- 80% track 20% street ride hight
- Trying to choose between these tires... anybody have input?
- can the brembo calipers be rebuilt?
- ABS ring tooth question. should any be missing??
- OEM lugnuts?
- What type of suspension goes on rally cars?
- NITTO 555R Extreme Drag tire weight answered
- need info on wheel fitment will they fit????????
- Powder coating calipers
- What have you done to stop Brake Squeal? No opinions, please!! FACTs ONLY!!
- ABS connector placement
- Camber HELP! - ANYONE!!!
- will evo X rotors fit on a evo IX
- Question from a noob...
- Evo steering wheel shakes pretty bad when i hit brake
- Strut top play....
- porterfield r4-s Squeal?
- what rims are these
- Q: How much does toe change with camber change?
- Whiteline Roll Center Kit KCA395 ??
- ROTA P45R with the tire 245/40 R 18
- 5mm Kics spacers
- Swaybar preload question
- tires
- I've searched but no luck
- Rota Grid 18x9.5 +20 or Rota DPTs 18x9.5 +22?
- Shaky steering wheel, different tire sizes
- Should I change my tires now?
- Anybody Have a Pic of a 235 & 245 Tire on a 9.5" Wide Wheel?
- brake problems
- Need 21mm (0.84") OD lug nuts !!!
- Wheel Lug Brand??
- stiff brake pedals after springs installed
- Whre I can find lug nuts wit OD 0.85" ????
- 2 questions: front CV Axles, and weird noise from rear susp.
- Stuck Coilover
- Evo X wheel lock nuts - Is it safe to use this type?
- now these are HOTT!!!
- Wheel Stud Installer ...
- 20' Wheels?????
- Spring questions on MR
- Megan Coilovers bad in less than 12 months
- What lug nuts for Konig Zero ???????
- Firestone Firehawk Wide Oval
- Neal out till May 1st
- People running 17x9's --- need some help
- BF Goodrich T/A KDW for **DD**?
- Toyo proxies air pressure?
- front caster adj?
- Front RHS braking shudder?
- Advan A032R vs. Nitto NT-05
- Any lightweight wheel recommendations?
- Need Help with TE37 +22
- goodyear eagle GT tires what u guys think?
- Blown D2
- Is installing only front springs okay?
- New brake pads... ??? before I install them
- Needs confirmation on 17x8+ 42 offset.
- 17x10 +25 5zigen FN01R-C
- car reacts badly to rain on road
- Shot Wheel Bearing
- Knuckle Nuts
- alignment help
- Evos with 255/40/17s on stock wheels --- post up pics!
- Question on the swift sport springs
- wheel/ tire combo question
- 3mm wheel spacer/ RPF1s
- Suspension help?
- Coilovers or new set of good springs?
- Rota grid 18x9.5 +20mm offset fitment
- Bottom strut bolts won't come out
- will this lugnut fit? (muteki sr35 + extrended studs + 6mm spacers)
- What slicks should I get
- Need new Tie rod end
- New rims with old tires
- megan coilovers
- HKS lowering springs??
- swift sport or spec-r?
- best lowering springs
- evo and tires
- Quick question guys....
- Anyone know if there are preload spacers available for stock struts/springs?
- HELP!!! 17x9.5 +15
- steering wheel vibrates when braking/slowing down
- Why is my Evo sitting slanted?
- Tein basics or Megan...
- Brokwn wheel lock key.. suggestions?
- what causes brakes to squeal?
- Advice for track tires please?
- Lugnut thread pitch size
- What does that black box do in the rear bumper
- to all you track guys
- K-Sport Coilovers
- What offset for 265/35/18 help please..
- The New Konig Zero In, suggestions and comments
- Steering wheel vibrating help
- 18x10 +9 Wheel with HRS Wide Fenders??
- Staggered Te37 Tire Question
- So I rolled my fenders this weekend...
- 6.5mm Spacer and Stock Studs ...
- Correct tire pressure.
- KW Variant 3 Coilovers.. need some help!
- Black Enkei RPF1 18x9.5 +38 available?
- So my new tires are 245/45/18....
- !!! Problem with wheel spacers !!!
- Evo IX MR USDM Stock Brakes specs
- hotchkis lowering springs
- Feedback on Buddy Club Racing Spec Coilovers
- suspension suggestions
- Ready to pull the trigger on wheels finally.
- Thinking about getting some wheels...
- squeaking while moving
- Tire pressure gauges - what to buy?
- Suspension Discussion Thread Links
- drag xxr 006 HELP
- Why are rt-615s so cheap?
- how do I instally center caps on oem rims?
- will 235/40 fit on stock rim?
- EVO IX - Coilovers - need help
- Advice/experience with installing Whiteline Roll Center correction kit (KCA395)?
- How long can you drive on your spare tire?
- Swaybars: Robispec or Whiteline?
- 245/45/17??
- help
- 20mm spacer on stock mr bbs's
- lost my wheel key
- 18x10 +20 wheel fitment?
