PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74
  1. Confirm my setup please...
  2. Centric Rotors
  3. Replacement struts
  4. Due for new brake pads! recommendation?
  5. Best coilovers ?
  6. What are good tires for all season?
  7. Any mech engineers majors on deck?
  8. Bolt on wheel spacer question
  9. Best Brakes For Bang of Buck
  10. Wheels for an evo 8 - Any tips?
  11. Replace or not, NAS trihead bolts in dba 5000T3?
  12. New Ball Joints and bushings
  13. EVO IX wheesl and snow tires
  14. Best Suspension For Road
  15. Evo 9 Brakes!
  16. 255/35/18s opinions
  17. Control arm brace with 3" downpipe
  18. Out of toe adjustment?
  19. Need help! Coils and wheels
  20. RHD Non Abs brake lines??
  21. Help need to find this bolt
  22. Possible bad wheel bearing?
  23. Spare tire for evo 8 wanted
  24. Does anyone know what two-piece rotors these are?
  25. Ambit wheels
  26. sway bar bushings
  27. 18" with mudflaps?
  28. Wheel type/Size for Evo 8
  29. Anyone running Falken FK510, chime in plz
  30. PF01 Evo 17x9.5 ET38 anyone?
  31. Wheel/tire size
  32. whats the best offset for evo 9
  33. Question regarding fitment
  34. Personalized question: Custom alignment needed or not
  35. Bridgestone Re-11's or nitto nt-05's?
  36. Is it safe to drive my car with one wheel stud broken?
  37. Evo X front BREMBO to Evo 8-9?
  38. Suspension replacement options for a street car
  39. Need opinions: painting wheels, which color?
  40. Any issues with running zero preload at rear of Ohlins R&T?
  41. any one know what wheels are those ?
  42. Bilstein B8 vs Bilstein Coilovers vs KW V3
  43. Picked up a Set of 18x9.5 +27 NT03s
  44. ABS pulsing for no reason
  45. How much brake fluid do I need to buy?
  46. Wheel advice
  47. Rear Lower Control Arm help
  48. would you change this disc? 9 yrs old
  49. KWv3 full lock noises
  50. OEM KYB Strut Assembly?
  51. Brembo Brake rotors
  52. Latest knocking sound
  53. What brake pads are compatible with Grex BBK for Evo 8/9
  54. Front Eccentric Bolt
  55. coilover help
  56. Goodridge front brake line too short
  57. Do I need a new rear cross member?
  58. Which two-piece front brake discs mount in evo viii?
  59. need brake pads (and maybe rotors)
  60. Help tired of squeaking brakes/ need input
  61. Help in determining the size of disks and tires
  62. 235 Advan Neova or 245 Hankook RS-3?
  63. getting an alignment what should i set it at??
  64. Nt03, spacers and alignment ?
  65. Rear roll center correction vs standard bushing for dd
  66. how to calculate bump and rebound of suspension?
  67. Strut replacement, shop recommendation for assembly?
  68. wheel spec question
  69. corner balancing - adjust preload or shock length?
  70. Ohlins and Whiteline questions
  71. CT9A without brembo brakes?
  72. Rear LCA bolts
  73. Stock Bilsteins garbage or rebuilt and shop rant!
  74. Pirelli RX5 Vs RX7
  75. Enkei NT03
  76. Grinding noise! Help!
  77. Has anybody used these rotors/pads?
  78. Trailing arm optoins for 285's
  79. 06 evo 9 mr swaybar question
  80. Cheap OEM wheels
  81. evo 9 rim offset
  82. Trying to remove axle from rear hub
  83. Shimmy in steering wheel
  84. ev0 7 wheel sensors
  85. Rota svn-r
  86. looking for photos of 17x9 +25, 235/45/17
  87. Evo 8 lug nut help
  88. Esr sr05 18x9.5 +35 fitment issue.
  89. Front suspension EVO6 and EVO8
  90. Is there any demand for used suspension parts for an VIII or IX?
  91. Tires
  92. Problem with back passenger wheel
  93. Searching for a BBK pad
  94. Federal Fz-201 opinions
  95. Tein flex edfc experience?
  96. Does added caster change alignment?
  97. whats the cut of age of R spec tyres when purchasing?
  98. swapping rims alignment question
  99. Cosmic Xt206r 17x9
  100. Front control arms
  101. Front end rattle
  102. anyone tried a hankook rs-4 yet?
  103. looking for some suspension advice...
  104. Enkei Rpf1 18x9.5+15 evo 8/9 wheels
  105. evo 8 enkei rpf1
  106. evo 8 enkei rpf1
  107. FSB rubbing front subframe
  108. Most offset without rubbing
  109. 18X10.5 +12 wheels with modified OEM fenders
  110. Evo 8/9 vs. Evo X
  111. 17" x 9" +35 on Swifts... 255/45R17, or 265/40R17?
  112. Lower Brake Pedal Effort
  113. Wheels and Offset
  114. TE37 +22 9.5 18" and 245/40/18" fit ?
  115. PN for Ohlins R&T front upper bearing
  116. Gtworx in Australia?
  117. Need help! Looking for 17x9 rims.
  118. Bilstein HD struts and swift spec r springs?
  119. New tires, better gas mileage
  120. Best looking and functional 17x8 rim?
  121. Corner Weight Balancinig, Proform 67650
  122. Anyone in Haywood, CA want to test fit some wheels?
  123. Lug nuts for stock enkei's
  124. Looking for a good performance wheel size and offset, with good tire combo.
  125. What coilovers to go with
  126. Best tire size for 18x9.5?
  127. Very Stiff Brake Pedal
  128. AMS Brake Duct Install Fail
  129. Cosmis 17x9.5 et5
  130. do RFP1 17x8 look odd?
