PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 [66] 67 68 69 70 71 72 73 74
  1. Black Racing N1 wheels
  2. Tein H-Techs
  3. steering wheel shaking violently at 100mph
  4. what a different -2 camber made from -1.7
  5. tires for black evo
  6. Need longer studs to fit some wheels
  7. Tire/wheel combo
  8. Which R-Compounds should I buy!?
  9. Stock tires are almost gone!!
  10. Opinions on Work XSA-02C Rims
  11. Tein Basic coilovers
  12. Fender rolling tool
  13. EVO stock front strut tower bar
  14. spring and shock combo
  15. Is the offset printed on the rim somewhere?
  16. Done some hard braking tonight with my Project Mu's
  17. Question for Neal ???
  18. Torque Thrust Wheels
  19. "HP EVO" rim fitment..
  20. volk te-37 question for all you wheel experts
  21. Volk GTC or Emotion Kai's ?
  22. ... and front swaybars ?
  23. Sumitomo tires? any good?
  24. What brake pads?
  25. Enkei WRC Tarmac Evo 18x8.5 price
  26. Rear S-tech springs
  27. Factory Specs for wheel alignment
  28. 18x9.5's +35
  29. Cusco lower cross bars or Works rear sway bar?
  30. Anyone have black rotors
  31. Rear Strut Bar Weight? Anyone?
  32. Shot in the dark (steelies that cover bremb's)
  33. Help! bled caliper dry
  34. black evo 8
  35. EBC pads
  36. EBC pads good or bad?
  37. lowering w/stereo equipment in trunk...
  38. Haven't seen this problem before...
  39. 11k miles..rotors warped!!
  40. BFGoodrich g-Force T/A KD question
  41. Just got my BBS LM F1s ( all gold, even lips) today...THANKS Gruppe-S
  42. Blown struts?!?
  43. Front End Clunk - Check Strut Bearings
  44. Which vendor here sells Roja wheels?
  45. Need Help With Tire and Wheel setup!!!
  46. Michelin Pilot Sport PS2
  47. I have a question about HKS Kansai tracks.
  48. Evo soon, winter wheel/tire shopping...
  49. Best Lowering Springs???
  50. Fuzion Tire Updates?
  51. Wheel and Tire fitment for 17x9 Rim
  52. First Evo in the U.S. with............
  53. Brembo Cross drilled rotors installed - WOW!!!
  54. Well, the ABS works . . .
  55. Outter Tire Wear 9000 miles
  56. Bizarre alignment at Firestone?
  57. Advan Wheels Group Buy!
  58. Coilovers or ?
  59. Winter steel wheels for Evo?
  60. AutoX wheel combo... Neal help..
  61. Stasis 2-Piece Floating Rotor
  62. Team Dynamics Racing Wheels Stock on FQ 340
  63. Enkei OR52
  64. Hallman PRO Kit MBC
  65. Need Help!!!
  66. Will Tein S-Tech's kill my stock struts?
  67. Pics (real or photochopped) of gun-metal ralliarts rims on Apex Silver?
  68. Brake air guides
  69. Stock tire is almost done...
  70. Factory Suspention Specs
  71. Cheapest place to find Advans..
  72. Cusco Or Hks Coilovers?
  73. Tein S-tech Alignment for AutoX?
  74. Ferodo's or Project Mu ?
  75. Tanabe GF210
  76. Street pressures, Kuhmo Ecsta MX
  77. To All Tien S-Tech Spring Owners
  78. Front Camber kit
  79. 01 Design Systems
  80. Where to buy adjustable camber plates
  81. Are the EVO wheels interchangable with 05 STI wheels?
  82. Tire circumference and the center Diff
  83. If I run a 18x9 or 9.5?
  84. Goodyear F1 GS-D3, any experience?
  85. Please gelp me decide! (Tein VS Tanabe)
  86. Enkei Stock rims with Blizzaks
  87. Anyone got pictures of black Ralliart R-01 on EVOs?
  88. buddy club p1 racing QF wheels?
  89. Stiffest Sidewall
  90. Brake Fluid
  91. Which New Tire for stock rims?
  92. Lug Nuts
  93. Hawk HPS, opinions? (I have searched)
  94. Toyo T1-s
  95. Which Tires For 18in Wheels??
  96. Neal, best 1/4 mile rubber?
  97. Pennie TEst Brake pads
  98. evo vii wheels?
  99. My new shoes. :)
  100. everyone, check your spare tires !
  101. Anyone know where to get a good deal on HKS Hyper Max II's?
  102. How long do summer tires last????
  103. Toyo tire question
  104. Tire/wheel weight question - performance view
  105. Directional Tires
  106. FS: TEIN Flex w/EDFC barely used!!!
  107. Brakes -what caused it
  108. G35 Coupe manual brake set for EVO?
  109. air bushing
  110. Suspension on 19"s???
  111. Pictures and Info on my Suspension mods
  112. Advan 048......what compound ?
  113. Just had an Alignment and I have a ?
  114. Source for Toyo Proxes RA-1s?
  115. BBS CH plasma...
  116. Running 18"x9.5" Wheels
  117. Grinding noise when braking and afterwards
  118. Brake Help
  119. Rear Swaybar Poly D-Bushings
  120. pics of 19" Konig Next w/nitto nt555
  121. Wheels: Rear wider than front?
  122. MOMO QUASAR 18 X 8 (45 Offset)
  123. Ohlins For Sale
  124. Custom rear lower control arm and front fender setup to run 305's...
  125. Inverted aftermarket struts?
  126. opinions bout bridgestone potenza re750
  127. Best Prices on Volk Wheels?
  128. Weds TC 005
  129. MIVEC engine for 97 LAncer
  130. Volk center caps
  131. Wheel bearing problems?
  132. Where do I get these rims?!
  133. Mines Trunk Bars
  134. New street/ track tires and wheels combo.
  135. Any got pic of 18" SSR comp on EVO VIII ?!
  136. 18 x 8,5 offset 40 or 32 on EVO VIII ?! (pic)
  137. Can someone measure their stock ride height please?
  138. alignment recommended????