- Suspension Discussion: Camber vs. Caster
- need brakes & tires
- waiting for bilsteins
- Ve3-b843-h2
- Powdercoat Rims
- rays/gram light center caps
- Wheel liner and 17x9.5 NT03 +38 ??
- 255/40/18?
- AST Double Adj. 5200RR Finally Here!
- Rota P45's
- Coilover problem
- Coilovers installed, the car rides amazing now.
- wide body fender liner
- Tail happy rear end, has me not so happy. Need advise
- Question about wheels and stock suspension
- Popping noise caused by lowering springs..
- WEDS SA70 RR - 18x10 +18 or +32
- Will 18/9.5/+25 and 255/35/18 fit stock, not lowered EVO 8????
- Looking 4 aggressive tires on stockies
- Soft Brake Pedal
- brakes for my 2003 evo 8???
- swift spec-r springs installed
- Cusco Camber plate help
- Falken ZE912 questions...
- Beatrush undertray + Carbing lower arm bar fitment???
- Problem???
- brake sqeal - driving me nuts
- Evo X Brakes on Evo 8?????
- rear suspension won't drop on 9 MR
- How do I reduce bounce and body roll?
- will a set of evo 8 springs work on evo 9 struts?
- Pulling rear fenders?
- Rear left ebaring on a JDM Evo 7
- Bridgestone Potenza RE-11
- How much fender rolling is required for 18x9.5 40mm with 25mm spacers
- sway bar question
- NEED HELP - Sway Bar related -
- Evo viii/ix brakes/steering wheel on a 1g?
- Braking problem
- Will these wheels fit ...
- 5Zigen FN01R-C 17z9 +15???
- Stick on wheel weights, will they last?
- Coilovers that match this criteria?
- What wheels are these? New EVO IX MR SE owner looking for rims
- Issue.. just replace rotors/lines/pads
- Pros and Cons about Hotchkis Lowering Springs
- wheel bearings
- ABS light - speed sensor codes all 4 wheels
- Help Rear Fender Roll
- Evo suspension parts
- STANCE Coilover Height Adjustment Problems
- tire opinions
- (Max) tire size Advan RGII 18*9 +29 on Evo IX
- 19" wheels on Evos
- Ohlins Flag Coilovers settings HELP!!!
- Front sway bar makes a big difference!
- RT615, Star Specs, or NT05.
- Remove Lower Front Control Arm on and EVo 8?
- evo 8
- Best Tire Size for AutoX?
- Question (Rubbing RE01R)
- fitment help with 18x9 + 20 offset
- question about lugnuts for new rims
- light wheels
- Has anyone successfully retrofitted Evo X brakes to an Evo 8 or 9?
- Help with front wheel well liner rubbing
- noise when braking and driving slow
- ROTA Subzero wheels 17 x 7.5 5x100 anyone??
- K-Mac or Vorshlag camber plates?
- Someone help with master cylinder brace installation!
- can wheel center caps come off by themselves or did I get jacked.
- Screeching, clicking noise when turning slight left?
- QQ about the alignment marks
- Megan Racing BBK
- best tire for my setup
- Which rear chasis bar setup?
- Girodisc Bailout Blank Rotors vs. RotorPros Blank Rotors
- Toyo R888 Vs Advan A048
- HELP! Need to know about a certain fitment!
- Best Looking wheels.....
- New Stance - GTWorx Street/Track Springs
- DD Tire recommendation?
- Would you pull the trigger on these wheels?
- Which tire would you reccomend?
- 255/45/17 Stock 8 Rims
- Another Alignment Question!
- any bby with the 5zigen fn01r-c on them?
- Will these wheels fit?
- Tire Valve Hole Size OEM BBS ???
- Rotor thickness question.. how far down?
- Wheels and rotating
- anything i should know before i tackle this?
- Centering my steering wheel
- tire size question
- Weds Sport SA-97F
- offset help.
- Nitto NT-01 tires noise.
- Diagnose My Brakes
- What rims to get
- Brakes squeaking badly!
- What size tires can be run on Evo 8 wheels?
- Front clearence Help!
- wheel spacer and studs install?
- PF-Z What?! (Performance Friction Z rated pads)
- Swifts or RobiSpecs? Help Me Decide!!
- Best tire size for auto-x on stock suspension
- Anyone interested in a custom set 18x9.5 Grids in white that fit w/o fender rolling??
- kmac camber/caster plates
- Volks CE28n T/A or Advan RS D/G
- Volk le28n gold chrome lip 18x8.5 +43
- Enkei RPF1 n00b question
- Ohlin flag series coilovers
- 255/40 (OEM non BBS wheels) what psi?
- Got the strut apart, quick question!!!
- cusco front control arm brace question
- How is this brake set?
- ANYONE here rock a Rota Sub Zero Rim?
- Brake Rotor Size's???
- Powdercoating brakes
- Thumping noise
- Solution to aftermarket wheels and spare tire
- Re01-R Break In and PSI Ques
- Jic tar and a2
