PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67 68 69 70 71 72 73 74
  1. Strange "squeek" after shock/spring install (Evo)
  2. Professor 18x9 and 245/40/18 question
  3. best all season tire
  4. 17" twelve spoke wheels
  5. Best place to mount & balance in chicago
  6. Hotchkis springs installed
  7. Just got my new KDW2's on.
  8. Tires
  9. looking for new wheels and tires
  10. Tire repair place knicked my Gramlight 57S while repairing a nail in tire
  11. 18x9.5 Wheels
  12. Saw a good deal on some Dunlop Super Sport Race Tires!
  13. Tein S Techs making rubbing noises
  14. Check out my new wheels............
  15. looking for wheels and tires
  16. Work Meister S2R owners (18") ...what did you pay for them?
  17. Enkei logo washed off !!!
  18. 19x8.5 with +22 offset gonna work on lowered evo???
  19. Kumho Asx Review (long Term)
  20. Spring Rate For Evo Mr ????
  21. WTB: Lowering Springs
  22. Rota Tarmacs
  23. Which Tires are on your car?
  24. MR Springs??
  25. ALL Kumho ASX owners. About to buy ASX
  26. michelin tweel
  27. Alignment feels better after springs?
  28. Question about Falken Azenis
  29. 5Zigen 17X8 FN01R-C fitment?
  30. Hre 843r
  31. Kumho Ecsta ASX review!
  32. Advan Neova AD07 or Michelin Pilot Sports-II or Bridgestone G-Grid-III?
  33. quick question (rear swaybar)
  34. Stock Wheel Problem
  35. Different Tires? help
  36. Tires, Nails, bolts, etc im tired
  37. Wheel Storage / Transport Cases
  38. who's running 245/45/17?
  39. Installing Hotchkis...which grease to use?
  40. Q: sway bar differences?
  41. GT Spec Titanium Evo Strut bar
  42. looking for Evo6 shocks... same as Evo8?
  43. Do your tires Flatspot when parked for a long time?
  44. Best way to remove tape residue from tyres?
  45. A little help please
  46. suspension and 1/4 mile
  47. spring/shcok/strut??
  48. Original Tyres Question
  49. Springs/Shocks/Strut
  50. Here is how to fix your high speed brake vibrations...
  51. Someone With Factory E8 Suspension Laying Around
  52. new tires for a newbe
  53. need help.. tire choice.. Nitto NT555 vs. Toyo Proxes 4...
  54. Federal ss595 tires
  55. Effects of large front sway bar????
  56. Tein Super street Dampers?
  57. wheel Fitment
  58. Emergency Brake Light Comes On When Breaking
  59. More Hotchikis springs installed with pics
  60. Someone with toyo R-888?
  61. How often do you get an alignment done?
  62. 245/45/17 Ques
  63. Quick tire size help
  64. Tien Flex Impressions-owners only please
  65. For those with 18
  66. 19x8.5 with 235/35/19 tires gonna work with hotchkis springs???
  67. Rear Strut Bar
  68. where can I get the Privat Fahrens?
  69. zero2r help
  70. Need tire help
  71. Brake Pad Test Case:
  72. White Advans?
  73. gb on winter tires?
  74. wat do you have?
  75. FS MR Wheels and Advan Tires
  76. Brake pads
  77. wide body and wheels
  78. FS Evo Wheels and Tires
  79. Spray-on wheel cleaner BADDDD!!!
  80. Anyone know what rims these are?
  81. how wide can you go with 18inch rims w/o rubbing??
  82. i need suspension
  83. Light, high quality wheels
  84. evo stocks for sale
  85. Tire Help!! Need Asap
  86. Thoughts on this new wheel
  87. Tein S dropped Evo - A lil' problem
  88. Toated Brakes - What are peoples thoughts
  89. Floor-mounted pedals?
  90. Racing Hart C4, will they fit?
  91. STI Brakes vs Evo Brakes
  92. Factory Offset
  93. Widest tire on Tein S tech drop with 17x8.5 wheels?
  94. Lowering springs for MR ???
  95. yokohama avs db
  96. Brake Pad Shims
  97. All you black wheel lovers out there...
  98. How to deactivate ABS
  99. Source for wheel spacers?
  100. sprint lowering springs
  101. Tein Flex, blown shock?
  102. Looking for the best replacement brake pad!
  103. Painting INterior
  104. Will be out till Monday!
  105. Konig Unknown wheel what do you think?
  106. Accident! Need Help!
  107. what do you think this could be? and what should i lube?
  108. ahhhhh what wheels?
  109. Check out these Axis Hiro wheels
  110. Electorstatic coating wheels
  111. Enkei RP03 with BFG KDW2
  112. SSR professors SP'1
  113. Neal and everyone else!!! Question about tires
  114. What happened to the Pirelli P Zero Neros?
  115. Loose back end around corners...
  116. Can't machine Rotor's????
  117. Need good 18 Inch Tires, any Suggestions?
  118. New tires, BFG KDW-2?
  119. Koni Bumpstops
  120. D2 Coilovers?
  121. OEM Brake Pads and EBD Question
  122. Hotchkis Springs and Sway Bar on a Road Course
  123. advan AD 07?
