PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74
  1. New WHEELS/TIRES? choices...
  2. What brand for dragracing.
  3. brake bs
  4. Squeaky OEM brakes
  5. Summer Tire that can handle a little snow?
  6. Pulsating brake pedal but only at high speed?
  7. Advan RS
  8. Best Tires to buy...
  9. Ebay Rotors?
  10. Little weights on wheels
  11. CBRD and RCE/GTWORX bring you RCE evo springs..
  12. 'D2' 8 piston brake kits
  13. PSS9 spring rate suggestions?
  14. quick question about installing brake pads
  15. Just installed new brakes, clicking?
  16. Work Emotion CR kai 18x8.5 +20 offset
  17. Just got a set of Falken 912's 245-40-18
  18. Anyone have ccw classics on their evo?
  19. Looking into Greddy Type S Coilovers
  20. Diamond Black Volks in stock ANYWHERE???
  21. thought on lowering the car?
  22. tires for 18 x 8.5 enkei or52's
  23. About to buy set of Kumho Ecsta ASX, 235 or 245?
  24. tanabe or swift?
  25. stock wheel dimensions?
  26. Gtworx
  27. best 18 inch tires to get
  28. Spacers w/ OEM MR wheels
  29. New Volk Time Attack rims
  30. Has anyone put works on an evo
  31. BBS 'Diamond Black' color code?
  32. Cursed Rust! Need some ideas.
  33. Tire rubbing - alignment or LCA bushings?
  34. Coilover squeaking
  35. Will this fit?
  36. help wheel spacers
  37. Can't decide - 2 sets of wheels? Or - all-season tires?
  38. HELP! Need GOOD suspension tuner in SE
  39. Megan and Apex N1 ExV same???
  40. break check
  41. Stance vs Megan Racing Coilovers
  42. warped rotors
  43. KW V3 vs Zeal Function Xs
  44. Larger Rotors (14") with adapters for Brembos?
  45. Effect of camber on toe
  46. blown mr bilsteins?!?
  47. Espelir GT Springs (I promised to say where they are available)
  48. Takata Green Paint
  49. do you like the viii or ix enkei's
  50. the best tires - but the don't last long
  51. Looking for UN-drilled/slotted 2 pc floating front disks
  52. tein FLEX vs MONO FLEX??
  53. Loud noise when braking
  54. Volk center caps hi or low?
  55. My 19inch Voltec Wheels...
  56. What brakes / Rotors should i get?
  57. Pulling + Rolling Help (Cracked Paint)
  58. Weird start-up/idling problem with EMS...
  59. Finally found quiet brake pads - noise free
  60. Went to lower my TEIN Coilovers, shock very close to axel boot? Problem? Pix inside
  61. Are coilovers easy ?
  62. Ones w GF210's and a lip
  63. Rotor removal questions
  64. think about lowering and I need opinions PICS
  65. Evo 8 Master cylinder bore
  66. Sqeaky brakes???
  67. breaking in new tires??
  68. Adjusting ride height with Tein Flex Coilovers...?
  69. GF 210's will it wear out ur tires faster?
  70. 17x9.5 Can someone level with me?
  71. Been beaten to death, but I need some more advice (Rt-615vsRE0-1R)
  72. which color for bby
  73. which color for bby
  74. Rear driver corner lower than passenger - normal?
  75. NEW Wheels & Tires..maybe some HELP!
  76. Setting sway bar stiffness
  77. Lowering spring for 9 Gsr
  78. disappointed with stock brakes
  79. Shelf life of ATE Super Blue
  80. Official concave 18x9.5 wheel thread.
  81. 19x8.5+30 / 18x9.5+20 Info
  82. 17x9 Works Emotion XT7 Offset for MR?
  83. Car slips
  84. alignment spec suggestions
  85. Brake Clearance Question
  86. rota p45r 18x9.5 with 265/35/18 rubbing problem
  87. 255x40x17 and need a drop
  88. Espelir GT springs on 06 MR. Please answer my question!
  89. Is anyone running Nitto NT-01's +0's? Review?
  90. Spector Tires?
  91. need help with wheels
  92. New Goodyear Eagle F1 Allseasons Anyone???
  93. wheel question
  94. Wheel weights affecting acceleration
  95. website tire Q
  96. Staggered wheels
  97. 19x8 front 19x9 rear...diff issues?
  98. 18x9.5 with 265 alignment angle
  99. Alcon 6 pistons...
  100. wheel question
  101. Konig Heatsink 17x8 Fitment?
  102. disc and pad install prices? help the brothers out.
  103. ABS delete kit??
  104. Rota MS1-R
  105. Are Pirelli P-Zero Neros being discontinued?
  106. Wheels weight question
  107. wheel spacer question!!
  108. Ksport dealers - Need rebuild kit for Ksport Kontrol Pro's
  109. I am lost in the world of Wheel and Offset Sizing
  110. Brake upgrade for Evo IV
  111. Advice on pads
  112. Do I need an aligment if I get wider wheels?
  113. Question regarding tire/alignment..
  114. Best suspension component for under $500
  115. What Vendor has the best price on Enkei RPF1 17x8.5 SBC color
  116. Best Springs for MR shocks
  117. Just changed my pads
  118. Stock wheels with long studs?
  119. value Of VIII rims W/tires
  120. Track rims. Paint or Powder coat?
  121. Wheels that create downforce!
  122. Look what I got today...
  123. What advans look like after 17k
  124. replacing brake line problem
  125. Brake Pad Recommendation (quietest)
  126. minor incident = abs problem
  127. Need help with my susp
  128. Review on Yokohama S. Drive tire
  129. web special: Ohlins coilovers
  130. Testing Cusco Strut Tower Bars: Does it really work?
  131. Any idea if these CTS-V Brakes will fit?
  132. What ARP wheel studs work for the evo?
  133. Re-installing stock Bilsteins
  134. D2 Racing coilovers/yes-no-eh?
  135. 17x9
  136. Too much negative camber binding axle?
  137. For Anyone in the Miltary
  138. -2 camber ?
