PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74
  1. Evo 9 camber help
  2. Giro discs surface cracks after a couple track days?
  3. Brake Issue
  4. M&H 17" drag slicks info
  5. Wheel Suggestions?
  6. Stock characteristics of aftermarket pads?
  7. Brembo leaking
  8. Suspension Set Up Question
  9. Neal out till June 3rd
  10. Which lug nut washer to use on oem wheels (aftermarket lug nut alternative)
  11. Buddy Club QF?!
  12. No camber question
  13. Fitting te37 on my evo ix
  14. My OEM camber bolt is pointing down. Is this bad ?
  15. whats the biggest size tire can run on a 18x8.5'' wheel?
  16. My new custom wheel job
  17. suspension adjustment
  18. Rota grids 18x9.5? Will it fit.
  19. Rota grid drift 18x9.5
  20. Custom stub fame
  21. Wheel alignment for drag racing
  22. Spacers with extended wheel studs
  23. NRG Innovations Rear Toe Control Arm - EVO 8?
  24. New rotors and pads
  25. Rear body roll
  26. Brembo Bleeder Screws.... HELP!
  27. Side to Side play on the rear wheel
  28. Aluminum hub-centric rings
  29. Works Wheels CR 18's For Trade/ For Sale - $2000 (Monticello)
  30. Evo 9 squirrely at highway speeds
  31. REAR Strut Brace--Which one?
  32. Evo 7 oem 8JJx17 et38. Set of 4 good condition $300
  33. Best budget pad
  34. Rota SVN-R 18x10 +30?????
  35. Sticky Daily Driver Tires
  36. Tirado Custom Coating - defunct or just clowns?
  37. Wheel spacers help!?
  38. Grease for ball joint
  39. Swap suspension
  40. Need help....rear upper control arm replacement
  41. Rubbing
  42. All sorts of clunking and banging
  43. RotorPro disks from MAP
  44. Wheel/Tire size for Evo V???
  45. Tilton Pedal Assembly
  46. AD08R release date?
  47. New centric rotors, stoptech pads, bedded, squealing?
  48. new tires needed - details included! :)
  49. Front camber adjust
  50. would these rotors be a good choice?
  51. bilstiens hd's shortend version
  52. need new tires!
  53. Pad squeel
  54. RPF 1 and noob question
  55. Ideas for fixing spring bind without removing strut assembly?
  56. KW vs Öhlins vs Fortune Auto
  57. Raceland Coilovers
  58. Wheel spacers help
  59. Rubbing with wheels: Should be OK, but isn't
  60. Which way should the arrow on my shims point to?
  61. trouble with Bilstein's
  62. Suspension cradle
  63. How hardcore for a street car
  64. 4 pot caliper using stock rotor
  65. Ride height ?
  66. Bent Rims /1 month old
  67. Brembo Family C rear calipers?
  68. RPF1 fitment
  69. Carbotech XP10 vs. Raybestos ST-43
  70. Factory IX MR BBS wheel scuff help!
  71. Konig torch 19b/s et 15 & 35
  72. XXR Wheel Center Caps
  73. Opinions needed, PSRS to fix caster?
  74. Gold 5Zigens on bby8
  75. Xxr 962 on evo 8
  76. wheel/tires fitment
  77. Weird Popping Noise
  78. fifteen52 tarmacs
  79. Just made some evo 8 wheel center caps
  80. Abs delete- proportioning valves different?
  81. STM Spec D2/swift coilovers
  82. Race Alignment specs???
  83. Looking for KW-V3's and found this
  84. Any merit?
  85. Master bushing set for Evo 5?
  86. Work XD9 18x10 +38 fitment
  87. Evo X MR BBS Wheels on a IX
  88. Centric pads question
  89. Lowering on coilovers
  90. New tires, new rear sway, new brakes upcoming
  91. 245/40/18 vs 255/35/18?
  92. Question about tire/wheel fitment
  93. Abs sensor
  94. Tire wear question
  95. G37 aluminum spare tire on Evo 9
  96. GiroDisc Vs. PF Vs. Else
  97. Knocking noise-HKS Hypermax II
  98. DANGEROUS D2 Coilover defect!!!
  99. ordering new bilstein struts but have a question about installation.
  100. Tire suggestions for AK summer.
  101. Wheel help
  102. DME 3-point front strut bar review
  103. What model HKS Coilovers are these?
  104. Weird ABS light issue
  105. Anyone using the Stance Super sport +?
  106. Clunking noise front drivers side???
  107. xxr 531 fitment update
  108. Tire rubbing with XXR. Help
  109. Question on Fitment
  110. Fact or Fiction
  111. A new Hankook R-S3?
  112. Stock camber plate alignment??
  113. clanking noise, passenger side
  114. Need help assembling coilovers
  115. Looking for Satisfied Gransport GS5/6 pads in 2013
  116. For all you evo 8&9 Tanabe fsb owners, check your bushings
  117. xxr 531 fitment?
  118. BC Coilovers - Help needed
  119. mr bilsteins vs hd bilsteins
  120. brembo rebuild
  121. Bolt-in Dual Master Cylinder Solution
  122. Aftermarket Springs question
  123. 275/40 on 17x9?
