PDA
View Full Version : Evo Tires / Wheels / Brakes / Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74
  1. What rims should i go with??
  2. 16 inch wheels do they fit the stock brakes?
  3. Advice on Reconditioning HKS coilovers...
  4. What After Market Springs Come In Red???
  5. Megan coilover springs
  6. my 03 evo VIII Pulls
  7. MR Bilsteins done?
  8. Parking Brake - Uneven Wear
  9. What ever happened to zzyzx?
  10. generic coil overs.....
  11. eBay brakes and rotors, good idea or not??
  12. Paint Peelings on Calipers
  13. NTO3s and me, what do i need + alignment spec?
  14. Evo VIII Chassis Bracing/Stiffening
  15. thoughts on this custom color combo? v. OZ wheels
  16. How do i prevent premature wheel bearing failure?
  17. torque wrench opinions
  18. 245/45/17 on stock rims
  19. new Eagle GT?
  20. Will 17x7 42mm offset work on my IX?
  21. Works 2pc rotors
  22. Help please! I'm looking for an aggressive rim
  23. my suspension questions
  24. OEM steelies that fit over the Brembos?
  25. Wheel Stud Help pics
  26. Brake Job
  27. looking for opinions of durability
  28. ride height fix/problems
  29. Tire Wear / Drivetrain Damage
  30. Advan RS 18x9 +29 with swift springs Fit?! Evo IX
  31. washers between the 2 bars under the DP???
  32. 235/40/18 fit?
  33. Bilstein compression question
  34. Suspension issues--do I have the solution?
  35. Tire Size on Stock SE Wheels
  36. wheel lock key?
  37. No one probably has this set up...
  38. What size Rota P45R will fit?
  39. Anyone Use Their Z1's In The Snow Yet?
  40. Evo's on 19's please
  41. Phanton brake light
  42. Looking for a light weight wheel..white with a red lip..
  43. Hotchkis spring snapped
  44. Brake squeal
  45. Coilover/Spring+Shock Jackets
  46. My Kuhmo ASX's wasted my time tonight...
  47. I need with wheel size. PLEASE
  48. Need to find some rota's
  49. ALL Robispec KW customers inside please!!
  50. duplicolor caliper paint kit?????
  51. Make your own toe bar
  52. Best overall street coilover
  53. Weird tire wear
  54. Eibach Drop numbers
  55. Brakes squeel when pulling into parking spot only.
  56. KYB or Bilstein Struts
  57. What PSI for 255's?
  58. 18 Inch Tires
  59. Blizzak WS-50's Brand New for $98.00 a piece
  60. All-Season tires. too large?
  61. alignment issue
  62. hks hypermax3
  63. what color lugnuts?
  64. MR Bilsteins & Swifts - Another Review
  65. spacers on stockers?
  66. Need suggestions on rotors and pads.
  67. Brembo Caliper Refurbishment?
  68. is the fender liner needed?
  69. Anyone running MR Bilsteins/AfterMkt Springs with 265/35/18 tires?
  70. help wheel!!!
  71. A lot fo smoke after hard braking
  72. Gramlights 57 Max 18 X 9.5 +22 In Evo 9
  73. 225 50 17?
  74. Lip on Rotor
  75. S.S. Brake Line ?
  76. muteki lugs on volk rims?
  77. DS2500 Pad Failure or Normal Wear?
  78. race set up
  79. Help? Tire and wheels.
  80. Espilir Spring install...HELP!
  81. How much should an alignment cost?
  82. Which size 215/ 55 R 17 or 245 /45 R17 snow tires would you run
  83. Help !! How To Get Rims Painted ??? (opinions Also Please)
  84. Stickyest 255/35/18
  85. Would you use these lugs?
  86. New Hawk pad compound - check it out
  87. Enkei RFP1s
  88. Need help. Grinding noise.
  89. Can someone identify these luguts?
  90. Whiteline Rearbumpsteer kit and alignment
  91. FYI: HD Bilstein front strut assembley part # has changed.
  92. Tire fitment
  93. I need help.
  94. TE37 Generation II a.k.a TE37 G2
  95. drawbacks of running wider tires?
  96. Apexi N1's??
  97. rotorpros rotor pictures
  98. Rotor fitment question
  99. What Is Largest Size 18" Tire I can fit on Evo 8 ??
  100. Brake light wont go off!
  101. Replacement tires?
  102. Brake screech after they ae warmed up
  103. Enkei RPF1's 17x9.5 +38 offset
  104. Racing Brake ET700 pads/RotorPros review
  105. clunking noise
  106. Just bought 18x9 rota g-force..Need fitment advice.
  107. Damned S-techs!
  108. HKS hipermax II coilover HELP!!!
  109. Alinement specs?
  110. What brake fluid am I using?
  111. Please post your Compomotive MO6
  112. Big Wheels
  113. Asking For Some Advice......On handling
  114. Juat got the 18x8.5 brozne 5zigen FN01R
  115. Confirm MR strut fitment
  116. My massive suspension question brain dump...pls. pic off a question or two!!!
  117. rota toruqe 35+
  118. can anyone help? fitment
  119. 225 too small for front wheels?
  120. Ichiba wheel apacers
  121. 18" Rims?
  122. racing brake 2 piece rotor
  123. how wide of a tire can i mount on OEM IX wheels ?