  131. Alignment
  132. Looking for Brembo Rebuilding:
  133. Coilover Cartridge Cross Compatibility?
  134. Best Tire/Rim Size for an Evo9
  135. Hankook Ventus V12 Evo 2 - A well rounded tire? (pun intended)
  136. Northeast Fender Rolling
  137. Works D9R 18x9.5 +30 fitment on evo 8
  138. dot 5 fluid?
  139. Wheels and Fits question for stock evo8
  140. camber and toe alignment problems
  141. Problem with Brakes
  142. Big Brake Kit options
  143. Help with tire choice/size
  144. Need Help with RPF1s PLEASE
  145. When to replace Brake lines
  146. Wheel and tire fits
  147. Best Alignment Specs for my Evo IX MR?
  148. Brake Pressure Problem
  149. Very loud high pitched squeel when braking & turning left only
  150. Sub $1500 Coilovers
  151. Fitment of RPF1 17x9+22 on Evo 8
  152. Blizzak WS80 Pricing?
  153. Estimated Cost to fix a bent rim?
  154. New YCW/MFactory Suspension Coilovers
  155. Vibration in steering wheel only during braking
  156. Front Camber change Toe that much?
  157. Has the frount clunking issue ever been solve?
  158. Gold Wheels
  159. question on brakes
  160. 18X10.5 +15 Evo 9
  161. White Wheels Hard to clean?
  162. MFactory/YCW Suspension/SWIFT Springs - Looking for sponsored driver(s)!
  163. How to fix sloppy suspension
  164. Evo brake line to -AN adapter?
  165. Te37 fitment question
  166. Recommend aftermarket rotors
  167. AP Racing Radi-cal Pro 5000 Caliper interest?
  168. Advan RS 18 x 9 et22
  169. CLOSEOUT on Hankook R-S3 v2
  170. Big Brake Kit, 6 Pot w/ 14" Front Rotors
  171. WedsSport TC105N or Gram Lights 57Transcend?
  172. Evo 8 springs
  173. Neal retiring as your moderator
  174. Street Pad Reccomendations Needed
  175. Brake Pads
  176. 2017 - Street Tire Options
  177. Best front/rear strut tower bars?
  178. how do you read willtheyfit
  179. Adjustable Rear *UPPER* Control Arm
  180. 57C Rays
  181. Enkei RPF1
  182. Volk RE30 center caps
  183. Bilstein B6 + OE springs, springs clicking
  184. Larger Wheel or Adapter?
  185. Help me choose a brake pad.
  186. Help with ce28 wheel fitment question.
  187. Toggling ABS On/Off... creative solutions?
  188. Enkei NT03RR fitment??
  189. Oem lug nuts
  190. Need help on fitment
  191. Best wheel setup for a bagged evo
  192. What size tires do you guys use with your lowered evo
  193. YCW Reference Series Coilovers - Tester Required for Development!
  194. Opinions Needed!
  195. Bilstein B6 & B8 Diference
  196. Help wheel firment
  197. Need some info,, Yes I did search 17x9 35 offset
  198. Fifteen52 wheels
  199. Ways to pick the right sway bar
  200. What anti sway bars are you using??
  201. RE760, Direzza DZ102 or DW
  202. Konig Flowform Wheels
  203. Pic Request: New CE28SL, 17x9
  204. OEM KYB to Bilstein B6 HD - bump stop question
  205. Factory Brembos under rear 15" wheels?
  206. Japan Racing Wheels JR5 with Brembo Brakes
  207. trying to track down the part number for OEM Evo 8/9 MR Bilstein rear struts
  208. Upgraded to Torque Solutions rear diff bushings
  209. bbs mr rims chipped
  210. Megan Racing Roll Center Adjuster? any thought?
  211. my first wheel alignment coming up, what should i ask for?
  212. spacers vs hub centrics
  213. S2k wheels on evo?
  214. rear wheels wobbling after spacer+extended studs
  215. Is there a smaller abs compatible brake master cylinder?
  216. Soft Pedal Solutions - Rd. 2
  217. Heeeelp!! Evo suspension!!
  218. High speed 1/2 and standing mile chassis set up?
  219. Tanabe & RS-R springs
  220. Front right tyre sticking out
  221. KW Variant 1 or Tein Flex Z reviews!!!
  222. need ENDLESS Brake Pad model name and part number
  223. HKS vs KW vs Tein street use
  224. TEIN Flex Z
  225. Fortune 500 series coilovers
  226. Alcon brakes with 3 pistons?!?
  227. WedsSport TC105N Center Cap
  228. Front Strut Replacement Options IX MR
  229. Oem Evo 9 wheel paint color code?
  230. Rear Wheel Bearing change
  231. Question: life of RE71R & 200 treadwear tires in general
  232. Centric pads are the WORST
  233. Ohlins R&T valving limit
  234. Better than stock MR Bilstein Performance and Ride Quality
  235. Stacking Spacers?
  236. SSL + Coilover Adjustment
  237. Evolution 9 hard brake lines
  238. Brake Pedal Popping When Depressed
  239. Anyone tried Doss Wheels?
  240. Replaced rear struts, alignment needed?
  241. Need help!! Brakes not releasing
  242. Good tires for 600whp weekend car? 18x8.5 +30
  243. Swift vs tein springs
  244. Evo 1 brake parts compatibility
  245. Evo brakes hanging up... figured out!
  246. Am I dumb? Any advice would mean or nice is welcome
  247. Confirming correct bushing needed
  248. Fender brace GB?
  249. Pic Request: Full Front Subframe
  250. coilover question
