PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74
  1. 06 MR or GSR strut differences
  2. BBS LM 18x9 +35, 255/40/18 will it fit?
  3. Best Evo X tire for less than $175
  4. help with some wheel spacing
  5. Running staggered wheels on your car. Bad?
  6. Wheel sizing pics
  7. Changing rotors
  8. 265/35/18 on 9" ET20
  9. Megan Rear LCA?
  10. Inner tie rod thread pitch.
  11. Winter Tire and Wheel Reminder
  12. Front suspension top mounts installation question
  13. 18x9 BBS LM reps, best offset?
  14. Will 18x9 +30 battles clear calipers?
  15. Pic request - driver's side ABS harness connection point
  16. Kosei k1 not TS
  17. clunking front passenger strut
  18. Best spring/shock combo
  19. Boring Stuff
  20. more winter ride height, subaru outback struts and springs in an 04 evo...
  21. Will EVO Master Cylinder fit an Eclipse?
  22. Outlander Master Cyl very similar to RS...
  23. Will these fit properly?
  24. trying to find this thread eith rim specs
  25. Using wheel spacers to help counter understeer
  26. When replacing caliper do i need to replace the pad
  27. Need help eliminating understeer
  28. Quick question....
  29. Budget suspension that is not junk
  30. Rally/ Hill climb/ Rally-X suspension setups?
  31. Stock BBS Evo 9 se
  32. Best coilovers?
  33. Race Brakes question.
  34. Ditching my coilover bug(shock/spring guys chime in)
  35. Scraping do luck style lip bad with tein
  36. Need powdercoating and new seals for Brembos
  37. Megan Coils Seized
  38. Quiet brake pads for street Evo IX
  39. Cars making a loud noise when trying to take off
  40. Driving problem, dont know what tho?
  41. Need new tires...Hankook v12's?
  42. Evo X brakes on Evo IX
  43. Evo IX squeaking noise coming from driver-side front wheel
  44. Performance Friction Brake pads Evo IX
  45. good year asymmetric 2 tires question?
  46. should I go with swift spec r's???
  47. 03 evo 8 Rear passenger caliper issues
  48. What suspension/coil overs to go with??
  49. Brake Pad Long Term Product Testimonial
  50. ABS Removal Assistance
  51. Here is my question
  52. Evo V control arms
  53. Identify this enkei wheel
  54. esm wheels fitment on evo 9 question
  55. Whiteline sway bar bushings-- squeaky?
  56. evo 4 brakes can be fit to FTO?
  57. Help!!! Jic flt a1
  58. Need Opinions : Suspension setup for lapping cheaper or go coilover
  59. Brake bias
  60. Spacing for DP clearance with suspension braces
  61. don evo 9 tire size issue
  62. Does anybody change to winter tires in the winter
  63. replacing parking brake cable - questions
  64. Magic pads screaming with light braking
  65. Stock KYBs to bilstein pss9's
  66. Electric brake coolers
  67. Alcon big brake kit winter?
  68. Help adjusting coilovers.
  69. Evo V OEM struts
  70. Steering quickener
  71. Brake motive rotors & pads
  72. help looking for struts!!
  73. what color brembos
  74. Best coilover set up
  75. Does anyone make rally springs for the OEM Bilsteins?
  76. 40+ mph humming
  77. What to buy? Track tires/slicks lapping days help please
  78. Finally someone tried the Konig Torch 17x9.5 ET35
  79. Popping noise from DS wheel well???
  80. Evo VIII and IX OEM Coil springs
  81. Pic request - Work Meister S1 3P 18X9.5 + 12 (R disc)
  82. rim questions
  83. OEM Brake Rotors - Evo IX
  84. hey MR, i got a suspension question
  85. Advan RG2 17x8.5 +31 can clear Alcon 6 pot 343 disc?
  86. Does anybody have experience with these coilovers?
  87. Broken Caliper Bolt
  88. Brembo Brakes Bolts
  89. Pitch and size of caliper mounting bolts x vs 6-9
  90. Can you recommend coilovers for me?
  91. Klutch sl14 and sl5 fitment
  92. 245/45 on 9.5 rota grids
  93. Brake Upgrade
  94. stock ix mr bbs rim... repair?
  95. rpf1 help
  96. wheel bearing replacement interval?
  97. Need a set of street pads
  98. evo 7 brake disc question
  99. how to take off inner tierod boot
  100. Help with swift spec-r
  101. Offset question
  102. bent frame or something not as major..?
  103. Looking for Best all season performance tires (stock evo x gsr wheels)
  104. Suspension/wheel figment
  105. Tire size question from a noob
  106. That damn front lower control arm bolt!
  107. DIY wheel alignment kits?
  108. about to buy some 18s need help with offset and tire size.
  109. What rims are these?
  110. lug nuts for stock BBS wheels help**
  111. Rim and Tire Suggestions for RR Evo 8
  112. brake upgrade disks/pads
  113. Sway bar preload - Question
  114. 18x9.5 +35 clear?
  115. Hub centric ring size
  116. Hawk Pads or OEM Brembs or Other?
  117. What Offset will work
  118. Brakes Shaking/Vibrating.
  119. Recommendation for new suspension setup
  120. For those with carbotech pads...
  121. Wheels that look like TE37?
  122. Brake Squeak When Turning
  123. Evo 5 brakes
  124. 18x8.5 +25 fitment
  125. RPF1 fitment without fender mods
  126. knocking noise driver side
  127. Went to inspection today and after leaving 3 acd lights on
  128. Tein Type Flex Coilovers height adjustment
  129. Billet uprights
  130. Cant get my evo to brake correctly
  131. would these fit the evo ix?
