PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74
  1. Thoughts on bc coils?
  2. mr bilstein revalve question
  3. steering wheel feels loose when hitting a bump mid turn
  4. Never ending brake noise problem
  5. Do sb know what that rims are?
  6. Question on DIY Install
  7. What is the EVO 8-9 MR Bilstein strut bolt/stud torque spec?
  8. GAB or D2 Coilovers?
  9. Stock kybs 100k miles ... Okay to lower?
  10. 275/35/18 on 18x9+29 fit with bilstein hd's w/ swift springs?
  11. good spring/shock set up
  12. Noise at +40 MPH
  13. Continental ExtremeContact DW VS Michelin Pilot Super Sports
  14. Raceland Coilovers
  15. 17x9.5 50 offset what spacers
  16. any thing like tien?
  17. Are these struts oem?
  18. Brake Pedal Mushy
  19. Brembo Powdercoat question
  20. Enkei NT03+M 18 9.5 - What spacers?
  21. Who`s running SWIFT SPEC R`s on an VIII GSR with stock KYB`s?
  22. suspension suggestions before I get new tires.
  23. Strut inspection
  24. Bad idea to run upgraded front and rear swaybars with stock struts?
  25. BFGoodrich g-Force Rival Official Review
  26. Does Evo 8 MR suspension fit Evo 8 GSR top hats?
  27. Does Evo 8 MR suspension fit Evo 8 GSR top hats?
  28. Ride height question
  29. Bigger brake master piston?
  30. my front hubs feel like they require a bit too much force to spin. is this normal?
  31. Input Needed. Cooper Zeon RS3-S vs Hankook Ventus V12 Evo
  32. DIY Rotors and Brakes questions
  33. Best Coilover for Track and Street use?
  34. Enkei Roijin pictures needed...
  35. Attempting to fix a mistake but still get the look I want
  36. Declassified Tire Testing Trip. The New BFGoodrich g-Force Rival
  37. Determining what tire size to go with
  38. n00b with suspension questions...
  39. A good deal?
  40. need help with ball joints in the rear suspension
  41. Swaybar rate?
  42. Lower Control Arms Question
  43. Front sway bar
  44. need brake pads ASAP
  45. Best Performance Tire - EVO VIII
  46. Neal out Mon - Wed testing a new top secret extreme performance summer tire
  47. Thoughts on skipping the normal "bed-in" procedure?
  48. Couple questions on coilovers
  49. Cusco Power BRace
  50. suspension question
  51. Using Non-Adjustable Camber Bolt
  52. Rota G-Force Lug nut question
  53. Coilover problems...
  54. Offset Question for TE37
  55. Question for Wheel gurus ??
  56. 10/18 et 18 Work emotion XD 9's
  57. Thumping noise when going over bumps or uneven roads
  58. Where can I get these brackets???
  59. Advan wheels in gold touch up paint
  60. popping/creaking while turning
  61. rs master cylinder vs abs master cylinder
  62. XXR 527 on Evo 9.
  63. Brake calipers
  64. caliper seals between halves
  65. Bilstein Evo 8 MR
  66. Evo 8/9 Rear lower control arms interchangeable with each other??
  67. XXR Wheel fitment??
  68. Need help with offset, anyone with experience willing to help?
  69. Suggestion about drag radials for my Evo IV
  70. Rota MXR
  71. 235/40/18 on 18x9.5 et20 rota grid will they fit?
  72. Help!!!!!
  73. Coilovers for snow and tarmac setting?
  74. 285/30/18
  75. Wheel Bearing Question
  76. 18x10 +18 Work XD9 clear Stoptech 332mm bbk?
  77. Lightweight rotors?
  78. brake issues.
  79. Stoptech pads and OEM shims
  80. How to: Front Subframe WL Roll Center Kit & Steering Rack bushings & FSB sway bar
  81. xxr 522 17x8 +35/40/45?? 235/45R17
  82. 255/40/18?
  83. Springs difference
  84. How many run studded tires on awd/ Evo ?
  85. Camber kits
  86. Brembo affilioate/vendor? Brembo specific parts
  87. Understeer with LSD Need Help With Setup?
  88. Need help with coil-over choice
  89. Hellaflush
  90. choosing the right tire...
  91. Stuck Coilover locking collar Zeal coilover
  92. Question on wheels and offset
  93. Enkei RPF1 18.95+15 Answer to end all threads
  94. Where to purchase outer tie rods + wheel hub assembly?
  95. thinking about trying different tires
  96. horrible brake noise
  97. Evo 8 with 9 wheels and spacer??
  98. Stock suspension question????
  99. Wheel firmest
  100. NEED HELP!! On wheel fittment
  101. Front struts installed backwards? (front left/right)
  102. cheap brakes??
  103. Will these TSW's fit on an Evo 8?
  104. Zeal function x spanner wrenches
  105. Question about Abs Delete.
  106. Will these fit my car?..
  107. work emotion cr kai center caps??
  108. Tein S Tech Spring
  109. Stock evo 8 rim/ tire fittment
  110. Help! Abs keep kicking in
  111. 2 sets of small differece tires sizes..will it hurt??
  112. brakes kit works with hydraulic brakes?
  113. Bilstein valving on Robispecs
  114. Need help on Evo 4 wheel size
  115. Best lower spring and spacers set up?
  116. Tire rubbing
  117. Versatile Coils
  118. Evo 4 rear suspension compatibility
  119. 315...suspension set up....
