PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74
  1. Suspension NEWB
  2. Weather got cold outside, and brakes started squeaking.
  3. Which Tires?
  4. Stiffest springs for stock dampers?
  5. Let's talk real about Rotas
  6. WTB: Motegi Traklite 15s for Drag Evo ASAP!!!
  7. Before I sell my springs.....
  8. Best drag tire for 18x9
  9. Widest rear rotor thickness possible
  10. New pads = no stopping power
  11. Broken lug please help
  12. Need help with Brembos!
  13. Suspension Upgrade Options
  14. Tires that don't burn out after 10,000 miles
  15. Brake kit?
  16. Stock Pad Replacement Cost?
  17. Requested Pics
  18. Megan or KSPORT Coilovers
  19. what wheels wuuld look the best on a white evo?
  20. need some clarification
  21. Noises after installing Megan Coilovers?
  22. Brembo 6 pot mono bloc
  23. winter tires
  24. will whiteline bumpsteer kit cause rear toe adjustments to run wide?
  25. looking for volk ce28n's
  26. Anyone running 18x9.5J +30 offset?
  27. SWIFT Springs or BC/Megan Coilovers
  28. whats a good choice for wheels?
  29. People with advan rgii's
  30. Hankook Icebear
  31. 18x8.5 +35 offset axis Hiro perfect evo 9?
  32. PIC / PURE TT Coilovers
  33. Brake pad sqeek...
  34. Jic flt-a2 dampening settings
  35. Enkei NT03 - hubcentric rings?
  36. Need help looking for tires
  37. Bilsteins + Tanabe springs= ??????
  38. New lug nuts from Rays
  39. stock brakes and bed in procedure information
  40. Volk TE-37 Time Attack 18x8.5 +40 compatible with Brembos?
  41. Has anyone tried Nitto 555 RII Tires?
  42. No Winter Tires = Crash
  43. Anyone do their own alignments??
  44. Anyone running 18x9.5 +22???
  45. tire replacment help!
  46. who's selling the R888's?
  47. Carbotech pads
  48. Anyone have Continental ContiExtremeContacts in stock?
  49. Best offset for 17x10JJ wheels?
  50. Brake light turns on and off
  51. brake pads
  52. How long to bed Hawk HPS brakes properly?
  53. After in spec alignment, car still pulls to the right
  54. will 245/45/17 works
  55. Bridgestone RE-01R size and pricing
  56. Falken rt-615
  57. Nitto NT-01 tyres
  58. need help
  59. Need Help Fast!
  60. Coilovers installed, I still hear clunking
  61. Lugnut Question
  62. Coilovers are touching tire and messing up alignment?
  63. 215s too small?
  64. Help With Wheel Fitment
  65. volk time attack
  66. any pics of Tenzo R DC-5 on evo?
  67. Has anyone tried antiseize on their caliper bleed screws?
  68. good price?
  69. BEST tires?
  70. LOwering issue
  71. Evo 7 wheels
  72. Evo 7 wheels
  73. evo IX: suspension & brakes
  74. New Product - S.W.I.F.T Sport Springs Spec-R
  75. swift spring weird with sound help
  76. Alignment Setting
  77. What will be affected when camber, caster, and toe changes?
  78. omni coilovers?
  79. Spring rate conversions kg/mm to lbs/in
  80. New Whiteline Catalog
  81. help on lowering springs
  82. fender for sale... and dented doors if anyone wants them
  83. how do bump steer kits work?
  84. Blizzak- LM25 or WS-50???
  85. 245/40, 255/50 on stockers
  86. evo ball joints
  87. Lowering Evo Alignment Kit
  88. Trying to install rear swaybar...help please
  89. coilover needs revalved, where to get it done?
  90. Replacing brake pads on rear
  91. Need Help!!! Dunlop M3
  92. Rear suspension is lower?
  93. Can't tell if the rear of car is lowered....
  94. Brembo brakes peeling....check this out
  95. Help me!
  96. Frozen Rotors
  97. Name this wheel...
  98. Evo IV Rotors
  99. perrin end links
  100. Advan AVS T7
  101. Technafit brake line question
  102. Is anyone using these new Cusco bars? How do you like em?
  103. Who's got Eibach springs?
  104. Brakers Sticking... PICS
  105. finally...swift springs on the way...
  106. For Sale EVO VIII enkei wheels
  107. Work VS TX or VS XX in stock ? anyone ?
  108. 350z pads on evo
  109. Evo 8 stock lugnuts?
  110. Will I rub wth Enkei RPF1s in 18x9.5 on 255/35/18 RE01s?
  111. Best Ultra High Performance All-Season Tires
  112. Squeals When Braking to the Left?
  113. rpm2 fitment?
  114. wtf brembo
  115. Coilover of choice - explaination
  116. Nitto 555R Drag Radial
  117. Max tire width on the 17x9 and 17x9.5
  118. All possible sway bar options...what are they
  119. Need a taller tire that wont rub with lowering springs!! HELP ASAP!
  120. Tyre Sharing Experience tread
  121. Tein Super Street Damping force question
  122. New tire from Toyo. The R1R.
  123. work wheel offset
  124. Lightweight/Strong 17's ?
  125. Questions about newly installed tires
  126. tein super street EDFC wiring help!
