Log In
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 [73] 74
  1. Lugnuts for stock Enkie wheels?
  2. I want THE lightest forged 17" rim...
  3. Has anybody tried these tires on the EVO yet?
  4. Final Speed Wheels
  5. Suspension question....Please read!!!
  6. Bad parking + Enkai = sadness
  7. Rally/Winter Tires and Wheels
  8. Strut Life
  9. Difficulty finding 17x8-17x9 wheels
  10. Any one with Volk/Espelir question????
  11. Replacement rotors...
  12. Tein Flex Coliovers
  13. Break dust... any Pad recomendations?
  14. unsprung weight
  15. Brake cooling for Evo8?
  16. Think Ohlins is sweet? LOOK AT THIS!
  17. Espelir springs from Mackin (Volk)
  18. who sells a endless brake kit?
  19. Pagid Brake Pads (RS14) in the USA
  20. please help me on this wheel question..
  21. WEDS Wheels
  22. Got the 5zigen fno1r-c's mounted...
  23. Ohlins Street Suspension
  24. Stock tire wear
  25. Rear Strut Bars
  26. How much camber? Suspension Guru(s) Needed
  27. Wanted Stock Evo Rims
  28. Evo Brembo Diagrams
  29. Carbotech Bobcat Pads
  30. I am looking for wheels
  31. What do you think of this wheel on an EVO? (big image)
  32. 5zigen wheels
  33. RE: Hawk HP+ pads for the Evo VIII
  34. Endless brake disc and pads
  35. What rims are these?
  36. Update on the RPM2 fitment saga
  37. Alignment problem, help
  38. Brake Squeel
  39. Interest in a Enkei GB?
  40. RPM2 17 by 8 35mm offset don't fit...
  41. Evo Fitment guide now online!
  42. Torque specs for Camber bolts????
  43. What the best tires for auto x? alignment settings?
  44. New Question on EVO factory breaks!
  45. Aftermarket cockpit adjustable airspring system
  46. Best Sway-Bar set-up for Evo?
  47. Cool website for what wheels looks like on Evos
  48. Need a wheels FAQ
  49. Evo 8 Stock Alignment Specs
  50. Check out My Wheels
  51. Black TE or SE -37's
  52. would an aftermarket lower chassis bar clear a 3" downpipe for Evo?
  53. Good news... 255/40 tires fit...
  54. Is the factory Evo 8 front upper strut bar good enough?
  55. What sizes and weights do the EVO RalliArt wheels come in?
  56. thump when braking
  57. Scratch the 17 x 8.5 SSR's off your list...
  58. BAY AREA Lancer and EVO owners....I need help????
  59. What shocks are available for the EVO 8?
  60. Brake noise
  61. Center caps, are they necessary?
  62. Are hubcentric rings required for aftermarket rims?
  63. Plenty of Cusco in stock
  64. These are some sweet wheels
  65. H&R's or Eibachs?
  66. Light weight FSTB
  67. Finally made my rim choice...
  68. Optional alloy wheels
  69. Gunmetal LE28N
  70. Evo Enkei Wheel Scratch
  71. WANTED: Lightest Rotors on earth
  72. Eibach drop on EVO VIII...
  73. Hawk Pads fitted on Evo 6 (pix)
  74. First Suspension Mod
  75. More wheel questions not answered in Read Me...
  76. okay dammit i need tires...
  77. Does TE37 17 x 8.0JJ +33, 114.3 fit our evo?
  78. what's the deal with the EVO's fenders...?
  79. Suspension from a GSX fit on the EVO8?
  80. EVO VII springs on an EVO VIII...?
  81. Offset and Spacers
  82. Yokohama AVS Kreuzer Vs on EVO?
  83. STi and EVO - Same exact brakes?
  84. Which rims are these. Exact fit for evo 8
  85. So once the tock tires are gone...
  86. where to get new brake pads?
  87. Look at what got delivered to me today ;)
  88. Wrong Offset Delivered
  89. New O.Z. Superleggera 19"s
  90. Tires for Minnesota
  91. Uneven front pad wear... normal?
  92. Bilstein Suspension for EVO-V anb VI
  93. tire decision is driving me nuts...!
  94. I bit concerned..
  95. caster/camber plates
  96. Tirerack finally has an Evo pic for their wheel search
  97. 245/45/17's, will they work?
  98. generic brake question
  99. Anybody has white TE37 pics on red evo? Where to buy?
  100. i've read every post on wheel fitment but...
  101. Evo Brakes
  102. warped brake rotors
  103. pshopped Bortex rims on Silver EVO
  104. Tire Presure
  105. Dirty brakes
  106. Front Camber Adjustment on stock EVO
  107. ??Evo 6 camber settings??
  108. What should the alignment be for daily driving?
  109. Where to get a great deal on Advan rims?
  110. What size are the stock Evo8 wheels?
  111. Black wheels
  112. Speedline GT1
  113. Snowing again in Colorado (May 10th) so what are good snow tires?
  114. Powder coating them white or just get a new set?
  115. Lightest 17x8 rims that fit
  116. Source of Race Evo Brake Pads
  117. Evo 8 front brake pads same as....?
  118. Has Anyone Boiled the Stock Brake Fluid?
  119. What wheels fit the VIII?
  120. Advanced Design Race Suspension
  121. Alignment/Balancing
  122. bedding in stock pads?
