PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 [58] 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74
  1. Tein Basic
  2. Toyo T1-R any one try them yet?
  3. yokohama avs es100, piece ripped off
  4. Anyone running HKS Hypermax RS's?
  5. will this rim fit
  6. Wheel \ tire side wall question
  7. Steet alignment
  8. Rotor Rust
  9. Where to buy stock brake disc replacements
  10. Re-finish Stock Wheels
  11. h and r race springs
  12. Omni Power Full Coilover Suspension?
  13. Rotor and pad Install Help
  14. Best price for pads?
  15. How long have your stock pads lasted?
  16. camber kits
  17. Just got new tires from the tire rack
  18. Car Wont move!!!!Help
  19. What the hell? Brown Spots?
  20. cusco camber plates
  21. Lowering Spring Drop & Ride Quality.
  22. WARNING!! BFG KDW2 with the new tread design
  23. ... about tightening suspension.
  24. Anyone had their fenders rolled...?
  25. strange sound when braking
  26. Is there a compilation of what lower arm bars work with x downpipe?
  27. Test Results: A Valuable Tire Rack Advantage
  28. Test Results: A Valuable Tire Rack Advantage
  29. Test Results: A Valuable Tire Rack Advantage
  30. neone needing stock rims?
  31. Vendors, looking for a set of Super Advans...
  32. what brake pads to go with?
  33. Gorilla wheel locks
  34. Wheel Stud Specs?
  35. SSR's Revival
  36. Tarmac Black owners - show me your aftermarket wheels!!!
  37. spacer question !
  38. Perrin Endlinks
  39. What to do about my alignment/camber?
  40. evo steering wheel shakes
  41. are falken RT-215 worth it?
  42. what psi are you running?
  43. hks kansai mr springs... is it worth it?
  44. how much $ are evo 8 wheels worth
  45. Lug nut specs for Evo 8/Enkei RPF1?
  46. Stock wheels and tires available now!!
  47. Extreme Inner Tire Wear!!
  48. PSI for Falken Azenis 615
  49. Adverse Effects Of Going To Low?
  50. TEIN Camber plates?
  51. Kosei K1 TS 17x9 +35?
  52. Best place to order Toyo Tires from?
  53. Serves me right for trying to save a buck ?
  54. SSR comparision
  55. Possible Alignment Problem??? Wiggly A$$
  56. Alignment Issues
  57. Cusco camber plate install
  58. H&R, DMS AND TEIN COILOVERS
  59. How low is to low?
  60. Resposive Tires
  61. Brake Pads Rubbing on Rotor Edge
  62. Carbon Brake Rotors? where is it?
  63. 05 VIII / Bilstein / Hotchkis combo question
  64. Steering wheel shakes during high speed braking
  65. POWER BLEEDER - What do you use?
  66. brembo rotors???
  67. !!!help!!! No Brake Petal After Bleeding
  68. Neal - Wheel Spacers
  69. how can i get a 5x100 wheel onto my car?
  70. Wheel Spacers - Final Prognosis?
  71. Machined Rotors re-warping
  72. F/S:three oem ENKEI wheel's
  73. Where to get a new stock rim for decent price?
  74. question
  75. Volk LE28n gunmetal with machined lip
  76. Stock tires work on 17x9.5 wheels?
  77. Anybody have Yokohama ADVAN A046s in stock?
  78. Bent Fn01r-Cs Help!!
  79. RotorPRos Vs the Rest
  80. What profile tires for my car would be best?
  81. Comparable Tires
  82. advan r032r and 046 stockers + 048.
  83. Lowering with 18's
  84. Best brake for the buck?
  85. Caliper question
  86. suspension problem, help needed
  87. Need help with factory wheel locks
  88. RRE and rubing?
  89. Zeal V6 12kg/10kg review
  90. wtt: 18x9 oz superleggaras for MR wheels
  91. 18" oz superleggaras???
  92. speedo & tire size
  93. What are some good black rims?
  94. Rear Lower Arm problems? These are nice
  95. Where to get fn01r-c's painted?
  96. Broken Kinesis wheel
  97. Tein Flex + EDFC.. Thoughts?
  98. Rotational Squeak
  99. suggestions on wheels
  100. The Tire Rack (and Neal) let me down...
  101. new shoes
  102. Anyone running different offsets from front to rear
  103. tanabe gf210's on bilsteins?
  104. Stupid question: how do i stop brake squeal?
  105. Will the Advan Neova be offered in 255/35/18....
  106. Rotorpros
  107. Best Rotors??
  108. Stitch welding...
  109. Has anyone put 225/45/17 tires on EVO8 rims?
  110. WTB Passgr side rear lower control arm
  111. Will Evo 8 suspension fit on my 5?
  112. whip em out...your wheels that is
  113. damanged the sidewall of my Advan, what can I do?
  114. 18x9.5 slower?
  115. stock mr rims ^^
  116. Wierd suspension noise
  117. Hehe....look what I got today!!
  118. Will Axis Reverbs fit?
  119. can I run Neova 245/40WR17 on stock Enkei's
  120. Stupid Nails...
  121. SS Brake Line Conversion -- Advice Needed
  122. Best places to look for a wheel/tire package???
  123. Best Suspension setup??
  124. Ohlins
  125. Racing Hart C4's
  126. need brakes?