  127. Places to revalve Ohlins
  128. Pirelli Winter 240 Sottozero Tires
  129. Most Comfy coilovers? as soft as MR shocks?
  130. 18 x 8 .... tire size ?
  131. Needed: Racing Sparco NTR
  132. 295/30R18 A6's on 18 x 9.5 wheels?
  133. Advan RS
  134. Bleed Brakes before every race?
  135. Replacing a pair of tires
  136. Will it fit? Volk Racing LE28N Rims 18x9 +35 Offset
  137. ksport coilovers...
  138. H&R sway bar clunk found!
  139. Street Coilovers Installed - Have questions and Pics!
  140. Ecsta v700 tires on the street?
  141. WORK emotion cr kai 18x9.5
  142. Hawk HPS pads
  143. opinions on brake pads/rotors
  144. 18x8 +45 offset fitment
  145. Robispec buddyclub anyone has them?
  146. Megan Track Coilovers.. NEED HELP
  147. Aligment Tutorital for Newbies...
  148. Cusco front sway bar installation
  149. Steering wheel vibrations, please help!
  150. ATTN: GTworks.com
  151. WORK Emotion XD-9 18x9
  152. Any pics of Gramlight 57c on evo 8 or 9?
  153. I need help with my Enkei stockies!
  154. maxing the stock front fenders
  155. Potenza RE-01R's tending to Hydroplane
  156. Sway Bars- My ticket to corner handling but stock ride on HWY?
  157. Gram Lights Pro 57s 17X8 w/ +40 offset fitment???
  158. Race tire question
  159. BremBo Retainer PINS and CLIPS
  160. Hub Assemblies, do they include wheel studs?
  161. looking for (1) stock evo 8 wheel
  162. Tein S.Racing Circuit Master Coilover vs KW Variant3
  163. Evo VIII rims on IX?
  164. need help(advan RS)
  165. higher spring rate on the rear?
  166. Optimal rim width for 265/35/18?
  167. Spring Rate Question on Non-ACD Evos
  168. Rays Extended Lugs
  169. need an oppinion
  170. TME rims in other sizes?
  171. stock brakes
  172. dunlop sp9000s suck....
  173. Favorite place to buy wheels from?
  174. powder coat MR BBS's
  175. Sway bar End Links...
  176. ralliart lug nuts
  177. Ideas to questions asked...
  178. Coilovers!
  179. Stock suspension tire wear?
  180. oem style lug nuts
  181. Springs or Coilover
  182. BF Goodrich g-force T/A KD Discontinued?
  183. s tech problem
  184. what rims are these?
  185. Factory Alignment
  186. Brake pad advice needed.
  187. ?Lug pattern for 05evo fit 04r32?
  188. Ebay rotors
  189. Think this wheel/tire combo will work?
  190. Repairing forged wheels?
  191. bilstein or stock shocks for the track
  192. wheel center bolts.
  193. New wheels ordered
  194. RacingHart J8 Pro
  195. 2-Piece rotors
  196. tein s-tech question
  197. RT-615's or RE001r's? pros/cons
  198. ABS Fuse
  199. Volks on Spacers
  200. High-end wheel set up
  201. what are the cheapest brakes?
  202. tein s tech
  203. Alignment after lowering Springs
  204. All Season Tires
  205. Brake and Rotor Warranty
  206. Work VS-SS
  207. will 42mm offset wheels fit on an evo
  208. STI wheels on the Evo??
  209. Best Place to buy Toyo Tires???
  210. MR BBS wheels, what size bfg drag radial?
  211. what spacers???
  212. Replacement wheels
  213. Just ordered some black w/ polished lip Rota D2's with 255/35/18s
  214. Anyone ever try MT DR's on stock rims?
  215. lowering my car need advice
  216. Anyone have experience w/AMS stage 1 (SP1) suspension upgrade?
  217. Tanabe pro 5 vs pro 7 coilovers
  218. brakes making a grinding noise
  219. ?-S-Techs back to Stock Springs
  220. Tires....Decision, Decision, Decisions
  221. Racing Hart J 8
  222. megan coilover help !!!
  223. pros and cons- spacers with and w/out studs
  224. KW Variant 3 Owners....need your help!!!
  225. wheel spacers
  226. Team dynamics pro race 1.2
  227. Red Brake Light comes on
  228. 245 45 yokohama yk520??
  229. Wheel/tire weights - are my calculations correct?
  230. swift springs with my 18X9.0 rotas
  231. What wheels are these?
  232. For those that have shipped wheels and tires..
  233. front and rear different offsets?~
  234. Really dumb question
  235. Which wheels do you like better for a silver 06 IX
  236. Bouncy ride
  237. clunking in the front end
  238. Toe change when adding negative camber
  239. coilover helper springs
  240. Wheel/tire question
  241. Caliper piston sizes
  242. Save $100 instantly Discount tire direct
  243. Need new tires on new wheels!
  244. Gold Volk GT-U's on RED EVO MR!?
  245. Best Size Tire for 18x8 +30
  246. craddle bolts sping freely need help
  247. Discount Tire Direct - $100 off until oct.20
  248. Any issue with 18's?
  249. Swift springs install
  250. Megan Racing Lowering Springs?