  123. Where to buy a set of stock Evo VII wheels?
  124. Tires on evo
  125. Front wheel gap...?
  126. smaller sway bar available for the front?
  127. suspension spec questions
  128. What Do you think about this rims??
  129. I want suspension.. but can't decide what?
  130. snow chains on lancer oz...
  131. Adjusting headlights higher?
  132. Weight of the front strut bar
  133. Rigid front strut bar
  134. US EVO8 rear brakes dragging
  135. Just got the RMR lower control arm brace
  136. Volks on Evo
  137. New Pics of my 19" TE37
  138. My Wheels
  139. 19" TEs on my Evo
  140. Lowering springs
  141. Brake air guides
  142. 5Zigen FN-01R
  143. Fikse Wheels
  144. Brake Squeal?
  145. would 245/45/17's work on evo?
  146. Evo 8 wheel options?
  147. Paint code for stock Evo rims
  148. A bunch of Suspension Components here.
  149. group buy on ferodo brake pads?
  150. Yokohama A046 now available at Tire Rack
  151. source for decent Coilovers?
  152. best lowering springs and coils for an ES??
  153. Evo sucks in the snow ! BAD
  154. Pics or white te37's on red or blue evo7-8?
  155. What is the recommended torque specs for wheel bolts on our evo's?
  156. Question regarding 2-piece "floating hat" rotors
  157. Te-37s
  158. Ralliart rim lookin might good!
  159. Enkei RPF1?
  160. What is a good brand racing brake pads for evo's?
  161. New wheels on the way...
  162. Recommended tires?
  163. question about static weights on the rims
  164. Evo stock alignment specs
  165. Heard ARAGOSTA suspension from Japan?
  166. weight of stock tire/wheel combo ~45lbs! :(
  167. Will this work?????
  168. EVO bolt pattern & offset?
  169. Will 17x9 Wheels fit on An EVO 8?
  170. where to get evo rotors and pads?
  171. disabling ABS
  172. Lugnuts
  173. Weight of stock Enkei Evo 8 wheel?
  174. 17 X 9.5" Volk racing TE37 fitment on Evo 8?
  175. Energy Suspension Polyurethane Bushing kit on Evo 8?
  176. SSR Wheel fitment
  177. how to hook up 4 point harness.
  178. Where is the EVO8 gas tank located?
  179. the spring spacer????
  180. spring spacers - how to remove
  181. Zeal Suspension
  182. Tires......when the time comes
  183. EVO VIII Tein Install...
  184. EVO 8 Rear sway bar stats?
  185. New Shoes and a How To!!!
  186. Need help choosing Evo rims
  187. What rims look good on an Evo VI?
  188. What will you torque your wheels at?
  189. Need new wheels...
  190. My evo8 breaks squeak......
  191. EVO lateral balance question
  192. Volk SE37A Wheels
  193. Brake rotors...
  194. EVO VIII Tires
  195. SSR Competition wheels
  196. yokohama ao46
  197. tein already makes coilover for evo VIII
  198. EVO VIII Suspension Components
  199. Wheel offset
  200. Brake pads for Evo 6 Brembos.. (street)
  201. 18" evo 8 wheels
  202. Enkei Tarmac Evo Wheels
  203. wheels for my vi rs?
  204. Knocking sound on Evo 7
  205. Spring rates
  206. Grp N. Bushings install (in progress)
  207. ok, CTF discs...but which pads
  208. Stock Evo Brembo Brakes
  209. Evo Wheel Diameter
  210. 18x8.5 te37
  211. Disks / Rotors?
  212. US Lancer & Evo7/8 have same offset?
  213. All Wheel Drive
  214. Best TeinSetup for the Evo7
  215. Two piece disc with TÜV
  216. Hydraulic Handbrakes
  217. Evo 4 Wheel size
  218. E7 wheels OZ Superleggera or Prodrive GC-07?
  219. Possible Strange Source Rotor Swap for ES
  220. Toyo Proxes
  221. EVO wheel offset and bolt pattern
  222. GAB shocks
  223. Intermittent squeal from brakes when turning
  224. Apex-i Brake Rotors & Pads
  225. I need new street tyres...
  226. Blitz Wheels
  227. Maximum Tyre Sizes for TME Rims
  228. 17 x 9 or 17 x 8.5 wheels
  229. Can't tuck my rims w/ enkei RS 6
  230. Speedline Magnesium Wheels
  231. Tyre pressures?
  232. Bolt Pattern on Evo VII vs OZ Rally
  233. Strut Bar
  234. New Suspension?
  235. OZ Superleggera for Evo6
  236. RMR ralliart Suspension
  237. New discs or 6-pot kit?
  238. lowered seven?
  239. JSpeed springs for Bembo calipers
  240. Wilwood Brakes
  241. Gas shocks vs oil
  242. Stock alignment figures and adjustability for Evo7
  243. RRM Brake pads
  244. Tein Suspensions
  245. Pads for OEM-discs
  246. I ain't crazy, BUT what do you think...
  247. Question about Coilovers and wheels
  248. Wheel Spacers
  249. Semi-slicks?
  250. Check dis, Magnesium wheels
