PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74
  1. Best bang for the buck tire
  2. What spring rates to get????
  3. New Front Axle
  4. Are EVO 6 shocks compatible with an EVO 8?
  5. Flushing Brake/Clutch System
  6. ssr professor ms1
  7. Rota Grid 18x9.5 38mm???
  8. Rota G force 17 X 8
  9. Camber plate for stock struts!?
  10. Anyone put 245/40/17 R888 or similar tire on a 17x8....
  11. wedsSport sa 5m wheels
  12. Help finding link... Replacing dust boots on Brembos
  13. abs code
  14. What have you heard of these wheels?
  15. Replacing a broken front lug w/o removing the hub
  16. Steering Shaft Placement
  17. Hotchkis Rear Bar Mount Broken...?
  18. Alternative to Willow Wood Brake kit?
  19. Camber Tires - with molded in camber
  20. A-046 vs. A-048 Advans?
  21. PFZ pad problems?
  22. squeaking from rear?
  23. GTWorx spring review
  24. CLUNK! is it the axles, tcase, strut etc....???
  25. Brake problem! plz help!
  26. Brembo Rotor Part Numbers
  27. Car now drives like a giant Marshmellow?
  28. Snow, Ice, and rough roads
  29. Endlinks choice
  30. Colored Rims
  31. have looked but need to know if the wheels with fit.
  32. 18x8.5 (17 lbs wheel) vs stock 17x8.0 (22 lbs wheel)
  33. Cheapest place to buy tires online?
  34. found a tire site
  35. has anyone found metal centercaps for oem enkei's?
  36. Coilover Issue
  37. Tie rod help???
  38. Anyone running kw v3?
  39. Evo 8 Front Camber Kits
  40. need help with breakpads
  41. Removing Front Tie Braces?
  42. recently bought 06 mr with swift springs?
  43. Question about upcoming alignment
  44. Eibach Pro Kit
  45. tein s techs
  46. cracked a volk wheel!
  47. Need help fitting a 18x9.5 +12 in the rear with a 255 Star Spec on my IX
  48. do these look like 38k on them w nothing wrong?
  49. Open ended lug nuts
  50. minimum rotor thickness
  51. Absolutely HORRIBLE noise from right side
  52. Question about hotchkis spring and setup
  53. DD tires needed!!!!
  54. evo 8 alloys
  55. 17x9 Concrete Info
  56. Spring install problem :(
  57. Problem after installing Teins.
  58. Rota Quality issues??
  59. Tires squealing after installing swift springs
  60. apexi N1 pro Damper Application Guide
  61. Need help, severe vibration under braking!
  62. best tire for DD and track days
  63. Looking for a simple suspensions setup
  64. Whiteline Endlink and Swaybar Install
  65. Why you upgrade your brakes
  66. Looking for Tein Flex spring size
  67. Coilover Alignment Setting Query!
  68. is it possible for evo x suspension to work on evo ix?
  69. Coilover suggestion for not the greatest quality of roads
  70. fixed my front suspension clunk
  71. cusco power brace system
  72. star specs after 5,000 miles 10 autox's
  73. First Autocross in the Evo. Gotta say, It sucks...
  74. Any dual valve stem wheels other than Kosei???
  75. BC coils squeaking noise??
  76. Help! Work Cr-Kai
  77. Neal out until Monday June 21st
  78. Cusco 2R damper rebuild, replace?
  79. measuring rotor thickness with ???
  80. My New Fortune Auto 500 series coilovers
  81. Help!!looking for beadlock wheels
  82. replace rotors while changing pads?
  83. wheel spacers BAD or OK!!
  84. ABS Lights on:(
  85. Powerslots with Brembo pads??
  86. Squeal on Full Lock
  87. Need new track wheels ASAP...
  88. changes after first auto x
  89. Clunk in Rack and Pinion Assembly
  90. Need some 2 Pc Rotor suggestions
  91. Rebuild calipers or keep running them?
  92. Stance Coilovers...getting a squeak...grrr!
  93. Beatrush 4 point bar hitting downpipe...normal?
  94. All-season tires
  95. odd wheel,strut clearance question with 265's or 255's
  96. Looking for input from Evo members with significant setup experience
  97. too big a swaybar?
  98. Limited VOLK caps,Who sells them ?
  99. looking to get rota grids, help
  100. Swift Sports on Stock Struts
  101. From stock to Aftermarket
  102. SSR wheels: SP3
  103. Flushing the brake system and... whoops!
  104. 255/35/18 all season tire
  105. Gtr face of advan rg2
  106. Questions about Swift's helper and assist springs
  107. Wheel/Tire Fitment Help
  108. Need some brake parts advice/feedback...rotors, pads, ss lines, fluids!!
  109. stock spring dimensions....
  110. which are lghter evo 8 rims or evo 9 rims
  111. Tire feedback: BFGoodrich Gforce Sport
  112. 245-45 vs 255-40
  113. do I need to replace all four
  114. Question on 245/45/17
  115. Looking for Z1* and Ecsta XS optimal operating temperatures
  116. Rubbing With Swift Spec R's
  117. "anti lock" light on after full lock uturn
  118. coilover question
  119. Continental ExtremeContact DW
  120. Can Evo X GSR wheels fit on Evo VIII ???
  121. Tire wheel rub
  122. Front Sway Bar - Yay or Nay?
  123. Enkei Nt03+m or OZ Ultraleggera?????
  124. Anyone running 265-40-17 on a 9.5?
  125. Aftermarket Strut Mounts?
  126. installed HDs and Spec Rs (and blown strut? question)
  127. Ball Joint Leak!
  128. Harbor Freight spring compressor on EVO 8?
  129. Blown Bilsteins !?!
  130. Tein Coilovers
  131. Despite multiple alignments, evo pulls drastically to right-any ideas??
  132. odd grinding from passenger side wheel
  133. Racingbrake ET500, Technafit SS lines, Motul RBF
  134. rolled fenders ??