  124. EVO IX Bump Steer fix?
  125. Its about that time for tires
  126. Awd d2 coilovers or stm d2/swift coilovers
  127. Best street-legal track tire?
  128. Cheap coilovers or just replace springs?
  129. Rotor suggestion
  130. Suspension help
  131. extreme summer tires 2013 - Z2 vs BFG Rival
  132. rotors/pads choise
  133. Advan AD08's
  134. Hankook s-drive
  135. heat cycling Hankook R-S3s
  136. Purchasing Lug Nuts (Not a Set)
  137. Evo 8 Stock lug nuts fit aftermarket rims? XXR Wheels..
  138. Need your Input! (suspension)
  139. Evo 8 Wheels
  140. question about +40 offset wheels
  141. wheel spacer ?
  142. Which model JIC Magic coilovers are these?
  143. Car at the shop - alignment issue
  144. Tanabe Coils
  145. Rota DPTs 18x9.5 +35 lug nut question
  146. Seized factory camber bolt removal
  147. looking for a decent comfortable suspension
  148. The brake squeak that WON'T go away!!!!!!!!!!!!! Need help please!
  149. hub bearings
  150. Good ride height
  151. Extended wheel studs in rear
  152. Cusco Suspension
  153. Evo 8 Coils?
  154. Very quick question wheel offsets and spacers
  155. Plasti dip wheels
  156. wheels
  157. How do you install brake speed bleeder screws without making a mess?
  158. section width and tire growth
  159. RPF1 19.5 with 265-40-18 Rubbing
  160. need to fix bouncy
  161. weight reduction
  162. Qu: On Alignment Rack / Camber Shift?
  163. Wheel helppppp
  164. Drag set up Questions
  165. Michelin pilot Super Sports, anyone?
  166. The mystery leak?
  167. 17x9 35 offset, need advice.
  168. Need help want to replace all sub frame bolts to stainless
  169. Which do you like?
  170. Front Noise Suspension
  171. Coilover Cleaning/Care
  172. wtb streeet radials for evo 8
  173. when its time
  174. Achilles ATR Sport
  175. KW V3 OEM Components Needed?
  176. yokohama review
  177. Spring Rates for daily driving
  178. Evo IV wheel/tire size?
  179. best tire size for the stock enkei for drag
  180. Whiteline roll center kit garbage
  181. Standard Suspension R3's?
  182. FA 500s vs Stance vs ???
  183. Knuckle to Strut bolt
  184. xxr 527 questions
  185. suspension question again
  186. Mb Battles 17x9
  187. Wheel bearing
  188. Putting only two new tires on
  189. Rear brakes not working??
  190. Enkei EV5
  191. bouncy
  192. Looking to organize a group buy for Rota DPT wheels in custom offset!
  193. Cosworth Trackmaster pads experience? Wanted: lots of bite!!
  194. Lowering springs just installed question
  195. Ultra racing Side bars for Evo CT9A
  196. Suspension upgrade path
  197. HKS Pillow Ball Mounts w/ KW V3s
  198. Fortune Auto Coilovers track reviews?
  199. New Wedsport TC105N or Used CE28N?
  200. Is this safe?
  201. Nitto NT555's Review
  202. Can (-) camber in the front make your can bang around turns?
  203. whiteline tie rod end separated from tie rod
  204. Bad wheel bearing?
  205. ACD codes 23,25,26
  206. Some helpful info..Installing whiteline rear bumpsteer and trailing link bushings.
  207. What kind of coilover should i go for???
  208. Gold Enkei rpf1 on Evo 8?
  209. Quick clarification questions re: swaybars/endlinks
  210. 10mm spacer and wheel studs
  211. Tire size
  212. problem with ABS !
  213. HyperFlex Master Kit Mitsubishi Lancer Evo 8
  214. Poor steering, Slack in steering wheel, loose steering
  215. Track/autox junkies. I have a question about cusco front member brace
  216. Drilled and Slotted brakes on snow
  217. Evo IV suspension and wheels
  218. HKS Pillow Ball Mounts w/ KW V3
  219. Will These Wheels and Tires Fit my Evo8?
  220. Will These Wheels and Tires Fit my Evo8?
  221. Is my DD brake choice a good one?
  222. Wheels and Tires???
  223. Anyone experince ATK coilovers?
  224. Which bushings should I replace first?
  225. Muteki Blue Lug Nuts
  226. Cusco Camber Plate Spherical Bearing Replacement
  227. Coilover Noise (not typical clunk)
  228. best brake rotors
  229. evo 8 suspension
  230. Front upper strut bearings
  231. enkei kojin
  232. warped rotors
  233. newb question about tein lowering springs..
  234. Evo 5 Brakes
  235. Alright tire size experts...
  236. Top Hat Question
  237. Rear end sway
  238. Need help ASAP; Bled brakes still soft
  239. Photoshop Request, Thinking about painting/ powedercoating my wheels
  240. My new Pads cut into my rotor
  241. Stupid Evo X Wheel question (for Evo IX)
  242. Replacing a rear hub bolt/wheel lug
  243. Stupid brake question
  244. FSB Question
  245. MRR GT1 rims anyone?
  246. Thoughts/opinions on spacers, tire size, fitment, and suspension.
  247. Struts Question
  248. slicks combo? or...?
  249. Suggest me a tire
  250. Swaybar Options?
