PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 [71] 72 73 74
  1. Neal@Tire Rack, Wheel question?
  2. Clear pictures of Tanable GF210 Springs Installed
  3. Force transmitted to steering wheel
  4. what makes my tires chrip?
  5. Ways to make the ride softer than stock? (springs vs. coilovers)
  6. Racing Hart CP F Tune R
  7. Azenis or Sumitomo
  8. Curbed car, alignments off, what else to expect?
  9. Yoko A046 off EVO and for sale
  10. Winter tires...
  11. Sumitomo HTR+ - On the EVO
  12. Which lowering springs are softer?
  13. Incredible Ride
  14. Wheelmax.com
  15. Ultra Hi Perf All Season Stock Replacement...?
  16. Need Chicago area, southern Wisconsin EVO owner for wheel test fit!
  17. Coilovers - Damper and Spring Settings
  18. Stock tires fit 8.5?
  19. SSR Competition 18x8.5
  20. can the camber be changed during alignment?
  21. Stock tires + rain...
  22. Ready to Buy - Need advice on vendor and pricing
  23. SSR Integral GT2 and Type-C wheels
  24. Braking Hard?
  25. Springs:CHOOSE 1
  26. Ok to replace just one tire?
  27. Hankook W300 On Evo In Snow??
  28. Dunlop Graspic DS-1, Ok tire for Winter?
  29. Stock Tires, Midwest Winter?
  30. Axis Spider..will these fit ok?
  31. Can i run this offset with these Volks?
  32. OZ Superleggera...
  33. New Evo Vendor
  34. Volk, SSR & Tein Pics
  35. The factory Enkei rims on EVO VI TME?
  36. My alignment sheet
  37. Setup for EVO VIII with 17" rims
  38. Michelin Pilot Alpins review
  39. privat wheels
  40. brake pads
  41. winter tires
  42. Volk LE37T Wheels
  43. $350 new set of Yokohama A046 tires
  44. Advan A048's
  45. Rims and the winter time
  46. Snow on the ground
  47. Snow and Stock Tires?
  48. ADj. Camber Plate
  49. tein Flex installed. Good yet bad too
  50. Recommended size / offset of 17" Volk TE-37 rims and tires to fit EVO VIII
  51. best compareable replacement tire?
  52. Damn Bolts
  53. Rotas - Info on wheel which doesn't need a spacer
  54. Wheel Spacers???
  55. lightest 17's for under $350
  56. Alinement with new tires?
  57. Coilovers
  58. EVO VII brakes
  59. Home made trunk bar
  60. Bronze stock rims?
  61. Axxis Ultimate pads
  62. Tein Dampers
  63. wheel studs
  64. What did you do with the stock wheels?
  65. Need help from Evo owners
  66. Replacement tires?
  67. carbon fiber rims ?
  68. Want to solve your Brake Disc woes!!!!!
  69. for those with progress springs
  70. Neal what is the weight of the 17x7.5" SSR Competition
  71. Need brake pads for my evo
  72. uneven tire wear
  73. Evo VIII - Rays Volk Racing SE37 rims
  74. Something New!
  75. coil over poll. Working Poll this time
  76. Stupid brake pads
  77. Slicks for the track
  78. Evo 8 wheels
  79. pulls to the left when I brake...
  80. brakes squeaking
  81. Tein Flex Vs. SS
  82. progressive sway and perrin links....
  83. Pics of New wheels on EVOs?
  84. Lowering the EVO ? good idea ?
  85. Inexpensive Black Rims for White Evo Where?
  86. WIll 18X8.5 5:114.3 +40 Offset Wheels work on the EVO?
  87. rims
  88. Racing Rain Tires
  89. Tanabe Pro S-0c Type-2 Coil-over
  90. Ralliart Wheels Where?
  91. Cheap assed steel rims?
  92. p/s failing at idle.
  93. Neal -- Tire size question for 17x8's
  94. new brakes and rotors
  95. New Wheel For The EVO
  96. Compomotive wheels
  97. BBS fitment issues...TR got any answers?
  98. Tein S Tech - Softer ride than Stock
  99. Wut's the best trie size and wheel size for evo??
  100. snow tires
  101. Q: Stock Evo's suspension spring rate / Coilover recommendation
  102. suspension question
  103. brakes
  104. Lowering/Drop Concerns please advise
  105. Post Your Aligment Settings
  106. Anybody using the Ralliart springs on there EVO?
  107. wat is the best spring?
  108. 245/45/18
  109. Gold TE37's!
  110. jUst curious about what sounds like a rubbing noise
  111. plan to get 19 volk g-game
  112. looking for tires around my area
  113. BBS LM Rims
  114. wheel size options
  115. Evo rims
  116. Evo Rims
  117. tire question
  118. Tire's lifetime?
  119. Wheel Size and bolt pattern help
  120. Any steel wheels?
  121. Rim Help
  122. cusco strut bar, sway bar, and perrin end link
  123. Tires after Willow Springs
  124. Tire pressure off the lot (46?!?)
  125. Pirelli PZero Nero M&S
  126. Tein SS installed!
  127. Nice, Lightweight Black Rims?
  128. Any feedback on R1 Concepts drilled / slotted rotors?
  129. Will this work?
  130. wheel locks
  131. Anyone try Yokohama AVS Sports on their Evo yet?
  132. 16" wheels for EVO 8?
