x10.5
  98. doing mild sus upgrade, help w/ supporting parts
  99. Went to get alignment think shop is screwing me
  100. Roll Center Kits results and longevity
  101. looking to do psrs kit/ bump steer and some other goodies, what bushing tool kit??
  102. ABS Sensor broke at knuckle
  103. Mustang SC Replica Wheels
  104. Best long lasting brake pad to buy to replace stock Evo 8 pads?
  105. GT Factory (Powered by Max) Suspension
  106. 15 by 8 centerline wheels w/ slicks
  107. What's the difference?
  108. what wheels are these?
  109. MR Bilstein + swift PLEASE HELP!
  110. Need wheels polished
  111. Strut question
  112. rear control arms?
  113. Replaced wheel bearing still have noise!!!
  114. any other mitsu cars using same center caps as IX gsr enkei wheel
  115. Star Spec II, Star Spec I, or RS3
  116. Zeal function x coilovers
  117. want to run slicks
  118. Need new 255/35/18s, suggestions?
  119. varrstoen es221 + evo 9 brembos
  120. RobiSpec ClubSports vs Ohlins Road & Track Coilovers
  121. HKS Coilover Upper Seat Picture
  122. SUPERTURISMO LM 18 or 19
  123. wire sticking out of brake pad?
  124. brakes alil hard!
  125. RPF1 Question
  126. lenso spec b
  127. Neal out till Aug 13th
  128. PSS9 vs. bilstein MR/swift combo?
  129. rear upper a arm adjustment?
  130. Anyone go with MAP Stage 2 Brake Package??
  131. Help: Steering Wheel L/R Shift ?
  132. EVO MR Bilsteins vs. Bilstein HDs
  133. Looking for real information about rear suspension ball joints and bushings
  134. Xxr 521 what tire size?
  135. Swift sport lowering springs any good? Can they be used on stock struts?
  136. HELP! Wheel Lug stripped
  137. Lisle Corporation Pad Spreader - Do you recommend?
  138. stoptech, girodisc, and ferodo pad reviews.
  139. Plastidip stock 8 enkeis black on a GG car?
  140. Brake rotor question
  141. Whiteline Upgrades
  142. All season tires?
  143. Saw these @ Mod
  144. Breaks sound like handbreak squeeling
  145. Evo X Suspension
  146. Tire Dilemma
  147. Overall Suspension Question (mostly auto-x)
  148. 5mm spacer on stock studs or go with longer studs?
  149. comments on the bfg Sport COMP-2
  150. Will 235's fit on 17x9+30??
  151. Real cheap coilovers/which brand or stock Evo MR Suspension for an Evo VIII?
  152. What front/rear swaybar combo for Bilstein + Swift Spec-R combo?
  153. Quick bolt size needed
  154. Evo 8 GSR strus with MR springs.
  155. Evo IX MR - Creaking Ship Noise When Turning Wheel
  156. Stretched tires with camber effect inner wear??
  157. anyone know the price for TME suspension
  158. New Rotors
  159. APR extended wheel studs...need lug nuts!!!!
  160. IX Bilstein shocks + king springs vs other brand
  161. BFG Drag Radials
  162. Brake pad clips, brake pad play
  163. 245/40/17?
  164. replacing just the front pairs of Strusts with Bilstien HD
  165. Bilstein MR shock factory rebuild experience?
  166. Tire suggestion between Nto5 or Rs3
  167. Rota p45r +30 stud extensions needed?
  168. Easton Fender roller vs. KTC fender roller
  169. Fender rolling question
  170. 18x9 rpf1
  171. evo pulling to the right alignment?
  172. What suspension should I go with ?
  173. Evo 9 - leaking front strut and making noise on the right front
  174. AP Racing 5000 Pro + rebuild kit
  175. master cylinder sensor?
  176. Evo 8 wheels not centering like Evo 9 wheels?
  177. Works 2 piece rotors
  178. Picture Request Flat Black Rota Grid
  179. crazy stock rotors
  180. lowering 06 GSR IX
  181. abs light on
  182. Solutions for steering wander during braking, etc?
  183. Tanabe gf owners?
  184. Rpf1 lug nut question
  185. Wheel spacers on stock evo8 rims
  186. Fitment Question
  187. swiftech rear mounting
  188. Brembo Calipers need help asap
  189. 17x9.5 et 30 spacers needed?
  190. Look what the UPS man just brought.. Stance Coilovers!
  191. Wheels
  192. Robi KW shock data
  193. Decided to cut my fenders instead of roll them.
  194. rpf1 tire size
  195. winter wheel and tire combo question.
  196. Bilstein HD spring clarification: MR or non MR
  197. 18x10 +25. fitment on evo 8/9?
  198. Rays Engineering center caps
  199. New EVO 8 wheels
  200. Tein flex with EDFC
  201. "Black Diamond Finish"
  202. Coilover Springs: Swift vs. Hyperco vs. Tein
  203. Neal out till July 9th.
  204. Best Mixed Track brake setup for lowest price
  205. Brakes squealing only at low speeds
  206. I hate to make this thread - yes I've searched (front sway bar)
  207. Need Suspension Help ASAP
  208. Affordale tire input
  209. Need help! Tire question
  210. Clicking noise on driver side area
  211. HELP with damper settings BILSTEIN pss9 (coilovers)
  212. Help. Wheel Hop in rear w/stock suspension...
  213. 2005 Evo 8 CV shaft seals..nightmare!
  214. dunlop z1 what are people paying for them?
  215. rota g force fitment issue! help!
  216. HELP. cant get my axle out of the hub.
  217. Center Caps for Stock Evo VIII wheels?
  218. anyone tried these bump stops??
  219. Wheel Fitment Question
  220. Performance Friction Vendors?
  221. Rim dilemma need opinions
  222. Will these wheels work?
  223. Will it rub? P45r's
  224. ACD faults question
  225. Replacing front main crossmember/subframe
  226. Need Help With Understeer/Suspenshion Tuning
  227. Installing springs questions.
  228. Adjustable suspension for my Evo 9
  229. Evo 8 GSR with front Bilstein and rear KYB
  230. 265/35Rr18 Fitment Question
  231. Name that wheel?
  232. 96 EVO IV wheel bearings
  233. 6" Coilovers for track
  234. Dunlop/Goodyear super sale in misc sizes
  235. A couple Dunlop super sales right now
  236. swift spec r/ mr and bilstein revalve
  237. Spherical bearing size - PIC coilovers
  238. Want to achieve -4 rear camber?!?! tips
  239. KW DDC Coilovers
  240. Adjustable height ball joint replacement in the works . . .
  241. Clunk in rear passenger side
  242. frontend tight.
  243. Need Rotors/pad for DD/Street
  244. 05 Lancer es newbie question
  245. Cracked RPF's..!?!?!!!!
  246. Rotorpro + Brake Man 93's
  247. Shocks are dead
  248. Turns feel bit wobbly...
  249. Coilover advice
  250. How is ICHIBA spacer?
