PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74
  1. 265/35/18 on oem X wheels...any issues?
  2. Tires for Texas?
  3. 265's on 8.5" rims?
  4. Nitto NT01 and NT555R tire wear question
  5. Front Hub Replacement
  6. What is Threshold & Trail Braking?
  7. Caliper Piston Removal Question
  8. Generic rotors.
  9. spacers rubbing against rims
  10. xxr 527 help
  11. Spacers dont fit!!
  12. Dynamic Camber, Toe Curves
  13. brake pads for the cold
  14. advan dark gunmetal
  15. Brake reservoir cap question....
  16. Are coilovers worth it?
  17. What is the best Strut Bar Tianium, Carbon , or Steel
  18. Need suggestions!!
  19. ABS light came on after driving up race ramp, won't go off....HELP!
  20. OEM Tire Size Rubbing on front
  21. Red or Black
  22. Help please: Custom Drag Wheel measurements needed
  23. Brake pedal travel ?
  24. Feal suspension??
  25. Megan streets or Tein super streets?
  26. Pushing all the way down during brake bleeding bad?
  27. Exhaust hanger bolt sIze?
  28. Sway Bars - Question for those that road race
  29. Anybody use Tire Softener compounds for racing/long term storing?
  30. Does the ULTRA RACING cage fit???
  31. Dragging brakes after brake flush...
  32. 1 man Brake Bleeding without speed or power bleeding
  33. will this setup work out?
  34. New RAYS Gramlights 57GTC
  35. Any need for extra bracing on Evo9.
  36. OEM strut bar from evo 8? or ralliart piece?
  37. Please teach me how to improve my Evo 5 handling...
  38. Rota Grids Cosmic Blue
  39. Strongest Wheel Material
  40. Need Help With Tire SIZE on evo 8
  41. R comp questions
  42. Wheel help?
  43. Vehicle height adjustment question
  44. Neal out till Nov 28th
  45. Need help finding some wheels
  46. Raising the car for the winter
  47. Anyone tried the AMS rear bumpsteer kit?
  48. 245/40/18 Nitto Neogens?
  49. is 17x9.5 +12 a good offset??
  50. Beatrush underpanel
  51. AutoX Brake Pads /w Hoosier A6 Tires
  52. OEM Wheels: Which Are Strongest?
  53. uneven wear
  54. Fortune 500 coilover problems
  55. Michelin PS2 stock size
  56. OEM Sway Bars - What size are they?
  57. Ohlins PCV problem ((
  58. 2006 rs abs?
  59. R-Comps for next year auto-x questions
  60. coilover reviews
  61. Need Help with rear control arm bolt #
  62. Yokohama IceGuard IG20 winter tire review
  63. Toyo R888
  64. Want photos of O.Z. Alleggerita in evo ix
  65. brake noise
  66. think put new wheels
  67. What are the best winter tires
  68. Help decide wheel/tire sizing (RPF1 with Z1*)!
  69. for those running XXR's.. becareful..
  70. Needing parts for coilovers!!
  71. Are driveshaft spacers necessary?
  72. bilstein B12 kit
  73. Exhaust rubbing on front braces?
  74. enkei wheels offset?
  75. There is a sensor on my clutch thats un plugged? (pic)
  76. Front Swaybar upgrade for Evo IX?
  77. evo x wheels on evo 8?
  78. Thinking about a suspension
  79. VARRSTOEN ES332 19x9.5 + 12 WILL IT FIT MY EVO 8?
  80. Dunlop Direzza's caused oversteer??
  81. Whiteline Bushings vs Energy Suspension or Works
  82. BBS SE Wheels
  83. 18x9.5 rpf1 question about spacers
  84. Will these fir on OEM VIII rims?
  85. Front sway bar moving up and down with control arms?
  86. Xxr 531
  87. Lug Nut Adapters to go from Shank Style to Acorn Style
  88. What wheel is this?
  89. Oem pads smaller than ds 2500= squeal?
  90. Alternative to bedding brakes, on freeway?
  91. Steering wheel shakes after Swift Spec R install
  92. Hankook z214 275/35/18 ideal rim size?
  93. Has anyone used the Ball Joints or tie rods from autozone NAPA or others.
  94. KW Variant 3 vs Fortune Auto vs Blistein/Swift
  95. Anyone know where i can find these in america?
  96. snow tires
  97. Crazy brake issues while on track
  98. running 2 different offsets?
