- wheel fitment PICTURES ONLY thread part two
- Volk RE-30
- Wheel Fitment PICTURES ONLY Thread
- Robispec visit to FL
- Bad wheel bearing?
- Rear Sway Bar recommedations?
- Stock BBS Evo IX MR Offset
- Advan RS 18x9 with 245/40/18 Rubbing???
- New ADVAN Wheels on the way!?
- works,swift or robi spec springs
- CE28N Sizes
- 255/40/17 RT615 Got Cancelled
- Hawk pad squeek
- Falken 615s
- quick question about ray's valve stems
- DBA 4000 rotors without slots
- Anyone know where I can get a brake hard line (FR)?
- alignment shop needed in central ohio!
- Lug Nuts fr Volg Gt-U's
- lug nut ?
- Edfc Users, Help!!!
- Hawk Plus Brake rear Pads
- 18x8 Rota Torque Gold on RR IX
- stock enkei's performance vs aftermarket
- Whats the Widest 17's that will fit?
- Tein Springs for 05+ Evo MR w/ ACD on Non-MR
- Painting center caps
- Swift Front sway bar
- Bad brake piston?
- Yokohama Tires Suck!
- HELP! For those with Falken Azenis RT-615
- Ralliart or FN0R-C
- Falken Hanabi...any pics on Evos?
- Buddy Club Racing Spec coilover problem...need some help
- Velox PG Rev10 - Who has them?
- HELP! asap... rotor question
- those running 255/35/18 w/lowered evo
- RT-615 OWNERS, got a question
- Tire Mounting Costs
- Wheel offset/spacer opinion needed.
- Different Tread Tires
- which ones?
- rims?
- Looking for rims vendors help me
- Who has painted their stock BBS's?
- Toyo Ra-1 Where???
- Ams Rims(racing hart c4) Pics
- carbing front lower arm brace
- Performance Friction Z-rated street pads
- brembo stencil
- Tire Wear
- Color matching evo mr wheels.
- BBS Rims
- EBC brakes...
- yay or neh?
- will 245/45/18 fit on 18 x 9.5 +30?
- Uneven pad wear (outside vs. inside) - What to do?...
- stock brake upgrade idea???
- rotora rotors anyone?
- MR Bilsteins
- [SEARCH] Volk Racing GT-U 18*9 +29
- loud clunk noise
- What offset should I go with?
- Performance Springs with Minimal Drop?
- Falken RT-615 or BFG T/A KDW 2
- For $100,U can have Brembo brake looks on your car !!
- FR sway bar links/stabilizer link Info
- Swift Mr Springs questions
- best brake pads under 200.00
- What would it take to improve steering feel?
- rain tires for track
- New tires needed? bad alignment?
- Wheel Suggestions?
- EVO IX MR/SE eibach springs
- Driverside front tire rubbing
- Team Dynamics 17x8 Pro Race 1.2 in ET40 ok???
- fitment?
- dampening and balance
- Help with wheels plz : )
- trunk cage?
- Rim Problem
- Alcon Front Kit. Who sells/stocks it?
- help me with rims to my EVO 9!
- D2 8 POT BRAKE KIT Vs KSPORT
- just got my alignment
- Swift Springs/ stock shocks
- people running coilovers camber bolt question for ya!
- RE-01R Stock Wheel 245/40 vs. 245/45
- teaser pics of zeal coilover
- Front wheel bearing noise/bearing preload?
- New chasis braces from Cusco for CT9A
- New Tire Advice - Toyo T1-R
- I can't narrow down my vibration at all, please help!
- Got Lip? SSR SP1 and MS1's do! :)
- Where to get Advan RS ?
- AMS Brake Duct Kit - Anyone tried it?
- Dunlop Direzza Sport Z1
- At my wit's end with these #$!&*% brakes!!
- 245/40/18 Potenza RE01-R's on 18x9 +29 Advan RS's
- Quick Camber Bolt Question
- Camber plate and aligment question
- Need Brakepad advice!!
- Best Tire Size for me
- Very Bumpy Ride
- will these rims and tires fit?
- ? for those who painted stock wheels
- any one run a 275x35x18?
- Robi-Spec and Alignment Q's
- Tire suggestions for my new wheels!
- axxis ultimate brake pads??
- brembo decal for my painted brake cal
- opinions on rota wheels
- Stock endlinks with hotchkis sway bar
- Monday's Project
- Toyo RA1 Alignment Question
- will these clear the brembo's and fit my 05 EVO
- Toyo RA-1 noise?
- Rays valve stems and TE37s
- Can EVO 9's Brembo brake(rotor+caliper+pad) fit on other Mitsubishi's car ??
- Which brake set do I get?
- will 05 evo 8 suspension interchange with evo 9 suspension?
- need some help with ohlins
- will 18x10's with a 44 offset fit?
- MB Wheels Competition 17x9
- tire vendor???
- powdercoat wheels gloss blk w/ red lip!!!