  135. hubcentric rings on enkei rct4s??
  136. Neal out until Tuesday June 1st
  137. Motive Pressure Bleeder
  138. Brake bleeder thread size?
  139. Strut bars...SEARCHED
  140. corner weight balance
  141. How bad would it be to fit 1 completely different tire on my car?
  142. 17x9 team dynamics !!
  143. someone please help
  144. HELP: knocking sound after Coilover adjustment
  145. 255/35/18 or 245/40/18
  146. The car did....... so so
  147. What width rim/tire would I need to have it sticking slightly out from OEM fender?
  148. HELP: How to adjust TEIN Coilover
  149. EBC Red v. EBC Yellow Review
  150. HELP! robispec front swaybar
  151. How much play in end links?
  152. 6 point -vs- 4 point underbody brace
  153. factory EVO 8 adjustment
  154. Advan RS-Ds in 18 x 9 +25.... anyone have a set mounted yet?
  155. Strange front end noise in '03 EVO
  156. Brembo Caliper Rebuild
  157. Energy Suspension Bushing Kit...
  158. does gtworx rebuild struts !?!
  159. problem with 245/45/17?
  160. Wheels scrapping. Need opinions!!
  161. How do I know if struts are bad?
  162. hubcentric rings
  163. looking to tighten things up a bit
  164. swift spec-r's and custom valved bilsteins ftw
  165. Spint spings..
  166. Feedback on Toyo R1R's
  167. Whats=Ferodo 2500 brake pads
  168. opinions on cutting bumpstops
  169. Alignment questions
  170. I don't want to sand mesh wheels
  171. Brembo Loop Line Help....
  172. difference in bfg dr and dr2 aka comp t/a dr
  173. Decision on Tires
  174. Disc brake weight
  175. Robi clubsport settings for DD
  176. Steering feels overboosted after pump replacement
  177. Buddy Club Suspension...
  178. wheel spacers
  179. what do you guys think??
  180. Poor service from kw suspensions
  181. Can I use these wheels?
  182. Rota grids scrapping ;(
  183. Shaking steering wheel at 70mph
  184. New Falken Azenis RT-615K!!!
  185. Best Sway Bar??
  186. Tires
  187. 245 tire too big for 7inch wheel?
  188. megan racing spec rs coils
  189. Caliper stain
  190. Replacing brake pads. Rotor questions
  191. enkei nt03
  192. Enkei RPF1 17x8.5
  193. 20mm spacers for roadracing?
  194. Megan coil over questions
  195. Evo 8 rear brakes change
  196. Best All-Weather Economy Tire
  197. MR suspension on 06 SSL
  198. Need help with a problem
  199. rear trailing arm ball joint question
  200. KW v3 install question
  201. staggered tire setup hurt my tcase?
  202. stock front sway bar size?
  203. Starting to sqeek again...
  204. BFG KDW? Opinion
  205. stainless brake lines.. i know
  206. Advan Sport vs Nitto Invo
  207. Coilover rebuilds
  208. Tein EDFC install and setup instructions needed
  209. removing pistons from calipers
  210. EVO X MR suspension on EVO IX?
  211. Just installed BC coilovers. Buddy lowered them.. uh ohs?
  212. got rid of the 18x9.5 Rota P45R...
  213. Evo x bbs rims
  214. whos running SPACERS with their ROTA GRIDS?
  215. Brake Calipers
  216. Do my brakes look ok?
  217. coilover help
  218. How adjustment is there in the stock suspension
  219. Best R-comp for Auto-x?
  220. Advan RGII Cracked
  221. CiroDesign Camber/Caster plates
  222. Can an MR BBS be trued?
  223. PIC R1 Coliovers
  224. Alignment Specs For Lowered Evo
  225. Hubcentric rings for Rota Grids 17x9???
  226. Choosing a tire size for 18x9 +36
  227. HKS coilovers?
  228. Stock Brembo Pads - Where can one find them cheap ??
  229. clanking noise?
  230. Grateful...
  231. Torn Upper Ball Joint Rear Upper Control ARM (passenger)
  232. Dba discs
  233. Ichiba wheel studs
  234. My new Poswerstop Drilled and Slotted Rotors
  235. Rear grooved disks
  236. GTWORX EVO Springs Photo Contest......
  237. quick lower crossbar question
  238. Powerstop Drilled and Slotted Rotors and Ceramic Pads
  239. Stance coilovers Suspension Travel
  240. Can't take axles off. Need Help!!!
  241. Fortune Auto coils? Who has them?? Best for the pricepoint
  242. wow what a difference!
  243. Check it out: an iPhone Rim Offset Calculator app
  244. Coilovers for my evo 8
  245. Brakes squealing
  246. full suspension and under chassis?
  247. Oddball suspension questions thread
  248. When to Rotate Tires
  249. Help me diagnose a noise after new tires and alignment
  250. Harsh Ride and Noisy Cabin..Help