  99. Metal Valve Stems
  100. 18X9.5jj +22 245/40 rubbing issue.
  101. swifts in the winter??
  102. Rotor hotspot? why?
  103. what rims are these??
  104. Post Your Wheel Setups on Apexi Silver Cars
  105. Social Survey - OZ Racing, as you?
  106. Best place to find deals on wheels and tires
  107. Help with wheel offset decision please!!!
  108. 2" brake ducting, keeping stock undertray and sides
  109. Question: Should Spring/Shock Install Be Done Same Time As BumpSteer/Bar/Bushings?
  110. Spacer size?
  111. wider wheels
  112. Brake Bleed - Stumped!
  113. Enkei Replacement lug nuts
  114. Whats the best coil over kit for evo 8
  115. EBC redstuff smokes with my stoptech slotted.
  116. Ce28n Dual Drilling?
  117. need help solving brake problem
  118. A comfortable Evo?
  119. What suspension i need for drag racing
  120. BBS Diamond Black Wheels
  121. What should I go with?
  122. Brake Question
  123. Stop Tech Rotor is Smoking!
  124. WTB: Rota grid 18x9.5 +20mm
  125. Where to buy NT03+m 17x9.5
  126. Goin for an alignment today
  127. brembo banjo bolt and crush washers
  128. SS Brake lines. Is there a specific brand people recommend?
  129. fortune auto 500 coilvers
  130. Control Arms
  131. BR is conducting a suspension test and looking for input
  132. Where to send Brembo calipers for rebuild
  133. About how many ft to run brake cooling ducts?
  134. Replacement rotors for DBA 5000 series
  135. Good Camber plate sale at PSI (Noltec)
  136. Stock evo 9 rim and MT MC slicks or MH and 16inch rota
  137. 18" vs 17"?
  138. How can I Protect the Threads on my Extended Wheel Studs?
  139. Will these rims fit? 112 fit 114?
  140. JDM OEM Evo VII wheels
  141. WORK Emotion CR Ultimate (Kiwami) - New For 2011 ** Super Concave Face
  142. Suspension on a budget
  143. Lug nut question for extended studs
  144. best place to buy FERODO DS2500 pads
  145. installation tips or strategy for front LCA with energy suspension
  146. BC coilovers?
  147. RE-11 vs Dunlop Z1
  148. Need Part# for OEM Front Camber bolts
  149. Cusco pillowball camberplates on ARC coilovers?
  150. Caliper Flex?
  151. New changes to brakes, suspension and tires on the Bad Bish.
  152. Whats the best bang for buck suspension mod (From these lists)
  153. Winter tire season 2011
  154. Evo X 235 40 18
  155. road racing/time attack coilover options
  156. Noise when turning
  157. Fortune Auto 500 Series owners chime in! Collars not locking
  158. XXR 527's
  159. Stock height track alignment
  160. one tire sticks out farther...help?
  161. do i need a white line center roll kit?
  162. Installing Porterfield pads. Questions about aftermarket pads.
  163. factory shield on brakes, remove or keep? (for a DD track car)
  164. stock wheels need snowtires....