  139. Resurfacing Brake Rotors
  140. Difference b/w Work Emotion CR and CR Kai
  141. WEDS Sports TC005 Wheel Sale!
  142. TDR hub ring and center cap?
  143. NEAL, I Need this wheel!!
  144. Confusion with tire ratings on Tire Rack.com?
  145. Thinking about going 265/30 on a 19x9 wheel
  146. 835.00 for new brake pads!!!!!
  147. Quick Question After Installing TEIN-S Springs
  148. Mitsubishi snow chains - Anyone used them?
  149. Alignment problems??
  150. Enkei PK6 on white evo
  151. My Thoughts on the Kumho ASX All-Season Performance Tires
  152. Brake Bleeding Problems
  153. Need opinion on Brake set up
  154. Request Pic: Emotion CR on BBY (stickers on)
  155. white vivid evo with RG's= sick! ;)
  156. Best Place To Buy VOLK Wheels
  157. Anthracite TDR PRORACE 1 Wheels on a Silver EVO
  158. EVO Center Boe Sie/ Hub Ring Size
  159. Coilover ste up: Proper preload?
  160. Who has the best price on Project Mu B-Force front and rear brake pads?
  161. Possible Solution to "Warped" Rotors
  162. Evo 6 TME Squeaky breaks
  163. Falken Azenis Sport: size
  164. Volk TE37's wanted
  165. How much are stock TME wheels worth?
  166. Ultimate Budget Track Wheel Setup
  167. Must have new wheels before friday; suggestions for wheels/vendors please!
  168. Destroyed wheel & tire
  169. Alignment question
  170. Stock Rims Powdercoated White on a WW Evo?
  171. 35mm offset??
  172. Squeeeeeeeeeek...
  173. Which coilover kits are compatible with 2-1/2" Eibach ERS springs?
  174. 275 40 17s -- anyone tried it?
  175. Anyone tried to fit a 16" wheel?
  176. yet another rim size question
  177. what are the evo stock rims specs?
  178. Torque down for rear strut bar?
  179. Help with steering
  180. Carbotech pads - great experience
  181. Kosei K1 TS... Neal??
  182. Running a wider wheel in front
  183. Enkie 4+ Wheel (where are these wheels?)
  184. Advan RG info!
  185. SSR Competition 17" Backordered?
  186. Finally!!!!!!!!!! Brembo aftermarket discs.
  187. question about rotate tires!
  188. Rough ride - daily driver - need tire/suspension recommendations
  189. Evo guys/gals, riddle me this about my setup.
  190. Tire pressure
  191. Work Emotion on Blue Evo?
  192. stock evo offset
  193. Changing to super blue break fluid
  194. Common cure for brake Squeal???
  195. What is your all opinion?? 17" and 18" both 8.5" wide
  196. Camber Plates & Alignment Process?
  197. Stock Wheels??
  198. When to change front brakes!
  199. Rubbing issues with 245/40 and Tein S? Yes or No
  200. 285/30/18's on 18x10's
  201. Where in Brooklyn or SI do I buy -
  202. Good Winter/Summer Tires?
  203. pics of new racing hart j8
  204. 17x7.5 on evo with stock yokos????
  205. A different type of chassis brace
  206. i just adjusted the camber on my EVO -- alignment tips inside...
  207. Gauging interest in sway bar endlinks and trunk braces at 2/3s the cost of others...
  208. Question on Tanabe springs
  209. cusco rear sway adjustment...
  210. Rim balancing weights taking chunks out of rim?
  211. volk gram lights
  212. Changing break fluid-
  213. My Steering Was SHaking at 140mph
  214. Are 17" Advan RGs hubcentric?
  215. looking for CHEAP backup set of brake pads
  216. Tires
  217. Michelin Pilot Sport PS2
  218. need some ideas for rims
  219. 9 or 9.5" wide wheels on Evo?
  220. Question for People with TEIN-S on EVO
  221. Springs Questions for tracking
  222. Rubber piece came off springs. What is it?
  223. Regular Struts/Shocks
  224. Need lugs and center cap.
  225. Rota Torque wheels group buy...
  226. Just installed Sumitomo HTRZ II
  227. KW INOX Coilovers for the EVO?
  228. Who has white wheels in stock?
  229. Tein Type RS Coilovers
  230. Choice in tires....
  231. Do Sparco nt-r's fit
  232. tlin8's New Look
  233. tlin8
  234. Tire Recommendation
  235. cryo-ed rotors
  236. Which Brake Pads Should I use for Track laping?
  237. D2 Racing Coilovers
  238. spring install help!
  239. Need some opinions on Volks
  240. New Wheels
  241. 255/40/17 fit on a 8.5 or 9
  242. which brand coil over are you using on your evo vi?
  243. alignment settings
  244. REAL brake testing.... NorCal style
  245. OZ Superturismo GT 18X8 Fitment for Evo?
  246. Help...uneven tire wear on stock suspension..evo8
  247. Nice Stock Evo Rims:
  248. OEm Brake Pads
  249. 2.5" True Brake Cooling Ducts
  250. Just got 19" Gunmetal Volk Racing SF Winning's