  132. Swift spec r noise
  133. Brake pad and rotor suggestion?
  134. Just purchased a set of rota grid 18x9.5 +20's
  135. First R-Comps for AutoX
  136. GTWorx Evo IX springs and factory bilsteins
  137. Nitto NT01s safe for street?
  138. Car handling strangely. Clunking noise.
  139. most agressive brake pads for a street/road course car
  140. Brake bleeding issues
  141. Zerk Fittings Question
  142. shipping tires at low cost?
  143. Pads to complement new rotors
  144. tanabe front swaybar
  145. Stripped 10mm nuts
  146. Wheel/Tire recommendations for roadcourse
  147. This ABS issue is going to be the death of me
  148. Hawk DTC-30 pad review
  149. EVO 9 MR Bilstein
  150. Brake Crunch Help
  151. Difference between GSR vs MR springs
  152. correct brembo caliper paint?????
  153. Evo feeling "Twitchy"
  154. (4)SSR comp C 18 x 9.5 (+35mm)
  155. fresh meat
  156. Question about Full Blown lug nuts on stock wheels
  157. Brembo O- Ring size
  158. Finally fixed shaking steering wheel!!!
  159. Brake bleeder valve not sealing?
  160. Heading to the Road Course with stock suspension......alignment suggestions?
  161. Volk Racing 18x9.5 +22 TE37SL pressed graphite Ready-to-ship
  162. evoscan ayc data log
  163. Dunlop Direzza Z1 235/45/17!!
  164. Voltex fender offset.
  165. Wheel advise
  166. Daily Driver: Coilovers or Springs?
  167. Road Race track pad recommendations. For an RS
  168. evo 7 wheel fitment question rota wheels?
  169. Tires?
  170. Fender rolling and wheel fitment question; RPF1 17x8.5 +30mm offset with 255-40R17
  171. squeeky brakes
  172. What drag wheels +tyres will fit me in 15"??
  173. Wheel question? Help me out
  174. Odd clunking noise
  175. bad ass evo...
  176. g35 forged 19s lighter than stock evos
  177. Evo 8/9 Fender flare and tire questions
  178. Coilovers/suspension
  179. Rusty Wheel Hub? (Pics)
  180. Frame braces
  181. List of adjustable swaybars (and rates)?
  182. Replacement options for Bilstein MR with swift sport mach springs
  183. quick comment on rear toe
  184. 2 month old centric rotors and stoptech streets pads already warped?
  185. 17x9 Rota Grids or 18x9.5
  186. Robispec kw coilover suspension
  187. Neal out until July 8th
  188. removing wheel caps? bad idea or not?
  189. Girodisc S/S Brake Pads - EVO X
  190. Axle nut size?
  191. Bump Steer on stock suspension.
  192. Brembo Brake calipers
  193. Brake pedal very firm
  194. Coilover installation!!!
  195. KW re-valve / re-spring
  196. Which wheels?!
  197. Video How much play should my diff have?
  198. Bilstein B6-HD Vs Bilstein B8
  199. brake bleeding sequence
  200. KYB shocks reviews?
  201. Removing calipers and lines question. (Quick one).
  202. URGENT loud knock on right hand side
  203. Evo 8 wheel choice ?
  204. Ohlins Flag L
  205. Lug nut fitment with spacers
  206. Spacers up front better handling??
  207. Max Dia. for slicks
  208. Evo Iv standard brake calipers
  209. Where can I order the 19mm bolts on the bottom of the struts
  210. wheel sits in issue!!! anyone seen this!!???
  211. Evo IV alignment specs?
  212. 18x10 +18 xd9
  213. Will these fit on an Evo V?
  214. evo x rotors
  215. ways to tighten up steering feel in e6
  216. DS2500 Different part #s for same pads?
  217. Front vs Rear sway bar thickness?
  218. Going Back to Basics
  219. ROTA T2R will they clear IX brembos?
  220. 18x9 +35 Volk CE28 spacers?
  221. North nj suspension and corner balance
  222. Brembo brakes on Evo3
  223. What is the best Tire and Mag Size for Evo3 on race tracks
  224. Grinding noise help
  225. Swift Spec-R spring and aftermarket wheels, post your fitment pics+sizes plz
  226. Cross member help
  227. Best Coilover/Suspension for IX
  228. Can a Evo 7 8 9 Suspension modded onto Evo 4 5 6?
  229. Just track/road tested Dunlop ZII's, BFG Rivals,
  230. Rear Upper Control Arm Help
  231. Evo 8/9 with oem bbs and wheel spacers
  232. Name that wheel...
  233. Cutting my wheel of my car
  234. 275's on a 9 inch rim???
  235. Adjustable Rear Lower Control Arms
  236. E6 crossmamber K member
  237. MSI uprights
  238. Enkei evo 5 wheels
  239. XXR 521 fitment question- 18x10
  240. Removing the front lower control arm bolt
  241. Yokohama ADVAN A046 Price Drop
  242. factory Subframe Brace Question HELP
  243. Help!
  244. From Oklahoma: New Powder Coat RPF1's, Seats, Harness, & Tornado Pic
  245. Rust on Front Suspension Top Hat bolts
  246. NO ABS brake bias
  247. Wheel size help
  248. JIC Magic coilovers installed, headed for corner balance
  249. 18x10.5 rim concerns
  250. Binding noise when turning