  124. Variable Ecentric Camber Bolts!
  125. Need some tires...
  126. Chassis Under Brace
  127. question regarding rota torque
  128. Need Help with brake rotors...PLEASE!!!!!!
  129. answer this please
  130. Any opinions on HKS RS coilovers??
  131. Plzz help. pushing a piston back???
  132. which volk wheels look good on yellow evo?
  133. which springs?
  134. Tanabe Springs or Tein Springs
  135. Any Recomendations for Rear Sway Bar ?
  136. will 245/45/R17 fit on stock rim?
  137. Brakes
  138. any pic's of volk gtp on a evo 8 ?
  139. Would these fit?
  140. Two 19mm bolts on strut
  141. Has anybody tried the SpringTech lowering spring?
  142. Help with tyre size (non-Evo)
  143. keeping stock wheels but not tires.
  144. Yellow Evos with Black wheels, post yer pics!
  145. NEED Coilover Street Impressions
  146. WHICH TIRES 265 40 17s or around there for my evo8
  147. Blizzaks are on
  148. ARRGGGHHHHHHHHH curbed my rim.... help?
  149. More Negative Camber For Free
  150. botched alignment?
  151. How do i get stock centercaps back in ?
  152. Rims Question
  153. 255/35/18 on 18x8.5?
  154. quick question... help.
  155. omnipower coilover review..
  156. Track junkies: what is your ideal ride height?
  157. Gram Lights center caps
  158. enkei RSV
  159. What rims are these?
  160. PBR brake pads?
  161. Best road legal track tyre for EVO VII to replace the A046?
  162. New Pads..Now squeeeek!!
  163. FS Like New MR Wheels and Tires
  164. 245/!35!/17s..noticable gain in acceleration?...any downsides?
  165. front caliper piston size?
  166. What offset do i want with 17X9.5
  167. WORKS Rear Pillow Ball Mounts
  168. Works springs
  169. will 235 55 17 fit evo?
  170. 5Zigen FN01R fitment ?
  171. Where to get allignment in Chicago
  172. stock wheels needed!!!!
  173. Hotchkis spring + 245x40x18 = good combo?
  174. Wheels for Evo StopTech 332 mm Kit
  175. perfect Toe/Camber for STREET?
  176. HELP: Click-Clunk noise after spring install
  177. Just got the Hotchkis Springs installed
  178. Pirelli's, How many miles?
  179. Tein-S Tech Problem?
  180. goodyear f1 vs Yokohama Advan
  181. TDR Pro RAce 1
  182. 245/45/17......rub POLL
  183. found 16x6 rims to clear Brembos
  184. Question for those with 255/40/17 and factory wheels
  185. What do you guys think of GT SPEC products?
  186. Kumo ECSTA ASX vs. Pirelli Pzero Nero MS: Problems with 245/40/17.
  187. Quick question for neal...
  188. Brakes squealing
  189. Coilovers + Cold Weather = Squeeks ?
  190. All Season Tire Question... Kumho???
  191. Camber adjust bolts - EVO 4 / 1G DSM
  192. whats the point?
  193. Tire Rack SUCKS!!!
  194. Brakes squealing
  195. Canards....worth it or not?
  196. Any problems after lowering an evo?
  197. 40psi a risk? or, just a backache?
  198. RS: Storing UNmounted tires and swapping 'em
  199. TEIN S-TECH's or Hotchkis Sports ?
  200. Widest Tire on stock EVO wheel?
  201. MR Bilsteins-Anyone Selling??
  202. Body Roll on 03 Evo
  203. What is the deal on Hawk Ceramic Brake pads
  204. Best tire for summer and close to stock performance
  205. Brakes have over an inch of free play
  206. To Drop or not to drop...
  207. Sway Bar Question !
  208. Tire Pricing ???
  209. Spring install question
  210. where to get motoforge speedgear 10 rims
  211. brake problem
  212. Need New rotors, which ones to get?
  213. Work meister s2r or Volk le37T
  214. Bose Suspension System
  215. Rear wheel drive conversion
  216. any suggestions on some cheap beater rims for my MR?????
  217. Wheel Locks for an Evo 8?
  218. leaking brake fluid
  219. hotchkis VS gf210's
  220. Take your pic
  221. Brakes, brakes and more brakes...
  222. Need advice on disk rotors
  223. Tire questions.
  224. Spring Preload
  225. ASA KA3 weight?
  226. I just want normal rotors
  227. Stoptech Slotted Rotors + Project MU NS anyone?
  228. New Falken Azenis Sport RT-615!
  229. newbie question
  230. 17x9 or 17x8.5 BLACK wheels and tires
  231. Speed Star D5R Wheels
  232. Weight Values
  233. Help with my Tires!!!
  234. Bad Steering Wheel Vibration Please help
  235. 3 tires, can I buy 1 or need to match w/2 ?
  236. Need help with alignment!
  237. Tire question Different profiles
  238. S-tech's or Flex
  239. Front wheel knocking noise
  240. Gold Rota Torques
  241. brake dust won't come off.
  242. installed springs today
  243. Silver, Gold or Gunmetal on Rally Red
  244. Street/Sport brake pads
  245. 17x8 5x114.3 48 on Evo?
  246. Felt really stupid today
  247. brake pads
  248. Need Rotor and Pad advice
  249. Evaluating Aftermarket Springs.
  250. QUICK wheel spacers question?? HELP