  133. which springs have the lowest drop?
  134. Gram Lights 57C
  135. Continental ContiExtremeContact
  136. Wheels
  137. Rim & Tire Gurus please help...
  138. Neal - What happened to the ASA KA3 wheel on Tirerack?
  139. What do you guys think bout these?
  140. Will wheels with 38mm offset fit the evo?
  141. Corner Weighting
  142. quick question please help
  143. What is a good price for Evo VII tires and wheels?
  144. HELP!! 1700 miles and brakes are making noise!!
  145. Some Questions Concerning Progress Springs
  146. Suggestions?? Steering Wheel Clunk
  147. Adaptor issues?
  148. Nitto NT 555 or Kuhmo MX
  149. White Evo with 18
  150. problems with tien springs install
  151. 17x9 ADVAN RG's on EVO
  152. brake rotors
  153. rims
  154. Winter tires
  155. Brake Noise?
  156. Anyone get the 2 pc rotors from Pruven yet...?
  157. Lowering My OZ Rally, need opinions...
  158. SSR Website
  159. Anyone rolled their fenders?
  160. Work Emotion CR Kai
  161. Flat with sidewall damage
  162. Space saver wheel
  163. Track and Street rims?
  164. High pitched squeak on bumps!!
  165. TE-37's from a Type R
  166. 17x9s that will fit
  167. Pics of Gold Volks??
  168. what accounts for the wider track of the evo5 and 6
  169. winter tires
  170. Ralliart RA-01
  171. Quick wheel question
  172. PIAA wheels FR-S
  173. SSR Professor SP-1's
  174. Lowering Evo, with just springs?
  175. What springs do you recommend?
  176. Contact or Infrared Pyrometer?
  177. Tein Flex Question
  178. New 7 Spoke from Final Speed
  179. Tuning damping force
  180. Enkei NT03's
  181. wheel weight numbers
  182. Want the lightest one out
  183. Which R Compound tire should I get??
  184. NEW SpeedStar Wheel
  185. Vacuum brake Booster
  186. Enkei RS6
  187. when should i replace my tires
  188. Finally, no more nose bleeds...
  189. will 18x7.5 +45 offset, adr sokudo wheels fit on evo 8?
  190. Putting 5Zigen 18x7.5 FN-01R rims on black Evo 8. Good idea? need advise.
  191. Rota Wheels
  192. The myth of the warped rotors...
  193. One of Moderators please read
  194. New and Improved Lower brace...
  195. feedback on Yok ES-100 in the rain
  196. Brembo Caliper?
  197. More negative camber?
  198. Another "Will this wheel fit my car" post
  199. Black Wheels???? Where???
  200. Lowered w/ Tein STechs
  201. I know this has been asked before but....
  202. How long have your breaks lasted?
  203. Tire Rotation
  204. for sale: $395.00 for all four 235/40 ZR18
  205. Where to get TOYO RA1's
  206. OEM alternative when replacing stock rotors
  207. what is the bolt pattern for US lancer...???
  208. custom 1 piece tie brace
  209. Yokohama lifespan
  210. TEIN Super Street Damper kit
  211. What are some good brake pads?
  212. Energy Suspension Bushings!!!
  213. Which wheel to choose for my TBE8?
  214. Diff. Spring Company Polls
  215. Dunlop Winter Sport M3
  216. Will lancer rear strut work?
  217. evo 7 stock rims
  218. looking to snag a set of...
  219. This is what im getting
  220. quiet tires
  221. 275/40 R17 tires on EVO ?
  222. SSR Professors SP-1
  223. Will wheel spacers f*ck up my car?
  224. Cusco coilover diffs?
  225. Brakes pop
  226. evo 7 rims
  227. Neil, does the Tire rack sell any suspension stuff for the EVO?
  228. Slight vibration under heavy braking
  229. 19" Volk SF-Winning, Fikse Mach V or the Profil 13
  230. OZ Superleggera in 17" for Evo??
  231. Optional Mesh Factory Wheels
  232. Lowering Springs Question
  233. Continental Extreme Contact:
  234. Tenabe Springs
  235. Suspension Problem
  236. Brake Air Guides
  237. Cusco Under Brace Question
  238. EVO 8 scaled
  239. Eibach Pro Kit with Pics
  240. Anyone running the 2' negative camber in the front?
  241. evo rims
  242. Are there any tuners that have rallly stuff.
  243. Stock height looks a little too tall
  244. Anyone get the factory accesory wheels?
  245. Sprint Springs????
  246. Lowering Springs question
  247. Stock Advans vs other tires
  248. Used stock Advans selling price?
  249. Will these wheel specs work on EVO???
  250. Tyre and suspension noise