  120. Rota Slipstream + Hoosiers Need some Experts!!!
  121. Changing brakes question
  122. Another suspension problem
  123. Can I run stock MR struts/springs with Whiteline roll-centre kit and 26mm fr swaybar?
  124. Rear control arm bushings
  125. Please help Need alignment specs for 12 mr
  126. Replacing Tie Rods
  127. Problems with brakes
  128. Girodisc Promo Video
  129. Question on PSRS install
  130. evo 9 suspension recommendation needed
  131. EVO 9 coilover choice?
  132. Evo 8/9 rotor dimensions
  133. Powdercoated Calipers used on the Track Longevity?
  134. Need some suspension advice/help
  135. Wheels similar to Advan RS / RZ?
  136. Evo 4, 5, 6, 7, 8 & 9 shock absorbers front & rear
  137. Best tire that you can run on the street for drag racing
  138. evo 9 brake pad question
  139. Stock struts
  140. Suspension help.
  141. Powder Coating Calipers
  142. Outer tie rod ends
  143. Bilstein/Robispec good combo?
  144. Help: Droning Noise Rear Pass
  145. wheel bearing clarification
  146. Whats the best tires for 18"x9.5 privat wheels with tein edfc coilovers?
  147. Anyone used robispec springs on kyb stock struts?
  148. Rota wheels keep bending! Something Stronger?
  149. How to remove ABS Wiring from 7,8,9 with ACD/AYC Guide
  150. stock ride height
  151. KW V3 Rebuild or buy other used coils. help.
  152. Rays G-Force question wheel fitment
  153. What Size Spacers for IX with X wheels
  154. Enkei RPF1 18"
  155. Need Parking Brake Cable!
  156. Master Cylinder Brace review - input - feedback
  157. New evo owner.. previous owner put tein springs on with stock struts...FML
  158. Is an alignment needed after height adjustment?
  159. Evoscan ABS codes
  160. Need help with Coilovers for my IX
  161. Bent wheel
  162. Alignment/tire question
  163. Alignment/tire question
  164. EVO X Calipers and Rotor Differences
  165. Alignment
  166. Need to be educated on BBS wheels
  167. What cheap quiet Brake pads to buy?
  168. Need some help
  169. Neal out till Nov 26th
  170. im a noob with rims help!
  171. Could be a dumb question Lower control arm to kunckle issue?
  172. need help with anti lock brakes on evo 9 mr
  173. Overly asked question?
  174. which coilovers are these ?
  175. Ohlins adjustment question.
  176. Anybody have any pics of Rota Torques on an 8 or 9?
  177. New Website
  178. Alignment Dilemma
  179. Need some under carriage body brace help please
  180. Help with coilover choice on Evo4
  181. installing roll-center/psrs any other bushings worth replacing?
  182. Best place to buy Hoosier QTP tires
  183. Seized up control arm bolts. Ideas?
  184. Creaking noises at low speeds!?!
  185. Need help with brakes.
  186. piston rod lock nut loosened?
  187. Evo IV Rear Rotor?
  188. Evo IV brakes?
  189. CorkScrewYou
  190. The new Dunlop Star Spec Direzzas will be available staring mid-February!!
  191. Evo 9 Caliper Leaking - Crossover tube/Metal Line Connecting Sides of Caliper
  192. Car won't stop pulling right!?!
  193. ABS; how do I find out if my Evo 8 has it?
  194. truck rims on evo?
  195. Works Croxx Plate II install
  196. SCCA Autocross in JDM car
  197. strange issue while reinstalling the steering rack.
  198. Leaking shock? AND dead ball joint?
  199. New sneak peak OZ for 2013
  200. Relocating ABS wiring coupler in wheelwell/fender?
  201. EBC Orangestuff Review - Evo VIII/IX
  202. Help troubleshoot shudder after rotors resurfaced
  203. Corner Balance
  204. Stock suspension need to know where to start
  205. Opinions on coilovers?
  206. Can EVO6 Lower Arm Ball Joint modified to Fit EVO3 Low Arm?
  207. Key identifier between swift spec r and swift sport
  208. MR Bilstein revalving info??
  209. Best cold stopping bite/silent brake pads?
  210. Advan A046 revisited
  211. Brembo respray help
  212. 18x9 +15 Work Emotion 11r
  213. FA510s....not sure about em
  214. helper springs on coilovers
  215. Outer Tie Rod out. Brand difference?
  216. 18x9.5 NT03+M w/ 245 and 255 Pics PLEASE!!!
  217. 18x10.5 +22????
  218. Rota Torque 17"
  219. NT03+M Tire Advice
  220. Longer strut tophat mount studs/bolts
  221. Evo 8 best front lower ball joint option?
  222. Noob question.. 18x8.5 +32, 5x114.3??
  223. ccw lm20's PROBLEM!
  224. Used falken rt615 tire price needed
  225. ideal suspension setup for street **
  226. Track discs - DBA vs. Centric
  227. new wheels
  228. help! tail wagging at speed/braking.
  229. 06 MR Bilstein Shock Replacement
  230. Rally Armor Mud Flaps Now At Tire Rack
  231. Useful Link
  232. Tireteam.com?
  233. Spacer option for MR bbs wheels?
  234. Spacers or not???
  235. Proportioning valve eliminators may be available
  236. Moton 2 way adjustable okay for street?
  237. Vishnu/Gerrard Ohlins Setup Instructions Needed
  238. Titanium Chrome Rota Grids on Apex silver evo?
  239. XXR 527 wheel/tire fitment help!
  240. Perfect Tire size for Rota G force 18 X 9?
  241. Squeaking Strut
  242. E Brake Wont Release. Adjustment Help!
  243. Weird bilstein install issue
  244. Strut question
  245. 17x10 question with RS3
  246. Hankook RS-3...When do they stop gripping?
  247. Is getting PERRIN P.S.R.S BUSHINGS worth it??
  248. Is this a hub centric ring and how to remove it?
  249. Spring broke...
  250. Stock vs swift sport..... help me tom cruise!