  139. 5 Zigen PRORACER ZR+520 wheels!!!!
  140. New Tires
  141. EVO IX wheel centercap compatibility
  142. tire help please!
  143. Brembo touch up paint?
  144. Tire noise
  145. chipped paint
  146. BBS RX 17x9 +28 ?
  147. play in rear right wheel
  148. coilovers
  149. Tie bar???
  150. how to change brake pads??
  151. work or swift springs
  152. Aftermarket Wheels...
  153. my steering gear works curious!...
  154. Lowering Spring Ride Quality
  155. OEM replacement brembo logos
  156. rim does not clear cal
  157. Alignment Problem!!
  158. suspension?? what to do???
  159. ce28 time attacks rubbing?
  160. brake bleeding questions
  161. Buddy Club Racing Specs
  162. good dirt tire?
  163. Official "I got really nice wheels with no center cap" Thread
  164. AP 5555 caliper & 362mm rotor vs. Endless 6-pot racing caliper & 370mm rotor
  165. New Girodisc Rotors!
  166. Brake pad chamfers?
  167. tein flex help
  168. help tein flex
  169. Anyone try Yokohama S Drive Tires
  170. 18x10.5 +15 with 265/35/18 rt-615's
  171. Racing Hart CP-S10
  172. HyperMax 3
  173. offset question
  174. Coilover Weights
  175. Falken RT-615s suck in the rain
  176. HELP! How do I roll my fenders on my Evo?
  177. is running spacers bad?
  178. i want 18x9.5 +22 with stock fenders, help!
  179. Volk offset help
  180. IX Enkies fit on WRX????????
  181. alignment specs
  182. tein R pillow ball mounts ?
  183. are my struts done for?
  184. Been looking haven't found it. Coilover tuning
  185. Brake caliper shims keep warping...
  186. Offset question
  187. ANyone have experience with Silk Road Coilovers?
  188. Racing Hart Problem!!!!
  189. Who all has 18 or 19" rims on their Evo 8 or 9?
  190. Looking for 18" Enkei wheels just like stock
  191. Rota D2 or P45R?
  192. 18x8....Max width and Sidewall
  193. '06 Evo IX SE lowered on Works springs
  194. brake servo booster
  195. gramlights questions
  196. 17x8.5 v.s. 17x9 equipped with 255/40/17
  197. 255/35/18 What tire pressure?
  198. Brake question
  199. Help! very strange shudder from front left.
  200. lost my wheel lock key.. suggestions??
  201. KW Coilover setup from Robispec. Lots of Pics.
  202. Brake problem???
  203. G4 Coilovers/Whiteline?
  204. Ro-Ja
  205. R Bridgestone Potenzo RE750 Tires any Good?
  206. Best Snow/Winter tire?
  207. Brake Combo - Street Performance
  208. Testing Prototype Endless Brake Pads
  209. Lost the wrench for my Ray's Lugs
  210. Converting normal Bilsteins/Ohlins to NASCAR-type shocks
  211. HELP! Can't decide which wheels to get for LY EVO
  212. What should I go with, used HKS Hipermax or brand new Megan Coilovers?
  213. Anyone have pix of Time Attack CE28Ns or other wheel like them?
  214. Body roll
  215. Odd tire wear
  216. break pads
  217. Stock Evo 9 rims /tires
  218. 17 x 10 " +12 offset 5Zigen FNO1RC vs 17x9.5 RPF1s
  219. Installed springs...Bunch of flywheel chatter???
  220. Nail in tire, ok?
  221. ORDERED: springs and wheels
  222. Rim decision Need Help
  223. best camber setting
  224. under brace wont fit my turbo kit
  225. what rims are these?? muellerized evo??
  226. Rear Brembo Caliper Damaged :(
  227. Caliper pad guide broken, part number ?
  228. Rays Lug Key's.........all the same?
  229. Anyone know a dealer with some lugs ?
  230. Pic request ZR 520s
  231. rotor question
  232. Custom Enkei RPF1
  233. Anyone using Nitto INVO?
  234. Robispec RULES
  235. anyone have the Yokohama Parda Spec-2 tires?
  236. Tried to fit 26's on my evo!!! PICS !!!
  237. Ce28n 18x9.5 Arriving soon, Need Help!
  238. what size tire on 18x9 rim on tanabe springs
  239. squeaking noises after fitting whiteline roll centre adj kit
  240. what Springs are good???
  241. Is it safe to drive my car with one wheel stud broken?
  242. Is it safe to drive my car with one wheel stud broken?
  243. Is it safe to drive my car with one wheel stud broken?
  244. to Resurface or not?
  245. Front Endlinks
  246. Aftermarket Rim Center Caps
  247. Rear Suspension Squeak
  248. Stock Advans = nails in tires!
  249. The Official Wide Tire Thread
  250. H&R rear sway bar hitting ??? Tirerack