  127. Jacking up Evo question (Idiot Question)
  128. Enkei RPF1 Wheels
  129. best coilover
  130. Brembo Brakes on an Eclipse
  131. Advan Wear Issue
  132. Question on MR Suspension
  133. New Rims
  134. 17X9.5 with +38 offset.. will they fit?
  135. stock tire question
  136. Toyo RA-1 or ADVANS?
  137. New Evo VIII, help with brakes???
  138. help me out with tire choice guys!
  139. painting wheels
  140. 97 GSX rims fit the EVO?
  141. The infamous Ralliart street springs: Installed!
  142. how low for 235/40-18's?
  143. Megan Racing coilovers?
  144. Rre
  145. Difference between tein s and high tech
  146. Testing: Apexi N1 Damper ExV (Expert Type V)
  147. Weird Brake Vibration Noise???
  148. Gram Light 57S-Pro
  149. 19" rims...anyone have them on their Evo?
  150. OEM Wheels and Tires...what are they worth?
  151. What tires should I get?
  152. Front Wheels Whine when slow down... Is this normal?
  153. New rotors
  154. Tanabe Coilovers ?
  155. Stabilizer Bar
  156. Falken Azenis ST115 or fuzion ZRi ???
  157. PZero Nero
  158. Brake padel height adjustment??
  159. Clear coat peeling on Brembos?
  160. 2 Michelin tires for sale 245/40/18
  161. Whats your opinions on Nitto NT555 tires?
  162. Best Rims?
  163. The difference between +22 and +29 on Volk TE37?
  164. questions about hawk pads or any other pads
  165. hawk hp brakes squeal VERY loud is this usual
  166. question about work emotion
  167. Lowering Springs, Feedback And Suggestions
  168. toe in on front tires ok?
  169. break squeal
  170. Will these tires clear my fenders. Please Help
  171. tein squeking noise
  172. Off-road/tarmac "Rally" Tire?
  173. Anyone runnng CCW rims?
  174. PLZ HELP w/Advan Question!!!!!!!!
  175. Tein Camber Plates
  176. MR Springs Feedback Thread , Got springs on ur MR? GO HERE!!
  177. Anyone need H&R 15mm hubcentric spacers?
  178. project MU brake pads
  179. Long run for springs?
  180. Strut bar weights
  181. Shock Technology Page
  182. Sti s03 pole position tires?
  183. Summer wheel/tire suggestion?
  184. So you want a light wheel
  185. 245/45/17 Rs2s on Hotchks springs.
  186. can I run 235/40/17's?
  187. Lookin For Some Wheel Suggestions.
  188. How to Tune Your Suspension!
  189. Stock Ride Height Question
  190. 2 Questions Axis Reverbs and price for stud install
  191. any 16" wheels that will fit on the evo
  192. steering wheels shakes when braking??
  193. Cusco Zero2R Spring diameter
  194. Gram Lights on Tire Rack?
  195. This is Dumb
  196. ROTORS wheight
  197. Anit-Sieze Compound on Wheel Studs.
  198. Wtb: Swift Springs
  199. warped rotors.. what to do?
  200. New tires - what would you reccommend, Neal?
  201. GramLights 17x9.5 fitiment question
  202. StopTech vs Brembo Rotors
  203. Tire pressure?
  204. pics of my new wheels.
  205. What size tire for 18x8.5 work emotions and which brand?
  206. Opinions Please 19x9.5
  207. Just installed my brake pads
  208. question about brake PAD install
  209. **STUPID*** Question
  210. Chronic Mis-Alignment DRIVING ME INSANE--please help!
  211. Guess the offsets to these....
  212. Tein Flex owners please read
  213. Hotchkis Rear Sway
  214. Alignment Shop in Socal
  215. Pictures of 9" wide wheels on the Evolution?
  216. Anybody use structural foam?
  217. will this fit my evo?
  218. FN01R-C avl at WORKS
  219. Tire Wear (alignment???)
  220. Buddy Club P1 Racing II?
  221. Unusual Front Passenger brake wear
  222. Tires for 18x9 29 offset volk gtu
  223. Need Help! - Vibration
  224. What are the Widest Tires Possable?
  225. MR suspension noise question
  226. Tire shop screws up rims
  227. aligment question
  228. What are some of the HOTTEST NEW wheels out?
  229. B Force pads, SS lines, and super blue review
  230. For those with the Sparco harness bar...
  231. 19x9 wheels
  232. Missing brake piece, what is it and is it 'really' necessary
  233. Tire Rotation
  234. Will camber plates OR"aftermarket eccentric bolts" fix chronicly UNEVEN front camber?
  235. Back-end Wiggle at High Speed: how can I eliminate?
  236. stock pads and stock rotors
  237. where to buy espelir
  238. Brake Pad Options Or Trade
  239. Works MR edition Springs
  240. EVO 7 parts change..FOR EVO 8
  241. How wide can you go ?
  242. Arrows on Stock Brake Pads?
  243. cusco bars...
  244. need you input on Gramlight 57S
  245. Wedsport SA90 -- Owners??
  246. Motegi Trak Lite wheels???
  247. I heard that we cant bleed our brakes??
  248. these line ups are the hotness
  249. need opinion on these 2 wheels!!!
  250. Rota wheels that fit STI's