  165. Pads - axxis vs. Stoptech vs. Girodisc magic
  166. Has anyone used godspeed sway bars?
  167. killed a set of rear rotors abs questions
  168. Gruppe-S Wheel Database *Need Your Help!!!*
  169. MDU coilovers
  170. Greedy coilovers
  171. Star Specs vs. Kumho XS vs. RS-3
  172. Part # Needed for rear shock bolt (goes through the LCA) and the nut
  173. Swift Spec-R springs - good price?
  174. Fitment Q: RPF1 17x8.5 +30, Z1* 255/40-17
  175. New rotors & pads for ix mr
  176. touchup paint
  177. Is there an easy way to remove the ABS sensor wire fron the top of the wheel well?
  178. Electric Impact Gun Recommendation for lower rear shock bolt...
  179. enkei rpf1 fitment
  180. HELP- One side tires sticking out farther causing one to rub
  181. Torque Solutions Bushings...
  182. Help! CCW LM20's Crackling/Rattling Noise
  183. Clocking bushings during suspension install...why is it not mentioned here?
  184. 18 volk 57s on evo
  185. Buy new tires now, or wait until after winter?
  186. Tanabe pro 7
  187. Bad Allignment Specs
  188. Swift Spec-R's now a different color?
  189. Name 3 coilovers for Road Racing
  190. billstein struts
  191. spacers, studs, and lugs help
  192. tire rub!!!!!!
  193. Finally... a 3" brake duct solution for the Evo
  194. Bc racing br coilover help!!!
  195. Evo 9 MR Lowering Springs on a Evo 9 SE
  196. Best High Speed Road Course Stock Brakes
  197. MR Bilstein top mounts on tein
  198. 275/40-17's
  199. Volk GT center caps on 18"s?
  200. 2003 stock Enkei for 2005 MR BBS
  201. BILS JDM coilovers, anyone heard of them?
  202. Wearever Ceramic Pads
  203. which camber kit? help please
  204. Neal out till Sept 19th
  205. Best match for tires
  206. Cutting Fender Liner
  207. Torque Solutions Driveshaft bushings?
  208. Weird Noise PLEASE HELP!!
  209. Best way to spend some $$ on handling...
  210. Noise in right frt over bumps please help
  211. 20mm Spacers & Handling
  212. How much powder coating needed for 4 wheels?
  213. Evo RS owners seeking ABS
  214. 03 Evo 8 and 06 Evo 9 MR, are front axels the sames ?
  215. Is this spring perch upside down????
  216. 18x9.5 with 275 tires
  217. Best Titanium Strut Bar
  218. Zimmerman Rotors?
  219. Just installed bilstien HD's now rear sits much higher?
  220. Higher Rate Springs than Swift Spec R?
  221. Suspension: DD and winter snow
  222. Rota slipstream track fitment help
  223. What are the best drilled rotors i can use without spending 350 a set?
  224. Lowering springs?
  225. Autocrossers Check-In: RS-3's Longevity
  226. Advice on a good daily driver tire ( with performance in mind)
  227. Brembo piston trashed.... Options?
  228. will these wheels fit?
  229. Fitment Q's - Rota Grid 18x9.5 +20 on Evo 8
  230. brake booster
  231. Where and what brake rotors to buy??
  232. Why is my friend's 2011 WRX easier to handle than my IX?
  233. Neal out till Sept 6th
  234. Request to see evo's with 18x10.5 wheels
  235. Brake cooling inlet ducts.
  236. Does anybody know what wheels these are ?
  237. How wide of an R comp can you go on stock wheels?
  238. Mullerized Ohlins or Robispec KW Race?
  239. Which lowering springs? Swift sport or spec r
  240. Anyone ever blown the rear MR Bilsteins out?
  241. Sharing of dimensions and clearances for wide wheels on OEM body
  242. 18x10+18 fitment
  243. Tire size/camber questions.. need help!
  244. How do I stop tripodding/3 wheeling at autox?
  245. Brand new tire blew out
  246. Snow tires?
  247. Advan wheels, offset
  248. 17x10 +35 FN01R-C fitment
  249. Rpf1 questions
  250. Jammed HB shoes on Rear Rotor