  124. Work Emotion CR Kai
  125. stronger legs
  126. 18" upgrade question
  127. New Release: Nitto NT05 Performance Tire
  128. Timken Wheel Hub Assy.
  129. What tire size on Stride Sevens, 18x8.5+29
  130. Robispec to FL
  131. What site had damaged wheels?
  132. Noob Question :(
  133. Bilstein HD versus Bilstein Sport
  134. Scratching sound when braking
  135. squeakin from driver side wheel well
  136. Rear end noises?!?
  137. BC Coilovers?
  138. Drag Wheels
  139. Evo X MR wheels on Evo8
  140. Question about wheels/tires
  141. Coilover Strut Help
  142. PSS9 Install, Setup Questions, etc....
  143. Coilover help
  144. Direzza Z1 Star Spec
  145. Front Sway Bar Install - Without Dropping Subframe?
  146. performance frictions brake?
  147. Tire pressure question......
  148. megan coilover noises
  149. Tread Depth difference
  150. tirerack belstein
  151. new shoes!!!
  152. Brake Rotors & Pads for < $600
  153. best replacement strut for my evo
  154. G-Games 99B? Discontinued?
  155. 2 pc. rotor question
  156. your tire choice
  157. Racecomp Engineering/GTWorx and At Speed Motorsports join forces!
  158. Need help with new KW V3's setup
  159. blown front struts...common?
  160. Best Choice in Coilvrs fo Around 1m
  161. Life Running 255's on stock rims..
  162. Direeza - Anything Better ?
  163. fill your tires with nitrogen
  164. where to get replacement drum brake pads?
  165. Review: Autozone Duralast Gold CMax Pads (Ceramic Brakes) for the Daily Driver
  166. help Brembo Caliper Bridge Pipes
  167. winter setup, on stock MR bbs.. opinions?
  168. New brakes, cant stand the dust
  169. Brake problem
  170. Team Dynamics Pro Race 1.2 18x9
  171. Coldest Temp for Direzza Z1 Star Spec
  172. Alignment, what do you guys run?
  173. Which Rims???
  174. New wheels and tires, suggestions on both?
  175. just got power slot rotors, small question
  176. Endless or rotara brakes?
  177. CORRECT hub centric rings for Rotas?
  178. Anyone using whiteline rear sway bar on an IX?
  179. so. .. yeah? sway bar bushing help?
  180. Neal out till Monday the 27th
  181. help rear spring noise
  182. Wheels color question...
  183. fitment??!
  184. stock brembo brake caliper question
  185. Rims Came In The Mail Today!
  186. Goodyear F1 A/Ss or Bridgetone Blizzak WS-60s?
  187. Best Pads For My Car...(Searched)
  188. color lug nuts too ricey?
  189. Which Rims are these???(exact model of Rays?)
  190. Help: Does 17x9.5 fit???
  191. Wtfuxs! Brakes are loud!
  192. ISO: Tierod and bootkit HELP!!!!!!!!!!!!!
  193. powder coating
  194. Brake pads under $17 !
  195. 245 45 17 Blizzacks Ok to run on 17"s?
  196. Big Brake Kits, Comments on Wilwood, Rotora & KSport
  197. Wheel fitment
  198. Roll Center Adj. Kit...
  199. Roll Center Adj. Kit...
  200. Argh, rear passenger suspension clunk BUT...
  201. Wheel conundrum
  202. Why we do what we do and the sacrifices we make to get what we want.
  203. Need help in identifying Wheels
  204. Which rims shoud i get? Poll
  205. Flexing calipers
  206. Just a simple question !
  207. Brakes Help!!!!!
  208. Loud knock when I first apply brakes at low speeds?
  209. Bilstien/Swift installed correctly?
  210. vibration when braking
  211. Wheel+Tire Fitment Help
  212. Need new rear lower control arm bushings
  213. Free Tires
  214. BIG suspension help question
  215. Nail punctured sidewall :(
  216. Wheel bearings?
  217. Tire Wear..
  218. Squealing Ferodo's?
  219. Ways to reduce tri pod mode?
  220. Measuring Tred on Stock Advans...
  221. Rota G-Force Yamaha Black
  222. p45r fitment.please help
  223. Feedback requested: Fender brace design
  224. Need help with winter tires (Neal pls read!)
  225. Just bought new rims...
  226. 17x9 +22 CE28 REALLLLY close to calipers!!!!
  227. Broken rear ABS tone ring?
  228. Brake Pads!!!
  229. Brakes only squeal when in reverse?
  230. Coilovers
  231. Just got alignment done. Quick questions
  232. Adjusting Megan Coilovers
  233. Dunlop Z1 Star Spec VS Bridgestone RE-01R
  234. need brakes all 4 corners pads rotors all the good stuff just reusing stock calipers
  235. evo 8 enkei
  236. all weather tire question
  237. negetive camber question
  238. Anyone have BBS LM rims on Evo 9?
  239. Need info on these wheels...
  240. Missing wheel lock key
  241. Lower ball joint removal & install
  242. Who said cusco front brace does not fit with after market IC???
  243. TIRES "R" Compound Looking for a Freind
  244. Neal out till Monday the 13th.
  245. Old Advan RGI 17x9.5 +35 clear brakes?
  246. Brake lines
  247. BBS RIMS what tires should i use?
  248. Sway Bar End Link Boots
  249. Tre rear diff upgrade!!!! Maxx lock
  250. need brakes best bang for buck street mostly