- FN01RC-- stock lugnuts ok?
- new wheels- sloppy feel
- 18x9.5/+20 Works Cr KAI......TRUTHS NEEDED!!!!!
- 19x9.5 offset +22, will these fit evo9?
- best cheap rain tires
- how good is stock suspension with springs?
- how do you STORE tires?!!@!@!@!
- Swift springs
- New Tires?
- 100 lb enough ???
- racing brake pads with brembo stock brake disks! please help!
- where can I buy ROTA P45R Black w red lip 18x9.5 +30
- tire help............please?
- Just Used my Motive Power Bleeder
- WORK Emotion CR Kai (18x9.5 +20mm offset) or WORK Emotion XD-9 (18x9 +20mm offset)
- What size tires for 18x8.5?
- Whiteline Bushing Kit
- 18x8 245/35 or 40 what would u run??
- SoCal Evo 35k Needs Brakes
- Next Stage Snow Tires with Retractable Studs! Delivered by Q Tires
- how to remove the read brake disk?
- 'nother noob question (sway bar)
- Projec Level 900 or Pagid Orange???
- Q's about RT-615
- where can I buy Brembo locking pins?
- replacing tires
- Will these fit? (275 40 17 on 8.5s with stock struts)
- who has Nitto NTO1 255x40x17 in stock ?
- Stock tires
- Tein Heads
- z06 brakes on evo???????
- Anyone from TireRack? Have Q regarding OZ ultraleggera 18X9 wheel?
- Megan Track coilovers on the street
- KICS wheel spacers
- volk te37?
- Changed Pads, ear piercing noise now
- best springs?
- Work Kai 18X10..... NAUGHTY!
- Installing swifts on MR
- Black Wheels on an EB
- OEM center caps?
- Which swaybar is better.
- Replacing stock lock nuts
- got my DBA 5000 red hats installed
- Advan A046 Tire Pressure for Track
- Whiteline Control Springs
- Camber plates twisted forward
- Skunk 2 Springs?
- Advan RS Gunmetal 18x9
- Brake DIY
- best rear sway bar for evo9 MR?
- what would it be?
- Widest Wheel I Can Fit?
- products used to buff out rims
- MR springs. which ones?
- Rear Upper Control Arm Ball Joint
- Will I need to roll my fender??
- upgraded brakes question (couldnt find anything with search)
- Cyro PowerSLots rotors
- who has good deals on wheels for EVOs
- Black or gunmetal alloys on a black Evo?
- Weird click noise on brakes...
- Block heat or block noise, 2 different pad shims from Girodisc
- Rays G-games fitment
- allowing springs to "settle"
- Volk GT-F
- CE28n Volks
- Swift or Hotchkis springs?
- if you know your ****, help me out
- Spacer / Rims Evolutin 18's
- modified brake ducts
- Will 9x17 ET35 fit EVO IX?
- Installed my Swift springs...
- want to run 18"'s
- Carbonetics brake pads
- When to change tires after a long drive?
- New Girodisc drilled/slotted rotors
- Best Rotors???
- Tire size question
- Free Tein Flex's or buy Swift's / Bilsteins?
- My replacement brembos now peeling!!!
- New Konig Wheel!! Need advice on fitment
- 235/55 on stock rim?
- Neal away 7th-12th
- Tanabe Rear Sway Bar
- What Type of Gold are the Advan RG IIs?
- Painted wheels... whatcha think?
- will SSR's fit on the evo?
- Hawks HP+ vs Hawks HPS
- Advan Vs Volk My choice
- Stasis Alcon Brake Kit Question
- Tein Flex Help
- Sa70tt
- DMS 50 VS KW Variant 3
- Toyo RA-1
- kumho mx...loud?
- How to tighten top shiock nut on Buddy Club
- Brake response with Snow Tires.
- exceeding stock evo susp.
- value of stock wheels?
- Whats the BEST TIRE for the Money?????
- what lugs do u recommend?
- springs for EVOIX MR?
- 2 Piece Rotors
- Problems with my new 2-pc Rotors and new pads :-/
- Many thanks to Neal and Tire Rack!!!
- Wheel help! FNo1-RC or Emotion CR kai??
- need help looking for the best pricing on some michelin tires
- Stock BBS = Aftermarket Lugs?!
- Volk GTN - 17x8" 5x114.3 +41 Will they fit
- 18x8.5 +22 Volk TE37s, will they fit?
- F/R Spring rate combo
- replacing camber plates
- stock wheel locks or volk lug nuts
- weird noise
- EVO 9 BBS SE wheel fitment on EVO 8
- Stock Alignment Off - Suggestions
- Pot hole damage questions......
- if know, please answer
- does going bigger means lots of recalibration?
- Volk Racing Wheels Time Attack
- RobiSpec to Omaha!
- owered evo w/ NT03 17x9.5+ 38 offset
- Steering wheel slack @ 93k miles
